PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19
  1. Elevon reversing on Flash 4
  2. MPX Rhino problems
  3. new surface transmitter
  4. QPCM Tx
  5. Help To ID Jumbo Servo
  6. hitec pcm
  7. HS-85MG+ ... stuck?
  8. hitec 5625
  9. Laser 6 two aileron servos
  10. Changing frequency on Receiver from 72Mhz to 35Mhz
  11. SP-1010 ESC
  12. Servos for a TF Giant Scale P-47
  13. 5955s pulsating
  14. Hitec service
  15. New Fusion receiver won't program
  16. Hitec HS-75 BB Gear Servo
  17. Looking for 35mhz Hitec modue or spectra
  18. Number's on side of servo's
  19. HS-85BB Input
  20. crystal color codes
  21. Hitech 05s receiver and 9C w/synth
  22. could it be my flash 5x?
  23. Am I programming my servo correctly?
  24. SERVO BOARD
  25. HS125MG retaining screws
  26. QPCM rx problem!!!!
  27. Help with aileron differential on Optic 6
  28. Dual elevators with one moving a little before the other
  29. New Radio System??
  30. FLIP TRIM switch
  31. Electron 6
  32. 5995 atv
  33. PROFI MC 4000 RF Module
  34. need new radio trx
  35. Hitec vs. multiplex crystals
  36. 49 -50 Mc.
  37. RCD 3500-HFD-08RD What frequency band?
  38. Linking Eclipse 7 QPCM 40Mhz to Focus FM 35Mhz. HELP PLEASE!!!
  39. Hitec Eclipse Programing
  40. Battery cover
  41. Electron 6 Channel 6
  42. HS-475HB servo problem
  43. XPS in Hitec transmitters
  44. Programming question
  45. antenna length
  46. Eclipse 7 Ch Radio w/Spectra - cycles through channels
  47. Hitec working on any new 7+ Ch radios??
  48. Multilpex RX-9 synth features missing from Fusion ?
  49. Gear set for 6965 Servo
  50. Optic 6 external power options?
  51. Hitec Optic 6 servo jittering
  52. Spread Spectrum for Hitec Eclipse 7
  53. Hitec Mini 6S SC FM Receiver's Range?
  54. Dual elevator servos
  55. Data Manager Evo 9
  56. Hitec servos-how do you get the screws out?
  57. Linear elevator half movement with rudder input
  58. HS56 Gearsets
  59. Servo Extension Cables with Filters
  60. Servos Off Center
  61. Wheres the love!!!
  62. Flat repair fees
  63. Multiplex EVO
  64. OPTIC 6 FMA CO-PILOT
  65. Hitec 325hb karbonite gear failure 3x in a row
  66. Burn-Rate
  67. ? 5955 Gritty Gear Train ?
  68. Optic 6 case handle
  69. 5th scale on-road
  70. The 2.4 MHZ
  71. Cockpit Tx with JR Rx
  72. Nylon servo gear grease
  73. A plea on transmitter case design
  74. Multiplex Micro IPD Rx
  75. Gold connectors
  76. Eclipse 7 program--function from knob to switch?
  77. Bad Credit Card info with Service Return
  78. Cleaning EVO Tx Case
  79. Twitching problem w/Supreme IIS and Cirrus CS601BB
  80. 5998tg servo boat use
  81. Servo issue....
  82. Hitec Rx Repair Estimates
  83. Hitec hs 5735
  84. exponential function
  85. Optic 6 gear/flaps/possible?
  86. 5995/5955 horns
  87. Kudos for HiTec RCD
  88. Servo wires?
  89. Focus 4 FM
  90. Rebuild Hitec Servos
  91. Hitech Zebra final result.
  92. 5955 Replacement Gear Sets
  93. Hitec HS-5475 Servo Erratic
  94. Dual elevator servos and aileron diff?
  95. Question about crystals in the US please?
  96. Hitec Eclipse 7 with twin engines
  97. Servo connector ratings
  98. Hitec Eclipse 7 QPCM
  99. Hitech UK Distibutor?
  100. faulty Hitech Zebra 40mhz FM radio.
  101. What happen to http://www.hitecrcd.com/education
  102. Optic 6 Seperate Flaps Operation and S/W SEL
  103. Hitec 2.4 ghz products
  104. is this Tx a good one for future projects?
  105. Cularis glue ?
  106. Cularis Power Pack
  107. eclipce problem
  108. HS-5625MG gear slop
  109. DuBro Arms on MG Hitecs?
  110. 5475HB Stripped as throttle
  111. What is purpose of the Antenna Bobbin?
  112. Fusion 9 vs Freedom 9
  113. 755HB and 805 servos
  114. 5645 centering problem
  115. HS645MG issue
  116. HS-65HB Micro Servo getting hot
  117. Afraid to fly with my Hitec Eclipse 7
  118. CULARIS SAILPLANE
  119. Installing gear set in 5945
  120. Can I use Optic 6 as Instructor to a Futaba 4YF as student?
  121. Multiplex mixing
  122. PLEASE HELP with programming flaperons for my glider
  123. OPTIC 6 TX Battery charge
  124. CRX Battery pack charging
  125. Optic 6 radio question
  126. Can't switch from Kyosho radio to HiTech Focus 4?
  127. Hitec Electron 6 Receiver Fire
  128. Hitec HS65HB
  129. Mini 6S receiver Glitches???
  130. Older 5645's wont work in auto.
  131. HS-5645MG Problem?
  132. Hitec radio glitching
  133. locktite/5985 servo?
