View Full Version : Glow Engines
- Saito 100 cam cover screws
- os fs 120 parts
- magnum xl-180-ar /comparison to moki 1.80
- Saito 450r backfires
- 4 Stroke Mixture Concern!!
- I need help
- RC-Bearings Company
- Is it normal...
- 3 blade vs 2 blade props
- New Moki 1.35, need help
- O.S. 45F Ringed?
- Picco 80 FIRE
- Thunder Tiger Pro 1.20
- Super Tigre muffler internals
- Moki/Mark glow engines
- Thunder Tiger Fuel Line
- Can I use RTV to seal the Carb on OS 55AX?
- 1/2 A Classic Engine Parts Needed
- Classic 1/2 A Engine Parts Wanted
- WANTED SUPER TIGRE 75 FOR STATIC
- Mac's Products, no contact info?
- Fuel issues! (OS 4 stroke)
- Evolution Glow Engine Success Story
- Saito FA 90T bearings
- Too much prop stopping ENYA 60X ?
- O.S. FT 160 Gemini
- Webra 61 rear exhaust long stroke question
- Too much Clearance?
- Saito 150, Carb settings
- OS FS 40 Water cooled?
- Magnum/ASP 108
- ST G75, OK Motor?
- enlarging holes for muffler/header question
- Highest RPM engine
- OS crankcase ventilation upgrade
- Muffler fell off!
- Uniflow tank for old Saito
- Turbo Head Conversion Kit ???
- Seized Saito
- Rossi Muffler - what is this?
- Muffler length for ST G34?
- EVO 60 confusion
- magnum .45 Pro won't unwind
- anyone have a parts list for ST
- Post-crash clean up
- mc coy 19
- Parts for an OS 40FP engine?
- ST .61 TST Series X RE- Need Help!
- O.S fs81a
- OS91 Surpass II w/pump Mixture Adjustment Problem
- Thunder tiger 61
- Tower Engine Muffler
- McCoy Series 21 .35 Engine.. Parts?
- micromotul 2t
- Help!: need a measurement; Slimline Muffler
- Super Tigre S29....are they runners?
- cleaning rusty crank
- saito 82
- Super Tigre S90K question?
- OS FSA 110 Problem
- SUEVIA???
- Saito FA65 tuning low needle
- How to Plumb a 4-stroke
- Crashed enya 90 4C
- Lucky Crash
- Irvine engines made by OS
- saito question please:
- Looking for OS FS 120 SI OR II Crankshaft
- Magnum engine
- Place to Buy Parts for Engines
- Schillings 4-stroke
- enya 60X 7301
- Saito FA 90T twin cylinder engine question
- Webra 1.40
- Picco .40 muffler
- Max rpm for a ringed 90/91?
- 5 Cyl engine
- Glycol Temperature
- Rossi Muffler
- 4 stroke back fire
- Magnum 180 4-stroke
- OS LA 46 flame out issues
- Heads up! Supercharged OS120 going for peanuts in the classifieds!
- HP VT49 twin?
- Saito Gasket Question
- Too much engine??
- supertigre 61 muffler adj?
- 120A and 120AR ASP?
- What engine 2 or 4 stroke or gas for Dynaflite Super Decathlon
- ASP RADIAL 400 5R
- Does any one know the size of the rear...
- Rossi 90 Crankshaft?
- 35 year old Enya 09 - Brand new..
- Webra Speed 61 parts source
- Saito 120 Bearing Question
- Saito 150 Leaking Needle Valve
- Saito 100 vs 125
- SC 91 four stroke engine Help!!!
- What exactly is a O.S. #9 glowplug?
- Truble tuning a Webra 91
- Looking for timing numbers...
- Thread Size
- Stuck Crankcase Gaskets
- Saito 1.80
- ASP Engine availability?
- O.S. 5cylinder radial FR5-300
- Saito 100T
- K&B .65 SPORTSTER Question
- Clarence Lee
- TT .46 Pro w/ Perry VP30
- prop ?
- asp 52A vs 52 AII
- Saito 300 twin check valve?
- Thunder Tiger F-130S PROP PLEASE
- My take on Thunder Tigers
- Webra T4-60 : Man, I hate a dirty engine!
- 4 stroke mounting
- thunder tigers
- Glow driver
- Bearing for old OS 40
- Enya 4-C's
- Magnum 52 4 stroke XLFS52AR question please?
- Webra T4-40
- YS 110 Running poor in a slightly inverted position..HELP
- Overheating twin 4 stroke
- Evolution 67NX all running great?
