- HS225 servo arm??
- programer EP question
- Hitec HFD-08RD Reciever with a JR 2610 Tran
- Hitec 5945's/5955's/ATV's/DB Width?
- Fusion 9
- Supreme 7 SS question
- Did I smoke my 5945's?
- Multiplex servo gears
- eclipse 7
- HS-5945MG Discontinued
- optic 6 problems
- Possible Hitec Receiver Problem
- 5945 centering problems
- 5955 servo dimension please
- 5995's jitter on a Y-harness?
- HS 5245 to nylon gear questions
- Screw Size for a HS-5245MG
- Hitec questions & support
- Hitec 5945 servo horn cross-threaded
- product problem with HS 69xx ???
- Advantages of PCM over PPM receivers
- How to replace the bearing in HS-225BB?
- RX 7 synth not working with DSC lead
- Changing direction of Servo
- Eclipse 7 Shows Wrong Voltage & Won't Work
- Using Optic 6 Trainer Switch for other use
- Did I get screwed again?
- HS-635's in parallel
- Hitec HFS-04MI+ Receiver
- EVO 12 question
- hs475 question
- Optic 6 Failure - spectra
- HS65 Gear sets?
- Programming servos with Futaba Eqt
- When should I retire my HS-55's?
- Hitec Optic 6 issues
- HS-635HB fitting J connector
- HFP-10 Internal Batt.
- Air Brakes with Optic 6?
- hitec warrenty in uk
- another brand cyrstal work in hitec RX?
- Problem with Multiplex Profi Speed Digi
- HS-5645MG's sloppy around center
- HS-5645MG Problems
- What Servo For the Giant Super Sportster
- Hitec repair service? They trashed my equipment.
- HS-635HB
- Date of Manufacture
- Frequency change
- New 5955 with the Jitters
- OPTIC 6
- Electron6 battery/ch6 connection?
- Long servo arms for Hitec
- Select Shift HFD-08RD
- HS-605BB
- using Eclipse 7 with 5channel rx
- Optic 6 problem with Spectra Module
- Servo arm screws for HS-81
- supreme rcd 3600 crystal question
- HS-425BB Servos Buzzing
- Optic 6 compatibility
- New Spread Spectrum Radio for ALL planes
- Hitech Flight Flight pack for JR 10SX?
- Programmer internal battery
- RCD micro 535 rx
- QPCM Rx
- Eclipse 7 PCM
- radio interference
- Replacement servo screws?
- multiplex receiver
- Hitec HS-56HB Karbonite Gear Micro Servo Failure
- hitech Rx for Jr Tx?
- Optic6 with HPD-07RH receiver
- Flash 5 System X and Flaps
- 5955 "Stepping"
- Firmware update from programmer to servo
- Can't complain
- 5245 version#??
- Eclipse7 QPCM blanks out (almost unused radio)
- HS 6965 Carbonite Driveshaft failure in flight
- 5645MG
- HS 5945 MG question
- PCM Delayed?
- Servo Version
- My Eclipse Quit Working
- Optic 6 throttle cut only goes one direction
- 3s LiPo as TX pack OK?
- HFP-10 Programmer
- Which servo for 120 Chipmunk?
- Generic vs Genuine Xtals
- Why was my post deleted?
- Optic 6 - 29MHz Module
- Jumper/polyswitch
- hitec lynx and hitec has-2mb reciever questions
- Servo Questions
- 40mhz module
- Prism 7
- HFP-10 Measure Pulse setting doesn't work
- Hmm, has this been fixed or made worse?
- Rotation of HS-225BB
- 635 Servos
- Old 5625 servos need reprogramming?
- Eclipse 7 resolution?
- how to discharge battery using multiplex LN-5014
- how do i find out where my radio is
- Servo programmer or matchbox
- Wood screws for HS-5955
- hitec gear on 2s lipos??
- Eclipse 7 Range Check Problems
- Throttle and Retract Servo?
- Re-posted servo problems
- HS-475HB
- Electron at 4.8V
- hfx-r
- HS-5955 Programmable from Radio?
- Optic 6 shell is cracking
- Optic 6 / Eclipse 7 Module
- Does Futaba CAMpac work with Eclipse7
- Optic 6 throttle/elevator reversed mode 1
- Futaba 5014 PCM G3 rx and v1.04
- 5645MG Arms available that fit
- 05s and jr transmitter
- HS-645MG and HS-5645mg Glitehes
- Universal servo connector?
