PDA
View Full Version : YS Engines Support
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. Y.S. 120 f fuel lines
  2. Ys 45 2-stoke.
  3. ys .60 2 stroke
  4. YS 120. WHICH MODELS DO I HAVE??
  5. YS 120 FZ
  6. YS 61 carb + pressure regulator
  7. Spinner Prop Nut
  8. YS 1.10 Horsepower
  9. ys 140 fz
  10. YS140DZ short life
  11. YS FZ 110 Fuel problems
  12. Where to purchase YS110FZ?
  13. YS 110 glow plug overtightened?
  14. YS f 120 modifications
  15. YS F-120
  16. YS 91-AC will not shut down
  17. YS 110 Sill having fuel problems
  18. rpm's dropping on my fz53.anyone else have this problem?
  19. ys110 valves
  20. YS1.10 idling w/ CooPower 15% heli fuel
  21. after run oil ?
  22. Which parts effected by oil?
  23. YS vs YS Futaba ??
  24. 140L
  25. Fuel Line Clamps
  26. YS 120 SF HP Rating about it ???
  27. 91 airbox availability?
  28. YS91 weight
  29. YS heli engines
  30. YS 120-AC
  31. Props on FZ63 and FZ110
  32. YS 63 S mounting bolt size ?
  33. ys 120 nc throwing prop
  34. Fuel question for a YS 91 AC
  35. Tuning my YS110 is whooping me.
  36. .63 FZ wont quit
  37. YS throttle barrel
  38. YS .63 Setup problem
  39. YS 1.10 cam gear
  40. 63s dying, fuel from exhaust, carb
  41. Tappet adjustment
  42. Y.S. 120 F locking nut
  43. Diaphragm
  44. on the bench or on the plane?
  45. What's the difference?
  46. 91 Clean up
  47. Cowl Setup...
  48. YS 140 Sport Fuel Tank Hookup with Fuel Dots ETC
  49. ys 63 3d props?
  50. Difference between FZ 140 and 140L?
  51. Dave - E-Mail problem
  52. Best Fuel For YS 110
  53. YS 140 sport
  54. 140DZ set-up/adjustment
  55. YS60FR header and pipe
  56. Hint for trouble shooting 110 idling
  57. YS 110 compression problem
  58. YS 120's
  59. YS 110 Idle
  60. Fuel filters
  61. YS 120 SF
  62. Difference between ys 160dz and ys 160dzm ?
  63. Ys 160 wont stop
  64. New 110 FZ tuning help
  65. removing carbon buildup
  66. YS 53 Prop?
  67. tank
  68. YS110 conrod disintigration
  69. YS 1.10, lack of tank pressure
  70. YS 63s Fuel consumption
  71. YS 91 AC
  72. YS 110 START UP AND SHUT DOWN
  73. Check valve repair
  74. Decals
  75. Two check valves, YS110?
  76. YS 91AC problems - please help
  77. Header length on 140L
  78. A new YS45FS
  79. 110FZ availability?
  80. Storing YS Engines
  81. YS- break-in fuel question
  82. Wild cat heli 30% accpetable for 160DZ?
  83. 140DZ idle problems
  84. How to remove Valve Spring Retainers ?
  85. 110 FZ: What Prop To Try Next?
  86. ys 110 valves closed
  87. Difference between
  88. Tappet clearance
  89. 4 blade APC 15.5X12 any good for YS 160 DZ?
  90. YS 63FZ-S in a Sig Four Star 60
  91. YS 1.10 Header Connection
  92. YS Fuel Question
  93. Tuning of a YS63 (new model)
  94. Could someone help?YS.AR .61Long
  95. YS 1.60DZ Rocker Clearance
  96. 91AC Muffler
  97. YS .63S - locking
  98. YS 140 fz need help or instructions
  99. YS120SF After Run Oil
  100. YS 91 FZ bubbles in fuel line
  101. Lost end of muffler on 110 and lost power
  102. Plunger Size for 63 fz
  103. 120 sags in hard rolls
  104. YS110FZ at altitude: fuel. prop, power ???
  105. YS 60 pump troublshooting
  106. YS 20 SR 2 storke (120 CI)
  107. Oil question
  108. YS 45 2-stroke. ...HELLLPP
  109. Cannot start YS 160
  110. Two YS 63 FZ sent for service
  111. Coolpower Heli 30
  112. YS 63FZ-S Inverted vs. Upright
  113. Oil for DZ140 in high heat
  114. YS 110 exhaust question
  115. YS' position on After-Run oild
  116. 160dz
  117. YS 160DZ
  118. YS1.40FZ Break in
  119. YS 63 prop nut size
  120. YS 91 Engines
  121. YS140 Compression??
  122. Couple of quick questions
  123. Any more 1.10's ?
  124. YS120 as a pusher
  125. dz140 soft mount
  126. .63 backfire
  127. 140 DZ Prop ?
