View Full Version : Glow Engines
- Hard starting Moki 1.8
- YS 110 thread size
- Eagle .46 engine ???
- Os 40 La
- saito 150 trouble
- OS 48 Surpass
- Saito .72 run in?
- My idle problem.
- Super Tigre
- Hp .40 Help!!!
- Mounting OS 52
- Where do you get TT parts?
- MVVS .49 Carb problems
- Saito .72 Question
- OS 48 surpass, what plane?
- Fuel pumps
- OS 120 II inverted ? Help !
- ys-91 ac
- Fuel Tank Placement
- Como Engines
- Os 46 Fx Crankcase Replacement
- Pitts style muffler for Rossi 40/45/53 what fits
- Saito 91 prop
- Engine for Mustang 60 size
- Magnum 4-Strokers
- Engines: Ringed Versus ABC
- magnum 46 xls
- Enya #3 vs OS-f or YS plug in YS 91.
- help!!!!
- Mds 2.18
- Help, ENGINE PROBLEMS!
- Breaking in new Rossi .53 HELP!
- Is this enough right thrust?
- PERRY REGULATOR PUMP
- What size prop on a OS 91 on a 60 size chipmunk
- modifying pitts exaust for a inverted 2stroke
- Engine exhaust gasket question
- Engine problem
- mvvs 77
- ys 140 L
- Got some 6 yr old Satios w/internal carbon build-up . . .
- Magnum XLS91A, OS Max 91FX, or Saito FA-100?
- OSvs Super tiger
- MDS .61 prop size
- Kline Regulator
- First fight after new sleeve & piston-46LA
- Hiness Inline Two-stroke
- carb screw size??
- Needle Valve clip broke ???
- O.S. 40LA High Throttle inconsistant
- Mds 40 Fs Pro ...good Or Bad?
- Moki 2.10
- OS 91 Surpass 11 Reg Parts
- Yezzzz! ST-90 @ 9200rpm 14x10, 79 DB
- Anyone tried pump for a Saito 300?
- Does anyone know how to time RCV engines?
- K&B 40 Glow plug?
- OS 50 SX problem
- ys120 question fuel line positions
- Mecoa engines
- Muffler
- TT.54 4-strokes
- Magnum Summer Sale
- Irvine .46 MK III Woes
- Thunder Tiger engine parts?
- Where do you break in/Run your new engines?
- Os 70 Fs
- OS 7D carb on ST 90??
- ******busted Fuel Tank*******
- .61 fsr question
- Evolution .46 or .61 NT??
- What to do with crankcase vent?
- TT .46 Pro Tips & Tricks?
- Engine YS Or Saito
- OS 1.20 surpass 2 pumper question
- O-ring between carb and crankcase on TT46
- Brass deteriorated in tank
- fuel tank location?
- .49 Engine Run Times
- Used slightly Abused OS 160 Is it Worth it opinions Wanted!
- OS 160 twin 3 blade prop size
- Once again low speed adjustments
- YS 140S or YS140L?
- What engine is this ?
- Novarossi .50cf on Sig's King Kobra?
- Mag .28 Carb Fix?
- Help : MVVS 1.6 Glow
- GMS.47 & Tower Hobbies .46 interchageable part's
- Plz help identify this Ross Engine
- lowdown on YS .45?
- Enya 40 Model 6002
- jett 50 fuel
- Enya 50cx Break in
- Thunder Tiger F-91S exploded view ?
- engine rebuilding
- YS .53 vs Saito .65
- old "os" 45 engine help
- norvel engine opinions.
- OS 160 w osc pump pressure or not
- Belt reduction drives
- OS 46 FX problems
- Satio 65 carb adjustment
- Super Tigre .51 Carb setting
- GMS Really did it
- Help adjusting Super tiger slow speed mix control
- Help! Irvine .53 assembly question
- I think I need a new Piston & Sleeve
- Old Saito 120 carb setup
- 20/20 fuel question
- Engine tune
- Don Harris smoke muffler
- Prop sizes for small Diesels?
- Moki 180 Fuel and prop?????
- Fa90t
- Saito 100, muffler snapped off
- 14X5 to much prop for supertiger 61 ?
- Replacement for OS.91 -2s/4s?
- Spinner balancing
- buying cheap engines
- Burning Glow Plugs
- Saito 100 - Gummed up valve, WHY?
