- 5900 series and Futaba pcm
- Module Jitters
- 5955 extension wires??
- 5945 Version and difference
- did i fry my transmitter?
- Waterproofing a servo
- Programming Servo End Points - Best Resolution
- problem with eclieps 7
- Hitec Receiver compatibility with Futaba Transmiter
- Optic Question!!!
- robonova at the puyallup show?
- Stripped control horn screws 645MG 625MG
- servo retaining screws -- 205 MG
- Hitec 625MG question...
- Michael servos on the way
- spectrum program problem
- replacement servo screws
- Programmable Failsafe
- 5955 setup
- HITEC 635 SERVOS
- 5925 gears
- Multiplex Motor Service
- HS-5625, HS-5645 with problems???
- 5955 Battery Needs?
- Flight Pack
- Digital Servo Locked up?
- Hitec servos
- Hitec 56 servos
- V 4.06?
- MG ARM SCREW SIZE ??
- Electron and Glow ok?
- returning servos for checkup
- HS225BB
- 5955 and HFP-10 Programmer
- Range Check for limited range receivers
- Hi Tec HD Switch Harness
- Hitec Digital Servo / Best Speed and DB
- Flap variable switch
- ECLIPSE 7 - Composite ARF Eurosport
- does anyone at HITEC read the mail !?
- Battery for Multiplex Receiver
- RCD3500 Reciever
- programmer update
- HS-5245 digital in nylon?
- Can't use DSC with shift select rec. & JR 8103 trans.
- Right side? Is this from the front or back?
- HS635
- HFD-08RD receiver
- Hitec Supreme Receiver
- programming
- servo failure
- Hitec optic 6 Programming problems
- Hitec Optic 6 Programming problems.
- complete digital servo information source?
- 645 with the jitters
- Optic 6 Battery Plug
- 5945's from 2002
- Karbonite Gear Failure
- diference between old and new Hitec 5945?
- Gear sets HS-85BB Vs HS-85 MG
- Problem with my Hitec Transmitter?
- OPTIC 6 PROGRAMMING
- Need for a programmer
- electron 6 rx problems
- optic 6 v-tail mixing
- 5125mg
- multiplex pico receiver copatibility prob!!
- Need back half of Eclipse Case
- Radio manuals
- Hitec service Turn around
- HS-635s - not very happy...
- Digital Servos (HS-5645)
- Connect Jr to an Hitec through trainer cord.
- Hitec retract servo
- hs 5645mg servo not centering?
- Eclipse 7 7Channel TX/Spectra
- making eclipse 7 in 35MHz
- Please help with my setup?
- multiplex receiver troubles
- Hitec servo spline
- fundamental trainer cord question
- Optic 6 timers
- Titanium gears
- Checking/indentifing crystals
- Manual for HiTec Laser 4 FM
- New Optic Tutorial
- how to change optic 6 from mode 1 to mode 2
- Programmer problem???
- HFP-10 Programmer Question
- Programing Endpoints
- 5945 servo question
- Neon Tx Charging Diode
- Hi-Tec service
- Hitec Servos
- 5945's V1.03 and O5.8
- Lynx 3D AUX 3 travel limits.
- optic 6 channel 1 problem
- Hitec 3 Channel 27MHz Receiver HAS-3MB AM
- Hitec Service
- airtronics receiver 92765 repair
- Karbonite servo info and Loctite thread lockers
- 5955 Questions???
- From checking the forum Hitec Tx's and Futaba Tx's are both negative shift.
- servo set up
- Eclipse 7 redundent system
- Eclipse 7-Channel has QPCM
- Eclipse 7 "twitch"
- Eclipse 7-Channel and Ailevator Functionality
- Lynx 3D module
- Crystal Backordered
- hs605's
- servo screws?
- Tx battery
- HS-55 Twitching...
- Micro 05S problem
- Gritty sound in HS-5645
- Hitec HFP-10 Servo Tester
- 5245 Digital Servo reboot
- If you take a hitec eclipse 7 for service, in how long it will take custumer service to returned?
- hitec optic 6 flaparon question
- Hitec Optic 6 = Count down to your crash.
- Costly 5945 Gear Set Replacement from HiTech?
