- Spectrum Module Upgrade Question
- OS MAX .46 SF
- Hangar 9 Guts PNP Models and major price hike!
- what airplane is this?
- Need info on two older/vintage kits
- What is it Need CG
- F4U Corsair Parts ?
- Midwest Aerogloss
- best price on spektrum recievers??
- Question on mufflers for ST S-75
- Deflection Meter Design
- tightening up covering
- Autogyro Flight Simulator
- Approximent Scale help?!
- 4* 40
- Flight Packs
- What size prop. would be good for GMS 76.
- composite fuse.
- engine on f-22 raptor pts
- control line conversion to rc
- OS 40 MAX-H problem
- Large scale rc setup
- os.91fx (RINGED) what prop?
- Four Star side thrust
- Two batteries in one plane Question
- JR wiring
- 2-56 and 4-40 threaded rods
- Question about receiver crystals
- HELP/ Centering Engine on Firewall
- Futaba radio giving trouble??
- battery position
- Radio Question
- Hanging RC Plane from Ceiling Advice
- Radio trouble?
- Recovering over exsisting cover
- Sig Rascal 40
- Zenoah G-26 Muffler
- best transmitter battery?
- Soldering Question
- Goldberg Decathalon Windscreen?
- 2.4
- A/C Power for Receiver
- modelflight cyclone 90 rc plane manual
- Pin on drive washer , os .90 2-stroke
- OKC Hobby Shop
- 4.8volts or 6volt Rx
- Header Tanks
- Do You Know The Name Of This Plane?
- aligning aileron with wing
- SCREENSAVERS? I AM LOOKING FOR SOME RC SCREENSAVERS
- K/B prop driver
- Ideas Needed for Travel With RC Equipment on Comercial Ariline
- electric retracts for bob cat size 50
- 60E Pitts Python from hobbycity.com
- Rubber-band aircraft design
- Maybe not the right forum but.............
- Covering Films???
- AMA numbers on aircraft
- push rod set up's
- O.S. 61 SF what prop?
- KMP Beaver cockpit kit
- Hobbico 180 starter
- Servo specs?
- 9C programming for air retracts
- Workbench Height
- MVVS .26 engine setup
- HELP Balancing Pac Aero Gee Bee 120 y
- Byron originals pitts
- covering
- O.S. FX 46
- Robart Retracts
- When do you use a 2 or 4 stroke
- balancing props
- wood props help !
- Conversion to gas
- CLUB FUEL PURCHASES
- Spektrum DSP60 Servo Shudder/Jitter
- Gas prop on an elecric plane?
- DECALS DECALS
- Help with ski mount.
- Epoxy didn't hardenYuk
- How are the hobby shops doing
- Matchbox Problem
- I bought a new plane.
- JR Reciever Compatibility
- How can I extend my throttle arm?
- Shipping an Airplane?
- Car gas vs. plane?
- Transfer letter
- Need a plane for OS 32 SX engine
- Hand Crafted 1-of-a-Kind RC Planes
- Anyone have a Funtana 90 Cowl?
- Engine block repair
- Please help out one arm club member
- painting covering film monokote ?
- Plans anyone? Electric
- Zenoah G-26 Prop Hub
- Looking for prop.
- prop nut [ alloy ]
- real time application
- tube bender
- Help! - need bolt for OS FS
- Zenoah G26/Choke
- Beijing
- SERVOS/COMPATIBILITY
- FOR WHAT IS A 13.4 X 13.5 THREE-BLADED PROP USED?????
- tuning 4 strokes
- How do you post pictures?
- Silane Finished Glass & WB PolyC
- smoke-writer cartridges
- What is Australian for polycrylic..?
- R/C related gear
- What servo size 1/5 Spitfire?
- Changing out Hitec radio crystals
- Who ate to much turkey dinner???
- transmitter ?
- prop size conversion-from two to 3 or 4 blade APC
- asphalt runway
- how low can a 6 volt be and be safe
- FUNTANA?
- OS 46 starting problem
- How to dispose of Lipo batteries
- aileron servo rod help ???
- Engine runup problem
- Need help
- twin engined electric plane setup options????
- what engine for GP RV 4 Sport 40?
- covering problem
- second plane
- altitude
- slow stick problem
- Sometin Extra w/ Smokey mod
- Hobby Lobby Gee Bee R3
- Name this plane!
