- Multiplex Synthesized rcvr
- Optic 6 Sailplane functions
- Optic 6
- Dual 5945 Servo Setup
- Hitec 605 or 635?
- Prism 7x and Prism 7 transmitter crystals
- Slow down retract movement for HS75BB?
- Electron 6 Rx good?
- Eclipse 7 with my new Ultra Stick
- OPTIC 6 without SPECTRA Synth module
- Digital servo reboot problem
- Karbonite & Metal arms
- Why discontinue the HS5975HB servo?
- 5945's Locked Up
- Multiplex Digi torque
- Hitec Laser4 Frequency
- Mike is out of the office at the Chicago trade show until the 19th
- Deleting Eclipse Memory
- Servo programmer
- Hitec 55 groans
- Regulator Needed??
- Hitec Programmer Battery Bit The Dust
- Flaperons/separate aileron servos on 5ch receiver?
- Hitec 635 HB
- Hitec servos for 1/3 Scale.
- hsr-5995tg servo
- what Hitec Tx can work dual elevator servos?
- New Optic 6 Tx
- Digital Servo Programer ?
- How do you tell if gears are stripped?
- Flash 5X + Flash 5 buddy box Question
- Hitec HS-635HB Karbonite for Funtana 90
- Puzzling problem this evening?????
- mem 7 dead on eclipse 7
- 5945 Any truth to case top failure
- Focus 6 Battery keeps draining
- Is a Reverser Ok to run on digitals
- Elevons and trainer box
- 5945 problems
- Flash 5 Issue
- Flash 5 Mode Conversion
- Antenna repair
- 5735 output shaft
- 125MG/5125MG gear sets availability ?
- 5945 Play in Gears???
- 5645mg question for mike
- Hitec service issues for Mike
- PCM
- 645 MG
- eclipse 7 and nimh battery
- Is this radio legal ??
- New wiring??
- Are HiTec transmitters type accepted for use on the part 90 commercial frequencies?
- Hitec servos for 65in p51
- Prism 7X Antenna Warranty?
- Li-Poly Powered Eclipse 7???
- Hitec Eclipse Pro Car
- 5995?
- Hitec 225mg problems
- Hitec Flash 5 Memory Battery
- servos
- Programming Digital servos??
- Hitec prism 7
- Hitec leads for Hobbico charger?
- Ranger 2N RFI
- air Brakes
- HFP-10 Digital Servo Programmer Protocol
- Max Voltage
- hitec servos
- Eclipse 7 channel remapping
- Length of receiver antenna
- Screw size for Hitech HS-55 Servo
- 5245 s ?
- Equipment Guidelines / Best Practices
- Can“t get full throttle
- 555 RX in gas planes?
- Hitec 5945 hunting for center position !!!
- Servo extensions
- matching electric engines
- Futaba TX and Hitec RX compatability
- Airtronics servos
- Mike servo arm screws
- servos for a 28% Gas airplane
- 5945 and Y-harness ?
- 5975 Karbonite application
- The DEFECT New EVO returned but still not function properly
- Phone Number
- 5475 servos "Chatter"
- 5475 vs 635
- Rx Crystals
- RC Frequencies
- Help Focus III throttle lever
- radio compatibility
- dead topic
- battery packs
- Multiplex servo's
- has5-3mb
- re transmitter
- Power Issues? - please elaborate
- HFP 10 questions
- Multiplex servos by Hitec ?
- transmitter
- Hitec coreless servos -- why so expensive?
- Hitec system for park flyer?
- Synth upgrade for RoyalEvo 9?
- eclipse 7 upgrade
- HS-5475 Servos Gear Stripping in Normal Flight -- Why no response???
- Mike is on vacation until Aug 13th
- Optic 6 and a 4 servo wing
- Hitec Eclipse 7 question???
- is the challenger 720 neg shift or pos shift?
- HS-5475HB servo shaft slop
- Hitec 555 receiver and "Sticky Antenna"
- HiTec 635
- Hitec Feather Receiver reliability?
- Optic 6
- 5625 question
- MIKE can you please take a look at this?
- Hitec HS-5475s -- They All Stripped In Flight???
- HS5945: Which date has the known programme probleme?
- 5945 Locking Up
- 5945 questions for Mike
- HFP-10 V1.03
- multiplex warranty card
- What's with this?? Why is Hitec servo doing this?
