View Full Version : Glow Engines
- Universal Remote Needle Valve??
- 4 strk Newb! Help identify parts
- Do not call Horizon Hobbies for MDS support
- prop recommenadtion for YS-FZ110
- 4ccm Pipe for 7,5ccm Engine ?
- Where to find a Pitts Style Muffer for 90 fsr?
- O.S Gemini 300 owners
- trouble starting GS40
- os 40fx ringed &46fx ringed-crank case is same
- saito 180 timing adjustment
- what engine is better?
- Saito 100 12 oz tank question
- Webra 160 bearings solution
- few ?? about saito .91
- What engine should I get!?
- Thunder Tiger pro .46
- webra bully????????
- Saito Carburetor Throttle Arm Came Off
- OS Gemini 1.6
- Magnum 70 4 stroke and APC 13x8???
- OS 120 W/Pump
- Saito 120 squealing problems?
- Tower (GMS) muffler on ST or TT 46?
- YS Engine - Please help
- pm what about 15X5?
- Engine quits at high RPM
- Webra 1.20 Problems
- In-tank fuel line
- Moki 135 pipe?
- The Best 4 Stroke Glow Fuel!
- Saito 72 Carb Settings
- Saito 100
- saito 450 radial performance
- Magnum XLS 52a
- ST s 2000/25 questions
- 2 Stroke vs 4 Stroke in TF Nobler
- 3 blade prop for .46 FX
- MAGNUM 91RFS 4stoke owners !!!
- OS 46 SF CARB TO OS FX QUESTION
- Old Saito 120 engine
- OS 1.60 FX - What prop, What RPM's?
- saito 130 twin
- Patrick Mokis
- Does a Super Tigre GS-40 fit in a Dave Brown Mount?
- SAITO 100, OS SURPASS 91, SAITO 91???
- Engine experts opinion required
- 4-Stroke exhaust threads... proper care?
- can't get max RPM
- Saito 4 stroke - How remove prop drive flange
- Ultrathrust or tuned pipe?
- Scimitar Propps?
- WHAT SAITO FOR SIG KADET SENIOR ARF
- Source for OS max FS 61 manual?
- Sovents for cleaning glow
- Hanger9 J3Piper cub (arf) with MDS 148 combo
- WHICH IS BETTER, THE SUPER TIGER G-34 OR THUNDER TIGER 36?
- Flex header qustion
- Anyone run an inverted TT GP 42?
- RCV120SP
- Break In With Perry Pump OS 61FX
- bad saito 100?????
- Nitro Content VS. Longevity
- the most powerful .21 buggy engine on the market
- Running saito 100 WITHOUT MUFFLER
- inverted 4 stoke engines
- OS fx 1.60
- What engine for a VF 540 Edge?
- Learning all the time
- Saito or YS engines.
- supretiger/como .61
- OS 25FX Transition
- cheap OS wankel rotary glow plugs
- Tuning the OS 160FX
- Dont need after run oil if you use morgans fuels?
- OS61FS Valve Springs
- Opinions on OS 32 SX
- 4 stroke perry pump
- os 120 lll w/pump
- ST g90 and Mac's tuned pipe???
- OS >15 pipe question
- Wooden engine mount plastic style?
- Cleaning after a crash
- Where do I to attach a pressure fitting on "sport scale" muffler?
- Dead point on the Piston?
- anouther ops .67 question
- Need new engine for CG Ultimate Bipe
- My 160 FX Problem
- OPS .67 rebuild problems
- OS FX 46 WITH PITTS MUFFLER QUESTION
- What after run oil for a YS engine?
- SH .28 ROTO START / XLB
- .60 engine in a .60 warbird?
- How does Super Tigre G-2300 run inverted w/ BCM Pitts muffler?
- FL-70 vs. FS-70 OS 4 Strokes
- RCV Service Center
- tuned exaust on 4 stroke
- os 1.60 2 stroke
- Cold Blooded OS 50 SX
- Saito 82a Reverse running?
- Magnum Customer Service?
- site to purchase perry carb?
- asp .75
- OS Gemini FT120 cam timing
- ADJUSTING VALVES ON OS61FS
- Saito 82a Tach issues
- Super Tigre's First Run!
- Super Tiger muffler
- Pitts Muffler for Magnum Pro .45
- hangar 9 4 stoke glow plug
- Will a pitts style motor for an OS 61SF work on a 91FX?
- Spinners that fit props?
- Super Tigre G-51 vs. Magnum XLS-51
- 2- YS 63 FZ-S Questions
- Older Fox .40's
- K&B Engine help
- I need a needle valve *help!!*
- Two old engines...help!! Please!!
- Aresti engine mounted upside down help.
- Saito .91 tuning question
- DPM MOKI 2.10 Prop ?'s
- Where to buy a header for 40 la?
- os 61 engine identification??
