View Full Version : Glow Engines
- OS 91 Surpass 4 stroke what fuel?
- Engine for a .25 trainer
- Break-in Prop For Enya 50cx
- New moki 2.1 vs old moki 2.1
- McCulloch muffler
- US41 problems
- diff. betwen new/old card 3216-mvvs ??
- mvvs manual wanted .49
- Asp 1.08 Redhead
- ball bearings
- How quiet is Slimline Pitts style muffler?
- Os 120 Older Non Surpass
- OS FS40 idle help
- Saito 100 White Box?
- Spinner for Enya 45 CX?
- Disassembly of OS Surpass II
- engine hard to start
- What tha???
- how do I break in a TT pro 46??
- Maloney 100
- Ok engine gooroos.... I need some info please
- Inverted engine and oil content
- Can anyone id this engine?
- saito 120 shaft size?
- Things to come
- Saito 182 Twin vs OS 160 Twin?
- Pusher
- Enya 40 X, MODEL # 6101 no compression
- Enya R1.55 Tuning Question
- What plug Webra 120
- ST 46 Muffler
- Anyone know the OS .32F?
- Prop drive washer for MDS .68 Heli
- Saito 1.70r3
- Help with Super Tiger 3000
- oil to gas mixture-help
- Piston and sleeve - O.S. 46FX
- Surpass II valve clearance specs
- Need help on cleaning solution
- Saito FA-65 and First 4-stroke questions
- Camparision Chart-all Engine
- MDS engine experts: I can't tune this .48?
- "Practical Range" engine specs, What does it mean??
- anti-vibe mount
- 60X Pitts Muffler
- Saito 1.50 fuel tubing
- Saito Question
- Replacing Bearings
- first engine questions
- Technical Glow Engine Book
- os .12 cv-rx
- FP airbleed type carbs. Is there a replacement?
- Fule tank must be level with fule jet?
- Saito .72 to OS 61FX to 91FX
- Using Diesels for RC Planes ?
- older .40 magnum engine spits out fuel, need help!
- Engine Tuning Question
- bubbles in fuel line
- Anyone using MDS 38 heli engine??
- 91FX prop shaft length & other
- OS 40FS, Cline or Perry?
- Hobbico Torqmaster 90. Is it REALLY only good for up to .90 engines?
- What engine for 54 inch WS plane?
- New st G90 report
- 90-4c compression
- 4 stroke break in
- os 91sx-h for pattern
- engine mt for saito 100
- Italian Aero Engine Builders,WHO!!!!
- OS .40 LA Break In - Oil from Exhaust
- new engine 4 a diamond tea
- Hot starting a moki 1.80
- fueling system - hands free ?
- Irvine 53 Carb Problem
- Are all large (1.60-1.80) Glow Engines the Same?
- Exhaust designed "too well"...
- What online dealer sells Irvine engines?
- New Tower .76 engine - too tight to start
- OS 1.08FSR vs Magnum 1.08FSR?
- Burping OS 32SX
- Enya .80 FS cam timing
- I want my TT Pro .46
- Best prop for ASP120FS ?
- Nostalgia
- 120 Surpass mods
- saito .91 and dave brown mount
- enya 35x idle speed adjust screw
- Prop for 45 CX?
- 300 cc, 240 mph, giant scale pylon racing
- Max speed from an OS15LA???
- OS 61 four stroke in a Pilot Christen Eagle
- Kawasaki engine for pitts special
- Where to purchase Thunder Tiger parts Online?
- Saito 90 Valve Failure?
- SaitoS or SKG
- YS 140:Is the DuBro Fuel Tank OK?
- Gas or Glow on a large DC-3
- OPINION .61 ASP,LEO, MAGNUM Engines
- Opinion: 46, Asp,leo,magnum !!
- O.S. Sirius 5 cylinder radial
- I am not an idiot! (or, Me and my RCV)
- .25 opinions
- R/C Carb for Super Tigre X40
- Which engine for Taube 40 ?
- Saito 150
- Is she going to blow up!!!! Saito 150 Problems
- saito 72 after break in Q
- Magnum 52 XLS
- Irvine 53 Muffler
- YS .91 Fuel Lines
- Props on saito .56?
- YS 91 vs. Puerto Rico Climate
- Opion of value of Maloney 125 engine new from 1986
- Fox Castings
- mufflers
- Prop for an Irvine .53
- 2 vers- 4 Stroke
- Question about TT GP .15 Engine
- New Guy Wondering Which Engine
- Enya 35 SS Heli
- Prop nut size?
- Saito 100 break in settings?
- CHANGING OLD VALVE SPRINGS MAKES BIG DIF.
