PDA
View Full Version : YS Engines Support
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. cleaned regulator, now not pumping fuel?
  2. How do you split the external regulator halves
  3. YS 1.20SF Crankshaft Replacement
  4. YS 63S - Owners - Final Needle Settings???
  5. New YS
  6. YS110S without crankcase pressure to regulator
  7. YS 91FZ throttle question
  8. replacement for YS-120AC
  9. Is YS Service OK?
  10. YS DZ 170 CDI Operator's manual
  11. Bubbles in carb line
  12. Coolpower Heli 30% L.S. for YS
  13. Which YS120 do I have?
  14. YS-63S question
  15. Stalls at Mid Range
  16. YS 1.10FZ Tank Size?
  17. f-120 pukes fuel
  18. YS 63 - best prop for 40 size warbird racing?
  19. YS170 high speed needle valve setting
  20. ys170 dz cdi
  21. 110s Tappet adjustment
  22. ys 120
  23. regulator cleaning
  24. Help on a YS F-91 four stroke
  25. YS needle valve
  26. YS DZ170M - Inbuilt Engine Mount Question
  27. YS 110fz idle problems
  28. Negative Pressure in Tank???
  29. Tuning...After initial break-in
  30. Throttle Servo Suggestion YS 63
  31. YS FZ110-S muffler dilemna.need suggestions
  32. 140 DZ quiting
  33. YS 63S break in instructions
  34. YS 110 FZ - Any tips on proper break- in???
  35. YS 1.40 DZ sudden rpm drop
  36. Broken valve springs
  37. YS 170 stops when glow removed
  38. YS 1.10 revival?
  39. YS Engines...What type of fuel?
  40. YS-110 won't hold idle when it's relatively cold
  41. ys 110 s
  42. Thread size?
  43. Engine Statistics
  44. 110fz run time?
  45. Old YS 60 two stroke
  46. YS160 DZ crankshaft end float
  47. YS FZ1.10-S HS adj leaner?
  48. YS .63 S Idle
  49. YS 120 problems
  50. Fuel system set up for a cowled plane
  51. YS 91 fz question
  52. YS 63 S sudden power loss
  53. ys 110 AT WITS END
  54. after run oil OK?
  55. YS Parts and Service Review
  56. tuning YS 120AC
  57. YS .91 Stuck Pushrod & now won't start.
  58. YS 140 sport
  59. Tettra tanks and tubing?
  60. YS 63 FZ Fuel Flow Problems
  61. YS F-120 parts compatibility
  62. YS Piston Gas Port Modification
  63. wildcat 15% 4 stroke fuel for 110?
  64. new or not
  65. YS 91 will not idle inverted
  66. YS 140 sport not wanting to idle
  67. Ys63 s help please!!!
  68. 140L cutting out
  69. Ys 63 s help
  70. Mejzlik prop on YS160?
  71. Bad Plugs....
  72. YS 61-S muffler or tuned pipe header
  73. YS 1.40 Sport air in fuel line from regulator to carb, will not idle!
  74. YS 1.40 Sport air in fuel line from regulator to carb, will not idle!
  75. ys 60 two stroke
  76. YS63S crankshaft thread size
  77. MOVED: Fuel leaks
  78. YS FZ110S regulator problem
  79. Stripped exhaust threads
  80. 110 tank size
  81. YS63 FZ plunger
  82. Bearings stuck
  83. Removing crankshaft and bearings
  84. YS 63s regulator pink buildup
  85. ys regulator
  86. YS 140 Prop shaft diameter??
  87. 3blade for 110
  88. YS F-120 info wanted
  89. YS63- Factory Default LSN
  90. Is power master 15% ok?
  91. YS 120 AC Help
  92. YS FS-91AC mounted inverted in WM Mustang 60 problem
  93. YS FZ110: Top end peaks and then quickly sags
  94. New 1.10 - Runs Backwards - Crash
  95. YS-91SR Engine Problem
  96. YS 160 Surging at idle
  97. YS 91 in Heli problem
  98. 3 Blade Prop??
  99. YS 1.20 w/Hatori Cooling Header
  100. Tank location for ys Fz 110 (height above carb)
  101. YS 63
  102. Flex Exhaust for YS140
  103. YS engine with a MK Floating beam mount.
  104. FX 91 won't pop
  105. YS 91 long stroke red head
  106. YS 63 question
  107. 63 FZ top end rpm
  108. YS 170DZ Won't Transition
  109. The start process of 160 DZ
  110. YS .63
  111. help needed with YS 91
  112. YS 91 manual needed
  113. diffrenceses in 160 and 170 parts
  114. Ys 140 sport oil %
  115. Richard Verano address
  116. YS .45 SE parts
  117. Fuel for a YS 170DZ
  118. YS 120 Questions
  119. HS Needle setting on YS-110S - just 1/8 turn out??
  120. 140 sport problems
  121. Tuning the DZ's
  122. Anyone uses Byron YS 20/20 fuel on their 110?
  123. YS-63 Engine Rebuild
  124. low speed needle valve vibration
  125. Suitable compatable after run oil for 140dz
  126. YS service question
  127. YS engine suggestion please
  128. YS160DZ Random Stopping
  129. Proper fuel for YS engines
  130. Questions for Xmans
  131. YS FZ 110 life span of metal parts and bearings
  132. 140 FZ 2 CRANKSHAFT
  133. FZ .91 Questions
  134. Seamless Tank in Hangar 9 Corsair
  135. ys 110 fz rough mid range
  136. YS-63 in Yak Cowl Cooling?
  137. Problems with new YS 170
  138. Headlock for glow plug
  139. YS63FZ fuel system problem
  140. ys 63 pitts muffler?
