- Dual aileron servos?
- New Servo?
- CG335 Upgrade?
- Digital servos & long leads.
- HFP-10 Programming Procedure Help
- servo kill switch for gas engines?
- 5625/45 + Li-Po's and voltage regulators
- Getting serious with the HFP-10
- 5245 possible oil contamination???
- Hitec service
- throttle trim question, laser 4
- HFP-10 Not charging...
- Hitec 605 problems
- Modify 5925 to 5945 with gear train??
- broken screw!!
- 225 servo for .60-size control surfaces?
- Hi Mike! Got an EVO availaibility update??
- THANKS HITEC!!!!!
- Aristocraft Hitec
- Crow function
- Replacement antenna
- Multiplex Servos
- HP-Programming Question
- Ecipse 7 mixing?
- Long term storage
- HFP-10 Digital programmer
- Hitech 720 aristo-craft 7ch
- 5945 Programming on Composite-arf 2.6
- help with the Hitec Laser4
- Glitching with radio gear
- How to Disable Hold
- Multiplex Evo Update
- Can an HS-475HB be reversed?
- What gauge wire do Hitec digital servos have?
- Mike need help!!! Servo won't work in steering output but will in throttle output
- 5945MG servos on JR receiver?
- Prism 7X and Micro 555
- Hitec servos with Airtronics Z
- Hitech digital servos and battery
- 5945 MG JR
- Laser 4 Air and Ground
- RCD Micro 535 receiver crystal question
- PCM Radio
- HS-5625MG Centering?
- 5xxx series failure rate
- Karbonite and Loc-tite is a no no
- No glitch with old Tx, glitches with Evo
- HS 605 centering
- HS-545BB vs HS-5475HB
- EVO 12 question
- Charging falsh 5 and prism 7
- 5475's on 120 Cap wing????
- Evo 12 question
- HS-81's Am I just unlucky?
- Royal Evo causing glitches?
- Gyro
- 5925 vs 5975
- Synthesized Royal EVO 7 availability?
- 5475's singing???
- HS-81MG Problems
- Flash 5X and expo only on low rate?
- radio selection
- servo arm/wheel post compatibility
- Any word on if the longer screw solves the 5975 problem?
- Can I activate Channel 7 on Acro mode?
- question about the new HS-475HB servos
- Upgrading from Futaba 8U
- SEvo repair canada
- Eclipse Q-PCM resolution
- Digital Servo's
- Hitec Flash 5 inside photo
- 5945 question
- 5945 MG spline
- Evo Software upgrade link down?
- HS-85
- eclipse 7
- Interchanging Receiver Crystals
- Supreme R/X upgrade
- Eclipse 7 with G2?
- Hitec Surface w/ JR XS3
- Focus 3 Compatibility
- Servo Programming
- Royal Evo 9 Synth - who has one?
- 3 ch Hitec Neon tx expandable to 4 ch?
- Royal Evo 12 question
- DO HOBBICO CS225'S equal HITEC 225'S
- Blips in Control & Jittery Airlons -- Hitec Super Slim 8 & Hitec 555???
- making a simple receiver
- Multiplex warranty
- flight pack query
- boat radio
- SERVO TESTING
- Heli radio on airplane?
- Multiplex sailplanes ?
- Hitec 5645's
- Eclipse7 w/Spectra Module
- Royal Evo software upgrade help
- Where can I buy a Profi 4000 transmitter in the USA?
- New Servo Screws
- Xmitter
- Hitec Eclipse 7 ?
- They assume too much
- Expo when using CCPM w/Eclipse 7
- Royal EVO 12 Synthesized
- battery and other channels
- HS5475hb
- micro 555 receiver
- Karlton Spindle
- Multiplex glitching
- 5625 problem
- problems charging my digital servo programer
- ECLIPSE HELI PROGRAMMING?
- Laser 6
- Old Aristocraft PCM
- 5645's
- Hitec Programmer
- Eclipse 7 Heli mode Flight Conditions ???
- Hitec Supreme 8 receiver - malfunction
- flash 5x - spoilers / mixing
- PPM control system info needed
- Aristo-Craft HITEC Challenger 720
- Maximum Digital Servo Travel?
- Multiple Servos into One Receiver ??
