PDA
View Full Version : YS Engines Support
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18
  1. YS Engine Dimensions chart
  2. F-91AC question for Dave
  3. 63FZ Help.....
  4. YS-63FZ spare pats.Where?
  5. YS 120 SF vers YS 120 AC
  6. YS FZ63S regulator problem
  7. Running Settings 63FZ
  8. YS 63 FZ s setting
  9. YS 63 Valve clearance
  10. YS 110 8mm prop shaft thread Pitch??
  11. YS 63 Fuel?
  12. Dave Shadel
  13. What power to use, ME-109
  14. YS 160
  15. 63FZ-sport
  16. 140DZ good or bad
  17. Early 120SF crankshaft
  18. YS60FR running issues
  19. YS80 Factory carb settings
  20. YS 170
  21. YS 120 F Disk Valve Clearance
  22. New YS 63 Specs. ?
  23. ys 140fz plumbing
  24. 140 Sport questions.
  25. Regulator Ajustment
  26. YS 63-S Compression Down
  27. Crank case getting hot on ys .91fz
  28. YS-120 NC help
  29. YS 63 HELP
  30. Thanks!
  31. Presure regulater locationYS 63?
  32. YS 63 Leaking
  33. Exhaust timing YS60FS and YS91ST
  34. castor lube new engine
  35. ys 110
  36. YS 63 regulator
  37. YS 120 Muffler
  38. 140 sport
  39. new ys 110
  40. 140FZ VS 140DZ
  41. Original YS-120? YS-0070
  42. 120 FZ Screw in backplate hole fell out
  43. need BIG TIME HELP
  44. Bringing a low time 61-S back to life problems
  45. Brabd New Ys 100
  46. FZ110, 3 blade prop size?
  47. YS 63 FZs plug
  48. YS 110 problem - HELP!
  49. Rocker Arms Replacement?
  50. Happy new Year 2007
  51. need info on 45 fs
  52. 140DZ VS 140Sport
  53. 110 idle problem continued
  54. ys 110/extra 300
  55. What is the prop nut thread on the YS 45FS
  56. 140 FZ Cam Cover Removal
  57. Rough running YS-61S
  58. ys 110/extra 300
  59. New YS FZ110 Problem when inverted
  60. YS91-Prop Sizes
  61. New YS 110 coming out ?
  62. 160DZ Idle
  63. Once a year a message which is Not a problem...
  64. ys 45 fr info
  65. Muffler choice
  66. Rich setting
  67. YS FZ91 prop nut / jam nut torque?
  68. YS 1.40L Valve Clearance
  69. New YS110 Low compression...
  70. YS45 & YS120
  71. YS 110 problems. Help!!!!
  72. 140 Sport coming in for service
  73. Thumbs UP YS .63S on a warbird
  74. 110 finally running
  75. How do I tell the difference between 140fz and 140L
  76. ADDRESS FOR YS SERVICE
  77. YS 120AC Thrust Washer
  78. DZ Pump assembly
  79. DZ 140
  80. 120-NC part number
  81. YS 120SF Exhaust Valve sticks
  82. ys63 3-blade
  83. Santa came early!
  84. YS63FZ-S regulator
  85. YS 110 height
  86. Update on the muffler on the Mayhem...
  87. YS91 Manual & YS53 question
  88. YS-120F engine
  89. Tank Preasure
  90. YS-63S for Pilot Seduction Freestyle
  91. MOVED: ys 140 sport and yak
  92. Air leak in YS 91 AC
  93. YS-45SF header
  94. 140DZ Disassembly... HELP PLEASE!!!!
  95. YS .63 questions
  96. YS regulator
  97. YS 110 break in
  98. ys 53
  99. YS 1.10 in new Funtana X100, Amazing!!!
  100. my .63 only needs about 2 seconds of pressurizing....normal?
