- Flaps
- Pico transmitter
- Programming Question 7955
- Hitec 645 MG Servo Failure?
- Optima 9 receiver SPC port
- Hitec HG-5000 gyro drifts
- AURORA TX. BATTERY PACK.
- Recommendation for HD servo?
- HITEC SOFTWARE UPDATES.
- HITEC FREE 7 CH. RECEIVER.
- PROGRAMING DIGITAL SERVOS
- Hitec 5998tg 5997tg
- Need version 1.40 of the data manager for Royal Evo
- Dual receiver set-up Optima 9
- PROGRAMMING STANDARD DIGITAL SERVOS
- Erratic Hitec Throttle Servo
- Boda antenna
- Hitec Optima 2.4 RX batteries??
- Help! - Radio problems in flight
- Aurora 9 chg adapter
- Aurora9 throtle->elevator Mix.
- 10x 2.4 module
- SRX Pro vs. CRX
- Brand New Aurora 9 - Deffective rudder stick and LCD
- Latency in Elevator Halves
- Linking Optima 2.4 Question
- Eclipse 7 trouble with 2.4 module
- Spectra pro - Late April!! ***?!!
- Using Dual Receivers with Hitec 2.4Ghz AFHSS
- Aurora 9 Receiver Battery Voltage Indicator
- Hitec 2.4 with Futaba TX
- Direct Update to 1.8?
- Eclipse 7 back cover
- Hitec Aurora 9 - can't turn on radio
- RF Synthesizer andupgrade for Royal Evo 9
- Questions about Optima 6 & 7 receivers
- New aurora 9 - question
- HS-5985MG Resistor Change for R6014FS
- Aurora 9 Bind question
- HS-5665MH and HS 5685MH servos
- Restrictive movement of two identical Hitec servos
- hp-22 offer aplicable
- FREE HTEC 7CH.RX.
- Hitec Auora 9 Died HELP
- Unanswered question
- Do i need to update my HFP-10?
- HS-85MG servo arm screw size?
- AURORA 9 and Variable pich prop program
- Optic 6 SPORT 2.4 and Zebra 4FM 35MHz
- 7955 and 7950 question
- Aurora 9 Firmware update and Optima 9 receivers
- Cleaning my Multiplex radios
- Aurora 9 charge socket issue
- Aurora 9 72MHz Module
- Aileron duel rate switch
- replacement 2.4ghz aerials
- Throttle lock switch odd behavior
- Trim Lever Tension
- New Aurora 9 User - Minimum Receiver Voltage
- Hitec HFP-10 V 1.03 will work on todays HS5625MG?
- servo failure
- Aurora 9 and opti kill
- 2.4 Module and Difference between 7 channel and 9 Channel Receiver Questions
- HPP-22 Receipt
- Hitec Optic 6 / aileron setup / shutdown
- got 4 hs-5645mg Sloppy right out of the box
- HSD-09RQ Freedom Rx Failsafe
- Hitec Optic 6 / BH Stuka / flap setup
- HPP-21 Overload
- hpp-22 receiver problem
- update question
- HS-5085MG for Standard Servo?
- ? about HPP-22 Interface
- Aurora 9 Firmware upgrade issue
- Specs on HS-5496MH & HS-5495BH
- Hitec CG-340 potensial problem?
- Hitec Spectra 2.4 module blue blinking LED
- Intermitant blue module light when servos are use
- Futaba 3004 Servos / Optima 9 and 7?
- Optima Rx's and cold weather problems
- Telemetry - Blue
- Aurora 9 Problems
- Battery charge question for TX
- Replacement gears for HS-7940TH?
- Servo Resolution
- Antenna coil replace
- Optima Antenna Re-enforcement
- Binding Aurora 9 and Optic 6 to same plane?
- Aurora 9 J1, 2, 3 and 4 functions
- Optic 6 linux device driver
- Aurora 9 throttle servo??
- A9 flap- elevator programming
- Multiplex Micro-IPD 7 channel receiver
- Aurora 9 HTS Telemetry - Fuel Sensor/Tach?
- Aurora 9 HTS telemetry not working
- Aurora 9 72Mhz and 2.4Ghz Module Swapping
- Aurora 9 switch replacement
- Optima 7 receiver ???
- Jitter/glitching on HS-7940TH 2S lipo direct
- hpp-22 update
- Gyro
- Hitec Aurora Telemetry speed/altitude reading bug.
- HS 5084 MG servo voltage
- Sport 6 has no model nameing only #
- micro 5 channel RX's
- aurora 9
- Aurora 9 trainer rig?
- Which radios can Hitec Aurora 9 buddy box to?
- The "jitter "contnues
- Hitec Digital Servo Programming
- Telemetry Not Working
- Servos for 100cc Yak
- RX battery included?
- Telemetry System finally Here!
- Hitec Aurora 9CH 2.4
- Hitec 81 MG servos
- Throttle Hold
- servos getting hot
- mutiplex twin jet
- Sorry, posted in wrong forum!
