- Wing Sheeting...1/16 Or 3/32...weight Difference??
- Modified Dremel Accessories for RTX
- Scratch Building an Engine Cowling???
- Local Hobby shops. What do yo do when its closed ?
- Good Epoxy Cheap
- Making a fiberglass mold
- removing tape on a canopy??
- Dremel 4" Table Saw
- Fiberglass Sheeting
- Aero Dope Paint........ What else can I thin with?
- Portable Wing Halves & Tail
- Bending/Warping Balsa
- Sig Lt-40 Mods Crash Proven
- 'pro' building services
- Post your water plane water proofing secrets..
- Easy Fuelel and the Kadet Lt-40
- What is best way to mark/center holes for mounting engine?
- Aero Photography CHEAP!!!!
- Need help with foam wing
- Paint trim for vacume formed canopies?
- What would be the consequence of...
- Aaaarrrrggg... I hate painting!!!
- I need to build a wing
- Beginner questions
- Cracked Canopy----How to fix correctly
- 40 size Gee Bee floats
- My ultimate Field Box
- Warbird Radio Antennae and Wing Guns
- On Off Switch Solution
- THE FIELD BOX FROM HELL! aka The Ultimate Field box!
- Battery and Inverter?
- Does Your Dremel Table Saw throw the belt every time you load it a little?
- A thought for attaching Transmitter to a tray.
- Wing Servos
- Painting plastic covering
- A way to mark them extentions
- covering from horizontal to fuse??
- Cleaning tip
- Newspaper tubes
- Cowl Wont Fit?
- Solutions for bending landing gear
- Helppp!!!! Arizona Aircrafters Lozange Fabric
- Fuel proofing foam.?
- i did not enjoy this part!
- Tip for easier building-don't laugh.
- Tip a cold one, Beer Plane!
- How To Glass? Clueless...
- Painting Props
- Warped trailing edges
- balance
- "Dolly" designs
- Tinting & Painting A Canopy
- Removing CA mist
- What would be the best way to a glo-fuel-proof finish?
- Tailwheel Linkage
- Removing dents in balsa
- what kind of clear coat can I use ?
- latex paint ?
- Cracked wheel pants....arrrggghhh!!!
- Interesting small fuel bottle
- glassing wings
- covering with ultra cote
- How to join wing halves for transport
- 2 tank system
- Servo hatch question
- Trailer
- Painting Koverall on a petrol plane?
- Tip for aileron wires...
- My tricks
- Painting Questions
- Making your own Carbon Fibre Undercarriages and other ‘trick’ bits
- Neon Monocote?
- canopy help
- Repairing foam core sheeted wings
- covering material
- Best way to clean muffler
- Fuel Line for quick fuel ups
- Avoiding "Bleeding" under masking Tape
- placing canopy problems
- Removing Masking tape lines???
- removing very old monocate from wing?
- small bubbles in fiberglass
- Polyester Covering
- Sticky Problem
- glueing fibreglass tubing
- laquer
- CA vs. Epoxy
- smoke
- Painting Fiberglass?
- Pressurized Fuel Tank ?
- Another one for you trailier owners. Hooking up to Elec?
- timing for Q 52
- bending 1/8 inch brass tubing
- Alt. Wiring Kraft Electric Retracts
- help with balsa sheeting on A-4 please
- Plans for the perfect field box
- RX antenna hook up
- Spinner nut
- Hobbico Superstar wing swap??
- Clear coating latex paint
- Tiger 60 pushrod
- Stika
- Engine Thrust Offset?
- interplane struts
- Landing Gear Bolts
- Mounting Floats
- Airfoiling stabs on a Dominator
- Locating the vent tube in plastic tanks
- Fixing a patch in a wing
- wing cover using 2 colors
- Music wire landing gear
- Removing Monokote
- what tools for plaster shaping?
- another smoke system question
- Windex method
- Smoke system questions
- Fiberglass Finishing
- Will PlexiGlas Hold up to Fuel?
- Super Coverite? Where to get it.
- SUV Wing Rack
- Ultracoat Plus
- great "stuff" to have around!!
- How do YOU make formers for fiberglass fuselages
- Pull-pull hardware....where ?
- Iron or Heatgun?
