View Full Version : RC Jets
- Building the second voyager jet blue angels
- Message to Beavar
- North American Sabreliner/T-39
- Jetlegend F20
- The U.K. JMA at Buckminster Lodge
- PLEASE HELP! Need CAI Crow Aviation documents/plans.
- CARF Ultra Flash Evo build thread +
- New JASDF F15 scheme
- HSD composite jets?
- RCJI October/November Issue Out Now!
- My Kingtech k 80 flames with fire on full throttle
- Tamjet A4 Pilot
- Jet World Masters 2021
- Digitech CG Wizard
- Rick Fusco Contact Info
- Fuel pump install
- FEJ F-86 Sabre Door Cylinders
- Help-I need a Jetcat Start Gas Can (Propane Start)
- Turbine throttle curves
- U.K. JMA Deenthorpe Meeting 12th / 13th Sept 2020
- Xtreme A.R.F.
- 400mm EDF Project
- Spectrum failsafe and flight modes help
- Who makes vector pipes besides Grumania?
- Intairco Mega Fuel Filter
- 13th Annual Oil Creek Flyers Fall OC-Turbo Fest Jet fun fly!
- Use of diesell
- Treating Kerosene
- test
- Quakertown Pa. jet event
- EMBRAER145 jet 4,7m length build
- Pirotti Heron - VTOL jet !
- Yellow Aircraft F18
- Tomahawk Aviation / BVM Jets Announcement
- Air leak hunter
- Manufacturer/Manuals of Light Controller
- BVM kingcat, maybe rocketcat! AMT Olympus HP
- Flying the JMP Firebird again!
- New Elite Aerosports Rogue
- Anyone else suffering from builder itis?
- Butch Sickels
- Vectored thrust 3D jet for a 200 or 140 besides a J-10
- Futaba 18MZ - Audio file (sound) by logic switch combination
- Jet Legend Models
- Jeti Multiple Receivers - Dual Path or Clone
- Hornet III ECU Help needed!
- Maiden flight Videos
- Regal Eagle Recycled
- Aviation Design 1/5th Rafale Electric Gears?
- Xicoy ECU
- BVM F 16 (original)
- Servo Connector Pins/ Sockets
- Fly Eagle F4
- uniLIGHT Controller, 8-Channel, PRO
- Great southwest jet rally 2020==cancelled
- 38th Greater Southwest Jet Rally - Waco TX 9/10 - 9/12
- CARF Bolt! Build thread
- Jettronics dual action valve setup
- Throttle curce - LINEAR, HALF EXPO, FULL EXPO & why?
- Low profile Hi-torque servi
- Horizon Airmeet Live on you tube
- I'm just old fashioned I guess.
- New Event Alert! Cactus Jets! 🌵 🛩 🌵
- Older D4S Light Controller needed
- Rogue Picaro
- CIA Nuclear Bird Drone
- Skymaster F-14 Jolly Roger
- Aeroworld Hummingbird 1.8m Sport Jet.
- most reliable air compressor?
- Kit countries of origin
- How to start twin turbines, individually.
- 1/6th scale F16
- Dry Transfer Decal Source?
- Looking for help or ideas on how to determine if there is oil in your fuel
- E-flite UMX Mig 15 EDF Review
- Radio Question
- Elvington Model Flyers Weekend 08/09 August
- New Powerbox Sensor Switch V3
- Jet (hood) stand makeover
- New Website
- Power Model Jet Oil
- T-One Models 1/7th Scale A-10
- 2020 Nighthawks Jets Over the Valley
- Ultra Bandit vs Ultra Bandit Evo
- Updated T-ONE Models 1/8.5 F-16 Build
- Swiwin SW220 by CRX
- Skymaster 1/6 F-18F or BVM 1/5.5 F-18C?
- Battery for Details 4 Scale controller
- Emcotec DPSI Twin, Dual Receiver
- Skymaster F-18E/F schemes.. Let's see them!
- HSD f-16 105mm retract
- FCC Nails Hobby King
- DS-24 Transmitter Bugs After Update
- The passing of Mark Frankel
- The 2020 Fall Jet Classic is October 7-10, 2020
- Freewing EPO Avanti conversion with K45 G3
- Michigan Jet Pilot's Boondoggle
- Older Jetcat P80 ecu battery?
- Tiger Meet 2020 jet event in SC, October 14-18
- RCJI August/September 2020 Issue Out Now!
- Ultimatum 2.0
- Jeti DS-12
- Max servo acceptable idle current
- "RT 66 Jets, 2020"--Cancelled
- First In Flight 2020 Cancelled :(
- Have Turbo Beaver, need brakes
- Help! Balsa Bandit dihedral setup
- Skymaster lighting kits problem
- Best in the west jet rally 2020
- 3D replica of your turbine for use during build
- Sun Covers for RC Jets
- Jeti LiIon RX batteries
- Purchase 1-K Kerosene online?
- In Flight Auto Restart.... Let's hear real world experiences?
- 1/4 scale F-104 build
- What is the name of this plane
- need help with bvm 1/6 f16 main gear
- F-15 paint schemes
- Skymaster F-15
- Baja Hobbies Viper
- Where to put center tank fittings on 3 tank system
- Hsd f16
- F22 origin?
- Your favorite online hobby supply store
- Jetlegend F-22 main gear needed.