- Mufflers for Magnum 180 AR Two Stroke Engine
- sell or keep my ).S. 91 II with pump???
- asp engines?distributor
- Drill Start. Is it safe for your engine?
- saito muffler problems
- MVVS .49 or Rossi .45 or Irvine .53 or Webra .50
- rossi 65,60
- Picco Engines?
- OS40FP Idle Problems
- OS 120 III Surpass regulator question
- Magnum 1.80 engine....
- Will a pitts style muffler designed for Os 61 fx work with TT PRO 61?
- Mounting Engine: Inverted vs. 8 Oclock ?
- Moki 2.10 PROP EXTENSION
- What prop for OS .46 FX?
- Help with K&B please!
- Another Head Gasket on the Dingo
- Saito 100 Pitts Muffler
- Help Engine Trouble!
- Engine testing
- Low end needle on old K&B 40
- FS-52 Surpass -- ENuff Engine???
- OS FS cam questions
- ASp 61 Plug Problems.
- need help tuning gms 76
- Engine filled with water
- Seized rear bearing
- .46 fx fuel line problem
- GMS 76 ring
- Sirio .18 engine, Fantom .18, or Wasp .18 engine for the T-MAXX?
- Help with YS FZ110
- Need engine re-worked
- webra 50 or os 46fx
- enya 120 muffler
- mod 6002
- con rod end play
- Saito 72 low idle
- norvel .25
- Please Delete
- Engine mount same for Moki 1.8 to 2.1??
- Enya 45 CX weight?
- Webra Engine problem
- YS-what is the idle rpm suppose to be?
- What engine...
- OS 70 Surpass 2 Question
- Pitts muffler installation
- Help, Carb and Engine have turned Grey
- XP Fuel
- OS BS-1 run in and starting help
- Throttle on Carb
- os91 to big for shrouh
- Magnum XLS 52 settings
- Runt time on 11oz tank/ saito.72?
- TT39 versus OS32
- I'm new, do I have a good engine?
- Need pro 45 & XL 40 Carb!!!!!
- OS 61rfp
- Irvine 53 Blowing Plugs---HELP!
- Os 61 Rfp
- YS on the test stand vs in the plane?
- Parts for OS FS61 - Carb and Intake Man
- Breaking in a new Saito 65 (help)
- Engine Idle problem fixed
- pumper carbs for glow
- Saito 100 fuel consumption help !!
- DarZeelon in the Hospital
- OS 160FX Help Needed
- Enya 50
- Moki still too hot?
- MVVS 91 Vs. OS fx 91
- piston-ring replacement
- TT 46 Pro bearing question
- sirio 3.0
- Saito 120 Restrictor Plate?
- YS 63 prop
- odonnel racing fuel ok for aero engine?
- planet hobby
- Asp Fs80ar
- Idle Problems Please Help!!!
- head shims to boost comp.
- MDS 1.48 Anyone know anything about it?
- Ys .53
- Kyosha Cub and Saito 45
- ys after run oil
- OS91 FX and tuned pipe
- Info for FR5-300 and/or FA-325R5D
- 60XL-F questions
- Saito Muffler wont stay on
- need some help!
- Force .15
- Tuned Pipes??
- OS 40 4-STROKE have enough power for this plane
- Irvine 39 ABC
- Tower Hobbies .46 BB Engine....Opinions??
- Magnum 91 Muffler Upgrade-Help!!!
- SuperTigre 90
- Super Tiger 60 Broken, need help
- OS 46 FX loosing power after repair
- Enya 60X
- Norvel .40???
- Enya 60X .60
- Saito 100 vibration help
- rcv 4 stroke engines?
- My new Saito 150...what the *%&$#@!
- Which engine....
- HELP I've craked my engine
- Prop Phasing
- Something extra engine
- Rossi Mini Pipe broke down in the sky
- Engine Won't Start
- OK, can you identify this engine
- Moki 2.10 Weak? Bambula 20/8 6500 RPM
- What sized 3-blade prop for a 91 4C?
- YS Trouble, HELP!
- Saito 150FS propeller?
- Thrust in pounds?
- Irvine 61 Prop
- TT Pro46 too rich in mid
- YS 91 problem
- Moki 2.10 will not idle down.
- which .46
- TT 46 Issues
- Engine wont run upsidedown
- Moki 1.8 sucking air?
- O.s. && Vrdf
- OS 61SFH carb
- Help running a OS FT-160 twin
- Fox Hawk .60
