PDA
View Full Version : YS Engines Support
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18
  1. 120 NC worth rebuild
  2. Soft mount YS 120 AC
  3. Fuel metering DZ
  4. YS 110 header and muffler
  5. YS 91AC Sluggish throttle response
  6. YS FZ 110 fuel
  7. 140 FZ prop and rpm
  8. My Luck Has Changed
  9. Older YS Carb Help
  10. YS 110 Idle Problems
  11. Ys 91 ST
  12. YS 140L hunting at low throttle
  13. 63FZ Problem
  14. Ys 63 throttle management
  15. YS .45 parts
  16. 120 nc cam
  17. YS61 Valve Question
  18. 63S Opening Diaphram
  19. 1.40FZ cylinder head
  20. prop size for break in YS 63
  21. Stripped Head
  22. YS .63 Threads
  23. 160 DZ Pump Issue?
  24. Y/S .91 exhaust port problem
  25. Extra 300 prop size?
  26. Air filter for YS 110
  27. Change bearings for YS 63 FZ
  28. YS .63FZ Problem
  29. bubles in the fuel line
  30. remove piston 120 nc
  31. Green Stuff
  32. 1.10 throttle curve
  33. .63 problems..
  34. YS 63 FZS question
  35. 1.10 leans out in flight (idle only)?
  36. YS 120 AC manual
  37. YS 140 Sport possible problem
  38. Dave,,Ive got ?'s and ive heard you have answers!!!
  39. Help insall disc valve - YS63
  40. 140l
  41. YS .63 + CP 25%
  42. YS63 Broken cylinder head screws
  43. Ys .63 S
  44. 140L rpm
  45. YS 110 - Where's the power?
  46. YS 110 break-in prop.
  47. YS 63 FZs question
  48. YS .53 Fuel trouble
  49. YS Jewel or Junk???
  50. ys 63 problem
  51. YS 140L Questions
  52. ys 63 problem
  53. Black head color
  54. YS110 Needs Service?
  55. Enough Cooling for YS in Tiger Moth?
  56. New YS-63FZS speeds up when closing the throttle ?
  57. YS 63S RE-LOCATE REGULATOR?
  58. YS 140 Sport Slimline Muffler Help
  59. YS woes
  60. I've about had it with this engine (YS63)
  61. YS 45 bearings
  62. YS 63 FZ muffler
  63. Plumbing a YS .63 ... HOW ???
  64. Information on YS engines
  65. Check-valve and regulator
  66. Loss of compression
  67. YS140S running problem
  68. YS 140 Sport Mounting
  69. YS 160 DZ Question for break in!!!!!!!!!
  70. What is size of exh port for YS140L
  71. YS170's
  72. YS glo plugs
  73. ys 1.10 wont idle
  74. Dave Loosing my smoke
  75. YS repair Q's for YS 110
  76. New 1.10 regulator
  77. DZ Pump Valve Installation
  78. ys 120
  79. YS 63 Problem
  80. Fox miracle plug OK in YS FZ6S ?
  81. YS63 FZ Starting/Running Problem
  82. 63s Problem
  83. YS 110 Prop driver
  84. 45 2 stroke problrms
  85. YS 1.10 Repair
  86. 1.40 Sport
  87. YS91 FZ problem
  88. YS .63FZ Problem
  89. YS 140 Sport or 140DZ ??
  90. YS 110 richer idle
  91. problem starting 1.10
  92. YS63FZ Problem
  93. set screw on the HS...what size?
  94. YS160DZ Shuts down in verts at WOT - Solution
  95. Decals
  96. YS 63 main needle adjustment
  97. ys open header???
  98. Changing YS 140 FZ Ring
  99. YS-63S loosing power
  100. Couple of 110 questions
  101. YS 61 FR
  102. YS 110 Problems
  103. YS110 adjustment problem
  104. Fuel for 63
  105. YS .63S Exhaust Valve Problem
  106. 140 DZ Problems
  107. Cam gear spun on L...how much needs replacing?
  108. Help on my horrible 91FZ please.
  109. YS 140 Sport leaves heavy smoke trail
  110. YS 140 Sport
  111. YS 110 lean run
  112. 40% NITRO DAVE?
  113. ys .63 DAVE?
