View Full Version : RC Jets
- Jets in action at Wings & Wheels Model Spectacular, UK
- Flying at Wingham today
- Useful life of our turbines?
- Bavarian Demon with 18MZ
- Freewings Stinger90
- Long Time Modeler Passes away
- Jet Legand F-15
- Simple Dubro brakes are back.
- Flightworks fuel pump
- What Gyros are you using for your jets.
- Little help programing the prolink electric gear and brakes PLEASE
- Jet Legand F-15
- Starter ring P-80
- Centre of gravity using g scales
- Yellow Aircraft Starfie II CG and Control Throws
- Skymaster f86 Sabre CG
- FAAs new rules interpretation
- Fei Bao Jets Dolphin build thread by RCISFUN
- Wanted RAM/FTE/RTI Data Terminal
- HELP with MAIN GEAR DOORS/ AIRWORLD PANTHER NEEDED
- JetCat P-140Rxi here
- Welcome to the highest performance engine on the market!
- Check This Out!!! Merlin 200XBL
- Twin or single? Pros and cons
- IGyro servo reversing
- Many of you know my husband Shaun Evans (also aka Yellow Aircraft) is very sick.
- Lets Talk About The Dreaded JetCat "Low RPM" off
- 1/8th Mig-21MF scratch build/kit
- Top Gun 2015
- Who made this retract, looking for trunions
- Some low passes by full size
- PST Jets
- Vinyl Graphics
- Pulse Jet Identification Assistance Requested!!!
- Bvm maverick wing plan required
- Boomerang Elan Question
- Check out Ali's new engine, K-210G
- Skymaster F-18 C of G ???
- Best in the west jet rally october 15th, - 19th., 2014
- JetCat P-180Rxi here
- Transmitter Range
- Jet tronics dual action valve
- B2'S and Buffs on deployment on the doorstep
- FeiBao Jet Models will attend Kentucky Jet Event
- JetCat PHT3 problem in AirStar Hughes 500e.
- Kingtech f-140 install questions
- Michigan jets 2014
- New color scheme on a Bandit Arf.
- 1/3 Scale F-86 Sabre, tomahawk
- Anyone of you guys work for L-3
- West Michigan (Baldwin) Jet Rally
- what happened to B1 Bob
- Question for Tidewater Virginia Area R/C'ers
- Original CARF Eurosport questions
- Robbe battery backer X Bus information
- FEJ A-7 Build
- Jetpower Fyresdal (Norway) video!!
- Jets displayed at Weston Park Model Airshow 2014
- dream works
- Custom color schemes on MacBook Pro
- Who is going no to buy BVM?
- WANTED: 1:6.7 F-16 Matrix Gear
- Weston Park Show (UK) 14-15th June
- WarBirds Over Oklahoma Jet Friendly Event June 27-28
- Tower Pro MG996R questions
- AMT Olympus electric start
- Classic Bandit Composite RX Battery suggestions
- RC Universe Issue
- easier to see F16 color scheme
- Jacknife jet
- jet-tronic double valve
- Tri Landing Gear. Toe in or Out
- F-15 one engine flame out during take off run.
- Do it yourself R/C jet cockpit.
- How to add drop tanks to an air world hawk wing. ?
- skymaster F15
- Mirage 3 sportjet
- JETS IN CHINA TODAY(more 100 pics,video later...)
- Best Presciption Sunglasses
- Plastic wheel wells
- New member, lots of questions!!! JPX turbine
- Fuel setups for Twin-Turbine models
- Can somebody explain the difference between Skymaster and Xtreme Jets please?
- Ultraflash. To crow or not to crow
- Skymaster A-10 main gear uplock air cylinders
- evojet double action valve
- 537lbs of thrust twin turbine jet luge with reburners project
- Skymaster Leaking Gear Struts
- MIBO A-10 pitot tube
- BVM F-68 old kit pre maiden
- Plum Island Jet Rally 1 week away
- P47 Superbolt racer-video
- F-35?
- First Turbine Jet Question
- SM F-14 Tomcat
- Airworld 1/4 scale F104 !
- switching over to dte lite
- Full size F-18 doing AOA 360 deg turns.
- FEJ T-33 remaiden a success
- Futura Flap question
- Airtech Germany Electric Retracts
- Kingtech K100 Turboprop
- Test Pilot
- Xcalibur modifications for Electron retracts
- Anybody tried these new fangled things- audible telemetry?
- Air Power EV-1u Leaking
- Props to Carf-Modles
- Anyone interested in seeing a SM 1/7 scale A10 build(put together) tread
- door sequencer
- Century Jet f-22 Build
- King Tech K80
- How to land an F16
- Building a Turbanator from a Ziroli short kit
- Byron F-15 twin turbine build thread
- Fei Bao F-18F maiden
- Damaged turboprop
- Jets over Pampa 2014
- JetCat SPT5v3 - gearbox tightening up.
- JL Yak 130 - Single turbine version.
- How do you guys store your jets in the garage
- Help please from JR DMSS users!
- 1/7 Skymaster F-18F
- wheres bob
- Futaba and Turbine's
- wheres bob
- 3mm Festo Tubing
- Jets for 12 pounds of thrust engines
- FIFA World Cup Boeing
- Long Marston model show (Nr Stratford upon Avon)
- Airpower 3.5" inflatable wheels
- Turnigy servos in Jets?
