- .91 AC
- YS FZ 70S a few questions
- YS 110FZ throttle barrel setting
- Ys fz 91
- Dz 160 fuel pump prime
- YS .60/.61 two stroke parts source?
- 61 and 80 Heli engine Qs...
- 160 down on power
- PETEC - HELP with YS parts and service
- What fuel tank for FZ .91?
- YS Heli engines for Pattern?
- Aftermarket venturi for YS 170 ?
- YS 110S won't prime
- YS 170 CDI on low nitro
- 170 DZ
- 91AC fuel running out carb and exhaust
- Could not start NIB YS115S
- YS 115 Leaking airbox
- YSE0895 Exhaust Pipe Assembly for YS
- YS 110 Full throttle with carb closed
- To all YS CDI users
- YS 70 prop choice
- YS 170 CDI
- YX 140L sensitive needle
- Which ys 120 is this
- Canadian YS engines part retailer ??
- how hard I have to close the prop nut ,dz160
- Recalcitrant 160
- 140s problem
- YS170 Setting Up
- YS 120AC Dependability Maintenance and tweaks
- FZ115 fuel consumption
- YS 120 cams
- DZ170 Throttle Linkage
- YS 91 Pulsating Idle
- How to take out cylinder liner of DZ170 ?
- HS needle not change maximum rpm dz160
- prop apc 17x12w for dz 160
- fuel system problem with YS 140s
- Backplate HELP
- YS 115 strange idle
- Best Nitro/OIL/methanol combo for Fz 1.10
- YS 1.20 FZ HELP!!!!
- YS115
- Regulator direction
- YS Setup and Photos
- 120FZ and drop of fuel
- YS110 FZ prop
- YS 1.10 FZ trouble since repair
- YS63 tickover
- Changing ring in YS1.10
- how to fill
- YS 70 REAR BEARINGS
- Rules for Posting in the YS Forum (Please Read)
- YS 110fz lacks of power
- YS-175 CDI ?
- AFTERRUN OIL MISTAKE...
- Tips fpr YS90 and 110
- Inverted ys120
- Starting my YS 1.40L
- Something new in the works from YS
- YS Fuel
- ys 115
- When to replace the bearings
- ys63 slight problem
- 91AC vs 91FZ vs a 120 size 4 stroke
- Prop chunker
- Rapicon 30% 2C fuel for 160dz
- YS63FZ
- Oily mess
- Recommended tank size
- YS FZ110-S Problems
- YS 160 Re-assymbly Help
- Ys Super Mount 3
- Fuel tank pressure
- Cam timing on a YS 1.10
- YS FZ91 Throttle Arm Question
- 140 DZ wont run still
- YS140FZ has both valves stuck in open position
- where to send my ys 140 for service
- Loose Screws on a 140s valve cover
- New YS 140 Sport Leaking fuel out the carb
- YS 110FZ inverted dripps gas from carb can't tune
- How do you lap a YS valve
- YS F-120 Low Compression?
- YS 110 FZ
- YS63FZ will not go above idle
- YS91AC Slow to Pick Up Revs on Occasion
- YS-45 problem (pump?)
- Best Tuned pipe and Engine mount for YS long stroke 61
- Spares for YS61 FR
- Engine dies when reducuing power from 100%
- 91 AC Plunger woes
- YS FZ 110S Case Bronzing
- Fuel Dots?
- Fuel Dots?
- YS70
- YS 91 ST runing hot on the High end
- YS 91 AC -(H)heli parts differences?
- YS 110 Barrel seal
- YS110FZ compression problem
- Lost 91 AC muffler, any thread matches?
- Need Advice YS 140FZ
- YS 140FZ idle RPM changes
- YS170 Maintenance
- YS170cdi conrod again
- Hatori Flex header for YS engines
- YS 140DZ and 160DZ exhaust header interchangeability
- YS 120 manual
- YS 160/170 pump question
- ys 140 is a 140L or a 140 FZ
- Fuel Pump ... principle.
- Conrod reassembly YS 170 cdi
- Which electric starter for 160-170DZ??
- What version is this YS 140 L or FZ ?
- Need YS 120AC Manual
- YS110s Mid Range RICH
- Cam gear bearing change - Help!
- DZ 160 exhaust
- YS 70S
- OK to run CP 30% nitro 23% syn oil in YS 140L?