  128. Ys 110
  129. Remove residual fuel from inside YS 140's regulator
  130. Torque Graph For YS 110FZ
  131. YS 45 in a Zen 50
  132. YS 63S fuel tank
  133. ys 91 ac leaking out of the carb
  134. fuel feed problem 120sf
  135. 1.10 vs 91AC
  136. YS160fz
  137. YS cam setting
  138. 140 l vs 140 FZ
  139. YS 140 sport idle setting
  140. 140 FZ 1 2 or Sport
  141. 120SC vs 120FZ
  142. 63-S, 3 Blade prop and straight pipe
  143. FOD screens
  144. New 110 constent fuel drips from carb
  145. YS F-120
  146. storing my YS over the winter
  147. Best YS 120 Prop for 68" EF YAK
  148. ys 120nc trouble in the midrange
  149. 110FZ Needle Valve Loose
  150. YS 120 NC, is 30% nitro Cool Power heli fuel OK?
  151. End float on sick YS91
  152. YS 110 FZ Valve question.
  153. YS 120 Identification
  154. YS 110FZ Break in
  155. YS 120NC idle
  156. YS 110 Plunger
  157. YS 120NC idle
  158. Have used F-91AC and don't know anything about it
  159. YS 91 fz?
  160. YS
  161. YS 110 rear cover
  162. Connecting rod : 140L vs DZ
  163. 63.bubbles in carb line
  164. 120 crankshaft
  165. regulator plunger
  166. YS .80 check valve location
  167. Cantankerous FZ 140
  168. 140 FZ-1 HP
  169. 4 stroke car engine??
  170. Current YS HP ratings
  171. YS Engine HP Figures
  172. YS 91 mid throttle problems
  173. Destroyed YS 110
  174. 110 tank pressure question
  175. 91ac considerations.....
  176. YS 140 question
  177. YS 110 fuel draw length
  178. Can I run a YS .61 ST2 in a PLane?
  179. YS 110 new engine compression?
  180. ys 110 fuel line
  181. YS-53
  182. YS 1.10 mid range settings
  183. How to distinguish version of YS 120?
  184. Props for 140 DZ
  185. New 110 dies after chopping throttle
  186. YS 140 FZ-1
  187. Regulator Rich YS 63
  188. YS110 rocker clearance gage
  189. 3D Prop for YS110
  190. 120 lineage
  191. YS 140 Limited muffler
  192. 1.10FZ break in question
  193. Where to find a 110FZ
  194. YS45
  195. valve clearance on 140's
  196. 120 Ac probs
  197. YS 110 1st four stroke!
  198. YS 91FZ HELP PLEASE
  199. YS 140 DZ questions
  200. YS 63S throttle arm
  201. YS 1.10 lost 1000 rpm and has internal obstruction
  202. YS 140 sport idle woes
  203. YS-91AC
  204. YS 110 New Owner with Stupid Questions
  205. Oil recommendation for YS140 L - DZ
  206. APC three blade prop question
  207. muffler for ys 120sf
  208. My YS has been sitting for 8 or so years...
  209. 120 AC leaking fuel
  210. YS 110 Run Time
  211. 1.10 in-cowl muffler
  212. AC muffler threads stripped
  213. 120 NC seized
  214. ys 91fz
  215. YS45 idle surges after warm-up / After Run Oil
  216. parts and photo contest questions
  217. glow plug thread ruined
  218. 120NC idle
  219. 140 DZ
  220. YS 110 Valve Clearance
  221. YS 120 NC prop
  222. How can I get the muffler back-piece for my YS-110?
  223. YS140FZ Sport
  224. YS 63S Prop Question
  225. New YS 110 getting ready
  226. YS45 or YS110
  227. Changing bearings in YS 120FZ
  228. A couple of Y.S. .63 questions
  229. 110 Too Lean
  230. YS 110 Seized in Flight!
  231. 91 FZ low power and compression
  232. YS 140L BREAK IN
  233. 140 DZ Dies at full throttle
  234. YS F120-NC/SC?
  235. YS 110 proping
  236. YS-45 Neddle assembly
  237. Whats the turn around on the Ys Engine Sevice Depot?
  238. 63 FZ fuel
  239. Factory Regulator Setting
  240. 140 DZ Storage.
  241. YS 91 Power lost?
  242. Muffler bolts
  243. YS 63s
  244. 120 AC idle fluctuates
  245. YS 120 NC Regulator Air Bubbles
  246. Awsome customre service!!!
  247. ys 61 st HELP PLEASE
  248. YS .61 2-Stroke Parts
  249. YS 1.10 too rich in the mid range
  250. 91AC what prop for 3D