- electric motor sizes for an airliner...or stick with glow
- Metal gear servos thread lock
- Second Airplane
- JR XF 622
- How do I reverse 1 hitec 985 coreless analog servo (split elevator)
- OS120 on 1/4 scale Sig Cub
- beaver information
- Elevator Repair
- Moki 210
- Repairing ASP FS120AR
- Tricycle To Tail Dragger
- BALL LINK CONTROL ROD
- Tuninig a Perry Pump
- which one to buy Magnum xl 40 or OS 40 LA?
- BEHR Silver Latex Paint 'NO MORE'
- Building Lighter - Titebond / Aliphatic Glues - dillute / water-down?
- connector to link different diameter tubing?
- DX7 / AR7000 receiver: how do I program 2 elevator servos?
- Large Box for shipping completed airplane
- Any issues in using larger fuel tank than usual?
- Piper Cub Decals???
- O.S .91FX..Muffler Restrictor
- How do I bend windshield plastic?
- storing planes in garage
- R/C Christmas Gift Ideas?
- MRC Super Brain 977 Help !
- Kyosho Calmato Sport wing incidence
- Building board and supplies!
- Zanoah g45
- Fuel Tank Setup
- HOW TO CHARGE NEW LIPOS
- TOP FLITE P-47 NOSES OVER ON LANDING
- aranka (sp?) champ plans?
- Balsa Usa Force one (MOD)
- whats your favorite plane?
- Motor / prop clearance: electric profile
- 72 MHz antenna and magnetic hatches
- Old Saito 80 4 stroke
- What is this motor???????????????
- YS F-91AC Question
- Long servo arm or short control horn?
- Where can I get a COX 1/5 WACO YMF ARF?
- Darker yellow...add what color??
- anyone have any good designs for a bracket for transporting and 27% edge for a small pickup truck?
- JR XP6102
- Zenoah G26
- Nitro Models Bobcat
- How to get a perfectly flat (=plan, leveled) workbench?
- E Flite 400 Parkrunner - reverse shaft
- Replacement wings.
- Help with choice of airbrush
- Hobbico Voltwatch w/6.0v battery issue?
- AIRPLANE TRANSMITTER BATTERIES
- WHICH PLYWOOD???
- Muffler bolt size for 46AX?
- Curing Epoxy
- Paint on UltraCote
- Flying with or fixing warped elevator control surface
- Setting the Timing in a Saito 150
- lanier stinger cowel
- Is OS 40 LA a good or bad engine?
- Whats the Strongest/Best .46 engine?
- Enya 60X Question
- What's the best incidence meter out there?
- what makes glow fuel so hard on paint?
- Starting a 4-stroke engine
- Vacum forming questions
- Nitro exposure and stiff servo wiring
- Nose gear in air retracts steering ?????
- 4-stroke Starters?
- Jett Powered SIG King Cobra
- crankcase vent mess
- Silk, Sanding Sealer & Water-based Polyurethane
- Jet Hobbie info
- Another Nose Gear Issue
- C-tronics onboard glow drivers
- Motor Mount 1.20 4-Stroke
- Mechanical vs Pneumatic retracts
- Help with covering
- Paint match for Ultracote Deep Red & White
- 2Stroke vs. Electric
- SERVO SEARCHING
- Dash 8 needed money not an issue
- New at glow plane building question
- Carbon fiber in Mid Star 40??
- Two Stroke VS four Stroke
- Has anybody built Venture 60 from plans?
- funtana s 40 control throws
- Ball linkage question..
- Repair
- Locktite, lockout: cowl bolts froze to blind nuts
- Best Place to buy Lipos?
- Big Stik History.
- What size servo?
- Installing twin ducted fans.
- Futaba 10 CAP & y-harness on rudder
- Redo paint on yellow arrow on F18C
- Engine for Seagull Extra 260 -180
- Carbon Fiber
- dope for strength
- Are there any RC flying clubs in Jacksonville fl?
- Charging a 6V 1400mh rx battery??
- Mark 3.160
- optic 6
- C G four-star 120
- Super Custom (SC) 40 Idle Problem
- Swap meets-worth the trouble?
- Horizon Price Increase
- JR X9303 mode 2 to mode 1
- *Black Residue From Gasser*
- SAITO 100 STARTS BACKWARDS ALOT
- Seagull Yak-54 .60 is this a good deal????
- evo 46 HS needle valve on carb
- servo plug replacement
- nylon hinges vs fiberglass
- Thunder Tiger .46 Pro, Won't go!
