PDA
View Full Version : RC Jets
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 [193] 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212
  1. F-18 1/7 th scale gears
  2. Hitec Servos on DF/Turbines?
  3. Panel Lines, how to?
  4. 104 cg
  5. Is it a Rossi 61 or 81?
  6. need help f-15 canopy
  7. New flying field (Field of Dreams)
  8. Anyone got a Saab Viggen or Info
  9. OS 77 pipe
  10. Bobcat XL is a gyro necessary?
  11. OS .77 and BVM standard pressure pipe
  12. HotSpot wings concern
  13. Where is the best place to buy Carbon Fiber Materials?
  14. Flaperons for Bobcat
  15. Waco on Sunday anybody ??
  16. Avonds F104 CG shift?
  17. California Jet Gatherings??
  18. Eurofighter Canard Control Arms
  19. Pst J600
  20. Rossi 90 Help
  21. Looking For A Good Fiberglass Glue ?
  22. Mig 15 Cockpit
  23. Need help!
  24. how hot does a compressor impellor get?
  25. Eureka Byro blaster Enforcer finally finished
  26. Mig 29
  27. need a dxf or dwg of F-15A or C to scale up my kit
  28. Offline for a Couple Days
  29. Spectre Turbine Conversion
  30. Rabbit Sun 1/19?
  31. I am new to turbine...
  32. Waiver demo opportunity in Vegas
  33. Anyone flying a LAVI with Rametc/OS91?
  34. JHH A4 Skyhawk D/F
  35. Flaperons VS separate flaps and ailerons
  36. turbine HELP!
  37. JHH panther
  38. What happened to the AC-130 Gunship thread??????????
  39. F-86 color scheme info
  40. Best home built turbine for a first off
  41. JR 5391 digital on HotSpot elevons
  42. Composite super bandit
  43. Is there a problem with Eurokit for HotSpot retracts on grass?
  44. OS 91 and Hurricane cobra
  45. Where can i go to see?
  46. Tinting f-16 canopy
  47. O.s. 91 Fuel Mixture??
  48. AD Rafale Almost Finished
  49. Whats the best way to glass wings
  50. Need a current # for Tom Robertson
  51. Aviation Design F-117
  52. Need help to identify this jet
  53. JHH Mirage
  54. byron f-16 turbine conversion
  55. Are there any special thai made gears for roo?
  56. Tom Cook F-4 Help!!!
  57. Os91 Vrdf New And In Stock !
  58. New Engine for Kyosho F-86 ! HB .18 or Toki .18 or ???
  59. remove old finish, strip off or sand?
  60. JR 8411 servo used on elevon?
  61. y/a stingray, any new input about it? how many being built out there?
  62. Mig 21? or any other migs?
  63. Jetcat GPS recievers
  64. Eurofighter With Jetcat GPS!
  65. Too Many Sabres Already?
  66. Fiber Classics F-86
  67. Spectre with Turbine
  68. Where to find small ducted fan (3.5c.c~7.5c.c.) unit!
  69. Terminator and X Terminator
  70. CS Models
  71. AVIATION DESIGN Starjet
  72. F-86 Sabre ´´The Huff´´
  73. Has anyone got or built a PMP Eurofighter
  74. Flap/aleron hinging
  75. RAM starter fix
  76. My Byron F-16 mods.
  77. byron f-16
  78. Do you use oil in your air lines?
  79. D&B Buckeye
  80. Stars & Bars
  81. Automix from Mini hobby
  82. Other jets for BVM Power
  83. How long of a runway??
  84. starting new os .91 vr- df
  85. Electric Jets?
  86. Drag Chutes
  87. Help with my O. S. .91
  88. double-up
  89. Y/a F-16
  90. Simjet 1200 ASE Question
  91. K.S. Facet 1200 **(FINALLY PAINTED!)**
  92. What Plane To Start With
  93. Reaper with MW54 finished and ready to fly
  94. Making scale retact doors for my Yellow f-18 single
  95. local flying field
  96. JR radio
  97. Webra 80 D/F
  98. Is it wise to buy a 2 years old, unused Simjet 2300 AES?
  99. Mini hobby brake valve
  100. Yellow Aircraft F22 Raptor
  101. Scale Photo Slide Shows Posted To The Georgia Jets Website
  102. Making Your Own Decals For Your Jet?
  103. Remote Tach
  104. Hurricane Fans?
  105. Vc-25a Air Force One Model???
  106. metal servo arm for futaba servo
  107. Great video
  108. mw 54
  109. Cordless Rechargable Air Pump!!!
  110. Byron F-16 Tail mods.
  111. New J600
  112. I want to buy a MR Super Reaper!!
  113. Byron Fan, OS 91 DF, what pipe???
  114. Convair F-106 Delta Dart
  115. UAT contamination
  116. TomHawk
  117. Fiberclassics Mig-29 Video
  118. Nelson Piano Hinges
  119. Toledo
  120. Webra 80 D/F
  121. foam wing glassing
  122. What is your preferred D/F engine and fan combo?
  123. Tubine Conv. Fuel tank question
  124. Jet newbie question
  125. Wheels
  126. Whats the best glue for canopy's, Best 6volt battery
  127. Byron F-15
  128. home built Phoenix 30.3/mk4 turbine
  129. Little Air guages????
  130. How many receivers, accu, servos for a HotSpot?
  131. KJ66 update.32lbs thrust.afterburnerand thrust reverser info required
  132. Washout on wings? How much?
  133. hotspot 12 or 17 lb??