- Robart air cylinder quality failed
- Your favourite battery
- Canopy back to life
- JB220 Failsafe Help
- Paperwork
- How to balance your jet on the stand,, (My 1/8 F-16 as an example)
- My first Kingtech failure
- Pilot Bust
- digital camoflage
- The need for speed
- Should I skip the trainer?
- Viability of sharing a turbine between 2 models..
- Shout out for Altecare RC
- Early Summer Oc-Turbo Fest
- Help with Danish Air Force F-16 colours
- Easiest to fly RC Scale Military Jets
- Me 262 with bombs & A6 Intruder
- What's happend to Jetlegend web site?
- Skymaster A-10 1/7 scale
- Hawgs
- Control throws yellow aircraft A4
- A New Aurora and AD Diamond
- FEJ or Yellow Aircraft Jets F/A18's builds in Texas
- Mounting Wren 100K in Bandit?
- Question? How to turn off gyros in flight with 12x?
- Whistling Turbine - Pipe Setup??
- Skymaster T-38
- Stupid frakin flippin Heat shield!
- JetJoe F-16??
- Hamburg PA jet flying
- RAM500 Propane Start Conversion
- Pulse Jet AMA Rules
- Looking for Hatch Latch Source
- Flare system for our models!
- a nice video to watch i did yesterday Scale CORSAIR, FLYEAGLE F16, FUTURA, ELAN BOOME
- Anyone have a JC P100RX they would sell??
- RNMAA / JMA Topgun 2014 May 17 / 18
- The Flames are back.. K100G
- Looking for Larry Krammer
- Hopper tank and UAT tank
- Joe Nall 2014
- Searching for Settings F9F Panther ZIROLI
- Fuel Pump location in the jet??
- Jetcat GSU ?
- Priming a Graupner GBooster 160
- 1/8 F-16 W/ JetCat P-120 Anyone??
- Blue Box Sabre helmet & goggles
- Anyone building or flying the latest version Feibao 120 Hawk?
- the beginning of jet propulsion-video
- skymaster 1/6 f-16 3D flying
- Can someone recommend a video camera suited for filming planes?
- BVM MiG 15 fuel system
- skymaster pc-21
- Visiting Gaspar/ Brazil - Manecojet 2014
- Help with Turbine Glider C of G
- Blackbushe model air show - 17th may
- wood jet trainer
- Mobil dte shelf life
- jet carrying case
- Robbe S-bus experts, need your help Aussie Bart, you out there???
- AD Diamond
- CARF Tucano TP with JetCat SPT10
- Great Alternative to Hysol
- Do It Yourself?
- Rt 66 jets 2014
- Warbirdpilots.com order
- Is there a way to clean your turbine after digesting grass
- Yellow F-15 Maiden
- UP@ & Tam FAil Safe unit
- Anyone using the Hobbico LiFE receiver batteries? Comments
- Maiden flight of my skymaster f-16 1/6 scale with k180g
- Shock Jet completed with Kingtech 100
- P-180RXI incoming
- Fuel tank problem ULTRA FLASH CARF
- Ad scorpion mkii
- Lance's SR-71 video
- Anybody lose an F-4?
- Boomerang Torus Merlin 140 Build
- Plum Island Jet Rally June 13th thru 15th
- Best gear fail safe unit
- WANTED: Yhunderbirds 12" pilot
- Power Distribution System
- Rookie 2 P80 or P120?
- Best in the west jet rally/ save the date:
- Ali Machinchy Presenting the Fouga Magister @ Florida Jets
- JMP Air Traps
- Transportation of turbine oils in airlines
- skymaster a10 MEXICO CITY
- Would you pay for someone Else's Bill?
- Skymaster Inflatable tires
- Flying with the Thunderbirds
- Pricing Announced For The JR 28X
- Supersonic exhaust?
- crosswind take off like a hornet
- Wren 44 glider?
- You may want to watch this before you buy a Boomerang Torus
- Installing ElectroDynamics Lights
- HELP with accessories for Scuba tank and propane tanks for AMT Air start Turbine
- Hats off to Skymaster for excellent customer service.
- CARF Ultra Flash with P-160SX
- question for Powerbox smoke pump users.
- 1/5th Scale Eurofighter from the Aurora Factory
- To Use Heading Hold or Rate Mode. Which do you prefer? Cortex/Guardian/Igyro
- The Making of Xtreme ARF F100 D Super Sabre
- BVM F86 ducted fan turbine conversion kit
- FEJ F-86 Sabre
- What are the dimensions of a BVM f16
- Tamjets A4 Skyhawk rudder
- Top Gun
- Confirmation of expirenced Skymaster Phantom 1/7 scale fliers on C of G settings.
- kingtech Europe
- GY520 Gyro
- Looking for help with static issues
- How to Forming plastic or a known plastic former
- HELP , looking for a Buer Me 262 manual.
- Team Kingtech and topgun
- Looking for Eurosport Retracts or Struts Robart or Airpower
- Asking before i try
- Pilot-RC Turbine Sport Jet
