View Full Version : YS Engines Support
Pages :
1
2
3
4
5
6
7
8
9
10
11]
12
13
14
15
16
17
18
- YS 160DZ check valve questions
- 1.40 L Fuel Issue
- YS 110 Top end
- YS 91 AC-H
- Metal dust.
- 140 Sport: Can that setup be right?
- 1.40L RPMs?
- YS91FZ Question
- 91 ac props for pattern
- fuel question
- YS 63FZ on 15% CoolPower Heli?
- YS F-120 Valve Clearance
- YS63 pump settings
- what is ok to use as storage or after run oil?
- DZ 1.60 Quitting
- YS91 FZ transition and idle problems
- YS 63 Application prospects
- YS 140 Problems
- YS .61AR
- YS 120 SF props
- Fuel Consumption
- Checking Pressure
- YS 63FZ question
- YS Glow Plug substitute
- Is 18x6 to big for 120 FZ?
- YS 63 questions
- 110 quitting
- YS 45 Stripped Glow Plug Threads
- Trouble with my 1.10
- a few questions on the ys .61 long stroke
- Cool power 30%, 30L or Magna
- Well Dave... Murphy caught up to me!
- What is the thread size on YS 120 FZ?
- Early F-120, Power missing ?
- YS 120 SF
- Cooling
- YS 110 - RUN IN ??
- DZ Fuel Question
- FZ 91 proble
- 120 SF regulator
- YS 140L and glow plugs
- YS 110 Muffler Replacement
- Can my 91FZ be repaired?
- YS F-120 Needle Valve Assy
- Large fuel line for 110?
- Fuel mileage problem with YS 140DZ
- YS 110 or YS 140 Sport
- YS F-120 NC NIB
- mejzlik prop on 120?
- YS 140 Sport Won'T Idel
- 110 muffler
- Eureka !!!
- YS160DZ loads up in vert
- YS 110 for repair
- Fuel line and fittings
- DZ 140 quitting problem
- YS-110 settings problems
- YS 110, Size of cowl cutouts for cooling?
- Ys 110 Very hard to start
- My first fly w old YS 120 SF
- YS140 Sport starting
- Exaust Header
- YS FZ-63S Idle RPM 2500RPM or 2000RPM?
- 91AC Backplate Gasket
- YS63 Running Lean
- ys 110 fz availability
- YS 91ST sagging in idleup
- YS 61
- YS 110 Propeller nut
- 91 FZ needle settings
- YS63FZs Silencer Failure
- Adjusting the YS 91AC
- DZ pump problem ?
- regulator question...on the 1.10
- YS FZ 110 Fuel
- Best Pipe for YS140FZ
- YS120 props
- YS FZ-140S Idle
- YS160 New NRV
- Electric starter or by hand?
- Byron Heli 30% VS CoolPover Heli 30%
- 160DZ Question - Throttle response
- YS 80 SURGING
- Feeler gauge
- Please Help!! New YS 1.40 leaking
- 91 prop
- YS 120 Problem
- YS Diaphragm
- YS 140DZ Idle
- ys 110 midrange
- 140dz stops
- Ys 10fz prop?
- ys .61 st heli engine quits running
- YS 160 prop for 3d
- Valve spring set for ys 120f
- FZ110 setup questions
- YS 1.10 Muffler coming loose
- YS 1.40 sport VS 1.40 DZ
- How fast is fast idle on a YS 91AC
- FZ110 availabililty
- Supercharging
- YS.Futaba 53FZ Problems
- YS low speed needle valve position?
- YS63 - air bubbles in the fuel feed line
- Y.S. Fatuba 60 FS engine
- 140dz quick prop question
- I need a 91fz muffler
- YS 91AC problem
- 140dz compression problem
- YS 63 FZ idle - changes from full to empty tank
- thread size for 110
- 110 adjustments?
- Low Iddle adjustment
- Needle Valve Setting YS .91AC
- Ys 140dz need a little help
- YS 120 problems
- Ys 110 not available till August?
- YS 110 Regulator & Plunger
- Request: YS 45 rear exhaust dimensions / documentation
- Do I need a new needle valve?
- YS fuel system question
- Running the DZ....
- I need help in getting my YS-91 to run correctly.
