PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19
  1. What does the failsafe cover?
  2. 635HB servos with long servo arms
  3. Optic vs. Eclipse
  4. Digital version of 77 low profile...?
  5. HFP-10 Dead?
  6. Does the Hitec programmer draw juice when it is off?
  7. CURRENT SETTING FOR EVO 9 USING SCHULZE OR TRITON
  8. servo programmer charging?
  9. crystals
  10. Hey Mike. . Whats the word on 5995's???
  11. Dual rates with elevons
  12. 555 antenna routing
  13. Flash 5 Conversion
  14. feather reciever and flash 4
  15. Gears Constantly Stripping
  16. Challanger 550 PCM 5CH Radio
  17. Optic 6 question.
  18. Electron 6 - range problem.
  19. Hitec Electron 6 channel
  20. ECLIPSE VOLTAGE
  21. BANDWITH TEST
  22. ALUMINUM GIMBALS STICKS FOR EVO 9?
  23. HS-225 on 6.0 volts- erratic
  24. Challanger 250 - AM or FM and Legal??
  25. Hitec 625MG servo Question
  26. How to setup radio for elevons?
  27. hs 645 mg servos
  28. 5945 Bad Amplifier?
  29. Mike can you please help me to understand
  30. Hitec Focus 4 HELP!!!!!
  31. New digital servo availability?
  32. Hitec service
  33. Hitec servo wiring
  34. Receiver Glitches ????
  35. Mike, Chattering servo????
  36. Digital Servo Noise, humming
  37. How many servos on Supreme Rcvr?
  38. How do i kno if i have QPCM already?
  39. Eclipse Radio???
  40. Double HS-5245 suitable for elevator 2M pattern plane?
  41. Venture CP & Hitec Eclipse - HELP!
  42. 555 Receiver
  43. Mike, How Do You Set Failsafe On Eclipse QPCM?
  44. New Optic 6 Channel Radio (What do you want to know?)
  45. HS-225BB Problem
  46. Converting 5925 to 5945
  47. Bad 5645
  48. Dead spot on Eclipse throttle
  49. MPX IPD 9 ch. problems - NIB
  50. Old RCD Platinum Receiver - Compatable?
  51. eclipse qpcm update question?
  52. Hitec trainer cord
  53. 5625 problems
  54. new hs 81
  55. hs 805 bb
  56. multiplex radio and hitec recievers
  57. Hs 5125 Digital HELP
  58. Multiplex support
  59. Stripped Servo Arm Screw--HS 55's
  60. Prism 4->2 mix
  61. Eclipse 7
  62. Consistent Glitches During Flight and Ground Operations???
  63. MIKE, what is it going on with MPX QOS?
  64. HS-605 Oscillates
  65. Mike, HS-85BB twitching with only one flight on it. **Video Included**
  66. Think I damaged my Radio
  67. HS-5625 question
  68. HITEC CRYSTAL SETS
  69. Whats with the Ver # ???????
  70. Centering Issues?
  71. Schematic
  72. Toledo
  73. New Hitec 6 CH Computer radio????
  74. 5645 on y cord for rudder?
