- YS 160DZ Fuel Consumption
- Need a YS 120-SF Drive Washer and Prop washer
- ys 110 overheating
- Need Help Troubleshooting My YS 120
- more speed for my 120ac?
- YS 160 cutting in flight
- Stock up on coolpower 30% heli...
- YS 45 FR
- YS 120 fuel pressure
- ys110 where,what ???????????
- Recommended fuel
- ys 160 missing beat
- Velocity stack on 160
- ys 140fz rebuild instructions and tips
- YS 140FZ problem help needed
- YS FZ110S carburetor...
- Best propeller for the YS FZ110S?
- YS 140l vs 140dz thrust figures
- YS 110 tuning problem
- 3 Blade prop for YS 91
- YS 110 mid range question
- Important Please Read!!!
- Air Leak ?
- YS 140 FZ
- YS 120FX lacks power
- o-ring for reg screw
- ys DZ160 fuel in valve cover
- YS63 Exhaust options
- Tank for Ys63
- YS 120 NC Running Rich, Leaking Fuel
- YS 63S Runs Super!
- YS-110FZ muffler
- HS needle adjustment
- FUEL LEAK
- New YS170DZ Qs?
- ys 91AC quitting
- Out of Pocket 16May thru 19May
- YS63 question / problem
- YS 2 stroke 61 w regulator
- Clean Muffler
- You got your new 12X?
- 170DZ RPM Confirmation
- YS91FZ
- They are different the YS 110 and 110S
- YS140FZ valve ajustment screw + nut
- !!!91 AC
- DZ 140
- YS 1.10S is Awesome
- sorry !! more help needed
- another after run oil question
- YS 140 SPORT RUNS TERRIBLE
- YS-110 idle problem
- Sticking plunger
- YS 110FZ engine repair
- 160-DZ hard to start of first run of the day
- 160 sounds/acts lean
- Tettra fuel tank question
- YS110FZ lost some power
- YS 120 general questions
- YS 1.40 sport RPM?
- Need muffler for YS140 Sport
- who makes this cool power 30% heli fuel
- YS160 Surging problem
- YS45
- Change fuels - re-tune engine?
- Coolpower Heli 20 same as Pro Pattern 20?
- Yet another fuel question
- YS^#FZ valve cover screw size
- YS 170 + Hatori 725?
- 91 ac valve aj.
- YS FZ 110-S & T.F Stinson
- 4k regulator tuning
- 3 blade and the 140 sport
- Dz 160
- YS IIOs
- YS 63S prop selection
- YS Mounts
- APC 19x8W on YS 170DZ
- PLastic Fuel Pump piece
- FZ63-S Parts help
- Powermaster YS 20/20 all synthetic
- 4/11/08 Out of Pocket
- ys foam clunk
- Dingo Help Please!
- Priming 110
- YS110S
- ys110s and 15x10 apc prop
- camshaft
- New FZ110S back pressure probs?
- First FZ110-S – WOW
- 140l upper end cuts out
- 63fz hesitation on throttle up
- 4 blade APC 15,5x12 on 160 DZ
- ys 110 long term storage
- YS63 FZ knocking as throttling up
- YS110fz prop selection
- YS 110 Needle Adjustments
- YS 160 fuel connection pro??
- ys dz 160 Crankshaft Ring broken
- FZ110 Carb fills up with fuel
- Check valves for YS 110
- YS170 DZ length
- ys 160 mount
- Leaking non return valve - 160DZ
- FZ110s vibrates bad
- YS 1.10 FS S new version...having problems
- At the end of a fliying day
- YS 110 FZ-S Running Problems
- Prop advice
- YS-160DZ won't cut-off
- YS 160DZ Prop Shaft
- YS DZ170 prop for break in
- YS 91 ac no compression -repost in the right place this time
- Pipes & Headers 4 YS's
- YS170DZ IMAC Prop
- 91AC or 91FZ
- Can you recognize this Motor mount?
