View Full Version : Glow Engines
- Magnum 91 RFS inverted question
- Need some info from a YS 63 God, Please
- Glow plug question
- Moki 1.8 or 2.1 and Perry pump or Cline reg issue.
- MVVS casting question
- Irvine 72
- Filled Crank
- Saito 180 mufler preasure or not?
- Can lb's thrust be calculated from these figures
- Problem with fuel tank lines. Please help.
- Lost Prop Washer??????
- Tuned Pipe
- U-CAN-DO-3D After run oil, how?
- how do you tell if you have bad fuel
- OS 91fx fix
- Royal Engine Parts - Available?
- Squeaked my Moki 1.80
- MDS parts ?
- OS 50sx prop size
- Stripped out glo plug thread on Saito 100
- enya 120
- Magnum .52 4-stroke problem
- NEED INFO ON OS .15 CV-A
- Engine quits (after awhile)
- Lightweight-powerful .15-.25 suggestions please...
- Exhaust Deflectors for 4-stroke Advise
- magnum 91fs or OS 61fx?
- Saito owners, case vent waste ?
- .46 FXi deadsticks
- Irvine .53 vs. Webra Speed .50
- Running-In OS 46AX
- Mounting inverted
- At the risk of sounding totally stupid, I need to ask about needle settings
- Engine Recommendation for Sig 4Star 60
- Online stores that accept Paypal ?
- NEW SAITO 2.2
- TT91 FS Runs in Reverse
- Glow Engines
- ASP 91 - Fuel Mix?
- Engine Overheating?
- MVVS 1.20 twin
- Who is selling Seidel radial engines?
- Question on Enya 90 4C motor. Need help please.
- Big Saito and Cline/I.B. Regulator ??
- G-Mark .061 engine manual
- Magnum 52 Cam Timing?
- Help!! Gummed up engine
- TT 91 ROUGH MID-RANGE THROTTLE
- Norvel Big Mig .061
- proper way to put on a prop nut???
- YS 110 mufflers falling apart.
- NORVEL 25 CARB QUESTON
- Valve Adjustment
- Instructions OS
- What is the difference FA 150 (h) or (S) . Is there one?
- ST .51 muffler
- Mounting YS 120 FX ????
- OS FT120
- help with magnum pro 45
- Saito 150 muffler
- Magnum .46 XLS Question
- MDS 1.48&2.13 Users
- 4 stroke engine maintenance?
- perry pump o OS 61fx
- Saito .56 crankshaft splines for cam gear
- New jtech super tigre incowl muffler is very bad
- Laser Engines. Any one got experience
- Question 4 u Perry Pump/1.60 fx owners
- Need help on GMS .47
- Problem with ASP .46
- SAITO 100 - STILL NOT RUNNING
- os 108 fsr vs os 91 fx
- FAST WM MIDGIT MUSTANG
- which has more power
- 1.60 fx vs 1.40 rx
- muffler problems
- Engine temps: infrared temp guns, emisivity and anodized heads.
- Funnel to pressurize fuel tank
- Need advice for Power Increase in OS FX46.
- aftermarket muffler for mvvs.49
- OS 52 Prop
- Idle mixture screw .28 mag xl
- flyQuiet mufflers--worth it?
- Bump without glow plug, is it normal?
- plz. who can explain heli-coil?
- smallest prop for an enya .09?
- Help With reassembly of os50sx
- Converting Saito's three-cylinder radial to ignition
- Does anyone have a Moki 1.35?
- heli-coil insert
- Enya 240 Twin
- SAITO 100 IN SIG 4 STAR
- How do I reverse the carb/needle valve on Saito 82?
- information on Super Tigre 40
- Saito acting weird
- Moki 1.35
- Is it just the prop?
- INFO 2 stroke vs 4 stroke vs Gas
- Magnum Cylinder Head - 91 FS
- RCV .60
- Sirio 23
- Just engines sandown sale
- im looking for a .60 size engine
- Saito Velocity Stack and O-Rings
- Magnum 61 fs won't run
- ST G-51 + Pitts Muffler = Lack of Pressure?
- super tigre 40 g-21?
- Having trouble starting my engine.
- SAITO 100 CARB SETTINGS
- what is good aerobatic plane with satio 150..
- Cylindrical Fuel tank leaks.
- Evolution .61 NT transition issue.
- saito90 vs. magnum 90 ?
- OS 60FP question
- Webra engine service, WHO????
- Macs Heli Muffler an FX25
- Flooded engine
- Engine Identification
- SAITO ENGINE STOPPING
- Lightening a Moki 2.1 radial mount
- engine for nosen 40 size champ?
