View Full Version : Glow Engines
- Saito 72 rpm figures
- Need input on Mackay engines
- Best brand of prop for 1.08
- what's the best 25 range 2stroke for a twin application
- YS- 45SE what pipe?
- How did I go so wrong tuning my Webra 1.20
- Supertiger G61 problems.
- Frustrating midrange! HELP!
- Need some help here guys!!!!!
- What Kind Of Glow Plug Do I Use?
- OS 46FX low speed trouble
- Engine Troubles. Help desperately needed!
- Rossi 45's dying
- Irvine 53 or YS 45?
- magnum xl80fsr dementions
- Picco airplane engine parts? anywhere?
- towerhobbies muffler. YAHOOOOOO!
- Does electroplating have to be done in sulfuric?
- YS Lovers - YS-110!
- Enya 90-4C valve adjustment
- main needle sticking
- 90-4 stroke parts list
- LEO .37 - Where to get
- Tuning an OS .91 FX engine - having problems.
- Looking for info on GMS 1.20
- TT 91 turns same prop 2000 rpm over sato 91?
- Old Enya motor
- Four strokes and tank position
- Max RPM limits on 4 strokes
- 2 Stroke Muffler
- New remote needle valve Magnum XL 46 for $40 ?
- O S 120 Surpass II Pumped Engine
- Tower Hobbies .61
- For multi-cylinder lovers - 46 size V-4 and 61 size V-6
- Pulled the Saito 56..put in the 72
- Need help plumbing 4/stroke with pump
- Looking for advice on a good .91 2-str.
- HELP - 4 Stroke Throttle-Carb Linkage
- Pitts Mufflers
- Enya 90 4 stroke prop nut
- tt46 pro needle setting
- Saito 65
- Webra .32 carb problems
- Irvine .53, now what fuel
- OS SX .50 vs MVVS .49 vs ?????
- Need to Identify engine
- What is the best .46 BB Engine Buy?
- Smoke system for a YS 63
- Several questions: OS vs Supertigre 40-60 range
- Enya 60s
- Breaking in new Super Tiger abc 61
- OS 1.08 running hot, thoughts
- Rossi vs Jett
- Who sells YS 45s online?
- New...
- Saito 180 Fuel Mixture Question
- YS fuel system setup
- 46fx too much engine for 4*40?
- #3W-50I engine starting problem
- Engine mount choices for Irvine .53?
- OS .46 FX - Weak?
- OS 1.20 muffler install in the GP Ryan....
- Will a RB Concepts X12T fit in a FT RC10GT?
- Irvine .53 carb question
- New 3W vs DA 100
- Long-Term "Pickling" of Engines
- how much
- Engine/Prop Question(s)
- Who makes best soft mount for 120 2stroke?
- Megatech/Leo, Magnum
- Odd sized SuperTigre
- Enya 60, low-end tuning , need advice!!
- G-45 blues
- Backplate on O.S. La.25 LEAKS!!!
- TT .91 break-in
- OS 1.60FX props?
- OS 1.60FX props?
- How can you accurately measure downthrust, right thrust?
- availability and support
- Who has the deals on the Big YS's?? Best Street Prices!
- OS 50 13.4k rpm
- Help !!! Super Tiger .90 Set Up
- OS 160 FX/fuel tank level Help Needed
- Question for Saito 150 Users
- Saito 150, what fuel should I use and diving idling going up and down
- Major Saito 150 Problem
- Chinese Engines ?
- Irvine warrantee?
- Saito FA-100 post 2 Gallons
- Powerhouse .60?
- Chinese Super Tigre
- Magnum 46 XLS clicks at top
- Engine Mount choices for YS 140 L ?
- RCS 1.4 pitts or tuner pipe muffler????
- Major prob! TH .46 drop in rpm after dirt nap!
- Webra/West .50 ??
- Rossi breakin? help!
- tuning per temp change
- TurboJett in cowl muffler?
- Dead Sticking on 4 stroke - need advice.
- ST 75 Problem
- SuperTiger 75 Ring
- Where to buy ys engine in europe
- another T.T. 120 problem
- Saito 72 Question
- Pipe for Irvine 53?
- ASP 120 4c
- After-run oil substitute
- uproar 60 with 91 four stroke
- Where do I start to build a tune pipe for an AP engine
- OS 70 Surpass Valve Clearance??
- 90 degree header for an OS 120 FS Surpass III ?
- Engine Recommendation
- Valve Sticking on a OS 61 FS :(
- Graupner Showflier
- Super Jett .50 or Quikee Jett 40 ??
- Engine Epoxy
- OS 1.08 fuel
- Norvel 25 Problems
- If Your YS-91 runs horrible!