  141. YS 120 SF regulator problem
  142. LN needle setting: YSFZ110 vs YSFZ110S
  143. Starter Motor for YS170
  144. YS Engine support
  145. YS160/170 CDI conversions
  146. 3 blade and 140 sport
  147. How do you open up the regulator from YS FZ110S?
  148. ys engine surging at full throttle
  149. YS-110fz: problem with air in the fuel tube
  150. YS 63FZ
  151. 1.40FZ trouble
  152. FZ110 idle
  153. exhaust pipe mounting nut
  154. ys 63s low speed needle adjustment
  155. fuel tank clunk for dz160
  156. YS FZ110s running in.... not very smoothly
  157. new ys 45 wont run wide open
  158. Power difference 1.60-1.70
  159. MV or HV 30% cool power ok for YS110?
  160. Sealant, loctite, locking washer for YS noob
  161. Need help with YS-45
  162. Complete noob on running in YS FZ110S
  163. YS - run till it will be dry
  164. YS110 fz-s idle issues
  165. YS 1.20AC regulator housing
  166. YS 1.10 and Sullivan Slant Flextank
  167. winter storage
  168. Grey tint in exhaust oil.
  169. YS FZ53
  170. YS110S and Cool Power 30% heli LS
  171. how do I set up a ys 45 with tune pipe?
  172. YS F91AC
  173. It won't die.....
  174. YS-110 middle range
  175. YS 160DZ prop for Sebart sokhoi 140
  176. YS FZ110s Fine Tuning
  177. Need Help with My Old YS 120 SF
  178. fuel dripping out carb
  179. YS 160DZ, o-rings popping pushrod cover
  180. I've got the 140 blues
  181. check valve airbox 120 AC
  182. YS61 Long Stroke - Parts?
  183. Best wide prop for ys63S
  184. muffler to dz160
  185. ve,
  186. ys 170 DZ Glow Drivers
  187. ys 53 help
  188. Nose Rings
  189. assembling YS120FZ camgear
  190. YS 140FZ Needs assistance
  191. Problem caused by cowl ?
  192. 140DZ Rebuild questions
  193. anything need pay attention of clean regulator(ys120fz)
  194. YS 110 prop selection
  195. reg. on new 100S
  196. YS 63S problems
  197. break-in to dz160 engine
  198. YS 140L manual
  199. YS 120 AC
  200. Onboard Glow??
  201. YS FZ110S Violent acceleration and sudden stop
  202. YS FZ 110 S
  203. Looking for confirmation
  204. .63 FZ
  205. Tank is 10in away and higher by 2in for YS110...OK?
  206. Crashed 110, trying to get it going again
  207. YS 170 DZ Strange Incident
  208. 120FZ buble problem.
  209. How many case of loose bushing on FZ110s? Is it resolved?
  210. YS FZ110 vs FZ110S
  211. YS 63S rear bearing let go
  212. YS FZ110 running in
  213. YSE5790 Regulator Operation
  214. 170 DZ Engine Mount
  215. YS 140L inverted
  216. Ys 110 FZ S
  217. YS61 LS
  218. low speed needle closed = cw or ccw???
  219. High Altitude Tuning
  220. 140 FZ
  221. 140DZ teardown, any ideas?
  222. YS 110 problems
  223. YS DZ Questions
  224. Help ! Ys170Dz won't strat
  225. YS 140dz timing marks
  226. YS 63 fz pressure problem.
  227. 140 DZ tuning issues
  228. YS63
  229. Airframe for the YS63S powerplant
  230. 3 1/2 to 4 turns on HS??????
  231. YS-63 FZ Loss of Power on Uplines
  232. Where is current YS Support?
  233. 140 L quits at Full Throttle
  234. YS 140L low compression ?
  235. Tetra One-Way Valve
  236. YS 63FZ air leak?
  237. Best exhaust setup for YS110S?
  238. YS-110 - brand new - first run on FAI Fuel : report
  239. 91 FZ won't idle
  240. ys 160 servicing
  241. YS 91 St
  242. YS 140 FZ Sport Valve Issue
  243. YS160DZ idel problem
  244. 140 DZ pump pproblems
  245. Teflon tape around front of YS with mount
  246. 170 DZ quitting in two loops manoeuvre PO9
  247. Ys63s midrange prob
  248. YS FZ 110 Tuning Help
  249. prop size for ys .91 fz
  250. YS 1.10FZ Idle Issues