- Hitec Flash 5 Radio handle cracking problem
- srvo calculation
- Eclipse 7 Crow Function
- two servo makes
- Electron 6
- 205 ? 225 gear sets
- LiPo power for EVO
- MC4000 RAM PAGE 6 Error
- HS-635HB shattered output shaft.
- my new Optic 6 TX stopped transmitting!
- Hitec Electron in a 6-ch sailplane
- Servo arms 5955tg and 5945
- 5645
- 5645MGs on "Y" some work some dont
- 5955 amp draw
- Prism 7
- Y lead set up on a 50cc plane/Reverser?????
- Radio transmitter to be attached to a PC
- 5955 TG Output Screw Size
- HITEC 5955TG and Futaba PCM
- 645
- 5 degree deflection in 5995-tg
- Hitec 5625 and 5645
- Rcv Memory
- Hitec Eclipse7 use for twin engines?
- optic 6 AAAA bug
- HS635 and other Karbonite gear servos
- 2.4 ghz module
- Flight Packs
- Royal Evo 9 discontinued ?
- Optic 6 LiPobattery?
- HITEC 635HB servo
- Trying To Make Sense Of It All
- I Appologize
- 555 / Super Slim
- Optic 6 question
- hitec 9ch
- What5985´s specs?
- supreme receiver
- dual rates on flash 5
- need hitech female tx pigtale
- Spread Spectrum
- Hitec servo and Futaba PCM RX
- Hitec? You Mean Lowtec
- RCD3200 RX jitters
- Ailevator Eclipse 7 Q-PCM
- dual elevator servos
- Radio suggestions
- Twin Elev setup question using 5955's
- Hitec Micro 555
- HS5645MG Jitter/Futaba PCM/Y-connector
- Hitec 5945 replaced by Hitec 5985
- 5955 question
- Electron Rx - high temperature problems
- hs-55 jerky
- Multiplex Micro IPD receiver and helicopter use
- Programmer Ship Date
- Double failure HS 325HB servos
- Hitec Optic 6 6-Channel Tx & Spectra Module
- Multiplex Connectors
- delete
- Hitec Eclipse 7-Channel QPCM
- HiTec Rx 750 mAh NiMH pack
- Spectra Module
- Optic stick gymbals gone stiff
- Optic 6 - SW 2 "ON" position
- Question about Hitec crystal?
- 5945 servos discontinued?
- Electron 6 Instructions
- Servo Suggestion for Helicopter use
- Do my new 475 servos have Karbonite gears?
- 5955TG servos @ 6V
- Base load antenna
- Hitec Micro 05S Receviver Auto Shift??
- Programmer version
- 5945 gears
- Programmer problem
- Antena
- question about Flash 5 throttle programming
- problems utilizing 8th channel on an 8 channel Hitec Receiver
- Laser 4 FM V-tail and elevon?
- WHEN are programmers going to be available!!
- 5997 vs 5955
- Optic 6 case broken
- Hitec Digital "Break in"
- amplified y harness on 2 HS-5645?
- HS 85BB servo loading
- Flaperons with Hitec (glider)
- Electron 6 question
- Hitec Servo Programmer...
- hitec servo suggestion
- hitec 56xx digitals and other pcm receivers
- Tx power for sim
- JR 652 needs Rx for Giant Stinger & Quadra
- Eclipse 7 and CCPM Questions
- Hitec Eclipse 7 problem...help me please
- 5955 and loc-tite?
- 5945 centering issue
- Optic 6 - Quits Transmitting Occassionaly
- Prism 7X help
- Are there any plans for a heli tail servo?
- Tx module
- deleted
- hitec reciever antennea
- hitec 5745mg & mpex rhino
- Y opto-isolator location
- Hitec 5475MG servo burnt out
- RCD Master Onboard Multi-mix 9210 help
- O5S Receiver won't work with Futaba 9Z?
- 5945 (included servo arms question)
- HFP-10 Programmer Question
- Hitec Supreme interference problems
- Flaps for Optic 6 in SW4?
- Hitec programmer
- Mixing Digital(356450) with regular(645MG Servos
- HITEC ChallengerTX module
- Hitec programmer software upgrade
- HS 805bb Mega Servo question
- Hitec Digitals and Futaba PCM
- HITEC SERVICE!!
- Chenging Eclipse To Ground from Air
- Mike Mayberry: Xtal exchange which never happened!
- 5955TG
- FMS cable for Eclipse 7 Spectra
- Did I screw up a 5945 ???
- 5955 servos
