View Full Version : RC Jets
- Spider Jets...
- extension wire source?
- CAD Programs?
- Ram
- JEFF HOLSINGER anyone have his phone no.
- Simjets
- Please keep this forum going.
- where do i get specs on a full scale jet?
- Scale Jets NOT meant to replace Jet Masters!
- Combat Models f16
- Turbine Regulations Update
- Glassing for the first time. Question
- Kfir 3-views
- SWB Mamba
- R8 Alternatives
- 9C vs 10x Why the big $$$ diference?
- Just bought a Yellow Aircraft MiG-25
- Jet World Masters 2003
- Montana Jets 2002 Update
- Hurricane Jet(cobra)
- RC Report Jet Column
- Ram
- Liberty Bell Jet Rally
- Looking for additional Comments on Tubine Questionare
- MW 54 issues
- RAM 500 repair status
- Spray Guns
- What happened to the RAM announcement ?
- Which DF jet is the fastest?
- Hangar 9 Pro fuel filters
- Philip Avonds F-16 kit pictures
- Please Call
- 6V ECU Batteries
- Pictures of Roo 11 ARF colors?
- Ram 500 repair Status
- grommets, front cover
- fiberglassing question
- Battery connectors
- Ram 750F start air pressure
- Gyro's
- F-16 kits for turbine?
- BVM F-86 Pilots
- Cermark F20 Prop Jet
- DJ -1 getting closer!!by pilot models? anyone heard of it !!allmost done!!!!!!!!!
- Thrust to weight of a model jet
- HOB, A-7 Prop-jet?
- Looking for reeds for an old pulse jet
- Bvm F-4
- Wing Repairs
- Ram 750F Electric start
- turbine oil mobil ii is it okay to use
- fiberclassics F86
- Picture shrinking
- F-14 Tomcat EDF first flight video.
- RAM 500 ECU Ques
- Photos from the Green Mountain Jet Rally, Middlebury Vermont
- Large electric jet question..
- Cermark Mb 339 give me a brake
- JR 3321 Servos ?
- Exhaust duct thrust loss
- Aviation Design F-16 LE Flap
- wren mw54 / Ram 500 or what else?
- Largest R/C scale jet in Europe.
- What not to do
- R/C Jet Photo Contest
- Please Help (Dynamax Fan)
- A thanks to all ---> pics too
- Help
- turbine ground school at MIchigan jets
- New Y/A F-16
- Ram750F
- Turbine Power
- Flying Jets with a Futaba 9C
- Kyosho F86f Sabre
- Is 130 Micron Polyester Screen filter good enough for turbine?
- dynamax inst. or exploded view?
- ziroli f-9f with wren mw54?
- Using PPG Omni Colors with PPG DBC 8000 Acrylic Enamels
- Question on servoe extensions
- turbine question
- Eurofighter Sport
- Roo Gear
- O.S. 91 problems
- Responses to R/C Babes website.
- Bandit Straight Vert. Fin Vs. Swept Fin>>
- My first jet\sailplane experience
- Pegasus flameout
- Mig Mad Marine
- Which Jets do you fly??
- Header Tanks
- Fan
- Avonds New F-16
- Matt's Tomcat
- Glennis Replacement Tires?
- BVM F-16 - Jetcat P80 conversion goes on !
- Albatros Hunting
- Can you spray water mist into turbine?
- Where to buy JR
- Scott,Cathy and gilrs from michigan?
- Honest Thrust numbers!
- FUTABA or JR for jets?
- Hurricane fan vs. Byron stock fan
- Gave my Byron F-16 the Smackdown!
- BIg Time Apologies
- DC-10 Gets a new Wing
- Another PPG Omni question
- interesting composite topic
- BVM Heat Shield
- PCM, is it absolutely necessary?
- Retracts for a newbie
- Hauling Jets (looking for a trailer)
- What A box !
- Hotspot Cobra
- Michigan Jets !!! What Where and When ?
- R500 "Strainer" FOD Protector?
- Sponsorship Required
- Need Turbine
- Wow, amazing what 100.00 will get you!
- Servo ext Leads..Neat bundles..extended close proximity... A problem??
- Re: 1st DF plane?
- MiG-29 AS YOU HAVE NEVER EXPERIENCED BEFORE
- jets for dummies
- Y/A F-18.. how much weight added in a tubine conversion?