  75. Electron 6 vs Suppreme 8 in 2M Pattern plane
  76. Eclipse 7 throttle problem
  77. overheated transmitter
  78. Eclipse 7 flutter only one two channels in QPCM mode?
  79. Extended servo wire length
  80. Is filtering needed on long servo leads
  81. gyro installation
  82. Battery capacity requirement for Hitech 5945 & 5735 servos
  83. Hitec service bad now?
  84. Where can I get a 3030/4000 tx module ?
  85. HiTec EZX-R Pro
  86. New Eclipse has dead CH 6
  87. Flash 5 w/2 elevator servos!
  88. Have you heard of this happening to hitec servos
  89. Servos for 1 1/2 lb fun fly plane
  90. hitec aggressor crx trims not working
  91. Hitec Servo Programmer
  92. Servo prog & 5125
  93. Multiplex Crystals
  94. Flash 5 methodology - Mike ?
  95. Flap set-up on a Prism 7X
  96. Hitec Challenger2 Rx ????
  97. Eclipse 7: Upgrading software
  98. Dual elevator
  99. Hitec Flash 5 Elevon mixing trim ?
  100. Message from Mike 3/8
  101. No radios!!
  102. problems with hitec flash 5
  103. EVO Shift Select; any good info?
  104. Hitec 81 and 81 MG servos are they really cheap??
  105. Really Dumb Question
  106. Multiplex connectors
  107. Future Hitec servos?
  108. Rumor of HS5125 gears failing
  109. Hitec 5125 problems
  110. Redundant Battery?
  111. Eclipse 7 PMX Elevator Mixing
  112. ok little late...5625 question
  113. Flash 5X elevon mixing ?
  114. ECLIPSE CH 7 SWITCH
  115. help please with MPX recievers
  116. What has happened to the Hitec home page?
  117. 545 centering
  118. data on Aristocraft Hitec Challenger 4000
  119. Mike ??? - pacemaker/defibrilator
  120. 2 - 5975s for Cap X
  121. Power Output
  122. RF Module for Eclipse
  123. Help! 5945 Servos Software Up to date?
  124. Recommended Hitec servo size for a GP Spectra EP glider?
  125. Hitec Supreme 8 Receiver FutJ question
  126. Hitec 5945 endpoint jitter???
  127. Trainer cord
  128. HiTec goes IPD !!!!
  129. Eclipse Throttle Ratchet
  130. hitec micro bb servo with aritronic rd8000
  131. best antiglitch advice please
  132. Aluminum Arms
  133. Multiplex Versus Hitec Receivers
  134. Retrofit Digitals from metal to karbonite gears?
  135. BIG problems with Eclipse7's in AUSTRALIA
  136. Can an Eclipse 7 (U.S. model) Be Legally Used in Japan?
  137. Switches for Profi 4000
  138. Eclipse7 and dual elevator servos?
  139. Diffrent Hitec servo numbers
  140. Servo Extns to long?
  141. Does the Electron 6 require a "special" crystal?
  142. Electron 6
  143. JR Rx Glitching Problems W/ROYAL EVO 12S
  144. Spare Battery for Royal evo
  145. eclipse 7 (usa-eu)
  146. Charging the programmer
  147. Prism question
  148. Your Idea's on Hitec bad Wrap
  149. Very noisy 545bb servo
  150. Question Regarding HS 5625
  151. Hitec Prism 7 Glitch
  152. Digital Servos and centering (Deadband)
  153. Where can I get Channel 70 Crystal for an Electron 6 in UK?
  154. Radio check-up?
  155. Thank you HiTec
  156. Miniture Rx Wish List
  157. Flight pack for BalsaUSA 1/4 scale Pup
  158. Mike do you have any idea how to do this on a RE12
  159. Which Hitec Servos??
  160. Eclipse 7 Spectra channel selection
  161. Jittery Servos with RCD 3200
  162. Evo-9
  163. First Charge Eclipse 7 With Focus 6 Charger
  164. Nicad Charger and Royal Evo
  165. Eclipse 7 set up for Heading hold gyros the quick and easy way.
  166. WRAM show discounts
  167. Hitec Heli servo factory set ups
  168. Mike what is this......
  169. Eclipse 7, Futaba GY401 = Confusion ???
  170. What servos for a Raptor 50 Heli
  171. Black HD Servo arm part#
  172. Connector from tx to FMS or PreFlight sims
  173. Hitec Servos in CG Sukhoi 26 1.20
  174. how many servos on receiver?
  175. EVO 12 Synth Shift update
  176. Hi torque servos?
  177. Hitec HS-5475HB - Do they include metal servo arms?
  178. HiTec service is fantastic!
  179. 625 mg glitches
  180. HS 75 BB failures
  181. Who owns Hitec/Multiplex?
  182. Hitec programming
  183. MIKE, where can i get 12 ch multiplex recivers?
  184. Eclipse 7 coupled flap mix/ snap spoilerons
  185. Lighter Battery Pack for NEON radio?
  186. NEON switch charging jack
  187. Can I change my battery to a 6 volt 5 cell pack?
  188. HITEC HS 700 SERVOS
  189. Potentiomters Failure
  190. Voltage regulators
  191. Signal shift
  192. Programmable servo question
  193. Radio hits.
  194. Hitec Receivers
  195. MIke help please!
  196. New Hitec to compete with 8611?(Help Mike)
  197. Glitches on Eclipse 7
  198. hey mike, focus 6 trouble
  199. gliching
  200. New 5945's
  201. Hitec specifications
  202. Hitech Ranger III FM 75Mhz 3ch problem
  203. Nylon to Karbonite Gear Switch
  204. Hitec 225 for DP Ultimate ailerons?
  205. Which reciever and servos
  206. SYNTHESIZER MODEL:
  207. Programming Endpoints...
  208. Which servo?
  209. Overdriving Servos
  210. using my Tx with PC interface
  211. 5735 double horn hole thread size ?
  212. Quality Issues with Hitec Servos?
  213. shift selectable receiver
  214. Mike, how about an EVO "heads up"?
  215. spoilers for roll control
  216. peak charging on a Eclipse transmitter battery
  217. Servos for GP 25% extra
  218. Flash 5X Radio setup for a powered glider
  219. 5625
  220. Karbonite Gears
  221. Hitec 645MG servos
  222. throttle trim question -- Hitec Eclipse 7
  223. Hitec quality
  224. Programmer question
  225. Royal EVO Status
  226. HS-625 and HS-5625 questions
  227. Hitec flash 5 (older one)
  228. Servo pausing with snap roll switch
  229. Setting up Eclipse 7
  230. Q about the supreme 7 receiver w/shift select
  231. HS5735MG output gear.
  232. The New 635HB Speed & Torque
  233. Hobbico CS-65 is a Hitec 605 BB
  234. JR PCM9X Sailplane mode question
  235. Hitec Digital Servo thick wire but standard extention?
  236. Center on a jr TX
  237. HS-5645MG Whining Noise Problem
  238. Hitec Digital servo question
  239. Correct way to plug servos into receiver?
  240. programming hitech servos
  241. Servo Horn Screw Size for HS 645MG Servo
  242. Royal Evo Concerns
  243. Focus 3 AM with BEC
  244. Dual elevator servo question
  245. Handle broke off Eclipse!
  246. Hitec eclipse 7, major malfunction
  247. hitec 5645 on t-maxx
  248. flash 5sx buddy bix compatabilities
  249. M G servo arm screw size?
  250. Eclipse 7 compatibility with various receivers