- HS-635HB Reversing
- ROYAL EVO DEFICIENCIES
- Any way to disable throttle/pitch trim on Optic 6 in heli mode?
- HFP-10 Battery Drain
- Ganged 5955s
- HS625MG jitters at center
- new 5945??
- Super Fl Digi
- 6 volt batteries
- brand new 5645's are sloppy
- hitec programmer
- Ultimate Hitec Tx
- Most precise for throttle?
- 5955tg
- Prism 7X jitters
- 1/4 scale gasser servo question for Mike
- servo programmer available when?
- Karbonite Quarter Scale question
- 5645 doesn't work after new wires
- MPX ROYAL EVO 12 utilising channel 10 - 12??
- HS 5997TG question
- Digital servo resolution
- Digital servo software version
- optic 6 elevator set up question
- Eclipse 7 Acting Up All The Sudden
- HiTec Master 5P not working
- no warranty card- how to register?
- servo gear slop fix
- optic 6
- Optic 6- more complaints than Futaba 7C?
- Can I use a 72MHz RF module on my European Eclipse 7?
- what's up with the slow turnaround?
- Loss of Channel Function
- RECEIVER NEWBIE question
- Hitec servo choice??????
- I wish a new product.
- Evo Help
- Shift Select Supreme Rx
- Imminent servo failure?
- Hitec PCM Rx gone wild!
- SERVO THROW
- Laser 6ch fm Hs322
- 5955 on Holding Power
- EasyGlider Brushless Hop-Up
- 5955TG compatibility with Futaba pcm rx
- Hitec Digital Servos
- Flash V & Flaperons
- Hitec HFP-10 V1.04
- diode in tx
- t
- Can't set timer 2 on Optic 6
- evo 12 synthetic tx
- 5955 versions and how to identify?
- Royal Evo resolution?
- hi-tech optic 6 problem
- Love the Electron 6 - have a question
- Aerofly Pro Deluxe & Optic 6
- Eclipse Channel Change
- Optic 6 transmitter
- QPCM range issue
- Spectra and RF Modules
- New Computer Radio
- Programmer problems
- Hitec transmitter parts
- Eclipse 7 and 8 channels
- Slider swithces on Optic 6
- eclips 7 and hitec 8 ch rec Glitches
- Electron 6 tuning
- Question MPX Royal evo 9
- 5995tg programming
- Flash 5X takes a powder
- 5995tg
- help with servos
- Optic 6
- HS-635HB center shift
- 5955 Problem
- 104
- Hitec programmer with new V1.04 software
- Hitec servo problem?
- Hitec QPCM a disappointment?
- seagull laser 200 which analog servo
- 635 HB servos in Excelleron 90 Will they stand up
- Optic 6 and Spectra Module
- Glitch problem, need help
- Antennae replacement and Hitec 555/ glitch problems
- Battery Cycling
- Disable Beeping on Digital 5945 ??
- Flaps Function
- Spectra Module
- Optic 6 stops Tx'ing
- 5745 Problem
- 5955 clarification please
- Notchy 925s
- Supreme II receiver
- model select mode
- HS-5945MG and external fail safe
- Hitec 5945 slop
- New 5955 Jitter
- Cost of Optic 6 bug fix?
- 5945 Version Identification
- hfs-05mg interference
- hitec receiver fuel soaked
- 2 Flap Wing Mix - listed on Optic features - what is it?
- Screws on HS-50 are too small!!!
- Stand for Optic 6
- Removing back of Optic 6
- can I send servo in to get it reversed?
- Optic 6 How to Center Channel 5
- Brand New Electron RX Issue
- Electron 6 question
- eclipse ailervators
- Electron heat problem
- metal to metal
- optic 6 problem
- HS 635HB gear failure
- HS 5245
- 5945 gears
- EPA and elevon mixing,
- Hitec 225MG Servo Failures
- RCD receiver
- Optic 6, Channel 2 hard over
- HS5245 Stop work !!!
- receiver battery voltage
- Flaps & Eclipse 7
- ANY HIGHER CHANNEL TX IN THE FUTURE?
- 5955 vs 5945 current drain
- Weird Optic 6 to Laser 4 Trainer cord Issue
- Great Planes Lipo friendly ESC & HS55 incompatibility?
