View Full Version : Glow Engines
- OS FS-91 Surpass II
- Cline Regulator with OS 46FX
- OS 91 4C
- TH 75 vibration problems ?
- help on asp outboard motor
- OS 55AX fuel question
- Super Tigre .90 Parts?
- installing a ring on a ringged engine
- measuring compression
- phase porting????
- suggestions on TH .75
- WANTED: ASP 160 Twin Manual
- Inverted installation for 2-Stroke engine
- deflector or no deflector
- Run Time
- which gives more power, Methanol or petrol?
- Other places for OS parts??
- Saito .72 plastic backplate reinforcement
- Motor Dies
- Glow Engine Dyno
- MOVED: Saito 220
- norvel 25 "review"
- Saito 180 with perry pump
- .81 alpha propeller for 3D.
- comparison of Saito 82a and the new Saito 82b
- EGT for Saito 300 twin
- Rossi.61 engine info please..!
- OS 75AX Cylinder Head Bolts
- Will this be enough Power!!
- 4-stroke eng. for cgb cub
- YS 110FZ best prop to start
- Trainer pipe
- A repost-Glow fuel & Walbro Carbs
- Slimline Q Series Muffler on OS 75AX
- Tuned pipe identification
- MVVS 40 GFSR piston scored to heck
- Tower .75 on 5% or FAI Fuel?
- MVVS 10cc black head
- FAI fuel
- parts for OS SF
- saito 125 running rich
- HOT!!! THUNDER TIGER F-91S
- Need Help: ASP FS 70 4 stroke
- Saito 100 won't quit running
- saito 115 problems
- Pusher Muffler
- ST-90K with Perry Pump
- ax 55 problems
- Moki 1.80 glow plug.
- 4 Stroke reverse
- Straight Header for Saito 65 GK
- Glow plug torque values
- Re: Welcome to Club Saito
- storing glow engine
- ASP FS61FSAR Four Stroke Glow Engine
- Cox Conquest .15
- MY CARB FLOODS >>>NEED HELP
- Taipan Glow Plugs
- Red grit?
- Magnum 1.20 Two Stroke Carb Modification
- Sputtering idle on OS 55AX.
- Will the cooling slits provide enough air flow for a 2 stroke?
- OS 7D Carb
- Magnum 28 running hot
- Enya Parts Available Anywhere?
- new to glow & engine ID ?s
- Bearing replacement for Saito .91
- SC 53 and couple of missing parts needed?
- Saito .82 Help....
- Super Tigre .51 Muffler ???
- OS EXHAUST VALVE SPRING SWAP
- Looking for GMS muffler extension
- Moki 1.80 detonation
- Picco Engine FIRE
- Magnum XLS 61
- SC FS52 Gasket???
- irvine
- O.S. Max-H 40 Help Please
- Saito FA-120S / Saito FA-125a differences?
- MVVS Brown head
- Picco .80 Piston and liner
- Simple On-Board glow
- Poor Idle From Bad Throttle Linkage
- YS 45 engine help
- cooling a pusher
- os 108 prop sizing
- Saito 72, intake manifold gasket,,,,,,
- OS .61 Four Stroke low end settings
- Need help with thunder tigre 4 stroke
- Avistar or Mark/moki 210???
- Engine Bogging Down
- Good, inexpensive replacement muffler for ST G-61?
- YS engines
- OS 25FX to Control line use
- Better ignition with CD Box save fuel??
- OS 46 AX Carb Question
- Magnum .52 FS - Messssy?
- Magnum 400 radial engine
- Anybody Manufacturing 50-70 Twin Cylinder?
- What to expect from a O.S 120 FS
- Unreliable engine
- Tower coupon for the OS FX .61
- YS 45 Muffler
- I want to see your fueling set up.
- Saito 180/Smoke question
- O.S. 120AX Breakin
- Need Help to find Moki 1.35 Spinner adapter
- Engine stops after aprox 45 sec's at max RPM
- Four stroke single vs twin cylinder power comparisons.
- Irvine OS Engines
- Engine for Sig KOBRA
- Engine for Sig Kougar
- Engine Gurus-An After Run Oil Question?????
- Newbie to 4 Cycle Engines - Need Recommendation
- Super Tigre 90K w/ Perry pump question?
- A WORD OF WARNING ABOUT OFF BRANDED ENGINES
- Royal .45 muffler bolts
- Is the SK50 the same as TS52? I need a TS52 Crank, where to get parts?
- OS 120 Surpass pump idle problem
- Old o.s.15r/c won't idle
- Problem with my magnum 15 2 stroke
- Saito 130 twin
- Best Break In Stand EVER
- Please help...
- Taylorcraft and Saito 300 twin
- Air Filter?