- Need to quiet down my Sport Jett 46
- Anyone ever . . .
- engine value ???
- Tower Hobbies .46BB
- Moki 2.10
- locking prop nuts
- OS .32 SPECS FOR J.M.
- carb problems
- OS .46LA sport prop selection
- FULL COMPLIMENT BEARING
- THRUST WASHER PULLER
- re-lubing my engine after washing
- Assistance with YS160
- OS 91 vent
- YS 110 surging problem solved!!
- TT .46 Pro Settings
- THUNDER TIGER 120 Please Help.
- saito 80T
- Saito 56 help with high speed needle.
- Want to buy YS .45 REAR EXHAUST
- ST G90K problems
- saito 1.80 prop? 3 blade
- O.S. 60FP Questions
- Saito vs YS
- HELP! I need a part...
- Just Need parts breakdown Thunder Tiger 25
- Problem (???) running in Saito 82
- YS regulator work
- Is my .049 ruined??
- tartan parts???
- 15x6 - OS 120 non pumped?
- Need engine advice
- Kyosho GX15-CRG Engine Problems!!
- OS 52 FS - breather nipple?
- OS 46 AX Break in procedure
- To OS300, or not to OS300, that is the question?
- Thunder Tiger 46 Bearings Size?
- Moki 2.1 owners, please help
- buy
- Magnum XLS 52 - A 'Hunk of Junk'?
- which pump
- rebuilding an OS 46/ringed engine
- Saito 100 Dies during spins
- Thunder Tiger 1.20
- Did I kill my OS 1.60?
- Replacing Bearings in OS 46AX
- GMS 1.20 on Pipe?
- Thunder tiger 91 4-stroke choke plate
- muffler problem
- super tigre X-40
- Rossi 40 Muffler
- OS 1.20 AX
- needle valve
- GMS Engine problem
- Enya 60 4 stroke (anyone)
- glow to electric equivalency
- Moderator please delete this thread
- I just had to check
- ASP 1.08 burning out glow plugs.
- tower .75 2 stroke engine
- Hobbsy - What were the results?
- jen 56 ringed?
- OS 46 SF ABC
- Older vs newer 4-stroke
- Cordless, spring-driven, wind-up starter
- OS carb for ST 4500
- SAITO 100 GK
- OS 140 rx idling problems
- Flexible Muffler problem
- OS .12TZ!!
- OS-FX or AX
- Saito 1.50 fuel question
- Saito 91s Rebuild question? bearings
- Dynamite mach .15 carb question
- fuel through low needle
- OS 160 FX 3D Prop!
- Jett 120 and Cline regulator
- GMS Engines!!!!!!!!!
- Warning to Evolution engine owners
- ABC PISTON MATERIAL
- 4-Blade Prop on a Moki 2.10??
- 2 cycle engines and nitro
- OS 91 FX with Pitts style muffler
- Case leaks?
- TT 91 FS Starting Problems
- Check valve on inverted 4-cycle breather update
- magnum 91 rfs drops thrust
- Saito FA-91 scale installation problem
- What caused this? Saito
- Fuel tank for OS 25LA
- OS bgx-1 3500
- Super Tiger 2500 or 3000???
- Which is stronger, OS FT-300 or Saito 300?
- Less revs with wooden props?
- Engine Mount for a YS 110
- Anyone try MAS GF3s
- ASP 400 radial
- Request: YS 45 rear exhaust dimensions / documentation
- Nose-Up problems & likely overheating
- New .47 GMS Engine squeaky
- Supertigre 90 Exhaust Extensions
- Handicap modifications.
- Is a Saito 100 FA a good choice to buy?
- Excellent service on Thunder Tiger 4-stroke
- Cline Regulator
- Who Makes The Best Four Stroke ?
- OPS RED HEAD
- Cleaning/flushing dirt/grit from crashed engine
- .75 2-stroke for 3D
- Royal 45 carb – similar to OS
- MVVS midrange
- enya 60 non pressurized
- Saito 91 rpms
- OS FL-70 idling problem
- GMS 2000 32s -- One Good, One Bad
- Engine Temp
- Super Tigre 3000
- I have never been able to get my YS 91 to run correctly.....help!
- Tower .40 ABC, OS .40FP Clone?
- Where can I buy a YS110?
- Saito 82a - Fuel or Oil Leak
- Ys 63 or saito 82?
- OS 61 FX Idle issue
- OS FS-120S-E
- YS 120 NC Supercharged.... FOUND FIX.....
- Need idea for glow plug socket
- OS .70SII exhaust options
- os 46 fx problems
- Enya .19 head screw size ?
