PDA
View Full Version : YS Engines Support
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18
  1. YS 1.20 AC parts availability...
  2. YS F-91 ACH Can I use it on an airplane?
  3. YS .91ST4 Conversion to prop
  4. YS 140 Sport - Mounting
  5. DZ Tuning
  6. YS 120 AC starting difficulties
  7. YS 63S carburettor
  8. YS91FZ Backfiring
  9. YS 110 super rich low end??
  10. 63s Clicking Valves
  11. YS 91FZ not running
  12. 63S exhaust ?
  13. YS 63S … may be a problem…
  14. 110 FZ Throttle Travel
  15. Prop nut sizes for 63 and 110
  16. 140L broken con/rod---
  17. PowerMaster 30% Heli Fuel Use
  18. .63 Muffler Baffle
  19. Cracked Rocker Arms
  20. availability
  21. Current YS thrust ratings
  22. YS110 bearing failure
  23. 1.20AC..... no fuel pressure
  24. YS 110!
  25. YS 63 vs 63S
  26. In flight idle wandering, YS63
  27. 140L seems down on power
  28. YS 140fz startin problem
  29. Homebrew for YS?
  30. YS website down?
  31. 63FZS regulator ???
  32. YS110 Fueling Set Up
  33. 110 going thru plugs
  34. YS 170 DZ?
  35. YS 63 Leaking Regulator
  36. YS110
  37. 140DZ
  38. Is a YS 160DZ more difficult to handle than a 2-stroke?
  39. prop for 120 AC for max speed
  40. Poor Transistion YS63
  41. Is the 160 a good friend for all days use?
  42. YS 61F.R - Long Stroke Airplane Version
  43. Trying to Break in new FZ110
  44. Supercharger....How's it work?
  45. YS 110 valve adjustment OOPS!
  46. YS 110 spun drive washer
  47. YS 45 FR/FS Tuned Pipes
  48. YS 91 AC Has No Compression. HELP!!!
  49. YS after-run oil
  50. YS Dealers
  51. which air filter will fit a .63?
  52. YS 45 FS with tune pipe
  53. Am I hurting my 63 running 12,000 rpm?
  54. YS engines for Catalina
  55. Do i use a 63 or a 110
  56. YS 91AC rust from leftover fuel
  57. YS 61.S
  58. YS91FZ Throttel sticking
  59. 1.40 sport
  60. YS 91AC -- Diaphragm
  61. YS 160DZ pipe
  62. YS 50ST heli engine
  63. YS140 FX idle problem
  64. 18/14 fuel?
  65. YS1.10 issue
  66. needle valve compatibility
  67. Tru-turn prop adapter for YS63?
  68. 110 prasies
  69. Saito Glo plug??
  70. MOVED: YS 63 + Alley Cat = Fast
  71. YS 91 Thank You
  72. YS63 Question
  73. Pressurizing the system
  74. YS110 regulator issues
  75. YS 63 - support problem
  76. Inverted YS 63
  77. Bent crank
  78. Worn threads YS 120SC
  79. YS 91FZ muffler wire support &/or locktite
  80. YS 110 bad vibes
  81. YS 120 Which version?
  82. YS140 DZ problem - help!!!
  83. YS110 leans out
  84. Parts availability for older YS 60FS
  85. YS91
  86. YS 63-S = INCREDIBLE ENGINE!!!
  87. YS .91ST4 Heli ?
  88. FZ63 problem
  89. where to buy muffler
  90. YS110 Regulator Setting
  91. Exhaust Pipe Threaded Rod for DZ140
  92. Is a YS engine factory pre-set to run out of the box?
  93. FZ110 fuel problems
  94. Ys 120 header pipe
  95. YS110 Idle Problems
  96. Fuel tank question
  97. YS 110
  98. Question on YS 91 crank case
  99. Adjust valves when???
  100. Which 30% Cool Power?
  101. will a backwards facing Tettra tank work?
  102. YS 91 or 110
  103. Inverted YS63
  104. ys 120 cutting off
  105. YS-63 surging problem
  106. Check valve
  107. 140L problems
  108. New to YS
  109. Sport 1.40 low speed needle fit
  110. Carb barrel binding (.45 FS)
  111. YS 110 failure
  112. YS 120SC newly rebuild 140 need propeller
  113. Muffler for YS45
  114. 140DZ Woes
  115. Coolpower
  116. YS-120SC Starting Problem
  117. Tank Placement and inverted YS 91
  118. YS 91 idle problem
  119. Starting points.
  120. 140 sport fuel leakage question
  121. Regulator Questions
  122. 120SF O-Ring??
