- Hitec Eclipse7 or Optic 6?
- 5945 with Version 1.04 firmware
- Screw size
- Dead Band Setting?
- 5945 question
- Servo Centering and Sub Trim
- My hitec 5945mg servo strange problem,help!
- Hitec aggressor crx
- Optic 6 Programming Lockup
- Quality Control
- New 5995TG on programmer results: Need help HiTec
- Traxxas Radio Crystals
- Supreme failing range test and buying crystals
- Optic 6 CROW Defect
- Two Optic 6 Bugs??
- Servo Programer
- Optic Fixes
- Electron 6 Receiver question
- Reciever Current Capacities
- Profi 4000 and 5995 TG robot servos
- Optic 6 hiccup...??
- Hitec Focus 4 to 5
- Optic 6 Firmware Jungle
- Spectra Module Heating Up
- Guaranteed unbreakable?
- Mode change on Optic 6
- Optic 6 on a big bird
- receiver question
- Maximum voltage that the Micro 555 can handle
- How much battery for Digi's?
- Rubber crystal boot
- help
- Got a new eclipse
- Servo weird random kicks
- Lost Alternate Evo sticks
- Servos for Funtana .90
- Plastic wheel?
- Hi Tech HS 5975 centering
- Latest Status: 1.04 digital servo vs 1.03 programmer?
- Hitec Feather 4ch crystal RA
- Optic 6 & AMA Insurance
- Karbonite Gears
- Hitec Flash 4
- Optic 6 Crow Defect
- Optic 6 Firmware Flaw
- 635HB
- Flash 5?
- Erratic Servo movement
- HS-645MG Servo Interferance
- JR servo plug / futaba receiver
- Dual Conversion
- Hitec Servo return procedure?
- Eclipse 7 trim backwards, among other things
- Flash 5 voltage and flight times?
- HS 605's??????
- "Burning out" 225 servos
- 5995TG
- Hitec Eclipse 7 Heli throttle problem
- Neon and E7; teacher/student; on ch 22
- AMPS?
- Optic 6 bug?
- READ THIS: Hitec Support Forum User Guidlines
- Safe to side load a 5945 or any servo for that matter?
- 1 memory gone on eclipse 7
- Optic 6 ADIF/Throttle Defect
- RANGER 2 + ESC ?
- Hitec Reciever/Crystal Question
- Lost servo arm screws hs-81
- Servo Mounting - Spacing of fasteners
- Hitec Programmer - setting EPAneuFS
- Multiplex RC Sets???
- SW bugs on Optic 6
- Optic 6 problem PLZ help!!
- Hitec programmer ??
- Hitec 555 rx vatl glider with spoileron mix
- Split Elevator Single Y-Harness Matching
- HS5925 warranty repair
- Servo jitters
- 6985s
- How do I setup elevator compensation on Optic 6 with a V-tail Sailplane
- Servo matching Q for Mike Glavin
- Eclipse 7 Mode 1
- Eclipse Memory
- Crashed Electron 6
- Hitec rx for hitec/airtronic servos
- Hitec HFS-05MG 5-Channel SC FM reciever?
- 635 7mm control horn screw
- HSR-5995TG centering issue
- Feather receiver interferance
- HITEC CRYSTALS
- Can't get a throttle/smoke mix setup right, eclipse 7
- Hitec Feather adn antenna shape
- Hitec 5955 ?
- flight pack for focus 3ss Am Radio
- Eclipse 7 Coupling Flaps & Ailerons
- New 20 Guage Twisted Wire Extensions
- hitec hs-635HB
- Htiec 335 Pro charger and Nimh Cells ?
- Receiver crystals
- HITEC E-7
- Question regarding HS-56 jittering
- Older flash 4 Radio question regarding frequency crystal
- Karbonite gears in HS-6985
- Optic 6 & 2 elev servos
- radio set up
- Brushless digital?
- Why doesn't Hitec sell aluminum arms?
- Servo arm question.
- Help: Electron 6 with JR 9303!
- 8 ch Supreme and 6 volts
- Receiver for Mixing
- Longer servo arms for HS-85/81 servos?
- Hitec Eclipse 7 problem
- HiTec Eclipse 7
- Battery for 6 hs-6635's
- Hitec feather receiver
- Hitec 5625 Problem - Crashed plane
- Hitec Optic 6 Not Available??
