- Ford Tri-Motor
- Vpp set up for futaba 7c
- Variable pich propeller automatic
- Configuration, radio
- VPP on a C130 Hercules.....haven't seen it done yet.
- What is a good VPP Set-Up ?
- Indoor 3d
- Planes for a VPP 4D Flying
- Mamo models Upside down system
- Mamo Upsidedown on a Nippel questions
- DX6i and VPP Setup
- What do I need to get started?
- cowl
- 4D ESC PROGRAMMING
- ESC Forward/Reverse
- VPP set up on 7C 2.4
- stupid question, can i use forward and reserve esc instead of vpp
- mamo models upside down vpp
- AXI 2212/34 Hollow Shaft vs 2212/34 Standard
- Has anyone programmed a Futaba T6XHS for VPP?
- Flying using a VPP system - switch or lever
- 4D MID MOUNT PROP PLANE AVAILABILITY IN US
- 4D planes? Should they be over 6oz?
- What makes it 4D? Suggestions for getting me going needed!
- Looking to get into 4D....
- Need help with V-Pitch using DX7?
- why don't many people fly 4d?
- nikitis animal 4D VPP set up
- e-flight extra 260 setup
- E-Flight Extra 260 with showstopper VPP
- New to 4D, TX question
- vpp for sim?
- Has anyone put a VPP on a E-Flite Tribute 3d?
- how do you keep the plane steady?
- Is VPP fun?
- Which VPP system is better?
- VP RADIO PROGRAM SETUP FOR FUTABA 9C
- weight for good vvp proformence
- Non heli TX VPP setup
- Newbie to 4D VPP (in a flightflex UCANDO)
- Looking for Video
- Radio Selection
- 100cc Gas VPP
- Radio capable of vpp?
- Rimfire vs Ikarus vpp
- MAMO UPSIDEDOWN VPP
- backward Harrier... anyone done it???
- Great Planes VPP
- Mounting a Variable pitch motor
- Conversion for non variable pitch rimfire
- New VPP from MP-jet
- great planes VPP and bl12 RPM?
- RimFire VPP setup for a JR 9303
- Sorry...but whats the best system?
- stiffy setup
- Java Script popup when navigating RCU web pages
- Manuel Nubel Mid mount VPP
- radio setup
- Question on RPM for governor mode VPP esc
- will it work
- Please help!!!
- video
- Radio setup
- Why not a 2208-20?
- how does this all work
- Is this thing on?
- Fast VP Setup
- GP Turmoil with VPP setup
- New V-pitch prop from Great Planes...
- rudder servo moving when throtle up
- Throttle and pitch curves.
- replacement hollow shafts???
- New pro series VPP
- New 4D model from Sweden
- VPP Program for MZ14?
- Receiver for VVP set up
- Just had a look at the new....
- Need expert help for a variable pitch system
- What amperage are you pulling with your Variable Pitch Prop?
- My "Hornet" VP motor, Claes in Sweden
- 4D back loop from Sweden
- Knuffel with Ikarus 4D-PPS prop video
- AXI 2212/34 HOLLOW SHAFT
- AXI 2208/34 HOLLOW SHAFT
- EVP/Animal Setup
- Efficient/Powerful mix?
- Is it just me.........
- Any ideas for making a set of blades for my Vp setup?
- 1
- Best servo for pitch??
- Feedback on my setup...Please!
- HL EVP Setup
- VPP
- What speed control to use?
- Pictures of your setups..
- My VPP Video
- Anyone flying the OMP Variable pitch unit yet?
- Scott Foster's setup??
- 4D Flying Techniques....
- First, Second, Third Test Flight
- Okay everything is ready just one problem
- Help!!!
- Setting it up
- Tell me it's not so....
- VPP or PPS
- 22/08/34???
- My Shocky Yak Setup
- pros and cons
- Brands available
- EVP Set Up
- BUILDING your own VPP Setup
- SETTING UP Your New VPP
- Your kidding,,,,,,
- Welcome to the new VPP - Variable Pitch Prop 4D electric flying forum!