- Discussion: Antenna position
- Servo Recommendations for 1st jet!
- Usps woes...
- Super Jet South 2020
- Scaled Composites Son of Ares
- 1/7 Fei bao F15E single engine pipe question
- 2020 houston jet rally june 26-27
- FLOW-meter / tank indicator
- Jeti Li-Ions to power the turbine???
- Top RC Hawker Hunter Main Struts
- If an F-18 and F-16 met in a bar
- Hawk Builders.
- Elite Aerosports Havoc - wingtip on the deck KE pass!
- Jettronics valve help
- Cylinder UATs - why is the fill on the bottom?
- BVM 80" Sabre drop tank length
- Looking for turbine waiver sign off
- JetPower(& props...)-CANCELLED
- Bvm f-15
- JetCat Fuel Pump Conversion
- 300 class turbine fuel system line size
- Fei Bao J-10
- Looking for Bvm rafale canopy glass
- Brake Parachute
- BD-5 1/1.5 scale FOKKERC
- A/D Mirage 2000 retract parts wanted
- 13th annual “Early Summer OC-Turbo Fest” – Titusville PA
- CARF felt clunk being used in diesel fuel
- boomerang sprint v2
- Jet weekend photos
- Pluses/Minuses of Two Radio Choices
- Thunder Valley Jet Rally
- Jets Over Kentucky 2020 Cancelled
- The new beast has arrived: Frank Turbine FT-250!
- Rear Exiting Smoke tube question
- Who is the go to distributor for fei bao jets
- How Long Satellite Rx’s Jeti CB400?
- Skymaster F16 1/6
- F-4 Phantom 1/8 scale Scratch Built
- scratch build
- Voltage Regulator recommendations
- F-4 Phantom 1/8 scale Canopy
- Alpha Jet
- Red Arrows Moving To Waddington
- F 100 New Ride
- Missing F4e Phantom Apollo Xi Sepulveda Basin
- T1 models Hawk
- Looking for a CARF Mig29 manual
- Thrust tube repair help.
- Servo extension wires
- RCJI June/July Issue Out Now!
- Looking for Pirotti Tuono Easy CG
- Jets Over Kentucky 2020 9th trailer
- What in the world are these people thinking?!?!
- Rivets
- Thinking of coming back!
- KingTech G4 Engines!
- Boeing T7A - XXL size
- Fly eagle
- Keroplug Electrode
- Skymaster F-18 1/5.75 scale build/assembly video thread. F18
- FAA Remote identification ID full speed ahead?
- RC Flying at full scale airshow.
- Jet Legend Clear Canopy
- Some 4K F-15 Mach Loop action
- Jet Central Cheetah Fuel Consumption
- Jets Over Kentucky 2020 8th trailer
- Gas can transparent gas filters benefits
- Tower Hobbies/Horizon will now be selling a turbine
- Jet Power is now 'Jets & Props'...
- Little bit of jet flying this afternoon.
- Has anyone made tanks out of G10 sheet?
- Comp Ark Lightning Silver Bullet
- Vspeak turbine telemetry
- PowerPox Core Radio Setup on Elite Aerosports Havoc
- A/D SU 37 brought back with a new paint job
- BVM 1/5 F18 and F16 ripping!
- Mibo 1/4 A-10 shop assembly video
- BVM PNP Sabre 1:7
- My Hysol 9462 is a bit 'clumpy'...Why ?
- Futaba 18MZ vs. PowerBox CORE
- Now that's a scheme
- Turbine balance
- A short safety note.
- Powerbox Mercury SRS & JR RG812BPX DMSS receivers
- Pilot Nav. Light Controller
- Jeti Jeti Wireless & Touch Switches, Servo Protection, Rx Battery Telemetry....
- Who painted this jet? CARF Flash F86 scheme
- Jets Over Kentucky 2020 7th Trailer
- Looking for a TRI Srat airliner
- MAP’s new Bubble Trap pick ups
- Classic 1990s BVM Bandit T Restoration
- Jeti 24 switch question
- Skymaster 1:6.75 F16 landing gear issues?
- Where to Get Service and Parts
- Some great jet video and stills from Death Valley
- Constipation Thanks RCU
- Vintage Bobcat XL help.....
- Any Jet Engine Kits Still Available?
- A Few Photographs From The Albums
- Data Analyzer Jeti DS-24 Question/Problem
- Help HSD Wing Connector repair!!!
- BVM / Tamjet F18F tailpipe dimensions
- BlueSky Smoke Oil
- Medium to large hawk T-1 wanted
- skymaster jets
- FIRST IN FLIGHT JET RALLY POSTPONED to Sept 2nd -Sept 6th
- Bob Violett (In Memory)
- Micro Turbojet Engine Beginner - need help
- Jets Over Kentucky 2020 6th trailer
- Bob Violett
- Fieldbox Fuel Pump Info Needed
- My next build - not a jet
- Mississippi Afterburner 2020 canceled
- Top RC F-16 build?
- enclosed jet trailer
- HSD Super Viper Turbine KIT build help!!!
- Spam PM
- Fuel Pump
- Byron f15 and fea boe f15
- Repair Technique Suggestions...
- Dont like crowds?
- Jets Over Kentucky 2020 5th trailer
- IAF-Zukit-Fouga Magister (RCJC)
