- diesel what to look for
- Stuka an other conversion on the way
- gms .47/ fox .25 to diesel???
- Rib-it!
- Figures
- Super Tigre 3000
- New plane
- Enya 4 strk diesel again
- Compression sensitivity and ether %
- 3 more Davis heads
- K&B 1.00
- need a engine for my J3 piper cub
- Home for my OS40AX davis conversiion
- PAW 60 review article in Stunt News ?
- P.A.W. Diesels
- Need some conversion heads?
- Modela 2cc
- A most pleasant conversation...
- OS FP40 DDD conversion venturi size?
- Enya 06D
- Got more heads
- Show and tell
- Rustler list and prices.
- A diesel powered airplane
- Replacing PAW ball bearings?
- Diesel engine availability
- experiment with glow/kerosene mix
- Diesel head conversion?
- I would like some info....
- I feel like a Newbie again...
- Tartan 1.34 run.
- Direct Injected UAV Diesel Engine
- Paw mounting bolts.
- OS 160 Conversion
- SE5 electric comversion to diesel
- TT10 convwersion on the way
- Are there any...
- Build your own coversion
- SK.90 conversion head?
- MVVS 3090 Diesel .61
- MVVS .49 and Irvine .53
- MVVS 09 back in service
- Saturn 2.5cc Diesel
- OS 1.20 AX head
- Leaky Irvine
- MVVS screw
- Convertering the OS 61 to pure diesel engine
- Bio Diesel using soybean oil
- RJL Diesel conversion head
- Sharma 09 paw Muffler
- lawnmower's converted to 4 stroke diesel
- Diesel Engine in R/C Stadium Truck
- New Engine
- My first diesel should be........
- OSAX120 heads
- Your first Diesel powered model...
- Who was it?
- Royal 40
- Who is the moderator of this forum?
- Update to this forum
- Enya cx11D
- Fiesler storch as a diesel??
- Norvel diesel again
- Your Input is Welcome!
- Why did the diesel thread get moved?
- MOVED: Substitute for Ether
- Super Tigre G90 Davis conversion
- OS55AX
- norvel 074
- PTFE ( Teflon ) as a contra piston.
- rtin
- Help me pick an engine for this Cox diesel head
- dieael Ladybug??
- Photo upload fixed
- OS46AX Davis head
- MVVS .49 and AJ head
- Diesel Basics (get to know diesel)
- Jen 56 and TS56 heads
- Kolibri 0.8
- OS46 diesel conversion
- Clean-up fluid - nice stuff
- Diesel hot rod
- Diesel float plane
- Davis Diesel Cox conversion
- New PAW 35 - seems tight?
- davis new heads
- Any body know what the .40 RJL head fits?
- Best 40 diesel conversion value
- PAW .60 vs MVVS .60 comparo.
- Enya 4 strk diesel modelflight
- IMPORTANT FUEL SAFETY NOTE!!
- MOVED: Oil alternatives
- The baby was born
- Magnum .40XL to diesel?
- PAW 35
- paw 19 ac rc
- Oil alternatives
- glow to diesel conversion
- PAW 19DS in OTS Ringmaster
- Cylinder head temps, idling and throttle control.
- True Turbo Diesle
- Davis diesel fuel?
- Yet another Glow to Diesel newbie needing help!
- Radial mount
- very old free flight diesel plane
- Diesel to glow?
- Not exactly diesel but...
- Cox/Norvel diesel conversion, conflicting advice!
- learning curves
- CS Replica Diesels
- Finally Diesel success! and notes on compressiong settings.
- Starter fluid and oil ?
- Coleman Fuel fired model Diesel???
- PAW 19DS set-up for profile Stunter?
- New made in USA diesel coming??
- Lapped Piston
- ED serial number codes
- Cronology of PAW 2.49cc engines
- S.E. 5 conversion
- Looking for Vincent J Donatiello
- Diesle Newbie
- Where can I buy a diesel RC truck?
- What's in Davis Diesel Fuel?
- Real diesel 4 troke conversion
- fuel just jumped up $5
- Mills .045 flooding
- ASP 46A ABC conversion
- My latest rebuild
- os 25fx
- Kicking start 15 years old engine ...
