PDA
View Full Version : Hitec/MultiPlex Radios- Ask Hitec Customer Service
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. HS-645MG Centering with FUTABA RX/TX
  2. Hitec Spectra 2.4GHz Module in my EVO and JR
  3. Hitec Neon-SS FM
  4. hitec aurora 9
  5. Hs 5645 MG
  6. Hitec HS625 MG compitablity
  7. Optic 6
  8. Mike - more Aurora screen shots please
  9. HS 605 & 645 max voltage
  10. Hi_tec Crystal Availablity
  11. MPX 3030 Heli Programming
  12. Optic 6 idle on
  13. Off to the Electric Flight Expo in Phoenix!
  14. royal evo pro
  15. Glitchy Receiver
  16. My servo
  17. Using Spektrum and XPS modules in Aurora
  18. hitec 2.4ghz reseiver compatiblity?
  19. Eclipse 7 with Futaba GY401 problem
  20. Optic 6 loss of control
  21. 2.4 module Corona with Eclipse7 Hitec
  22. is the flat fee gone?
  23. Hitec Flash 4 Sudden Prob Ch1 and Edit/Save Access
  24. RX problems
  25. Hitec HS-7955TG hum
  26. New style transmitter
  27. Servo Recommendation for 25% Edge
  28. eclipse 7 sailplane flightconditions?
  29. Flaperon and channel 5-weird behavior
  30. Flash 5X trainer cord adapter???
  31. Update on Optic6 with spectra module?
  32. Hitec Servo's / Futaba Servo Horns
  33. RX problems
  34. Receiver battery
  35. HPP-21 Help with Centering
  36. hitec 625 servos
  37. Measuring Pulse Width
  38. Why use a Digital Servo Programmer?
  39. stall current of hitec digitals
  40. Micro 535 vs 555
  41. HPF 20 Questions
  42. Upper Voltage Spec for Supreme IIS
  43. Hitec 7940 and 7950. lithium polymer ready?
  44. Futaba spectrum and Hitec compatibility?
  45. Full charge li-ion
  46. Hitec HS-5945 and HS-5985 Question
  47. Hitec Supreme IIS Comaptibility with Futaba S3107 Micro servos?
  48. hitec7955tg small noise
  49. Multiplex Products- 2.4 Ghz
  50. Aurora 9 radio
  51. Spectra module
  52. Which crystals??
  53. eclipse 7 timer
  54. 5645 servo gear replacement
  55. HS311 Question
  56. 5955 VS 7955 phenomenon
  57. Hitec DCX crystals
  58. EVO/Profi Tx Crystals
  59. HFP-20
  60. HS-7975HB Servo Problem
  61. Eclipse trainer problem
  62. are these supposed to work together?
  63. HS 645 MG Servo Horns offset
  64. Hitec Spectra -RCD4400 - Using with Futaba
  65. 7985MG degree of rotation
  66. Royal Evo 9 upgrade to pro
  67. 7985MG on unregulated A123 battery
  68. Hitec Laser 6 troubles
  69. Prism 7x dual elevator setup?
  70. Prism 7x dual elevator setup?
  71. Hitec Eclipse wirings
  72. 2.4Ghz Master with 72Mhz trainer box
  73. FASST signal voltage compatability
  74. Sending in HiTec servos for checkup?
  75. Hi tec servos not getting full travel
  76. Optic 6 Sport 36MHz not communicating with synth receivers
  77. Optic vs Optic sport
  78. Servo voltage
  79. HPP 21 plus availability
  80. Eclipse 7 and ESC's
  81. 75BB Help, please
  82. Why no 2.4GHz SS?
  83. HS-5485 question
  84. Servo Buzzing questions?
  85. Optic 6 battery problem?
  86. Neutron 6S constant beep ?
  87. Hitec Power Mate II dummy load
  88. hitec 7950tg
  89. numbers on the side of the servo
  90. HS-7955TG servo saver
  91. HPP-21 plus PC
  92. Hitec HFD-08RD
  93. Help....Optic 6 and Spektrum
  94. Hitec 545 high torque servos
  95. Multiplex PICO line Manual
  96. HS 5475 HB servo - High Pitch sound?
  97. Hitec Servo advertisement - nice job
  98. HS5625mg
  99. Thinking of getting a new radio
  100. replacing 5625 gears with nonmetal ?
  101. HPP or HFP ?
  102. 5945mg servos
  103. Running transmitter with external 12v battery?
  104. assigning negative values n decimal values, examples -3 degrees, 16.5 deg in the pitch curve settin
  105. MPX 5645MG voltage issue with Futaba R6014FS receiver?
  106. Throtle Servo Problem
  107. HS-65MG question (concern?)
  108. Thank you HiTec
  109. sevromix on MPX 4000
  110. 5625 servos locks up
  111. programmer
  112. What servos can I use?
  113. 7955 servo
  114. Servo's for Top Flite Gold Edition "63 P47D
  115. What to do for 25% planes
  116. Does TX dictates single or dual conversion ??
  117. Deadband for HS-5645
  118. battery cover
  119. servo reversal
  120. Multiplex EVO radios in the US.....
  121. Optic Switch trainer switch problem?
  122. Freedom 9S vs gas engine/glow engine
  123. Hitec neon
  124. 2.4 Ghz from Multiplex in 2009
  125. 625MG for a 1/4 scale ??
