- Hitec 5625?
- beginner radio?
- Will a Futaba buddy trainer cord work between a Flash 5 and a Flash 4?
- Hitech RCD3200 Reviever and crystal dont work
- Gyro Servo
- Servo Arm Compatability
- questions on the Flash 5
- Need help setting up a dual Elevator servo mixing.
- 5645's and y-harness not working
- hitec 5945
- Output Shaft Dimensions on Hitec 5735
- Shift Selectable RX 3800
- Reversing Digital servos
- 225BB Problems
- Soldering servo extentions for 5945's.
- Hitec on 6 meters?
- 5925's, slop in gear train
- 225MG holding power
- 50MHz support?
- Repair in europe?
- Differential aileron throw on a Flash5X
- Hitec 555 receivers; repair process?
- Hitec servo jitter using 6 volt battery
- Troubleshooting
- What battery on GP Extra?
- Need an old AM receiver checked
- HS-5645MG Digital Super High Torque Servos
- Hitec Receiver (J) 8 channel - Battery Charging?
- Hitec Supreme Shift Select RCD 3800
- Need Help With Servo Programmer
- Flaps/ elevator mix
- Hs-645mg?
- Which Hitec digi's for 80" Staudacher?
- eclipse-feather glitching
- Eclipse throttle curve help
- 5245 servos
- RCD 3800 setup
- Trainer Cord Compatability
- POwer Bus or not
- Crow feature
- Prism 7
- 5x
- Hitec Spectrum Module in Futaba 9C
- 545 -> 525
- R Aileron (ch1) won't go up?????
- Flash 5 and flapperons
- Info on HS 205?
- Better that than a JR single conversion
- New Hitec website now on-line
- Hi-Tec Eclipse Fut J?
- Where to buy RX Xtal
- Hitec Servos
- Where to get the HFP-10
- Thanks for the presentation to our club!
- What's hitecs stand on receiver channel changes??
- Where to send.
- Earth to Mike ,come in MIKE .......
- Does Hitec make Megatech's Radio Equipment?
- Tx battery connector
- servo wandering
- repair a hitec hs-55? gears?
- 605 Centering issue
- HS-5645 unresponsive on Y harness
- New "Mini 555" Receiver
- prism 7
- Mini Digital
- Hitec Rocks!!
- Thread size of metal geared servos
- Digital Servo Failure...
- Battery connector Prism 7X
- Hitech Spectra Xmtr
- Hitec MG 605
- HS5945 noise
- 5125mg
- Eclipse Throttle Lock?
- Eclipse and Gyro
- Spectra Module Repair/Maintenance
- Universal 7 Shift Select
- 605 question
- Hitec 625 servo acting strange
- Using Hitec Trainer Cord
- 5625's 5645's
- My Spectra has Sprung!
- Mike, Supreme 8 vs. Super Slim 8?
- dual elevator servos
- Consequences of exceeding servo rated values
- hitec 5645 digitals
- Hitec Piezo Gyro
- What should receiver do when transmitter is off?
- Erratic servo behavor with extensions. Please help Mike.
- Digital Servo Specifications - Already Answered!
- Charging transmitter with CG 340 charger
- TX Crystal
- Mike, Please bolster my confidence.
- nice picture Mike
- Trainer cord set up, JR to Hitec?
- Hitec Master 7
- HS-605's
- 5945 servo problem
- Diamond Dust + 225mgs?
- 5945 output gear
- Help?? Hitec / Futaba buddy boxes
- Hitec servos for use in Helicopters?
- Toledo show
- Servo's buzzing not under load
- 5735 Question
- hITEC 5625'S
- Centering on Digitals
- Hitec / Airtronics compatibility
- Servo's keep stripping gears
- water logged equipment
- Flash 5 and flaperons
- Which servos for which planes?
- 605 Centering and Resolution
- Hitec GY130 & gain control problems
- 90* CCPM for Eclipse
- :confused:
- hitec 225 nylon vs metal gears
- Eclipse 7 and Airtronics RX's
- "xp8103 - The 303's are made for the car market. The 300's and every other Hitec serv
- Flash / Prism "X" - Whats the "X" mean ?
- READ THIS! IMPORTANT! New dedicated Hitec Support forum