- DZ160: hard 1st start of the day
- YS 120 NZ Supercharged dos and donts
- 2 Fuel tanks
- Dave brown Engine mount for YS110S
- YS 63S won't idle and drips fuel
- YS 61-R 2C
- YS-140 L Production Years
- YS FZ-110- FZ-110-S difference
- After run/storage oil for YS 120 NC
- ys 45
- Glow Plug Tap Size
- YS 45SF
- YS 63FZs I can't be the only one...
- YS 170 DZ Serial No
- Anti Vibration Mount
- YS engines
- YS 63s
- YS 140 FZ - stuck valve
- New FZ63S..problems
- YS performance website????????
- TDC
- YS 63s Drive washer
- 91 ac
- HS niddle setup for 160DZ
- On-line ordering for Cool Power 30% Heli fuel
- YS 110fz engine problem
- FZ120 Fuel Tank
- YS DZ170 leaning at top end.
- Rebuild????
- YS Foam Fuel Clunk
- ys 60 fs
- YS 110 quitting??
- 160 fuel spitting
- Filter
- YS 91 ST4 RPM "happy band"
- Power Master 30/23
- YS 140 Sport Throttle barrel stuck
- ys63 fz power dropping off
- 120 SF or 120 NC
- YS 170 vs. Saito 220
- Air Tool Oil. A No No???
- Cold weather starting
- Wildcat YS 20/20 fuel for YS's
- YS 160 DZ - Small Diameter Prop
- ys 91 versus 1.10
- Removing backplate 63fz
- Storage
- YS FZ110-S Regulator screw position
- YS FZ110-S out of production?
- YS .91 AC
- YS 63 S
- YS 63s priming problems
- ys 140
- replacing the YS160 with the YS170
- Running in 110s
- ys100fz vs ys120ac differences?
- YS FZ110S & tuned pipe
- Recommended RPM range's
- 3.5" spinner for 140s
- YS 50ST sticky regulator
- Can Hatori 675 pipe be used with 160/170DZ
- Inverted YS 1.10
- My first YS!
- Ys63FZ-s Loose valve guide/seat
- YS140FZ Propeller size
- ys63s air bubbles.
- 170dz
- YS .63 FZS Problem
- 91AC Question
- Back plate assembly versus separate parts
- YS 45FS
- 140fz
- Cool power for YS
- YS .53FZ - no fuel to carb???
- Header O.S. in YS FZ63S
- intake push rod cover is partially out of place
- YS 170 prop
- Carburetor of YS FZ110S
- Klotz oil for YS-engines
- Engine life
- ys 91 and ys 110 Question
- YS-110 and 15X8
- Merry Christmas Troy Newman
- YS 110 fuel feed problem.
- ys exhaust port question
- 110 FZ problem
- YS 1.40S throttle arm extension
- YS FZ 110s won't stop running
- YS What?
- ys 91 carb problems
- ys 110fz s with big problems
- Weight of YS 140L with muffler
- YS 120NC Front Bearing
- Parts
- YS HS setting
- Over tightened prop nut?
- YS60 advise.
- YS heli engines
- NEW TO 4 STROKE, NEED ADVICE
- 91AC timing ?
- YS 63S
- differance 91AC and 110FZ
- YS160 Front bearing oil seal replacement ?
- 140 FZ plumbing
- Recommended Fuel filters?
- Props
- Fuel and Pressure line length
- 160 DZ Fuel line pressure too high
- new 110s flooding is plumbing or trash
- 4 bladed prop for a YS120AC
- Older YS 1.10 fuel line hookups
- Where to buy a YS FZ110S?
- 91 AC muffler question
- Solivan 16 oz for YS-110
- YS 170 Characteristics
- YS 170 Fuel
- ys fz110 idle problems
- Valve Cover Paint
- .91ST dies on transiton
- YS63fz vibration
- FZ63S regulator set
- YS 110FZ problem question,,
- ys 50 ST?
- Header pipe for YS 91 AC
- Extention for YS 1.10?
- 110 won't run
- Good end of day routine?
- Bent YS 1.10 FZ crankshaft
- Spinner adaptor for YS-110
- Props on YS1.70
- What version of the 120
- Any 170dz news ?
- fz110s and fz110