  126. Optic 6 System Timer Question
  127. ? Eclipse 7
  128. How do I find the servo center point?
  129. Which channel controls which function?
  130. Problem Programming HS-5645 Servos
  131. EVO Recall
  132. hitec servo on tamiya
  133. Radio Troubles
  134. HS225&125 with Fasst RX6014?
  135. Power useage 5995 TG's
  136. Eclipse 7 QPCM( NO MORE problem)
  137. Optic 6 Timer Beep Volume
  138. Operation travel HS 7955TG G2???
  139. Servo's in the exhaust stream.......
  140. Optic 6 Easy Question
  141. Flash 5 Problem
  142. 645mg servo
  143. What Is This?
  144. Eclipse 7 Glitch or Ground?
  145. Help....Synth DX setup...no manual
  146. HS-475 vs HS-5475 Specifications
  147. HS475-HB broken output shaft
  148. Is HS645MG/HS5645MG ok with FASST 6/7/8 ch RX
  149. HS-5085MG case and gearset
  150. Questions about Hitec Eclipse 7
  151. hitec eclipse 7
  152. NEW Hitec 9 Channel Tx Does anybody if and when it will be available
  153. Receiver Crystal for hitec Micro 555
  154. HG-5000 gyro combo pack, cant select proper servo
  155. EVO 12 - PROGRAMING RESOURCES
  156. Mulitex EVO case
  157. Royal Evo 9 servo reversing issue, please help
  158. 7955 Question.
  159. I have a XTAL compatability prob
  160. faulty receiver Hitec Neutron 6S
  161. 1/4 scale servos
  162. Royal Evo 12 & 12 DS IPD Issue
  163. HITEC Karbonite to Metal gear Upgrade
  164. HS 645 MG failure
  165. Eclipse 7 problem
  166. Nicked wire on a HS-965MG
  167. Hitec 645 Output shaft/servo arm
  168. HS 75BB Retract servo failures
  169. Hitec 605MG Gear Set
  170. HFP-10 upgrade
  171. HS-5965MG Servo problem?
  172. HS-5645 Centering
  173. optic 6 IDLE ON
  174. Radio serial number
  175. Need Help Identifying Former Product Line
  176. Charging NiMh batteries in Hitec Ranger II N
  177. Hitec Freedom 9, has anyone tried to program this new receiver?
  178. LiPos
  179. Loctite?
  180. 5955tg refurbish
  181. Binding two models on same TX
  182. Hitec 7955TG version
  183. Hitec 6965
  184. single vs. dual conversion receiver crystals
  185. Hitec 7955 overload question
  186. Question about the new 7955TG servo
  187. Flap Setup Help
  188. Eclipse with spectra module glitchn
  189. Multiplex Questions
  190. Hitec 605BB servo question
  191. Hitech HS-6985HB servos
  192. delete
  193. :( plugged in battery, reverse polerity :'(
  194. Simple question
  195. Laser 6 & HFD08RO
  196. New Multiplex USA website on-line.
  197. 5955 meltdown
  198. Could the heat be causing a glitch with my Flash 5X?
  199. Convert a HS225BB to HS 225MG?
  200. Issues with Mini6S
  201. 7955TG work with lower signal voltages?
  202. HS-475HB flutter w/ servo reverser
  203. EVO 9 pulse width
  204. Hitec Eclipse 7
  205. Eclipse 7
  206. Hitech Eclipse 7 up in smoke
  207. Mixing JR and HiTec.
  208. Hitec Eclipse 7 Program for RES Sailplane
  209. HS-45HB Strong enough?
  210. HS525BB servo servo horn
  211. USA ROYALevo recall
  212. HITEC 2.4
  213. Setting endpoint/centerpoint using HFP-20 or programmable Tx
  214. Deadband setting for ganged 7955 servos
  215. HFP-20
  216. output signal voltage of 2.7 volts
  217. HS-645MG Issues
  218. Optic 6 receiver compatibility. Please Help!
  219. Different Versions 5955 For Same Surface?
  220. Hi Tech Receiver for Sailplane
  221. antenna lenght
  222. Hitec 5955 boot speed Question
  223. Multipex radiosWarning!!
  224. Metal replacement gears for HS-5475HB
  225. HFP-10 and centering
  226. Optic 6 screen failure
  227. Optic 6 screen failure
  228. Extensions
  229. Hitec HS-81MG
  230. HS-7955TG overload question
  231. Hitec Radio Issue after using a simulator cord! plz help!!
  232. Service Question
  233. Multiplex harness
  234. Eclipse 7 and 4 servo wing
  235. Optic 6 Idle on on model memory 1
  236. Optic 6 for Piper J-3 CUB 1/4 scale
  237. Hitec 5945 centering issues.
  238. Hitec (servos) Here I Come!
  239. Problems with Hitec 5955 TG Digital Servo
  240. Optic 6 tx walkera rx?
  241. lynx 3d battery and tray
  242. Spread spectrum radios
  243. Why the odd size for screws on MG servos?
  244. Hitec EZX-R
  245. Sport Lynx Transmitter Goes Full Throttle All the Time
  246. Eclipse spectra 7
  247. Throttle curve on Optic6,.. for plane
  248. Faster Servo
  249. eclipse 7 no response
  250. Optic 6 looses its sense of direction