- Fox Customer Service
- mvvs 77 carb info needed please
- Leaning out high speed idle on Saito 100
- Engine test stand extra muffling
- needle setting info needed
- ROSSI ENGINES
- Starters
- Manual for Saito 91GK
- Enya .049-II TV
- Help anyone have os 40/45fsr, asp 40, irvine 40,
- R/c Radial
- Anyone using the new MDS .58?
- Supertigre G-90 fuel question
- Help!!!!!! Engine for kyosho gee bee Z
- Webra speed .52 heli - Airplane muffler?
- Magnum 75 specs?
- Macs Quiet tuned pipe & muffled tuned pipe
- OS 160 and 3 blade prop
- What do I use to remove engine Varnish
- Supertigre V60 information?
- What is The Hottest Best Performing ENYA Marine??
- Will an OS header fit a YS 140 motor?
- dave brown adapter on 4 sroke
- pre ignition question
- Saito 91
- where to buy moki engines in hungary or italy
- inverted O.S. 1.20 Surpass II question
- Is this Normal?
- Help! macs header dimensions
- JB quik vs. JB weld
- ABC liner/piston for OS 61 FSR
- Repairing engine flanges
- is the asp 40 anygood?
- Saito 56 won't idle down
- Matching engine to plane
- Saito 120 help please
- Engine Storage
- Sluggish Thunder Tiger 46 Pro
- HELP IRVINE SPORT 61 FROM THE 80's
- Need A Muffler For My .60
- os 50 sx
- Slimline Pitts & Saito 180
- Saito FA 90T
- WHATS THE RIGHT .21 FOR MY TMAXX
- Bearings
- Will this work?
- supertigre 3000 fuel delivery?
- O.S. 48/52 surpass
- gearboxes for engines?
- S Tigre 45 vs OS 46 FX ??
- Reverse rotation for an Enya .80 four stroke
- OS FX .61 Heli Head
- Question about an OS 40 FS Surpass
- Mvvs Engines .40 & .49
- less engines cmpression-not starting
- OS max 91 four stroke...no power or compression
- Nova Rossi and O.S. questions.................
- New test on 61's in M.A.N.
- os .46fx-h tunning
- ABC or ring
- Which Fox should I get
- Flawed carburetor on my Magnum 1.08
- Can I Use A Du Bro Kwik Fill Valve With An OS 91 Surpass II Pumper?
- mounting engine on stick
- After RUN Oil Starrett M1 works??
- ThunderTiger Pro 120, ABC or Ring?
- YS engine evolution?
- Thunder Tiger 120 2stk
- Saito 325 5 raidal
- Enya 46-4c
- wanted: McCoy.29 fuel & needle valve assembly
- Engine Wont Richen!
- who has the best buy on Saito's
- Twin & multi cylinder forum
- st40
- Prop Reamer
- How do you tune a Tuned pipe???
- Brake In for OS .40LA
- enya 120 four stroke Pitts muffler?
- Need Some Help Jeff
- K&B Newer 2-stroke`s .48 & .61 Anygood??
- Supercharger
- Supercharger
- Supercharger
- Dual Glowplugs
- Tuned Pipe YS 45
- Leo and Tiger Shark engines
- Moki parts???!!
- Moki 2.1 Bisson Muffler
- webra 120 bully
- Arresti cooling...
- How much difference between TT engines...
- O.S. .46 FX - which piston and sleeve?
- ABC or RING ...???
- Please Help!!!!!!!!!!!!!!!!!
- aluminum spinner on 4 stroke
- webra 120 motor mount
- OS 1.40 prop
- R-155 /idle difficulty
- Ideal prop and tank size for a Moki 1.8
- STILL can any one help finding leo engines
- Cline Regulator - Inverted Saito 100
- Thunder Tiger 54s help needed
- Irvine .53 vs. osmax46fx
- Webra 145 - R
- Royal-45
- L@@k CRANKS? Right?
- Enya 45 Carb to intake ring seal
- 3 bladed prop for saito 100
- saito gk80 needs pump?
- what size 3 bladed prop for 1.60 fx
- Help!!!!!!
- os 1.40 rx efi
- TARTAN engines
- Saito 1.50/ APC prop trouble???
- Idle RPM and full power RPM - OS FS 52 Surpass
- Best engine for Sig SE?
- OS 20 FS question
- Help with .61 FX Idling
- HELP!!! Prop suggestions for Supertigre G-90
- os 70 fs or webra 50?
- Plug, prop & fuel for TT GP-07 engine?
- TT GP-07 plug, fuel, & prop recommendations?
- Question for the experts..
- Saito 72 compression