  123. Break in question
  124. AFTER RUN OILS
  125. Yet another muffler question
  126. YS 63S -- Idle problem
  127. YS 140 hoses
  128. 110 with no Muffler?
  129. YS 91 AC in in the line
  130. YS DZ pump problems alot of them!
  131. YS 91 HELP!!!!!!!!! PLEASE!!!
  132. YS smoke
  133. ys 120 head
  134. 63FZS
  135. YS 63 FZS refuses to idle or run properly from new
  136. YS low speed needle
  137. YS 1.10 Fuel
  138. YS61 prop
  139. YS160 muffler
  140. 91FZ Muffler Baffle
  141. 1.10 flaming out
  142. 110 low end all the way in?
  143. Strange Regulator setting on 110
  144. YS63 needle valve set screw size?
  145. New ys 63 tuning help
  146. Tuned pipe for YS 110
  147. YS 120SF
  148. 3 bladed prop for 1.10?
  149. YS .91AC plumbing question
  150. 120 wont stay running
  151. Air in fuel line
  152. YS 110 idle problem
  153. Erratic YS63
  154. Propeller Shaft size for YS 110
  155. YS .91
  156. Cool power 15% for ys engines
  157. YS 110 throttle up question
  158. ys63s and ys63fzs - whats the difference ?
  159. Sending my YS 63S In for Repair
  160. YS 140 FZ problem
  161. Suddn change in YS140DZ performance
  162. YS 91FZ big problem
  163. .63 regulator, change diaphragm or whole regulator?
  164. YS 110 low and middle problems
  165. F120 Service
  166. Do I need a check valve? YS63
  167. YS 140 Tank
  168. WHich 140 to use
  169. YS 61ST2 heli engine for airplane use?
  170. YS 63 dead?
  171. YS 110 info
  172. YS 110 stockup with metal particles
  173. YS 1.1 and .91 same valve cover ?
  174. YS63FZ-S, I need to go back to square 1 ARG
  175. FZ 63S
  176. 140L rough idle
  177. YS 63 FZ Starting procedure
  178. Smoke system by tank pressure?
  179. Inconsistent RPM for YS63S
  180. YS 63S Prop Question
  181. YS 110 pump
  182. 63 FZ
  183. YS 120SC, NEED A LOW speed needle valve
  184. ys 63 loads up, quits
  185. 160 Dz - Hunting
  186. Replace gasket??
  187. ys110 high rev problems
  188. DZ160 Tuning
  189. APC 16.5 x 5W Prop for YS110
  190. 63 FZ, awesome engine!
  191. YS110 quits when it idle's
  192. YS 63 Prop Question
  193. Prop for YS63S?
  194. YS 63S plumbing questions
  195. YS 91 AC help
  196. YS 63 in Funtana 40
  197. YS 120FZ
  198. .63 s valves
  199. Cam Gear Bearing
  200. YS 120 SF lot of smoke
  201. YS - .63S in for repair
  202. YS 61LS documentation needed
  203. 1.60 DZ Question
  204. 140dz starting
  205. 160DZ problem
  206. .63 s exhaust
  207. YS 63 s
  208. 1st Four Stroke ............. YS FZ63s !!!
  209. ys 140 problem
  210. 30% Heli...
  211. ys 120 ac fuel lines
  212. Damaged threads on 140 DZ crankshaft
  213. YS 63 Help
  214. YS110FZ Fuel Pump Pressure
  215. leaky YS110
  216. 160DZ Problem
  217. YS 140 Propellers
  218. YS .91 AC ROCKS
  219. 91 FZ inverted and airbox problem
  220. 120SF max temperature
  221. YS .63 regulator vs. Cline type regulator
  222. Remote fuel and YS 91FZ
  223. YS140L or 140 sport
  224. Low end needle query
  225. YS 1.40 Sport Problem
  226. YS1.10
  227. YS 140 running rough at full throttle
  228. 120SF Problems
  229. Odd needle setting on a 140?
  230. idle problem ...1.10
  231. 140DZ green valve
  232. Good starting point YS 1.40 sport
  233. YS 110 Lifter Issue?
  234. Differences between 120SF and 120FZ
  235. YS 1.4 EXHAUST Choice??
  236. 160 Exhaust temp
  237. YS 1.40 engine quitting????
  238. YS 110 FZ Availability
  239. lost muffler baffle
  240. YS61SH
  241. YS110 - SOS!!!
  242. 140 sport problem
  243. ys 63
  244. 1.40 L Issues
  245. YS 160DZ Fuel Consumption
  246. 91 AC
  247. 140DZ set-up
  248. YS 110 Issues
  249. YS 120NC bubbles in fuel line
  250. Threw the prop