- HP VT-21
- Glow plug patents and design
- Satio FA-100 exhaust plumbing questions
- (breatherless) new OS 4-strokes
- owners manual enya 90 4C
- Repair coil on glow plug
- McCoy 35
- Need OS SF "P" 61 Engine Box
- Older OS 1.20 Pumper
- Discolored OS Engine
- Saito 150 Help
- Mufflers with around 40mm bolt spacing?
- tiger shark 52 conn rod = JBA 56 rod?
- I'm beginning to love Enyas
- Magnum .10 ABC needle valve
- ID this engine
- What Engine Should i get?
- Norvel AX-.40 Owners
- Noise Abatement
- bubbles in fuel
- Old OS engine parts
- Broken Needle Valve Stem
- GP Reactor .46
- O.S. carb to fit Magnum .61 XLS
- new to building nitro engines
- Washing the exterior of a four stoke
- Saito 82 bent shaft...how to know?
- Is this a MVVS .49 or 8cc engine?
- Test stand running
- OS 61 Heli - Aircraft ?
- OS 120
- Super Tiger carb guru's...
- Moki 2.1
- Du-Bro Muff'l Aire Mufflers
- DZ170CDI on low nitro
- OS .21 Max RG parts needed..
- NIB Engines and care storing and care question please.
- Saito 450
- MDS 48
- ..magnetic valve pneumatic silencer...?
- Help!! ASP (Magnum) 91fs dies abruptly
- Need a carb screw for my ST G90
- Tuned pipe for 55AX ?
- Super Tigre Problems
- Best tyle of prop for 4 strokes?
- Como 51 ABC SCH
- OS 70FS/Magnum XL 70 Are The Dimensions The Same???
- WANTED! CAM COVER FOR PRE-SURPASS OS FS40
- can anybody give me an answer please.
- GMS 120
- Super Tigre 60 cc Twin . . . . ?
- TopFlite prop balancer...
- Saito FA-120R3 radial, who has one and in what plane?
- OS 46AX, or a ST G51?????
- Super tigre 3000 question please:
- Magnum 52XL 4-stroke valve leaks.
- Foam Fuel Tank Blanket
- Saito 100, fuel from Crankcase vent?
- Webra 50 GT
- GLOW PLUG RECYCLE PROGRAM , it figures
- TT .46Pro - trainer suggestion
- i need help
- RCV 58 CD engine problems
- Engine for a Patriot 40
- Magnum .91 4 stroke
- OS 1.60FX Pumped
- Saito Carb Screw / Spring Set
- Super Tigre G3250
- what prop for a Magnum FS-120?
- Thunder Tiger F-54S giving me a hard time!
- Old K&B 45
- Best fuel for a ST G90
- Evo 52 acting up
- Evolution break in?
- How much nitro will a 2 stroke take?
- Super Tigre S3000K Info Please !
- Cylinder/case seal?
- "Fuel/Line reducing couplings"....
- Perry Carb question..
- Saito 100 Throttle Barrel Not Closing
- O.S. 91FX exhaust options
- YS 63s run in?
- ASP 108A
- Can't unscrew muffler
- engine recomendation please:
- Fox Engine
- OS FS-62V
- Saito rocker screws the same?
- Bearings for OS on ebay
- diagnos engine behavior?
- super tigre G3250 inverted
- super tigre 90 question please:
- bubbles from pump
- super tigre carb parts s -3000
- Tuning with an extra head shim
- YS 140 stuck intake valve
- OS .61 FS
- Thunder Tiger 91 Problems ....
- BAD BEARINGS IN SAITOS
- Glow engine on gravel roads. Air Filter?
- OS 120 Ax
- OS 91FX in a Skybolt .60
- ASP 65 FOUR STROKE Cam Setting HELLLP
- Engine I.D.
- temp for a os 120
- help! help! Enya 40 cx
- Two to four bladed prop, how?
- Saito 220 FS fuel consumption
- .46 Megatech Engine Troubleshooting
- Cox Engine ID ...
- Graupner 3-Blade props
- YS 110 Extra 300S APC 14x9 - Need Spinner
- Enya 40BB Std. Muffler Needed
- MDS .46
- WONT IDLE
- BGX3500 spinner
- O.S. 55AX 3-blade prop size question
- Weak OS 75 AX - Maybe?
- ...unusual carb?
- bgx 3500
- Help needed, parts for an enya 90 4 stroke
- Help with Saito 91.s
- Enya 45SS (ring)
