PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19
  1. RCD reciever
  2. Help Mike, older 6 wire servos
  3. Buddy Box Compatibility
  4. Programmer Warning
  5. 5645 problems
  6. Digital Servo Programming
  7. Servos for small plane question
  8. Small suggestion for new Eclipse
  9. Fried Reciever?
  10. Eclipse w/Spectra questions...???
  11. 5735/5945 output gear screw size
  12. Programmer Question....
  13. Eclipse with Sperctra - Battey Life
  14. hitec eclipse programming?
  15. Antenna for the Prism 7
  16. Digital Servo question
  17. Fried receiver, any hope?
  18. Converting Hitec RX's.
  19. Receiver Battery Failure on Laser 4
  20. Problem with 5735
  21. Are the 425's being replaced
  22. Were could I get the New Hitec Neon Transmitter?
  23. Star Washer on MG 225
  24. New Hitec QPCM receiver
  25. HS-422 v. HS425
  26. How Do I Tighten-up 5925/5945 Gears?
  27. connector compatibility
  28. base loaded antenna
  29. HS-225BB in a Laser 3D
  30. hs 85 MG stripped "plastic"
  31. PCM tx and FM rx
  32. Power On Strips Gears - Help!
  33. 5735 Hi Tec Dig. Servo
  34. Hitec Supreme RX antenna damaged
  35. 5945 Digital Puzzle
  36. Battery connector Question
  37. New Radio-Battery won't charge
  38. Odd grinding noises from 2 new 5925s
  39. Charging HFP-10 Programmer
  40. Accu-Cycle RX/TX Battery Cycler
  41. warning warning warning
  42. HS-81 - Servo Gear Question.
  43. Hitec 205 servos?
  44. 5945 deadband
  45. Hitec 5925 ?
  46. Transmitter Springs
  47. Helicopter servo recommendations
  48. Synthesized Module Swap?
  49. Prism 7 w/Spectra question
  50. Hitecs HS 5625 servos
  51. Crystal Differences
  52. Programmer Part Deux
  53. 5245's
  54. Change of band/frequency
  55. Spectra 75 mhz module with Eclipse
  56. CG-340 charger and BIG packs
  57. focus 6fm
  58. Change 422's to B.B.?
  59. Servo Usage Suggestion.
  60. flash5 hitec ch3 trim on mode 1
  61. 5645 servo
  62. 10 channel unit
  63. Which works better with Prism 7X, positive or negative shift??
  64. Hitec PCM Reciever
  65. Pondering the Eclipse for a 1st radio
  66. changing crystals
  67. No RC controller dealers in India
  68. TX modules?
  69. Digital Servo Interference or something else?
  70. Problems with Hitec Digital Servos
  71. Programmer
  72. 6 Meter Crystals
  73. Dual elevator servos with an Eclipse?
  74. Coreless vs Digital?
  75. Metal and Plastic Gears (mixed)
  76. Eclipse - Switched camber and reflex control
  77. 425 vs 475
  78. Digital Servosl
  79. 5645,s
  80. Y-harness questions
  81. Old Hitec 5625's
  82. HFP-10 Programmer
  83. 555 Rx
  84. Sent 5625's for service upgrade
  85. NEW 5645mg high pitch hum
  86. Servos
  87. Warranty for private party purchases?
  88. 555 RX. Question...
  89. Servo selection for Goldberg Ex-treme 330 ARF
  90. Lynx Charger Jack
  91. U CAN DO 3D Servos
  92. flash 5 rudder aileron mixing
  93. Choices..
  94. New 5945 and fiber optic cable?
  95. when to buy....
  96. Flash 5 w/ three channels
  97. servo glitching normal?
  98. Hitec 225MG/BB
  99. Hitec service info
  100. Hitec programmer prob
  101. Electron 6 receiver question.
  102. micro 555 shorter antennae
  103. Hitec HFP Programer
  104. Eclipse 7 Removable Board
  105. Flash 5 Tx. Gimbals(gymbols?)
  106. servo choice on Diablotin XL
  107. Older Digital Programmer
  108. sending back digitals for upgrade
  109. PCM question
  110. Hitec focus 6 ch.
  111. Hitec horn screws and slop
  112. HELP!!!!! 425BB's buzzing a lot.
  113. Hitec Receiver question
  114. Question on 605 servos
  115. Repair mixup
  116. servo checkup
  117. CG-330 questions
  118. Lost manual
  119. Date codes on Digitals
  120. Returning Equipment for check
  121. Question on jittery servo’s
  122. Bad Hitec Digital causes crash
  123. CLOSED - A few questions about my Flash 5X
  124. Eclipse transmitter -> Futaba receiver
  125. HS-5735MG Need Update????
  126. Troubles with HS 5245
  127. Dual rates on Focus 4 buddy box?
  128. HS-5475 digitals
  129. Dual aileron servos
  130. Eclipse 7 to be issued in Jan. 2003
  131. Big Hitec Servo Problem
  132. Prism 7 problems
  133. Hitec Flash5x - Dual and Exp Rates
  134. hitec Rx and Futaba Tx ?