- Saito 150 RPMs
- Please vote for the "Multi-Engine" page
- piston stopper
- Been awhile!
- Os 10 Fp
- cox Med 09 needle valve and spring
- Glow conversion??
- Seems right place
- Smoke System on G62
- Breakin In A Moki 180 on a H9 Cap 232
- OS 40FP needs more power
- Rcs 140 - Best Of The Lot ????
- Back Plate nipple in Saito 91 ?
- timing Saito 91
- Novarossi top TN12 S1
- 91 engines
- Best and most powerful .48 -- .53 ?
- Prop for a Super Tiger 90
- Engine Choice....
- Super Tigre 90 in stock
- Mvvs .91 Props
- TT 120 PRO problems
- 46la exhaust
- Where's the cheapest place to buy a DA-100?
- Help with carb settings (inverted)
- Running small 4strokes inverted?
- asp 65 4stroke
- saito 56
- Frustrated with my Saito 72...Help!
- 4 stroke or 2 stroke
- Need help with a YS 63
- Best glow plug for a mvvs 49
- best 2 stroke 4 US60?
- GP .40 size Ultimate, engine recommendations
- K&B .40 Muffler screws
- Enya 50 CX and pipe?
- Enya engine specs???
- OS 120 Surpass III rpm with 16 X 8 APC
- First 4-stroke - Saito 100 - do I need a glow driver?
- Surging YS 120F
- Irvine 46 MKIII ?
- Irvine 53 vs. Tower Hobbies 46
- Moki 1.35 fuel problem
- RCS 1.4 and 1.8
- YS 91 FZ Valve Adjustment
- Cline Regulator
- Webra silverline 40
- Enya 60 4-stroke
- converted ryobi 31 on telemaster
- OS46&Tower Muffler
- Best props for OS 70 FS
- Exhaust direction
- K&B 60 engine
- O.S. .70 Surpass II ?
- Whats the point of a fourstroke, anyway?
- Magnum 120rfs Four Stroke Muffler Problem
- Enya 90-4c
- Moki 1.8 VS BGX 1 ??
- Saito 150 new, problems setting it up , please help
- which one is better
- TT GP .42 break in and other questions.
- Porting HELP..Please.Emergency
- Rossi 45 muffler
- Fuel pump or Muffler pressure to tank, or both? ...What to do?
- Maybe A Stupid Newbie Question
- Users of GMS engines post a message
- What's small but stronger than a Saito 180?
- OS40FX Cuts out only at Full Throttle?!?!
- YS 61RF
- What is the best glow plug for Moki 1.8?
- Turbocharger or Blower
- Static Thrust and ThrustHP
- What size tank for an OS 1.20 pumper?
- Four strokes, cam timing, and fuel economy
- Drilling out prop for Satio 72
- saito blew apart
- MDS Engine problems
- changing fuel?
- Help!! Os 48fs initial carb settings
- Os 91 Fx Rpm/props
- Problem with Saito 72 Quitting in Flight
- Irvine .53...geesh!
- What has more power, YS120 or Moki135?
- Enya 80 four stroke
- Leo 37
- Enya 1.55 and Laser 1.50
- OPS Monza Sport
- Piston Reset Tool for .010 and .020
- webra/bolly 1.20
- Saito 180 spray bar question?
- i Need help choosing a motor!
- Best Prop for irvine 1.5
- Address needed for Saito online manuals
- Best hovering or torque rolling prop for a Saito 91?
- .91 1.08 1.20
- Perry pump...
- Best YS 61 Prop
- ST 91 carb Switch
- glow plug for TT GP 25
- YS 140 L and what fuel tank size ?
- OS 160FX - Will it SMOKE well?
- Questions on Irvine .53
- Why some LA Engines run good and some bad?
- OS 91 Fix
- Irvine .53 Break In
- what is the factory setting for the OS 46 FX mixture controle needle
- exploded case
- GP Ryan/OS 120 pumped engine owners need only reply
- YS Engine with pitts muffler?
- Thristy Saito 100
- Problems with OS 50 SX-H
- Successor to Supertigre?
- OS120 FS, how much is it worth?
- Small glow to a fan unit?
- Magnum XL 32A
- Any thoughts on this engine?
- Enya 35 SS
- 4 stroke engines maintenance
- Asp32??
- Muffler for TT GP42?
- problem os.25fsr
- Changing Prop Length?
- Remove baffles from muffler or not?
- fuel tubing diameter
- RCV-90sp
- fuel tubing
- Why is my piston pitted?
- Ys-91fz Info Please
- Engine weight comparison