- YS 110 - Transition Adjustment rich or lean
- ys regulator diaphram
- DZ140 crash
- .63 High Speed Needle Extension...
- YS .63 FZ- bottom end problems
- Ys110 Plug probs!
- symptom..and cure
- Problems with 140L
- Confused about fuel
- lots of dark oil from my YS110 YS110
- YS Mount rubber delamination
- size fuel tubing for 1.10?
- DZ Part Replacement Help
- settings and adjustment for a YS 53
- 120-SC
- Regarding sent in 91fz
- YS120-SF manual needed
- YS45 Noise
- YSYS F-120
- Spinner for YS 63FZ
- YS 110 low rpm
- comparing the 140DZ and 160DZ
- Needle Settings needed please
- Torque for tightening down bolts
- YS 110 loading up in air
- YS 91 AC, impossible to tune, always rich
- fuel coming through the carburator.
- fuel line woes
- ys 53 bubbles
- YS .63 surging 1/4 throttle
- 160DZ , first start problem
- ys 140 sport and ys 140-2
- YS 110FZ and Edge 540T
- 110 v.s. 140s real world fuel consumption
- HP rating for the .61 long rod 2 stroke ?
- 140L With Black Gaskets??
- Props for YS53
- prop size for break in on 1.10?
- 140L regulator
- Timing Question 6 vs 12...does it matter?
- YS 110 Engines shipping?
- carburator air filter ys 110
- YS110 new. From Italy. wich fuel-help
- Straight pipe for exhaust on YS .53FZ
- YS f-120 better than os 120 pump?
- 110 set-up changes 5000' to 1000' altitude
- ys 110 problem, huge problem
- YS 110 Mounting
- YS 110 surging problem
- YS 91 FZ 4-stroke Engine Vs YS F 91-AC 4-stroke
- Magnum 30% heli fuel and YS engines
- YS 45 Regulator - same care as 63?
- Ys 110 help
- Ys 63 FZ fuel regulator
- 160DZ with Venturi Restrictor?
- Will it be 110 heaven or.......?
- YS 140DZ
- Two 63S in a VQ P-38
- 91AC muffler
- Curtis Youngblood Performance 30 Heli Mix: OK for FZ and DZ?
- Seating the Ring on YS63fz
- YS 110 will not idle, maintains 8000 RPM
- sf 120 i think
- Mid range surge/YS 110 FZ
- CP heli 30% VS Byron YS 20%
- .91 Fuel burn
- YS63 Nose Up Dies?
- YS 63FZs Crash
- ys sf 120 parts
- YS63 loss of RPM
- YS 110 max RPM
- YS 110 no low throttle response
- YS venturis
- Which cycle to adjust tappet clearance ?
- Bad Fuel
- ys 120 sf
- ys 120
- YS 110 Dead Stick
- YS 140s intake valve?
- YS 61 rear exhaust set-up?
- YS63S question
- Where to send ys 1.10 for repairs?
- bent push rods for 110
- YS 120-FZ start up advice.
- Fuel economy comparison
- 120 sf
- power/torque curve for 140DZ
- YS 110 half muffler
- YS 120SF Help!!
- YS stock Muffler for YS 140 Sport?
- YS 120FZ
- engine mount for 1.10 and .63 ?
- YS110FZ, won't run
- ?? Tunedpipe for a YS .61 Long
- Cool Power red oil
- New YS63S break in?
- What fuel and plugs with YS63S?
- 160DZ HP rating
- Dave...you've got a customer for life..
- YS 160 Dingo
- YS 53
- YS 120SF Muffler Header Thread Size?
- YS 110FZ RPM?
- Question about RPM and a YS 2-stroke
- YS .61S Short Stroke
- 63FZ
- Thanks Dave!!
- Ys F-120 manual required and advice
- My YS 110's Idle Screw Is All The Way In
- Delivery Status
- YS 110 recently serviced, still won't idle
- YS experts need help
- YS 160 sport????
- YS 63?
- YS 110 leaning shortly after takeoff...
- YS 110 Low idle Problem
- YS .61 Heli for airplane?
- YS 120 SF
- ys 63
- ys110 or ys120??
- Crashed plane...what to do for YS63?
- YS 110 as a pusher
- Dave Shadel out from 2/23 to 3/2/05
- YS 140 Question
- All YS 4 strokes "supercharged"?
- YS 120's