- Will glow plugs go bad with age?
- Aero Engine Choice?
- Engine won't quite start
- saito 82 and ys 63 dimensions for PA Edge 540
- Wrap-Around Pitts for G4500?
- Front bearing leak in Magnum 46 pro se...What to do?
- YS 4-stroke header threads
- Is ASP the same as a Magnum engine ?
- What Do You Know About HB Drone 61 Motors????
- Super Tigre G 2300..Compare to OS 160 ?
- g-51 and .46 pro
- MOKI ENGINES
- FOX 4 Stroke Miracle Plug
- MOVED: THROTTLE KILL FOR TWIN ENGINE
- YS 160DZ or 140DZ
- YS 63FZ hard to start
- FUEL REGULATOR ON A SAITO 270 ????
- OS Max 90 2-stroke
- OS91FX
- Magnum 91 2-Stroke Head Gasket
- Saito 82 Low End Idle Screw STOCK setting?
- To owners of ASP 46 and 52 'S' and TT 46 Pro
- Saito 80 Power Loss
- Inverted Engine Installation ?
- o.s. .46 la(natural)
- prop for magnum 91 rfs
- Thunder Tiger
- YS .53
- RPM range for Saito 180 w/ 18x6 prop
- Saito 91 Fuel Tank Location
- Magnum .91 fs weight
- MVVS .49
- Engine Surging
- I did it!... finally brazed aluminum
- Biggest Engine for APC 8.75x7.75 props?
- ran a four strokefour stroke engines
- Thunder Tiger 120 Tank ?
- YS 1.10
- Mag 52 4-strokes on sale
- GS40 leaning out midflight. what to do?
- Saito 65
- New SAITO .82 what prop for 3D,,,,
- SuperTigre GS-40 Ringed
- Saito Muffler Manifold
- ASP Super series 52
- OS .61 FX Quits upon throttle advancement
- strap on muffler for Webra 91 speed
- Cox Pee wee 0.020
- Idle Bar Glo Plugs Advantages ...Disadvantages..???
- Glow Engines have a 15 hour life?
- .50sx break in ?
- saito 91 bearing change help
- Saito 72 glow plugs?
- Saito 72
- Which Pitts-style .61 muffler?
- Need Help with Saito 120 !!!
- YS 45 Rear Exhaust
- YS Engine question
- Saito 180 Carb Rebuild Help
- Saito.82 Low Speed Needle - Break-in Setting
- who makes the best muffler for quite runnin
- Saito 82 F.S. Questions
- Enya 60 4C manual??
- MAS vs APC Props
- Putting engine back together...precautions??
- Mecoa .46 specs?
- Saito 72 tear down help
- Smallest engine ever
- ST G90 fuel
- Super Tiger 75
- ASP .21 Engine
- MVVS .45
- OS 1.60 woes (with perry pump even)
- engine question, please help
- Which Webra do I have?
- Prop nut woes with Enya 90 FS
- which engine, 32-40?
- 4-STROKE engine is equivelent to what 2-stroke
- moki 1.8 thrust
- Enya engines and after market mufflers
- *OS .46 & Magnum .46 Comparison*
- 4-stroke newbie
- Thunder Tiger 36 Pro Carb/Mixture Problem
- O.S. Ultimate .70
- Ys & Saito Pricing in Japan
- Merry Christmas To Everyone!!
- Evo 46 major help needed
- Thunder Tiger 120 Pro W/Pump
- Old engine help
- Saito 180 props
- Super Tigre G2300! Help!
- Webra 50 GT Break in
- Older Saito 120 out of moth balls
- Whats best 70 size four stroke at cheapest price?
- Coldweather starting
- Magnum 70 4s wont idle below 4000 rpm
- Super Tigre 4500 problem....Help!
- Saito 100 props...
- after run oil in 4 strokes?
- saito 82 carb mounting
- OS FL-70 Problems
- Using car engines in planes?
- OS 160 Gemini - muffler set up?
- Magnum 400 Radial
- Anyone flying RCV 58 four strokes?
- Vibration Isolation Engine Mounts
- Saito .91... No compression
- OS 61FX help
- Italian supertigres still in circulation?
- Carburator's for Webra .61 Silverline
- One way valve for inverted engine
- FL-70 & Seagull Spacewalker II
- SAITO 100 OR THUNDER TIGER 91 4 STROKE
- Cold weather and glow engines?
- Magnum 70fs spitting
- Novarossi-50
- What is the best kept engine secret in RC?
- Norvel .15 tuning?
- Moki 2.1 thrust
- Props
- AP wasp .061 any good?
- 4*60 engine
- help me pick: OS46FX/AX, OS50SX, EVO46
- sait0 150 two plugs
- Obvious Air Leak
- feasible? Modified ducted fan by cutting down prop...
- Du-Bro Qwik Fill
- Rhino gas convertated to glow 140