  135. Digitals and battery voltage
  136. Gear grease
  137. Welcome back Mike!
  138. Hs-81/ Hs-85
  139. Servo speed - Analog vs. Digital
  140. How much time to change ch module on my Eclipse if I were to send in?
  141. manual for focus #4
  142. HItec Servo and Gyro Problem
  143. Digital Servo Programmer
  144. Crystal Compatability
  145. what does the number mean?
  146. Best servo choice for DP Ultimate 1.20
  147. eclipse reverse trim
  148. any new tech. being considered?
  149. RCD3500 Rx Shift Selection
  150. Eclipse 7
  151. How much servo do I need
  152. digital servos
  153. naming models in flash 5x?
  154. RCD 3400 Receiver Airtronics
  155. Chargers
  156. What to expect from Hitec for next year?
  157. spectrum transmit module
  158. 5625 Slop
  159. 40 Size Fun Fly
  160. To Program, or Not to Program ????
  161. Eclipse7 and dual rates
  162. New Decals
  163. defference between -225 and -5245
  164. Setting up Crow on a powered aircraft?
  165. Does battery really have to be on Ch 8?
  166. Eclipse flapperons 5ch reciever
  167. Mike is on Vacation!
  168. Flash 5 Transmitter
  169. New 475HB Servos?
  170. Bought my Eclipse 7 Today!
  171. New digital servos... $? Availability?
  172. Hitec website typos
  173. Digital Servo Programming and Bearing Slop...
  174. Hey Mike, Receiver Compatability?
  175. Spectra Case replacement?
  176. Disabeling Flight conditions on a Eclipse
  177. Does Eclipse 7 Heli have Spectra?
  178. Is Spectra Receiver also multi channel?
  179. screaming feather
  180. Dual Elevator Servos
  181. Futaba PCM and 5625's?
  182. 5945s on extentions?
  183. Flash 5x and elevons?
  184. Setting end points, what is the benefit?
  185. 5245 Dead
  186. Sticks to lose?
  187. Changing Aircraft Frequencies
  188. Safe or Sorry???? Hitec Digital Servos
  189. Hitec Servo Programmer Version?
  190. Are these servos adequate?
  191. 5625 servos
  192. Hi Tech 5945 servos
  193. 90" Seafury which servo(s)
  194. Flash 5X trainer compatibility?
  195. Digital Hitec servo conpatibility with Airtronics?
  196. Newly purchased RCD 3800 and crystal. (Problems)
  197. yet another programmer question / eclipse radio
  198. Which Hitec rcvr for 9c
  199. 5625 Problem
  200. 555 RX / Airtronics Stylus Tx Problem
  201. Hitec Servo Position
  202. Eclipse 7 throttle expo?
  203. question about hitec flash 5x
  204. HS-125 oil leak
  205. Hitec Focus 4 fm (for Dummies)
  206. General questions about Hitec.
  207. Best Hi Tec Servo 1/4 Scale
  208. Eclipse TX frequency modules
  209. Focus AM problem
  210. Hitec 425 Servo
  211. Hitech HFD-7RF rcvr
  212. What is a 5 pole servo?
  213. Hitec Supreme Receiver
  214. Mix and match TX / RX?
  215. Surface freq's 61-90 in a Flash 4?
  216. 555 repair
  217. HiTec Focus lll ss FM 3 ch tx.
  218. HITEC Shift Selectable reciever
  219. Challenger
  220. Laser 6 Flaperon
  221. Rx problem
  222. RX antenna length
  223. Servo extensions on GP Extra 330L
  224. Feather flight pack
  225. Flight Cond. Switch good for 6 D/R's
  226. HS81's
  227. what is the voltage tolerance?
  228. HS-5245 servo arm?
  229. Eclipse 7 instructions
  230. 2-servo elevator
  231. Things I would like to see change on the Eclipse 7
  232. Feather Receiver & Sanwa Tx
  233. Hitec Rx Rcd3500
  234. CG330 question for mike
  235. does eclipse have 2 idle settings capability?
  236. RC Car Radio control lost!
  237. Eclipse Dual Elevator Servo Mix Problem
  238. Flash 5
  239. Whip type Antenna (HELP)
  240. Hitec eclipse 7ch vs JR
  241. Challenger 720 receiver
  242. Eclipse 7 PCM
  243. mixing/servo problem
  244. Digital reprogramming
  245. hitec receiver gone bad
  246. Eclipse for a newbe?
  247. Programmer & Microseconds
  248. Hitec RCD3500 Rx might be glitching....
  249. Transmitter Failsafe??