  101. YS-110 Loads up at Mid Throttle
  102. DZ160 question
  103. Need help with new 140 Sport!!
  104. Mayhem photos
  105. YS-63 Help
  106. YS 110 Oil content ?
  107. Why high nitro for YS Engines???
  108. YS F-1.20 Manual
  109. New YS-110 Lean after half a tank?
  110. YS160 muffler
  111. FZ-140 plumbing - extra fittings at back
  112. Custome Exhaust for YS 110
  113. How to unstick a sticking regulator, YS63?
  114. FZ110 Regulator
  115. ys 63 problme
  116. YS 60 problem
  117. Working on a YS engine myself....
  118. YS 140L SURGING AT IDLE!!!
  119. YS160 First start problem
  120. Using a starter
  121. YS 63 FZ S plug
  122. ys63fz
  123. Warranty question
  124. YS .61 parts?
  125. YS 160 wont peak
  126. Scale Muffler YS63FZ
  127. YS 160 PROBLEM
  128. RPM Limit
  129. 63FZ with 13x6
  130. YS 140 Sport Tuning Questions
  131. 140 sport
  132. Idles great but bubbles flowing .. YS 110
  133. transition question on the 110
  134. DZ 160
  135. YS 110 idle problem
  136. breaking in problem - fz63
  137. YS110 fuel lne has bubbles in line past 1/2 throttle
  138. Exhaust valve carbon
  139. instruction mannual for the YS 110 FZ
  140. ys 91 fa
  141. different fuel for YS91
  142. New YS FZ 110 S
  143. YS1.60 back fired now won't start
  144. new prop for YS 1.10
  145. YS Motor service Dave ??
  146. Wich YS engine for a 11-13 lbs plane?
  147. YS 61 on the pipe...prop?
  148. YS 140L
  149. What motor mount for YS140 Sport?
  150. YS 110 lack of respond
  151. YS 140 s problems
  152. Future of Yamada Engines
  153. What YS do I need?
  154. YS 120SC problem
  155. Run out of adjustment on 63 FZ-S
  156. Can't get YS 110 to idle well
  157. ys 63fz
  158. engine manual
  159. YS 110 fuel coming out of carb
  160. Cool Power 30% vs. 30% LS
  161. regulator vs idling adjusting for YS61
  162. Old 1.10 Problem
  163. 140DZ Idle Problem
  164. service time
  165. YS.45 Rear Exaust Tuned Pipe
  166. Explain---have some noise( knock) YS-63FZ
  167. YS 120 SC?
  168. YS 140L in a Balsa USA Nieuport 28?
  169. YS 63 and a 14 X 4 APC
  170. YS-63s Applications
  171. YS110FZ, crackling noise??
  172. YS 110 updated?
  173. YS .63s 20% to 30%
  174. foaming fuel on 110
  175. YS 110 RPM
  176. Regulator screw on YS .63s
  177. YS Decals
  178. Tappet clearance adjustment for YS-140s
  179. YS120 sc vs ys 140 sport/140l
  180. YS110 questions
  181. thread size for the prop nut YS61AR
  182. YS 110 new regulator
  183. Where is the best place to send a YS 140 to get rebuilt
  184. new 1.10 is sweet
  185. remote fueling setup for FZ110
  186. Ultra Thrust for .45FS?
  187. YS FZ63 trouble
  188. YS 160 fueling
  189. YS 91 problem
  190. YS 45FS
  191. YS 63 -S
  192. I'm breaking in my new 110
  193. castor and 4 strokes
  194. Misc YS questions
  195. YS53 Parts
  196. YS 140 sport is cutting out.
  197. Thrust #'s
  198. YS 91 AC
  199. YS 140 Sport starting advice
  200. Newer YS 110 regulator question
  201. 140DZ Muffler Recommendation
  202. YS140 S Break-in
  203. Best 120 YS
  204. YS 63 prop for break in
  205. RPMS/Prop for YS 160DZ
  206. 1.40DZ - What Bolly prop for IMAC and 3d?
  207. YS 53 FZ feedback needed
  208. YS-140 Sport Engine Transition Problem
  209. YS91ST
  210. DZ 140 check valve??
  211. ys fuel
  212. 63-S fresh out of the box
  213. My 110FZ history & question
  214. Test
  215. Diaphram for ys 61ar
  216. YS 63 FZS consumption
  217. prop for 3D with a 1.10
  218. YS Engine oz/min?
  219. 61ST2 won't start
  220. .91AC & .91FZ Needle valve compatibility
  221. YS 110 drive washer "stripped"
  222. YS110
  223. apparel and decals
  224. 110FZ Regulator Retrofit?
  225. 110FZ
  226. When to replace piston?
  227. 140DZ Idle Trouble
  228. Carb fuel leaking- 110
  229. YS 63 FZS prop
  230. YS110 conrod direction
  231. YS140 idle problem
  232. YS 110 runs lean on idle
  233. Prop Size??????
  234. Can my YS110 be serviced in the UK
  235. 91 AC versis FZ
  236. Why did YS stop making 2 strokes for airplanes?
  237. Y.S. Valve Adjustment
  238. Ys engines and nitro %
  239. Gotta Love that little powerhouse
  240. 63s regulator
  241. FZ110: new or old regulator?
  242. 1.40 Prop size
  243. spanner size
  244. CF Prop
  245. routine flame out of YS110
  246. used 91 AC
  247. 140DZ and a Tettra Tank
  248. YS 110 FZ Reliable???
  249. Valve clearance and tools for 140 FZ-Sport
  250. Install connecting rod ?