- Multiplex IPD Synth RX and Futaba TX
- Flash 5X and expo/dual rates programming
- mode 3 for eclipse
- 5245 gears
- Eclipse with glitches
- servos are stiff
- Hitec Throttle to Rudder
- Eclipse 7 preset question
- Hitec Eclipse 7 swamps reciever
- gears for 205
- JR crystal in Hitec
- 5625 Bearing
- Gyro info
- IDLE ON warning is driving me crazy :)
- typo in manual eclipse 7 for GLID ch3
- help with servo question on HS625MG
- 5475 problems
- warranty
- Surpreme 8
- Hitec Support Forum Policies!
- HS-635HB
- 5945's (or 25's for that matter) and Power Box Champion use.....
- 2*945 OR 1*5735
- Hitec 5945 servos are junk!
- Model Memory Corruption - Eclipse 7
- A stupid question
- HITEC CRYSTALS
- multiplex rx not working
- Preventitive Maintenance?
- 5945's
- EVO Setting Problem or Product defect ??
- Prizim 7 help ??
- Spilled water on Tx... screwed?
- A questin for Mike on Hitec Repair/Service
- 5475's on 6V.?
- Buddy Cord - Different modes?
- AAAGH I am so mad at Hitec right now!!!
- HS-311 or HS-422 servos?
- Eclips7 QPCM
- Hitec Eclipse 7 TX with non-Hitec RX???
- Signal flow chart for Hitec TX
- Why YOU should never do business with Hitec.
- 5475 gears
- Can I run a HS-805 without the Y Cable?
- ? about servos going bad
- Dumb Semi-Newbie Question
- Hitech 5645 and 5945 servo arm bolt size
- Will HS-475HBs Push 90 Sq inches?
- Mutiplex TX software
- Servo Noise Immunity
- Eclipse with dual elavater servos?
- servo application question
- Replacement "gear" Switch for Eclipse 7
- HS-755?? WHEN???
- Transmitter caused crash
- Hitec for Funtana 90
- Royal EVO Help
- New Eclispe with spectra module
- Hitec crystals
- Convert a laser 4 from air to ground
- Cockpit 2.3 manual and HELP! reversing forward and back pitch
- servo rewire warranty issue?
- screw size 5945mg
- Installing 2 Speed Controllers
- Trainer cord identification
- 5475 issue in GP 1/4 PW Extra - looking for help
- Hitec Eclipse 7 to Futaba 6EXA trainer cord?
- Crashed RX, twitching servos
- Servo, connector question
- Hey Mike-- am I asking for trouble?
- New Eclipse 7 only works half the time
- hs77-bb
- Eclipse 7 revo mix
- Strange incident Hitec Radio
- EVO compatibility w/ futaba rx
- 5945 smoothness?
- Crash due to control stick failure
- Rewiring servo extensions
- Which Servo for 3D?
- What's up with the HS-5125MG's ?
- emergency help needed tonight 5375 top gear change
- Ultra Stick and Royal Evo
- Eclipse 7, Futaba buddy box, and 2 aileron channels
- flash 5 x manual
- Increase rotation of servo
- flash 4 mixing
- Hitec RCD 3500
- Hitec Servos/JR Equipment
- DCX Range?
- Hitec Programmer 201 (or is it still 101)???
- speed controllers, almost lost a finger!!!
- 5945 "Too Tight"?
- 5995 release date?
- module change Eclipse -> Prism?
- good date on 5645 and 5625 servos
- Are Hitec 605 and 635 Gear sets similar?
- Eclipse 7
- Programming with extensions and y's
- Which transmitter
- Electron 6 with 635 servos
- Red arm numbers
- Would carbon fiber cause reception problems?
- Which Hitec Digital?
- 635-HB Stripped Gear
- discharging transmitter batteries
- Supreme 8 Range Check
- eclipse 7 mode change
- 645 centering issue
- Cheap Rx for combat planes
- Hitec 9c radio
- 925 & 945 gears ?
- Great Service
- Mike service problem
- Karbonite gear sets for HS-5645 and HS-5945
- RX frequency
- HS-635HB gear strip = NOT HAPPY
- yo , mike, eclipse and heliS!
- can i mix crow for gas plane with eclipse7?
- What the heck happend... to this servo ????
- Mixing on the Optic 6
- Eclipse 7 Mixing and trim
- HS-645MG SERVO
- 6965, 6975, 6985 sevos