- Unsure of Binding sequence between Normal and Scan mode:
- latest version of EVO data manager
- Optic 6 freez up
- Different behavior after Converting Evo 9 to 2.4Ghz using Spectra module
- HS 7954 SERVOS
- Servo jitter after installing Optima 7 rx.
- optic 6 antenna issue
- Does Hitec Aurora 9 have the 72mhz module yet? I'm waiting.
- Freedom 9s Rx
- Electric Rotowing
- RX battery with Hitec 2.4
- HS 7966 servo
- Aurora 9 2.4 system
- aurora 9 battery
- Telemetry... How much longer??
- Hitec Aurora 9CH 2.4 manuel book
- Will SPC port get mess up
- Basic questions regarding conversion of old 8UAP
- Reversing a HS-55
- Fried Eclipse 7
- Aurora tension on the sticks
- Hitec A9 Transmitter Antenna Modification...
- boda antenna holder
- Lost Switch Lever
- 1.07 Upgrade
- Careful when tightening your gimbal springs on the A9
- Aurora 9 and servo jitter
- What's wrong with my A9?
- Aurora Programing
- Replacement BODA antennas
- BODA antenna
- Eclipse 7 /Spectra 72 pin connection issues
- Resetting count down timer 2
- New Optima 7 RX with pigtail?
- Servo Programmer question
- Aurora 9 trainer cord.
- burned 5955´s replacements
- Spectra and Optima update question
- New Aurora 9 battery problem... maybe??
- Can the Aurora 9....
- Servo jitter
- Hitec A9 and receiver for park flyer????
- Aurora 9 transmitter firmware upgrading connections and procedure ?
- Just looking for confirmation about LIFESource batteries
- Faulty Eclipse 7 no stick control
- 2.4GHz Promotional Module Exchange
- Optic 6 using all 6 Channels
- Aurora 9 Tx battery toast?
- Aurora 9 Optima 7 receiver Install
- hpp-22 and spectra 2.4 upgrade question
- Trimming Out Twin Motors on an Aurora 9
- Aurora 9 and Optima 9
- Spectra 2.4 Tx module compatible with 9Z?
- 7985 Servo Question
- Aurora 9 with Optima Rx Brown out Q&A - Rx 4 or 5cell??
- Spectra antenna problem
- 2.4 module for JR radios
- Hitec digital servos, and two questions on using them...
- 2.4 antennae adaptor question??
- Where are the receiver's
- Spectra 2.4 blue led flash and Beep
- Any plans for 2.4Ghz micro receiver?
- Antena problem, Optic 6, 72Mhz
- Hitec Spectra Module compatability wit Futaba 9c?
- A9 flap control?
- 2.4 Upgrade Kit
- oPTIC 6 -72 MG OR 2.4
- Servo case
- HS75BB HELP NEEDED
- Hi Tec Opti 672 mhg
- 985MG top gear
- hitec 422 servo installation
- Multiplex Evo with Gy401 gyro
- Optic 6 Range?
- A9 Stick tension
- Hitec Aurora 9 slider problem
- Eclipse 7 Spectra
- which servo to get
- 5955 & 7955. Are they 1024 or 2048?
- ***** NEW**** Hitec Joe Nall 2011 video
- Optima 9 receiver missing beeps
- HPP-22 interface
- Aurora 9 -Dead Trim slider?
- Aurora 9 and Swashplate Phasing
- A9 Trim Step
- Linking Hitec Aurora 9 with Reflex XTR Sim
- upgrading to 2.4 ghz
- Using servo arm w/ bracket for ailerons?
- Installing Airwild servo arms?
- A9 cut off voltage
- "Optic 6" big problem
- HPD-O7RH Reciever
- 2.4 module for JR
- hitec 2.4 TX module
- HS 65MG question
- 2.4 Ghz question
- Aurora 9 Throttle Up - Throttle Curve
- Hitec Optic 6 2.4GHz
- Question about repair
- RRS System
- Powersafe RXs and HS7950 servos
- Hitec 605BB servo gears??
- hitec version of F 9254?
- optic 6 4 ch receiver programming?
- Optima 7
- 7955TG servo buzz
- Now what - part 2
- Now what??
- HS 5065 servo arm screw thread.
- Optic 6 Programming assistance needed
- Aurora9 Fail Safe
- Optima receiver power consumption and a HUGE thanks to Mike Mayberry
- Hitec Eclipse 7
- Aurora 9 - Toledo Symposium
- 2.4 and li.ion battiese
- Multiplex Royal Pro: Expo, D/R and trim
- eclipse dual elevator function
- Trouble with brand new Optic 6
- Tx battery voltage drops in brand new Optic 6 2.4 Ghz
- Hitec eclipse 7 issues
- Optic 6 programing problems
- Aurora 9 telemetry
- delete
- Transmitter/Recievers
- MPX Hitech 2.4 compatability
- Max Voltage
- Hitec Optic 6 battery cover.
- Aurora 9 swash calibration
- coupon rx's
- Aurora and Mode 1.
