PDA
View Full Version : RC Jets
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 [189] 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212
  1. thailand gear?
  2. Want a good chuckle??
  3. tga intercepter
  4. Robart's new Turbine?
  5. CJM F4 Phantom Help
  6. La Jet Pictures?
  7. Picture of successfully Maverick Pro conversion to turbine
  8. Cermark MB339 ARF Good or Bad ?
  9. Yellow Stingray and AD Starjet prices
  10. JHH jet takeoff of grass?
  11. YA A-4 questions
  12. K&B 7.5 help
  13. Y/A twin F18 - a flyaway dream
  14. Y/A F-4 Jet Rotation Questions...
  15. Military Sport Trainer Jet
  16. FOD guard & thrust
  17. Loose Head
  18. Ziroli F9F in person?
  19. Best servo's to use?
  20. me 262
  21. F-86 Sabre HELP I need a pic of the Minute man color. Also help with airinlet design
  22. French Riviera Jet Meeting
  23. Cen TX jet rally WX
  24. Welding on Robart Struts?
  25. Adequate enough servo torque on my YA18 Twin flaps?
  26. Kangaroo new spar install question
  27. Avonds DF F15 to turbine
  28. Sanding Smooth coat on wing - when gone too far...
  29. F-16 ARF Mini RC Jet
  30. New jet trainer from Bruce Tharpe
  31. Fed Ex
  32. Futaba 350 gyro setup for Bobcat
  33. G&P F-18 pusher
  34. Before the Heat
  35. Added HP/RPM from OS91 ? ? ? ? ? ?
  36. Best fuel for a wren
  37. Dynamax fan and pipe
  38. avonds f 15 cg need help
  39. cbm f-16 / need wing rib patterns
  40. buccaneer model
  41. Super Reaper wing mounting - is it good?
  42. midi fan
  43. Clear-coat???
  44. Sunday fun-day
  45. RPModel F16 (CBM copy) What retracts to use??
  46. FC Eurosport Question
  47. Pics or links for a Mig 15
  48. enforcer POD outlet diameter and speed
  49. BV Brakes And Wheels using other brands
  50. Kangaroo - control throws, help
  51. Which trainer?
  52. Jason Solmes???
  53. power for a a4 question.
  54. Need fuel pump help
  55. Jet World Masters just over 2 weeks time !
  56. bellmouth for homade pipe?
  57. Avonds F-15 Cg
  58. Wren 54 question
  59. Civilian jets
  60. Ramtec fans
  61. hitec, jr servos
  62. Z Models again
  63. Bvm A4
  64. Fentress NALF
  65. Toledo Show Pictures
  66. This may sound dumb but.....cbmf16 plans
  67. Twin Engine Eurofighter update
  68. Louisiana Gas Grill
  69. Kangaroo pusher ???????
  70. problem with long servo leads...help!
  71. RAM 1000X Thrust Question
  72. Kangaroo Gyro Question
  73. Top Gun F-15 Help
  74. Euro 3D Canard Flight-mode
  75. Dyna Jet
  76. Who makes a Mig 21 DF
  77. new to jets
  78. Futaba 350 gyro
  79. 10x on my kangaroo, setup question
  80. wemotec MidiFan / wemotec MiniFan
  81. yellow a4 take off length.
  82. Trying to locate Jaime Cortez
  83. Avonds F-16
  84. Anyone heard of Protech PT80?
  85. Need help in choosing KIt
  86. Looking for someone to build my Combat Models F16....
  87. Simjet question
  88. Y/A F-16C buildup
  89. Lazer Works
  90. Kangaroo Spar Question
  91. Cyano vs. Epoxy ??
  92. Old kit identification
  93. Y/A Kit HELP Please
  94. Countersinking Poly-Ply Screws
  95. Bent Robart Struts
  96. Weston byron pipe mystery solved
  97. A.D F-117A builders,photos???
  98. RTI
  99. YA F-18 Inlet shroud installation
  100. Wren 54 Question
  101. Area Rule?????
  102. Wren
  103. twin turbine operation?