- royalEvo and old MPX Servos
- Hitec service info
- Another TX problem - NOT!
- Flash 5 x
- hitec prism 7
- 5925/5945 gear sets
- Programing on the 5925's
- Low Profile Wing Servo
- flash 5x mixing help
- Gonna eat crow here
- Hitec Transmitter Defect!!! Beware!!!
- Eclipse 7 up in smoke (literally)
- Spectrum 7 transmitting when used as a Buddy Slave??
- Servo programmer shuts off by itself
- Programmer version level
- Flaperons
- Strange Servo Response #5945
- Trim problems on Hitec Flash 5
- Hitec Customer Support
- Servo wires
- Eclipse 7 throttle trim
- Eclipse 7 Ailerons and Flaps
- Royal Evo 12...When??
- Hitec TX connector
- Feather Receiver
- Receivers
- Crystals
- Hitec RCD3200 on 50mhz in need of repair or replacement
- Spectra module for rx?
- Mike - Need Help To Purchase Hitec Radio
- Mike - Hitec 5975 application question
- Servos stop working intermittantly
- Next level up from 5475
- Grumbler/ailerons & flaperons
- 5245 Gearset
- Focus 4 TX problem
- 5475 output shaft
- Short antenna wire
- Programming Digital 5645's
- crow mixing from a hi-tec flash 5
- Battery Upgrade for Eclipse??
- 605 Hitec servo arms
- Eclipse upgrade to QPCM for antepodians?
- 311 servo
- Challenger 550 - Still good?
- HFS-04MI+ failure
- QPCM FAil-Safe
- Receiver switch
- Hitec crystals inerchangeable
- 5945 servo arm screw size?
- Eclipse with Spectra
- Metal Gear Lube
- 605's are discontinued?
- Prism 7x programming
- Mike, programming thru long leads?????
- HS225 BB centering....
- Servo wheels.
- Did i buy the wrong reciever
- Feather Antenna
- Eclipse 7 - dual elevator
- Plantinum Receivers
- 605BB Causes Big Loss
- Eclipse update?
- Help......Hitec 555 receiver
- Hitec Servo horn Screw
- HS 5475 Servos
- End Point Adjustment VS Dual Rates
- Crystal Fell out
- Amp draw on Eclipse?
- Speed up servo reaction
- Hitec Servo Programmer
- Another vote for HAM band
- electron 6 vs. micro 555 - HELP
- 5975hb/5475hb
- Reversed Trim
- Possible to buy the tiwsted wire that comes on digitals
- Can I make this work?
- 5645 centering issue on Turbine Jet
- receiver replacement
- Mike is out of the office until 9/17
- Hey Mike Answer rumor????
- I think my Eclipse is still messed up.... much more inside
- Differant 5925's
- Multiplex evo 12
- FG 1/5 Race Buggy steering servo?
- Antenna Length of Hitec RCD 3500 Receiver?
- Feather for Surface use
- Servo Programmer
- 5475 Failure
- Multiplex IPD Receivers
- New 8 Ch. Receiver
- 5975 KARBONITE Question
- Recommended servo
- Hitec Flash 5
- Hs-5125
- Post the good stuff! :D
- Converting US 72 to Australian 36 Mhz
- HS81 problems
- Hitec reciever/crystal question
- Spectra Modules Out of Tune???
- Digital Servos
- Hitec laser 6
- laser 6
- 5475s
- 422 Arm Screws
- hfsc 04mi receiver
- HS 81 gears
- 225 Mg Servos
- MIKE, NEED HELP........Eclipse 7 won't work
- single conversion/dual conversion
- Hitec 5945
- For Mike, Flash 5 Display question...
- Multiplex Royal Evo question
- I have a servo question , Mike....
- Reversing a 625MG Servo
- Anyone: Eclipse 7 vs Prism 7...
- Neon/ Focus, Obsolete?
- For Mike at Hitec (Servo Question)
- Digital 5645's Stripping All The Time!!!!!
- RCD3800 and HFD-08RD Difference?
- Dual Elevator Servo Eclipse 7
- Mike is on vacation until Aug 27th
- 605 (nylon gear) on pull-pull, good idea?
- Eclipse 7 QPCM 1850 Mah Update...
- Mike, Eclipse question please.
- 5735 Failure
- Bizzar interference???????
