PDA
View Full Version : YS Engines Support
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18
  1. Ys 110
  2. Fuel tank position
  3. F120 will not lean
  4. YS 50 question
  5. YS Service
  6. YS 91AC plumbing?
  7. Old YS 120 - where to drill the hole
  8. 170 dz
  9. YS 91 & 110
  10. 160 DZ
  11. How to change throttle arm position ?
  12. YS FZ 110S Propeller
  13. YS 110 S fuel system
  14. YS Performance file
  15. camshaft timing on ys 140L
  16. camshaft timing on ys 140L
  17. 30% heli fuel
  18. using an FZ63s regulator for the FZ110
  19. valve ys160DZ
  20. YS-140 FZ idle issues
  21. YS 160 starter and mount
  22. YS Check Valve Bouncing On Head
  23. YS 63 FZS breaking in
  24. First throttle up (tank pressurizing) leaning on YS63
  25. ys 110 pinch test
  26. ys 110
  27. Gone until June 11
  28. another 110 with problems
  29. YS 140DZ, gets no fuel
  30. YS engine mount
  31. Dingos - Routine Maintenance
  32. Differences between 140-sport and 140 DZ
  33. YS 63 S
  34. 110 Loading up
  35. spare parts
  36. swapping mufflers on 140 and 110 OK?
  37. YS 120 NC
  38. .63 Question
  39. engine ys 63
  40. YS engines exhaust less oil?
  41. YS .63 high idle issue
  42. YS 60 for pylon racing
  43. YS160DZ Rocker Valve gap
  44. 140DZ fuel consumption
  45. YS160DZ: Chaning the crank shaft.
  46. Nitro Up - Fuel - Where?
  47. YS 63 and OS .55
  48. Y.S. 170 power comparison question
  49. 110 FZ wont hold rpm
  50. gas ported a 53
  51. check valve
  52. RPM's on the 110FZ
  53. ys 110 muffler
  54. YS-120 Plumbing
  55. fuel for 1.10fz
  56. More 110 Problems
  57. routine maintenance question
  58. Attending an Event, will return 5/21
  59. Presumably Damaged YS 63 S
  60. Ys 140 difference between the fz and dz
  61. 110 Diaphragm and Exhaust help
  62. Magnum #2 in 160DZ
  63. YS .63S prop for high speed
  64. F120
  65. YS60FS
  66. operating recomendations
  67. header nut
  68. Happy with YS service
  69. 110FZ Messy
  70. How to tell if you need new bearings
  71. YS-110 Storage
  72. YS 110 will not idle inverted!
  73. Fuel Question about a YS 61 ST2
  74. Muffler Pipe Thread Size
  75. Wild Cat Fuel for YS Engines
  76. Needle Settings for YS .63FZ-s
  77. 110 Mid-Range
  78. YS 140L
  79. YS 1.60 3B prop
  80. YS 160DZ SETUP
  81. 110S
  82. YS 149 FZ
  83. YS Mount
  84. ys 110
  85. YS 140 FZ - Valve Adjustment
  86. New 160 DZ - Excessive oil
  87. YS 160DZ nitro
  88. YS 160DZuel
  89. YS 120F
  90. YS 160DZ Prop F3A and 3D use
  91. My first YS 160 DZ
  92. YS 63 problem
  93. 120 SC
  94. YS63FZ fuel Labema
  95. End of flight procedure
  96. YS 120
  97. ys 140 not running right
  98. Wildcat Youngblood Performance 30 for the YS
  99. YS Engine Physical Sizes
  100. YS110 will not throttle up
  101. Newbie Break In Confusion
  102. Valve adjustment...uh oh...
  103. Fuel changes
  104. ys 1.60
  105. YS .61LS Exhaust...
  106. Gone to a contest return on 4-15-07
  107. FZ 110 fuels
  108. New YS FZ110S
  109. ys61 header
  110. New YS 110 Full Throttle Trouble
  111. diference 140fz and 140 sport
  112. YS 110 dripping
  113. YS 110 that vibrates much
  114. YS 45 FS
  115. Bad flat spot at ~1/4 throttle on 1.10
  116. Help Please. YS60 disassembly question
  117. .63FZ Was Low On Compression
  118. DZ 160 Exhaust "Pop"
  119. 140DZ for a 73 Somenzini Yak
  120. YS 110 FZ Vent and Fuel Hook-up
  121. YS 110FZ Questions?
  122. YS 140 Sport prop dilema
  123. YS 63FZ Problem
  124. YS 140S Prop
  125. Check valve in vent system
  126. Broken 1.10!
  127. .45 regulator parts?
