PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19
  1. Mike, Eclipse question please.
  2. 5735 Failure
  3. Bizzar interference???????
  4. crystal swapping
  5. Quick question Mike...
  6. Eclipse 7 upgrade
  7. Mike
  8. HS-5625 problems... should I use them ?
  9. Compatibility with Old Airtronics
  10. reciever antenna lengh
  11. Supreme 8CH RX & Gas Ignition?
  12. Hitec Futaba Crystal Compatability
  13. Which servo is the best bang for the buck for 1/4 scale
  14. Hitec DIGITAL HS5945MG/ .50 nitro helicopter application?
  15. Flash 5 ail. D/R trim problem
  16. Can I run 605BB's at 6 volts?
  17. rcd3800 receiver[ MIKE]
  18. trying to use Neon as trainier for Fut6EXA
  19. Problem programming servo.
  20. hitec eclipse 7 w/ spectra
  21. Buddy Box w/ 2 Eclipses
  22. Mike, you might want to let them know
  23. 5645s Stop responding
  24. Severe glitching problem with new Lynx 3D?
  25. eclipse 7 battery
  26. Supreme 8ch D/C reciever problem
  27. Eclipse 7 Glitching with Trainer switch
  28. Prisam 7 help please !!!
  29. servo arms for "+" style ?
  30. hitec 5945mg servo
  31. Programmer driving me nuts
  32. 5625 strange behaviour
  33. Servo's for the Seamaster II?
  34. metal gears
  35. HS-55 not centering
  36. proper battery care - help
  37. Laser 6
  38. 5475 Servos
  39. Eclipse7 QPCM Problems
  40. eclipse 7
  41. Red servo arms!!
  42. Misuse of HS225BB?
  43. flash 5x v-tail
  44. Software
  45. Hitec HS-475HB ? New servos
  46. Royal Evo Question
  47. HiTec stickers
  48. Hitec Eclipse 7 help
  49. Got my new Eclipse in
  50. Servos going nuts with Electron 6 Receiver
  51. Hitec HS-5245 high pitched whine....
  52. Thread Size
  53. Eclipse 7 TX battery
  54. 605 servos ?
  55. Hitec 5925 Hi Speed Digital Dead? :(
  56. Focus 4 5th channel?
  57. Hitec RCD3800 Receiver problem
  58. Synthesized Tx & Rx !
  59. Servo delay in movement condition UPDATED REUPDATED
  60. Hitec Eclipse 7 Firmware
  61. HS-5945?!?!?! Need Help
  62. interference w/ lynx FM on gas boat
  63. Eclipse 7 Manual
  64. laser 4 throttle not working
  65. Tx charging plus
  66. Eclipse 7 with feather reciever
  67. Buddy box for Eclipse7
  68. Prism 7X battery holder polarity
  69. royal evo switches
  70. Newbie Help / Supreme rx for JR tx
  71. HS-5625mg ?
  72. 5 channel Rx; 2 independent ailerons
  73. Eclipse 7 and dual elevator servos
  74. Hs60 used as a throttle servo?
  75. hs 81 problems
  76. HS-5975HB Digital Servo Arms
  77. Programming digital servoes
  78. Current turnaround time
  79. 525 failure
  80. Programming 8411 with Hitec programer
  81. HS5945MG Digital servos
  82. How much juice for Digitals Mike?
  83. New Hitec Eclipes W/ Spectrum
  84. Hitec Receiver - Dual or Single Conversion?
  85. Prism 7X Program
  86. Mike, Got a PROBLEM.
  87. servo arms
  88. Question about the 5475 servo...
  89. Eclipse Hitec 7
  90. Multiplex & PCM?
  91. Problem switching frequencies, Eclipse 7
  92. Eclipse antennae
  93. HFS 04MI compatability
  94. High rf or bad rx
  95. Flash 5 programming question
  96. 225MG question
  97. Trouble w/RCD3200 RX
  98. HFP-10 operation manuel
  99. ace/hitec nautical commander problem
  100. HS-5975 servos out of the box
  101. Hitec Focus ss AM to FM?
  102. Upgrade Eclipse 7 TX battery
  103. Servo Current draw ratings
  104. Which radio system is best for the long haul?
  105. Eclipse 7 & JR Channel xpander
  106. Mini Servo For Throttle
  107. Happy 4th!
  108. Prism + PCM-receiver
  109. Hitec 555 Receiver Models?
  110. Problem with Lynx 3D TX
  111. 5735 and surface frequency transmitters
  112. Servo Programmer
  113. Alum. Servo Arms For 5645 Digitals
  114. --> 3 servo wing <--
  115. Eclipse 7 and redundant flight system ??
  116. Micro 555 / Electron 6 on glow engine planes
  117. Hitec 5925 gear train
  118. Digital servo help, 5625mg/5945mg
  119. Hitec Eclipse 7 (Spectra) and FMA Micro 2000 RX
  120. Re-program digitals?
  121. What version of Eclipse do I get
  122. Eclipse 7 Flap EPA ??
  123. Hi tec lazer 4
  124. Eclipse 7 90 degree ccpm
  125. Hitec Service
  126. is this batt big enough???