- diesel getting to hot in the air
- After run oil problem for diesels?
- How to identify my Mills?
- Paranoia about using electric starters
- Contra-piston/head button clearance
- Joe wagners column Mod Av aug 06
- Substitute for Ether
- Engine info wanted please
- Re Sabre 2.5 Diesel
- mds 18 convertion
- Dieselized Norvel .15 revisited
- Cox TD .049 DD conversion - venturi change
- etherless model diesel? Seems doable!
- sad news
- New diesel tubing
- Hmmmm...
- Davis plane mix from tower?
- Check out these old timer diesels
- Bad night with K&B .65
- Carbon Disulphide in place of ether?
- JD Starting Fluid
- where to buy ether?
- Best place to get a PAW engine?
- Fuel dangers?
- Enya 41 4 strk diesel
- Dieselized Norvel .25
- Fuel line for Diesel
- Racing Marine Diesels
- After running - clean / flush / oil?
- JEN 56 Diesel
- Dieselized Norvel .40
- Fuel tank options for diesel?
- muffler for diesel
- Whurd-ya-go?
- End of Contra piston diesels and glo engines?
- Dieselized Norvel .074 earning its keep.
- MDS 38 Conversion
- K.I.S.S principal
- Questions for engine builders?
- MOVED: What brands of starter fluid work in diesel fuel?
- MOVED: Has anybody ever made Bio-Diesel for RCs
- PAW 100 Mk2
- MOVED: Starter Fluid diesel fuel blend - stale
- Diesel Conversion Performance Problem
- Help IDing motor pls
- ML Midge articles?
- Prop boiling
- Diesel fuel from Aerodyne?
- OS 46 LA diesel clicks
- I said I wasnt going to bother ..but
- Diesel COnverstions.......
- tuning MVVS61DFS help
- Davis Head Reassembly
- Diesel starting techneque
- PAW .19
- Arne Hende baby Drone
- Can build your own diesel head ???
- that neat diesel smell
- Fuel site posting
- MOVED: Lamp oil for fuel
- MOVED: diesel fuel additive
- Anybody covert a S.T. .51?
- Conversion head for K&B 6.5
- MOVED: Diesel Engine Information HELP
- MOVED: Commercial Diesel Fuel
- Dieselized Brodak .049
- OS 1.60 Diesel Conversion???
- homelite 25cc diesel conversion?
- Reedy Diesel Conversion
- Polyurethane tube for diesel??
- Thin walled fuel tube in UK?
- Contra-piston Calamity
- Basic Questions
- Latest Restoration
- tt 25 rust
- new large diesel
- MOVED: What is the most efficient air compression method?
- Diesel Head for a magnum XLS 46
- pb 033 micro diesel
- Come on. What's wrong?
- diesel cars?
- Queston on PAW diesels
- new Cyclon 09 Diesel engine
- wasp .061 convertion
- My next Diesel project.
- New MVVS 61DFS on SPAD
- ENYA 45CX
- Getting the stink off your hands.
- Davis conversion head question
- PAW >19 TBR
- Aussie Diesel Fuel Available Again!!
- Zenoah G20 gas/vs diesel
- ENYA 41 4 STRK DIESEL NOW LISTED
- os fp idle problem
- Diesel fuel tank and fuel line requirements
- largest model diesel?
- Diesel wakeup call
- Don't it look nice!
- Overheating Diesels?
- What is dis Lanova cell?
- OS AX46 very uoset to ectasy
- Would love a Diesel, but don't know how to.
- Why (an Enya 11 CX D) Diesel?
- Fox .45 Davis Diesel Conversion Problem
- OS Max 10 FP raise up from grave with a new soul as dieselengine.
- diesel v tissue paper
- is diesel the answer to my problem?
- Blue OS 40
- small rc retro engine LINKS...
- a quicker irvine 36
- Fuel tanks
- PAW 80
- AP hornet 09 update
- Put life back into diesel fuel?
- Dang...
- Ether and fuel storage containers
- Enua 4 strk diesel again
- A few old Diesels