  104. Wren MW 54 balancing question
  105. Whoo Hooo, maiden is a success!
  106. JHH Bought Out by Yellow Aircraft, Int'l
  107. Running a turbine in the desert (dusty?)
  108. DFW jet fields?
  109. Kit turbines good for Jet novice?
  110. Jets in Shreveort
  111. Sals Super Bandit (awesome custom scheme !)
  112. Any one from AZ comming to BITW
  113. MW54 speed sensor help!!!
  114. Toledo Show
  115. Best of The West..Hotels?
  116. Edwards AFB F-16???
  117. Phantom Throw rates
  118. LA jets report?
  119. JHH Hawk w/K&B 7.5cc?
  120. Airworld L39 Albatross
  121. Tennessee Jets update
  122. Measured speed compared to visual conception
  123. Super Reaper – assembly questions
  124. Yellow F-16 construction
  125. EuroSport Aileron Linkage
  126. Bob Parkinson F-18
  127. Best in the West - directions
  128. Jet action seen east of Baghdad.....................ARIZONA
  129. Desert Roo
  130. How much Smoke oil do you carry?
  131. Jets and Turbines at Altitude ?
  132. Weston byron short pipe not so good
  133. Super Reaper Landing Gear
  134. My new Winter build project/summer project,Updated
  135. Avonds F-16 info
  136. Yellow F-16 plug in wings
  137. AMA weight limits BVM web site
  138. Converting a Yellow F-4 to Turbine
  139. scale rafale cockpit
  140. JR Matchbox vs JR Channel Expander
  141. Denver Jet Rally June 6-7-8
  142. Rudders And The AMA, Need Quick Response
  143. My first ducted fan
  144. Help I.D. this aircraft!
  145. Electronic brake valve or Smoothstop ?
  146. yellow a4 directions
  147. Backorder...How longdid you wait
  148. JDE F-15 deluxe kit
  149. byron f-16
  150. Anyone make DF units for .061-15 engines anymore
  151. Bvm F-4 CG
  152. D/F pipe or fan presure?
  153. in time for Best in the west?---Made it there...*now with Superbandit video!*
  154. San Jose Jets Meet - Notice of cancellation
  155. screamin' d/f
  156. Mid Atlantic Jet Rally Important info Please Read
  157. Air Speed Indicator ready to go tomorrow
  158. Got a question for ya Terry holston !
  159. turbines for $800
  160. Mig-21 Toki update.
  161. Scott booth
  162. ArubaMaverick Are You Out There? Visiting and Need Directions
  163. here's my first MW54 Diffusor
  164. metal-kote question
  165. D/f Plans, website to purchase from?
  166. Loctite hysol 9462 source?
  167. jet,jets,jets....
  168. Byron F16 Rudder
  169. Jetcat auto altitude hold
  170. New Bobcat flies
  171. jetmart F-14
  172. Li battery poll
  173. 1/9th Scale F-15 Pilot
  174. Looking for Joey Tomez
  175. Viper Jet MK2
  176. Confused!!
  177. Rafale Colours
  178. Twin Engine Eurofighter
  179. Kangaroo powered by 1.08 glow engine??
  180. Tudor Kit?
  181. FC Eurosport Balance Question
  182. New additions to Pensacola.
  183. Roo's on sale!
  184. Will This Dog Hunt?
  185. A-4 Radar Gunsight ?
  186. P80 ?????
  187. Minijet???
  188. Duralites for your Turbine!
  189. Cleveland hobby shops/flying fields
  190. f-16 thunderbird font type
  191. Rcm F-18
  192. Mid Atlantic jet rally-fentress NALF -Chesapeake,Va!!
  193. Air Magic T-38
  194. .91 Ducted Fan F/A-18 Hornet
  195. High Desert ROO
  196. Harrier, anyone?
  197. Turbine Runway Dimensions??
  198. Avonds & AD F-16C Scale Retracts
  199. Air Speed indicator
  200. Edf F-18
  201. Great Planes F-15
  202. OS 91 DF with no Needle Valve??
  203. Fuel gauge question....
  204. Did jetcat turbines go up in price
  205. Aviation Design F 16 problem
  206. Wattage Turbo Hawk
  207. Canopy making
  208. Power box 40/24 professional
  209. Bobcat Balancing
  210. Yellow Aircraft Plug in Wing Spars?
  211. Cg Cooks F-4
  212. 1/7th scale Avro Vulcan B2.
  213. Weston pipe smoke
  214. New Roo test hop this weekend
  215. Y/A F-18, balanced stabilators????
  216. FA22 Raptor??
  217. Best in West
  218. Need help balancing a wren 54 (PLEASE!!)
  219. Spray Guns
  220. JetCat's new web site!
  221. dealings with "yellow aircraft"
  222. Looking 4 Tres Lowery
  223. Speed brakes on struts
  224. Help-David Gladwin's Avonds F-15 upgrade articles
  225. Question on a KBV/Dynamax combo?
  226. nother pic
  227. f-9f2 panther progress UPDATED
  228. LE-slats
  229. K&b 1.00 Df
  230. Mag. Subscriptions?
  231. paper mache' jets
  232. TROUBLE STARTING AN ST-3000
  233. Those of you considering using Robart struts on the Avonds F-16 PLEASE READ!!!!
  234. Yellow Stingray retail price?
  235. Need some help and Have a question
  236. F-18 or F-15 that will fly on toki .18 90mm fan?
  237. Combat models f-16 construction questions
  238. Eurosport with Mercury HP?????
  239. Rice Lake Model Airplane Club Fun Fly- Jets invited!
  240. B-1 Lancer
  241. Any one have a # for Billy Harrod in Indiana
  242. SU27 landing gear?
  243. Eurosport Fin Attachment
  244. Eurosport - Speedbrake Landing
  245. Under $1,500??
  246. Jet event
  247. Kerosene Question
  248. The real Tucson jet rally pics
  249. Byron FA 18
  250. Todd, Well here it is