  128. 110 problem
  129. YS 63 FZS prop
  130. ys 45 help please
  131. Some questions about 110FZ
  132. What YS do I have?
  133. ys 110
  134. YS-140FZ Plumbing Diagram?
  135. YS .63 S
  136. YS160 Cuts
  137. Need some simple help with YS 140 Sport.
  138. YS 45 tune up
  139. Trouble running after sitting up
  140. Problems with new 160DZ...
  141. YS Engine mount
  142. YS 63 - Carburation advice requested
  143. Need YS Advice!
  144. question about fuel?
  145. master airscrew 16x8 3-bladed prop too much for 120 sf ?
  146. 110FZ - Does this sound right?
  147. Torquing screws do or don't
  148. FZ 91/110 Bearing Removal / Installation
  149. Dz140
  150. 120 ac diaphram question
  151. Information.......
  152. Gone for a Couple Days
  153. 110 tuning question
  154. FZ91 Crankshaft Replacement
  155. Questions on YS 110
  156. YS 110 Fuel and Such
  157. 160 DZ head trouble
  158. YS63s - cam timing
  159. YS FZ110 Break in problem
  160. YS 120 identification
  161. YS1.60 that refuses to start.
  162. truturn product
  163. Idle & Fuel level
  164. YS 63 Barely runs?
  165. Alternate fuel for YS 1.10
  166. YS engines and Mobil 1 as after run oil
  167. YS160DZ thread
  168. 160 DZ pump presure
  169. YS 140 FZ Starting problem
  170. YS 140 FZ Starting Problem
  171. stripped threads on exhaust port
  172. CrankCase Pressure on a YS 110
  173. DZ 160 READINGS AND MODIFICATIONS
  174. YS110 sluggish transisition
  175. YS Decals
  176. 63S valve adjustment how-to
  177. ys 45 se
  178. YS91 needs a new sleeve
  179. YS FZ110 Backfiring Question
  180. Need help with fuel dripping and lean outs caused by air in carb line
  181. Where to order parts from??
  182. YS troublesome?
  183. H
  184. 3 Blade for the 110?
  185. Still having issues with my YS 63FZ-S
  186. Unavailable until next week
  187. YS110 FZ - Will Not Idle
  188. YS 45fs Muffler
  189. Need YS-120 F NC settup help
  190. YS-120,Seems to be surging
  191. no compression new 140fz
  192. 160DZ Regulator Question
  193. the instructions ys
  194. suitable 3 blade prop for a 140-sport
  195. Ultrathrust??
  196. YS logo's
  197. YS 63 FZS issues.... help needed
  198. Where to buy a YS61 ST2 heli engine
  199. YS 110 break in question
  200. With 30% of nitro...whichever % of oil???
  201. '56' F1258 Throttle Stop Screw "ys63fz"
  202. YS 110 = power
  203. Bearings of the YS
  204. YS 45 and glow plugs
  205. 140 Sport
  206. 63S Startup pressure issue
  207. 160 injecter
  208. My 110 died, no warranty from my LHS:-(
  209. Prop for YS63s/Reactor of GreatPlanes
  210. Exhaust Deflector for YS 110??
  211. YS 140 DZ Tuning
  212. Getting Confused here
  213. Model Number progression of ys 1.20's
  214. YS 140 DZ problem
  215. marine 4-strokes?
  216. Thanks, Troy
  217. YS 63 fuel leakage!
  218. Prop for YS 110/Funtana 90
  219. Straight Pipe for FZ110
  220. After Run Oil
  221. glow plug YS 110
  222. Sticky Horse Power
  223. Sig Heli 30% Good or Bad?
  224. New Forum Answer guy
  225. 16-7 APC for 110
  226. fuel for YS 110
  227. ys 110/extra 300
  228. Dave Shadel no longer answering ? on this forum.
  229. YS 120 Problem
  230. Info on break in...
  231. Rebuild
  232. 110 Exhaust
  233. YS Decals
  234. YS Header Pipe and Muffler
  235. YS Parts and Service Web Site
  236. Parts for YS .61's?
  237. prop size
  238. hyde mount
  239. Regulator and valve adjustment
  240. YS-63 for twin?
  241. 140 Crankshaft question
  242. Dave, can you identify this engine? And do you have a manual for it?
  243. YS61ST2 and prop?
  244. Thanks
  245. Motor Mount Question
  246. YS 63-S and 160DZ
  247. 53 fz
  248. question for Dave Shadel,
  249. what to check after storage?
  250. YS-140 Sport Prop Selection????