- Need Byron F 86 CG and Throw info
- EASYTIGER: check your PM
- Ziroli F-14 and Kress Jets
- OS .91 Fuel
- Are your building boards clear?
- turbines
- BobCat main legs
- byron f16 first flight today - need advice
- Hot Spot Canopy
- BVM T-33 flight characteristics
- Scale Gear for Avonds F-15
- Hand-Me-Down
- Variable Thrust Vectoring in a Hot Spot
- F-4 Phantom .90 size?
- Too much RPM??
- PPG Omni Paint
- Christian Diffusion YF22 Raptor Gear
- Turbine certification
- 750 electric start
- Any setting changes expected for RAM 500 starting at different altitudes?
- Scale Jets International
- Let down by Spiderjets and Simjet
- jet chargers
- RAM setup questions
- TGA F-15 first flight
- cobra jet by hurricane jets info needed
- Kangaroo Canards
- Who wants to build a turbine?
- Y/A Starfire
- Where's the JF 50 Bee?????
- Pat McCurry
- F-15 ready for Pampa 2002 & 100+ pictures of meeting and results.
- OD Airplane with smoke
- Jr 8417 ?
- Bvm F-86
- Eclipse Aviation new exec jet
- Shaun a question about the Yellow Hawk
- Jet Scratch/Plans Builders --- Mig 29 plans
- Turbine Oil
- Skin my wings for me ???
- CJM Talon flights
- Yellow F/16 ?
- BVM F100 Kit ?
- Jhh F-15????
- OT: Shipping fuse to Canada
- Exhausts
- F14 Tomcat
- F-16 Cockpit and ejection seat
- Os 77
- Bobcat rudder servos, gyros, nose wheel steering, Y harnesses,etc
- Ram Service?
- I was just thinking. Income tax write off
- Career Opportunities- Research and Development Technician
- Electronic fuel pump for K1
- Byron F-16
- How does the Renegade fly???
- Bad day at Floyd Bennet!
- Kress thrust???
- Bob Fiorenze
- RAM website message
- Jetteam MB339
- Scale Ref for Jets
- Missouri Valley Jet Scramble
- Byron F-16 with elevons only? Nobody has done this?
- Turbine P51 mustang?
- Patriot repair?
- Looking for flying fields near Palm Coast FL.
- Viper Conversion - Help!
- Montana Jets 2002 (update)
- Is a Delta a Delta, no matter what?
- Yellow Aircraft F-18 Hornet ARF
- Michigan Jets Rooms
- OS 77 head?
- Roo Setup
- Jerry Krause of Logictrol - Know where he is?
- First Starfire II flight off grass.
- O.s. .91
- Jet Cat vs AMT
- Viper Question
- Mystery F-18 Hornet/ trying to identify kit?
- Willing to scan the Roo manual
- Bvm T-33 Turbine Question
- Bonus for Folks comming to Heart of Ohio
- AV8R: Adapt to P120
- Avonds F-15...Bypass or no Bypass?
- Byron F-16- want diagram of tail mods
- 20th annual Greater Southwest Jet Rally
- TGA HD Turbine retract units
- Y/A F-18 canopy
- How do you guys transport your jets?
- RAM 750PR max RPM adjust
- *** JohnVH ***
- info reqest
- panther color schemes
- Titanium vs Stainless Exhaust pipes
- JMP T-33 Questions
- Y/A F-18 Single or F-16C?
- Glennis air brake adjust ?
- Harrier Help????
- Carbon Fiber Re-enforcement?
- radio range problems
- Anyone running the Byro fan and pipe?
- Jmp /yellow Starfire Help
- DFW Jet Rodeo
- Need a pipe retention clamp for a OS91
- Pressure tap for OS91 ducted fan?
- Pressure tap for a ducted fan?
- Ceramic Paper Insulation - Supplier?
- Starfire Help
- JR radios and Horizon Hobbies.
- SpiderJets F-16
- F-101 Kit
- Ducted Fan Power
- hopper tank a must?
- Celebrities and jets
- Where to get stand off for speed sensor?
- New Bobcat construction photos!
- yellow aircraft rep in here?
- johnny hernandez out there
- Frequency scanner?
- t-2
- Robart HotSpot/Kang gear still backordered?
- Regal Eagle or Byro-Enforcer?
- Best Receiver
- How much servo for Roo steering?
- Weight ?? DL Aero MB339
- Duralites Plus, JR Matchbox, RAM