- FZ110 / Front and Rear Bearing Replacement
- YS DZ 175 CDI
- YS FZ110S - problem removing prop hub
- I need help tuning 91 fz
- YS70...In the air & Haul'in
- Where to Find manuals for YS engines online?
- YS 91 FZ fuel drip
- YS91AC - Trouble making revs
- starting problem with YS 140s
- YS 110 FZ idle issues
- YS FZ140 sport regulator screw direction
- YS Foam Clunk
- YS .91FZ original production needle valve question
- YS170 CDI difficult start
- After run oil
- YS 140DZ no fuel
- Trouble 63S
- shaft dia and thread count FZ 110
- ys 45 and ys 60 needle valve
- YS-FZ 70
- YS spare parts dealers in AUS
- YS FZ 110S Camgear timing adjustment
- YS 110FZ Problems... re-build?
- 3blade prop for fz-140
- YS 63 vibration
- 1.60DZ Sudden problem
- YS Parts and Service new website
- ys 140 fz s above idle problems
- YS .63 Straight pipe (Flexible)
- what fuel for ys 140 DZ
- F-120 Manual
- YS91AC vs YS120NC
- YS - 120 F set up & Operating Instructions
- YS 63 FZS airbleed
- New YS owner seeks info
- YS 110 FZ
- What starter and battery best for YS 1.10
- YS drip fuel
- YS 60FS Short Stroke Air vs. Heli
- Ys Super Mounts
- moving up from 20/20 to 30% and prop size
- FZ53 or FZ63 What's the difference?
- YS 1.40DZ failure
- stuck valve?
- YS 110 rebuild
- i
- YS 1.40 vs 1.10 for racing
- YS 1.10 - Mount Upside Down?
- the new y.s. motors
- Ys 110FZ crankcase and rod pitting
- 63S Regulator
- Muffler for YS170DZ -CDI
- YS-110 idle
- Ys 110's First start
- YS 1.10FZ fuel pump / pressure
- ys 45 fuel consumption
- ID this YS 140
- Neddle valve o-rings
- What is a good way to inject after run oil in a YS 140?
- YS Parts???
- 3mm left hand screw
- Where to get YS decals?
- FZ-110 won't start and I tried everything under the sun
- ys 1.20
- FZ110 VS FZ110S
- YS .91ST for speed prop plane
- YS170 CDI - INGINITON SWITCH
- 91AC drive washer
- 110 FZ runs perfect til it warms up.. then...
- ys 140 valve tappet clearance
- YS 91 AC and Muffler Piping options- Please help...
- idle issue
- YS 61 AR LONG STROKE DONT IDLE
- YS 120 Disassembly
- 120-FS rich low throttle
- YS F-120AC
- Looking fo a YS110
- YS and gas
- YS 70
- JBA 75 FS = YAMADA rebuild?
- ys 140 sport problem
- ys 140s will not start
- new ys 1.40 FZ
- YS 91 in T-Rex 700
- ys 140 sport
- ys newbie questions
- Fuel system in dz160
- 110 FZ squirting from carb
- YS110 idle variation
- YS110FZ-S won't quit
- Ys 53 problem
- Just a little info please
- 149 FZ drips from carb even after cleaning the regulator
- YS-91 AC
- YS FZ 110Detecting Air Leaks
- 140s midrange problem
- 140 FZ
- YS-110S dies at idle in flight, runs great on ground
- YS .91FZ frustrations....
- Ys 110FZ Low end too rich
- YS 91ST Bearing Replacement
- 110 FZ deadsticks and bad idle...
- FZ-110 idle inconsistancy
- YS-140 Limited
- Where to Buy?
- YS=63 FZ regulator orientation
- starter to dz160
- 63FZ trouble
- YS 170 fuel pump issue
- How do you remove the crankshaft to get the bearings out YS 110 FZ?
- YS 160 DZ CDI ?
- YS 110 keeps going dead stick
- YS 1.20AC Tuning Help Needed
- YS 140 Sport
- YS 91,no pressure in lines?
- dz 170 cdi
- Cleaning a dirty YS
- tunning video
- Sport or DZ?
- 110s Top End issues
- YS115FZ-S when/where available??
- YS 110 - lots of fuel leakage: just part of it?
- YS FZ 110 S Three Blade Prop
- YS-53 throws Prop / Detonation
- Moving throttle arm to the other side
- YS FZ110 Problem
- 91FZ not running
- Gaskets
- YS 140 Limited Edition