  127. Neon / Battery question
  128. Hitec 605 servo arm slip
  129. Focus 4 question
  130. no trainer socket can i add one???
  131. old & new 5945 servoarm size, any difference??
  132. Fixed freq module
  133. Hitec 475HB broke!
  134. wet receiver
  135. Range problems with digital servos
  136. How to run duel rudder servo
  137. HiTec receiver battery issues
  138. challenger 455
  139. Eclipse 7 current draw
  140. Mike: Need servo repaired
  141. lost manual
  142. Use of Allen Cap Head Bolts vs Phillips Head for Servo Arm
  143. Hitec 425's turn so easily
  144. Karbonite gears in older digitals?
  145. Loose 605Bb Servos
  146. New 5975 digitals
  147. HPD-07RH and Sanwa (Airtronics) RD6000-Super ?
  148. Programer-Don't want Mike's answer
  149. Jitter servos
  150. eclipse 7 endpoints on flaperons/e>f mix?
  151. Eclipse 7 for Helis
  152. Eclipse 7 Mode II to Mode I
  153. can cg340 charge < 4?
  154. Servo Arms with a Hole at 20 mm?
  155. HiTec HFS-07RI
  156. Hitec Compatibility
  157. Conflicts in Eclipse 7 manual
  158. Mike: Hitec focus 55 fm
  159. Royal EVO transmitter in USA
  160. Hs-5645mg
  161. GWS receiver Shift
  162. Setting up a bi-plane
  163. Royal EVO 12 on 6 meters?
  164. Hitec Equipment, Thanks
  165. Laser 4 DIN pinout
  166. Flash5 Throttle Programming
  167. Adding a dual rate switch to a Flash 4 ?
  168. Mike ? - Challenger 720 Rx
  169. Buddy Box Failure with Prism 7 PCM
  170. eclipse manual
  171. use programmer or matchboxes?
  172. Servo Compatability Question
  173. Eclipse 7 HELI mode swash numbers
  174. Flash 5 glider radio battery charging?
  175. 545BB Saga
  176. Swapping Nylon for MG ?
  177. Are servo arm screws for 605mg's available seperately?
  178. Bad HS-77 Servos?
  179. Mike : 5925 jitters
  180. Hitec Prism will not turn on
  181. Receiver compatability
  182. Mike, When you get back from vacation..
  183. Challenger 720?
  184. bad rx
  185. Hitec receiver frequency
  186. Hitec servo on JR receiver
  187. Best Hitec servo for Heli
  188. Is resolution all I will lose?
  189. Eclipse 7 w/ spectrum module
  190. HiTec Master 7 Transmitter Voltmeter
  191. Loctite in 5945MG's
  192. servo compatability
  193. HS300 internal connection
  194. miracle y w/ 5645's
  195. Mike my Hitec Rx got a little wet
  196. Flash 5X Aileron-Rudder mixing problem
  197. Eclipse 7 problem
  198. Nickel Metal Hydride Batteries
  199. Mike ? - servo connection to flaps
  200. Do the same rules apply to digital servos?
  201. Multiplex RoyalEVO9 PC link cable
  202. Eclipse Acro/Crow SW update?
  203. Hitec Flash 5 programming question
  204. Hitec Eclipse Question
  205. Help...I fried my HFP-10 Digital Programmer?
  206. Laser 6 mode 2 to mode 1.
  207. Hitec receiver and futaba servos on 6v?
  208. 605BB on a Raptor 50
  209. Platinum receivers
  210. Only Rudder channel has glitch!
  211. Just a case and antenna ?????s
  212. HS 545BB Jitters
  213. Is hitec 5925MG a super servo?
  214. grommets
  215. CG 315 charger
  216. make an rc-cable
  217. Hitec Receiver/JR 10X transmitter
  218. Hitec laser 4. Single or dual conversion?
  219. Multiplex service
  220. hitec training cord
  221. Hey Mike,How do I soften the throtle response on a eclipse 7 for airplane hovering
  222. -
  223. Eclipse 7 pcm in Uk
  224. Micro 535
  225. Eclipse 7 charger
  226. AM, FM RADIOS - What Gives?
  227. Speed Control Unit SP-1801N
  228. Flash 5X
  229. HITEC 555 receiver compatible with Futaba?
  230. Hey Mike! Date Code and 5945
  231. Eclipse 7 and G2
  232. Service work
  233. A Synthesized Receiver??
  234. Challenger 620/720?
  235. Prism 7X Doesn't like Airtronics
  236. Eclipse 7 gyro questions
  237. 5625 - Safe to use with Futabat?
  238. hitec 605s
  239. Prizm Low Voltage Warning Goes Off to Soon
  240. 225 metal gears
  241. 225BB Questions
  242. Hs 425BB vs HS 75bb
  243. Can I use the GWS R4P Pico Type Receiver(single conversion )w my eclipse 7 transmiter
  244. Programming Question
  245. Hitec Flash 5
  246. Eclipse Flap Programming
  247. Eclipse Q-PCM Update Info
  248. Hitec High dollar problem round #2
  249. Mike - Flexible Antenna for Hitec Eclipse?
  250. Great Customer Service!!!