  114. YS 63S braking in
  115. RPM's 120 AC
  116. YS110 Damage
  117. Dave! Replace a YS140L w/a YS140 Sport?
  118. YS 63 FZS Muffler options
  119. 110 FZ pressure problem
  120. YS 91 AC Parts List
  121. YS 63 FZS
  122. first ys
  123. YS 110 Fuel leaking from Carb
  124. YS 160DZ question
  125. YS 110 repair advice needed
  126. YS and tuned pipe.
  127. Changing Fuel and adjusting settings?
  128. YS .63 FZS
  129. YS 160 DZ PROBLEMS
  130. YS 63 FZS transition question
  131. YS 1.10 and YS 1.20
  132. YS 120 AC
  133. YS 63 FZS tappets
  134. Nose Ring for YS 160 DZ.
  135. 140L regulator plunger size.
  136. Ys -FZ & SF
  137. 1.10
  138. YS 110 - Compression way down
  139. YS 63 Four stroke
  140. ys 120f engine mount
  141. Rocker questoin ?
  142. 110 bearing size
  143. 110 Fuel leakage question
  144. YS 140 FZ back plate
  145. YS140DZ problem
  146. YS 63 FZ s question
  147. YS 140 Leaning out on top end
  148. Problem with .63
  149. Dave need breakin question answered please
  150. YS FZ91 ???
  151. YS-45 FS Issues
  152. need help
  153. YS 110 out of fit
  154. YS 45 & Aurora pattern plane
  155. ys63 inconsistant
  156. YS 110 idle problems
  157. YS 110 air in fuel.
  158. YS110 Easy Refuelling
  159. Kudos to Dave and Richard!
  160. More YS 110 diaphram questions
  161. YS 120 Won't Pump Fuel
  162. YS 110 FZ-S
  163. black oil
  164. YS 110 Knock?
  165. YS 61 ST1 Update
  166. Cool Power 30% Heli fuel
  167. YS63 Fuel
  168. Prop for 140DZ???
  169. YS-110 spinner spacer collar...
  170. YS FZ 110 problems
  171. YS120 3-Blade
  172. MOVED: YS FZ110
  173. YS 63 FZS
  174. YS 63S Won't Hold Idle
  175. Ys 120 history
  176. YS DZ160 Fuel injector pops out
  177. YS 120NC /SIG Mayhem(72") ????
  178. Max A/C weight w/YS
  179. YS 45 Muffled Tuned Pipe
  180. YS 63 FZS tappets
  181. 140 DZ changing idle
  182. Cool Power 30% heli fuel and after run oil??
  183. YS 120 MANUAL
  184. YS 63FZ Rough idle
  185. Problem with my YS 140 sport
  186. ys 140 sport not working
  187. FZ91 Prop Nut
  188. YS 61 Rear
  189. YS 45 FS broken needle valve
  190. ys 60's
  191. YS 110 prop choice
  192. my YS110 problem
  193. YS .63FZ
  194. My 110 is giving me fits again...
  195. ys 140 differences
  196. Info on YS F120
  197. Where is YS110?
  198. YS 61ST
  199. Header Tanks needed?
  200. YS 110 Leak detection
  201. ys120sf no fuel at top end
  202. .63s fuel consumption
  203. YS AC's ??
  204. YS 60 FS
  205. YS 63 FZ S muffler
  206. Help! FZ 63s failed to start
  207. Needing parts for a ys 45
  208. Yamada 63 FZ
  209. DZ 160 starting question
  210. 120SF early or late model?
  211. YS 63 in flight problems
  212. Question about my YS 110
  213. engine mount for 160DZ and 140L
  214. Requesting YS 120FZ Help
  215. Is 140L Vs 140Sport
  216. Is Coolpower Heli 30% OK in a YS 63 FZ-S?
  217. YS 110 Valve Lifter Oil
  218. Regulator housing
  219. YS-120SC Leaking Fuel Out of Carb.
  220. YS 140L Header Problem
  221. Inverted YS 110 problem, carb leaking
  222. YS 61R
  223. F-120 NC Fuel metering problem
  224. low speed for ys 120sf
  225. YS .63 no compression
  226. 160 DZ After run oil in to the crankcase
  227. ys 63 fzs WORKING GREAT
  228. YS63S, loading up slightly after inverted flat spins
  229. YS 110 not running
  230. YS 120 NC
  231. 160DZ Questions
  232. I Broke My YS
  233. YS61 leaking fuel- doesn't stay running
  234. YS120NC
  235. FZ63S - Won't stop running
  236. YS 45 Service
  237. YS-45
  238. YS 110 running too rich and idle problem
  239. YS-45 FS Issues
  240. which engine?
  241. Availibility of Parts for Older Engines
  242. 63 transistion
  243. dz keeps popping hose from regulator to carb
  244. YS 63 FZS break in
  245. YS 45 cleaning regulator
  246. 140 sport rough idle
  247. ys61 stII quits in flight
  248. ys 110 break in
  249. YS 110 after run recomendations
  250. YS 110 not running