  134. Best pump for Jet-A or Kero?
  135. Wren MW-54
  136. Building a Composite Jet Epoxy Questions
  137. Where's a good website for 3 views of modern jets?
  138. 12 lb thrust turbine info
  139. Simjet 1200 AES
  140. Pump power for Wren 54 using 6 cells, Fadec ECU, etc
  141. Yellow F-18 twin
  142. What now for D/F
  143. Cock pit kit healp
  144. Jet Help
  145. need some df flying tip for jhh f86?
  146. Combat Model A-10 Fans???
  147. Bandit dihedral
  148. Painting after hinging?
  149. Ram 750 & 1000 same engine ?????
  150. Eurofighter Sport Modifications...
  151. Icing problems with turbines??
  152. Dumb question about AeroPoxy
  153. What JR servo to use with gyro
  154. Eurokit retracts and struts
  155. Kangaroo Question
  156. ANOTHER VOLTAGE REGULATOR QUESTION
  157. Now here's a project for the MW44!
  158. bd 10 model
  159. brakes for a mig, where do i find them?
  160. fresh from the paint booth
  161. Glascat
  162. Test pics
  163. pst600 question
  164. Maiden on Compo Bandit #2
  165. Has anyone put Nelson water based paint over PPG primer
  166. Pneumatics WHY???
  167. Roo engine thrust
  168. 750 gokart ?????????
  169. 1357 users on RCU
  170. Pneumatic Cylinders?
  171. New Eurosport is really RED
  172. Byron F-86 ?
  173. What Jet events are you attending?
  174. Wheel well size..
  175. Turbine Plans
  176. Skyburner
  177. Painted F-18 in the booth
  178. The Saab-Hummer SUA
  179. Anyone help with Sea Vixen kit
  180. roo gears
  181. Austin Jet show...what dates?
  182. Lithium Polymers for turbine?
  183. ECU and Transmitter Batteries
  184. F-5 color schemes
  185. Turbine CD needed near Nashville
  186. Aggressor 2 flap set up
  187. Looking for David Gladwin
  188. Turbine waiver signoff
  189. Problems starting my Mercury
  190. New baby Jetcat?
  191. Bobcat XL Deflection plates?
  192. need some advice on my new AD 1/6 Rafale please
  193. Bob Parkinson F-18 pusher...
  194. MIG29 convert to turbine
  195. Eurosport ARF Question
  196. F-4 Lights
  197. Happy New Year!!!!!!!!
  198. Glue tips
  199. OS .46VX-DF and Turbax I. How much thrust?
  200. Unknown name - Jet from the 60's
  201. Where do I get .15 to .21 size ducted fans?
  202. Flush Panel Flite-Metal Application.
  203. What Engine for DF.?
  204. Holy Smokin Bobcat !!!
  205. Kress Jets
  206. Boeing Bird of Prey
  207. Plasma bag fuel cells...
  208. Ramtech parts
  209. SWB Mamba
  210. Ziroli F4??
  211. OS .15CV-DF Where to buy?
  212. New Arrival
  213. Plumbing II
  214. Great Planes F-14 Tomcat
  215. Newbie brake question.
  216. Bob Fiorenze JMP F4 Black Bunny Phantom
  217. Plumbing questions
  218. Promark
  219. Great L1011 photo
  220. PCM Models AV8R ?
  221. New Small Jet (BEE Jet )
  222. Who sells 1/6 scale painted civilian and military pilot busts ?
  223. Austin Gang
  224. aeropoxy
  225. F16 Color scheme
  226. Something scared the crap out of me flying my Bobcat this weekend.
  227. Need advice on electric DF motors! HELP!
  228. Antenna Location
  229. BVM scale nose strut O-ring
  230. Who Makes Parachutes?
  231. F16 Tiger Scheme
  232. please help me
  233. p-120 INSTALLATION IN Bob Cat XL
  234. Where to buy a Mw-54
  235. OS .15 CV-DF. Where to buy?
  236. Need advice on electric DF motors! HELP!
  237. su 27
  238. regal eagle and os 91 ducted fan engine
  239. 1/6th scale Hawk 100!!
  240. Blue Angels Eurosport flies in The Netherlands
  241. JMP Firebird First flight
  242. Some information
  243. Bobcat Owners
  244. Kj 66
  245. Alabama jet away
  246. Glow Plugs
  247. Turbine Fever
  248. poll... 4.8volt/6volt no regulator/6volt with regulator?
  249. jpx question
  250. HELP !!!!! Center of gravity question