- Evolution 46 NX
- Comparing Tower 75 and Super Tigre G75
- OS 55ax with Perry pump...¿Is it possible?
- smoke coming out the top of my xtm28 motor
- OS61 Max SF
- magnum .91 fs
- 70 sz (heli eng)
- OS .45FS problems
- 3-bladed prop for an LA .15
- elliptical or pagoda roof burning chamber
- New design Saito 82
- Adjusting valves and rockers on Four strokes.
- Aviastar .46 mounting holes
- Magnum or ASP 4 stroke
- How to make a Saito 82 smoke
- best .40 sized engine
- Super Tigre 3250 Muffler?
- Super Tigre Question
- Spinner Nut question
- mistery in the plug
- Starting difficulties
- Saito 100FA
- Aircraft mousse can muffler question.
- Is this the new magnum 4 stroke?
- RCV 130 CD question
- HB 61 PDP ???
- OS FS-70 rebuild problem
- Thunderbolt 4stroke glow plugs
- ASP 91 won't hammer-head
- O.S.VR77 as a propellor motor.
- OS .61 SF Muffler Needed
- glow Plug thread repair
- Muffler for a RJL Kraft 61
- supertiger g 2300
- LEO Glow Engines/ .46 Aero..???
- Unknown long chamber pipe?
- Poll : Glow engines, Oil & Bearing Failures
- K&B .65 Sportster Idle
- Saito FA 120 nose seal ??
- Do I have an English or Japanese Irvine?
- O.S. 1.80 AX 2-stroke
- Uni-Flow engines
- SAITO 100 Run Up Issues
- Glow-plug taps - what we pay for the title...
- Aviastar carb swicth
- os 1.08fsr vs os ax120?
- SC Engines any good?
- Mac tuned pipe
- ASP 21 GOING CRAZY trying to find the propnut size and thread count??? HELP
- saito 125?
- OS91FS-II ignition knocking. Wrong fuel or prop?
- Tower 60 two stroke Problems
- Castor oil in fuel
- Magnum XLS 61?
- Merco 4 stroke??
- saito .65
- Thunder Tiger .15 glow plug
- OS MAX H60F GP, Use it or not?
- Throttle Arm for FS-91 Surpass II?
- Overheat or Lean?
- Old Engines, Gummed Up / Rust
- Os 160 tank size
- Looking for manual Magnum XL-15A
- Found some problems with TT F-75s
- BME CAP Maniac
- OS 61 VR going lean
- .72 and .91 Saito owners, what are your idle rpms??
- Rossi engine
- Engine parts needed
- engine cleaner?
- ys 110........
- Which propeller for OS 55 AX
- FS91SII no start???
- Nelson LS
- GMS overheating engine
- Repairing an OS 46 AX
- Evolution (EVOE 100) Tuning
- YS63 metal shavings
- Webra 120 High Speed Needle Valve
- Are Laser engines in UK out of business?
- another OS120 SurpIII question
- Carburetor questions
- Main diference APC vs Master Airscrew
- OS26fs Q's
- Gemini FT-120 problems
- APS .46 teardown
- DIY ON-BOARD GLOW SYSTEM THAT WORKS
- OS 120 AX
- MDS 48 FS
- Saito 100
- Has anyone changed bearings in an RCV 90 SP?
- Saito 62a (Pics),DESTROYED...!!!!
- OS FS91SII FI TOP END CUTS OUT
- What vibration does...
- help with new saito FA115
- Where To Buy Rossi And Pipe?
- OS FS-70 ULTIMATE Pump Question
- Saito FA-120s Identification
- Thunder Tiger Pro 46 or OS Max 46 AX????
- OS1.60FX fuel system
- Saito 180 with issues
- OS 120Surpass III carb
- Muffler adapter for super tigre 2300
- O.S. 55AX vs. 61FX?
- What RPM should I see with a Saito 150
- Saito 82 Four Stroke Idle Problem
- Need to replace push rod tube-Saito 82
- Places to buy Magnum engine parts?
- supertigre gs 40 low compression
- Considerations on FL-70
- Pock Marks on Cylinder Head
- can sripped threads in muffler be repaired?
- Going to YS, I'm done with Saito
- Irvine .25 ABC MkIII - CAN'T GET TO SPEED
- YS 63S - Owners Final Needle Settings
- Saito 1.25 or YS-F 1.20
- Saito 450 3-Cyl Fuel Consumption & Reliability?
- Ring installation
- APC prop Constants (Pé's Spreadsheet)
- Low run time ringed engine sat for years, all gummed up, what to do?
- Are these piston and cylider toasted?
- MDS engines
- Post Places to buy strait mentahnol in your area
- Moki 180 problems!