  134. Can the HFP-10 program HS5245 mini-digital servos ?
  135. spektrum dx3
  136. Rudder Servo Centering Problem
  137. Servo Failure
  138. Hitec 5955 servo arm screw size
  139. Trainer cord compatible?
  140. Transmitter repair turn around
  141. 5245 stopped working after 2 hours on bench
  142. control arm screw for 225mg...size?
  143. HS-325HB Servo
  144. Electron 6 Antenna length
  145. Hitec service top notch
  146. Quick Question about hs645
  147. fried programmer
  148. Hitec Fusion 9 reciever?
  149. Hitec programming ???????
  150. 5245 Problem
  151. HiTec Focus 4 Channel Radio
  152. Hitec Eclipse 7 w/spectra
  153. Hitec first time servo User (HS-5955)
  154. Multiplex IPD????
  155. transmitter mode 3 (same as a left mode 2!)
  156. Mosfet amplifier?
  157. hitec 5955s servo arms?
  158. Multiplex Royal 9 EVO
  159. Output shaft spline count ?
  160. HELP CRASHED AGAIN WITH ROYAL EVO 7
  161. Hitec programmer and transmitter question
  162. Cyclic Ring for Eclipse 7, Throttle Ratchet
  163. Hitec 5745 - 5625 Problems
  164. Hitec 985 servos??
  165. Hitec HS-55 glitch
  166. Hitec Digital Servo set up Question
  167. HIS-03MK fail safe
  168. Glitching with Eclipse 7 and Fusion ... help
  169. Optic 6 not trimming?
  170. Eclipse7 & Futaba 9C Freq Module Compatibility
  171. 5245 Issues
  172. Servo Selection help
  173. Hitec 5955 - JR ATV Setting
  174. Hitec Optic 6 setting up issues
  175. Eclipse 7 Tx battery charging lead
  176. New Hitec Web Site On-line
  177. Dual elevator servos
  178. programmer 1.03 should I update it?
  179. Servo twitch on my digital servos
  180. muiltiplex EVO 12
  181. HS-6635HB and Fuji Imvac 64
  182. Buying new Optic6 with Spectrum. Fixed?
  183. HELP - setting up Hitec Eclipse 7 for full house motor glider
  184. Erasing Royal Evo memory?
  185. Help Please: Eclipse 7 QPCM - Electric Heli
  186. Eclipse 7 EPA Function
  187. Servos on 8 volts
  188. 5645 servo service question
  189. Hitec Supreme8 Chnl Auto Shift FM Rcvr.
  190. Conversion of Multiplex 12 DS IPD receiver to use with Graupner/JR MC24
  191. Optic 6 with spectra problem
  192. 5945 vs 5985 servo case
  193. Profi 4000 discontinued???
  194. HS 5945 on elevators different speed
  195. Can I put HS-65 metal gears in HS-56B?
  196. HG-5000 Gyro and HSG-8053MG servo
  197. Centering issues with 5985's
  198. HFX-R quit working
  199. Optic 6 SPECTRA module
  200. Supreme 8 and JR 821 digitals?
  201. Hitec HSR-5995t servo
  202. supreme 8 reciever
  203. Optic 6 spoilerons on a switch?
  204. the gold question ... Spektrum for Evo's
  205. Hitec company has no integrity
  206. 645 issues
  207. Hitec 645 MG Servo Problem
  208. Hitec Servo Fail Safe
  209. Hitec Digital Servo Amplifiers
  210. Profi 5000, when ?
  211. All Optic 6's or just those with Spectra ?
  212. 645MG gears in a 635HB Servo?
  213. Karbonite Gear failure before I even take flight.
  214. Receiver works and then it doesn't
  215. Does everyone need to ship their Optic 6 Back?
  216. multiplex Battery
  217. hitec programmer problems
  218. HS 635HB problem - What to do?
  219. Evo 12 programming: Throttle lock?
  220. Hitec servo to substitute JR 2721
  221. hitec 3200 reciver
  222. Digital servo failure
  223. hitec 3800 reciver
  224. Lost a customer to Futaba
  225. Fusion 9 shipping?
  226. XL servo arms?
  227. Multiple servo Q
  228. Is Venom Compatiable
  229. Optic 6 flap travel
  230. 5995 SERVOS
  231. cycle optic6 transmitter battery?
  232. HITEC OPTIC 6 FAULT – MODULE GLITCH CAUSING DROPOUTS
  233. What Functions Do I Need????
  234. 5945 eyelets, grommets, and servo arm screws
  235. Servo
  236. Programmer fault
  237. Channel Setup Lead M85048 , do YOU have one ?
  238. Spectra Module question
  239. Optic6 without spectra module?
  240. Spectra problems
  241. Programmer software revision
  242. Changing hitec eclipse 7 frequency
  243. Optic case back replacement
  244. 5965/5985 centering question
  245. How 'bout that Optic 6 case fix....
  246. crystal change AM
  247. HS 5645 convert to HS5625?
  248. eclipse 7 dual elevators
  249. 9 channel radio?
  250. Servo recommendation