- Hitec NEW X-16 flight pack
- 805 servos
- Digital 5245MG Startup Delay
- receiver search
- Hitec Q-PCM
- Hitec 5955 problems
- Will Dubro Long servo arms fit HS 5645mg???
- HITEC Servo Programmer
- Replacement Gears for HS 615 MG
- Eclipse trainer Cord Questions
- Suggestions, please....
- 5955 software version 1.04?????
- Hitec Website...
- 5625 for heli application
- HiTec Eclipse 7 Question
- Optic 6 Problem
- Cyrstals
- Flash 5 Owner's Manual needed
- Heat
- Module or Crystal?
- Hitec Eclipse 7
- Aristo Craft Hitec Challenger 455 circuit
- Elevon Question
- Mini Vs. Standard Output Shafts
- Hitec RCD3600 Question...
- Hitech Eclipse w/ a spectra
- Optic 6 sailplane question
- My Eclipse radio doesnt transmit!!!
- E7 channel 7
- Eclipse 7 problem
- Eclipse tx battery
- Opinion Needed
- Flap control
- hitec crystal into JR transmitter?
- Optic 6 Gyro switch???
- Flash 5 spring tension
- Hitec Rx Problem?
- Mike Mayberry - 945MG Servo Problems
- gy401 and eclipse 7
- Synthesized Channels
- Two stick controller for Xfactor2
- Jumpy 5245s
- 5945 gearset
- where to get pots for 5945
- Karbonite Horn Screws?
- HITEC REPAIR SERVICE UNFAIR
- HS-85BB on .40 profile throttle?
- (4) 5245's on one rx channel
- Hi Tec Servos
- Will HFP-10 Eliminate my JR Problem
- Plastic gears in HS 311 Standart SErvo ?
- Broken clips on modules
- 805 servo
- Hitec crystals
- Can HS81's be converted to MG version?
- Can I use Multiplex receivers with my JR ?
- Transmitter low voltage warning
- HS-56HB "Jumps" Like Interference
- sail winch
- servo recommendation
- Are the 625, 635 and 645 the same???
- Question about Flash 5X + Flying Wing
- What Metal arm for 5945???
- Turn-around time for crystal change?
- Crow setup for acro
- 5625 gear noise
- Major Beef with my brand new HS-225's
- Dumb Eclipse 7 question---?
- Retract gear servo question
- Hitec 5945's seem stiff
- 5995 max travel ?
- 615
- 5955 ?
- hitec optic 6 questuin
- Newer vs Older HS 9x5 MG servo differences??
- servo arms
- 5995TG Question
- HFP-10 Question
- Hitec HFX-R ESC took a dive
- Eclipse 7 - How low can you go...
- Threadlock on Servo?
- any hitec eclipse 7 users in germany?
- focus 4 Tx Charger
- Focus 4 “Channel 5 for Gear Switch”
- Nylon gear 525 servo slop
- HS 5245 Mini Digital
- Laser6 Tx - Convert from Mode2 to Mode1
- Radio hookup for Bipe using ECLIPSE 7
- Mode 4 radio from Hitec?
- Hitec 645mg servos
- Regulator for 5 5945's
- EXCELLENT Service
- Eclipse 7 tx failure
- 5475 changed its center on its own!!
- Stiffer Gimbles for Eclipse 7????
- Partnumber for potentiometer?
- Hitec – master, and Futaba – slave
- Seeker 6 Receiver and Spectra
- 5945 and 5645 potentiometer question
- The ole switching crystals question
- Alternates to 635 HB Servos
- HS-325HB for aileron?
- Troubleshooting a Rumbling Servo
- 635 Servo and Futaba 127 Rx Glitch
- "Replacement" for 5945MG
- Prism 7x: Does it retain the settings when battery removed?
- What PCM receiver for the Optic 6?
- Gears for my 625s
- Hitec HS50 disassembly
- Fee for changing transmitter crystal?
- JR vs Futaba Servos/Radios, what's the difference
- module
- Optic 6 current drain?
- Focus 4 Problem
- Eclipse 7 Twitch
- How Much Batt for HS945MG Servos
- Prop shortened antenna---
- Jumping Digis 5125
- Hitec lazer 6 or flash 5 sx????
- Optic 6 in stock in 2005?
- Multiplex/Hitec Digi Polo Servo
- HS-225MG
- DAD reciever crystals
- 422 Servo Bushing
- HS225MG gone belly-up
- OPTIC 6 with Crystal
- 5625 Centering?
- HS-805BB and the HS-705MG in battery drain
- Servo screws