- What adhesive to use for sheeting?
- Building Foam Wings
- Making spinners
- Gummy Epoxy
- Ultracote Plus
- Canopy tinting
- Is Goop Fuelproof?
- Foam Core Wings???
- Painting canopy
- Spray Paint for Cowls??
- Covering Tools-Not Irons/Heat Guns
- Foam Wing Repair
- Pica 1/5 Scale Bucker Jungmeister
- Securing Sullivan Gold-N-Rods Outer Sheath
- Transporting planes in an open bed truck (The Trick)
- wheel hub shim
- cub wheel threads stripped
- Wing tip Lighting
- Covering info needed
- CA for fiberglassing
- Vacume Systems Made EASY!!!
- Reattach wing tip
- CA hinges on CG Decathlon ARF
- ultimate bipe incidence
- CG on a Balsa USA Enforcer
- lustrekote paint durability with gloss top coat finish
- antenna wire locations
- Hollyday Design switch jacks
- Dead Flat Clear
- Monokote base and additional stripes
- Get thee to Kmart!
- How to rebuild torn out landing gear?
- re:size of flaps
- C of G for Legacy Light
- Recovering over Monocote
- Photos Of Trailer Interior Layout, Please Post Yours Too!!
- Air brushes/spray guns
- welding aluminium
- Separate Fueling line
- Locking fuel lines in place
- Does Anyone Have Photos Of The Interior Of Their Cargo Trailers??
- milled fiberglass... size?
- Trailers***could You Guys Tell Me What Size Trailers You Use For Transport???
- Lustrekote
- Great Planes Cap 232 40 Size... Motor?
- Toe in check up
- adding tail weight for first time - what to do
- CA to reinforce wood glue joints?
- Apache 2 Repair Advice
- help with goo from self-stick covering!
- aileron repair
- balancing an f-16????????
- Need Help, painting Worldtex covering
- Koverall & Dope Repairs
- bombs & missles( How to )
- 3 gear retracts ( How to)
- Perfect Paint = Perfect Crap
- Wingtip smoke
- Bladder in a Mold when Vac. Bagging?
- CG superchipmunk
- Tinting Epoxy
- Simple (& Cheap) Dummy Engine
- Slowing down retract servos
- from my little experience....
- Hanger 9 Cub\Saito .91
- Nitrate Dope
- Hinging Alternative
- Midwest Beercat
- Most common?
- hobby hanger kits
- Slow Poke
- Substitute for HobbyPoxy Part B
- Wing Jig
- monokote hinges, how to?
- Stopping the prop at horizontal
- Pull-pull on my Four-Star 60 ? How ?
- Correx/coreflute adhesive.
- Sig Senorita CG
- Coroplast
- easy and cheap and good prop balancer
- Welcome!!
- Primer and butyrate dope
- Here's a Helpful Hint We Need To Use More Often
- Styrofoam
- gluing end-pipe to alum. muffler
- Re-painting questions
- electric gearing help
- Landing gear height ?
- Smok'em if ya got'em
- Fields to fill out on for sale items
- K2r
- Robart Hinge point removal?
- Monokote on edge of firewall
- LusterKote
- Latex Paint
- Tailheavy - what to do
- Cleaning engines
- Fuel Stains On Canopy
- Stuck on CA caps? How to remove them?
- Need mold built
- Will polyurethane glues cure in a vacum?
- Painting Monokote
- Alcohol to thin epoxy
- getting those bevels true
- Motor for Patric Ultimate?
- How to replace a broken CA Hinge?
- Tail wheel doors, how to get them to close?
- lighting that plane
- Frequency Scanner, Don't go to the field without one!!
- Attn: Fiberglassers- I Need Help PLEEZE
- Windex method for Monokote / Ultakote
- Vacuum former 101
- patterns that are Easy to See???
- What to use for vacuuming wings?
- Removing decals
- 20 lb propane tank to air tank conversion?
- Flourescent Utlracote, HELP!!!
- Will They Be Putting Ca Hinges In The 35/40% Scale ARF Kits
- Applying adhesive covering over covering
- Lustrecote Removal
- CA on Monokote- how to remove???
- Painting Checkerboard on Cowl
- Stick and Japanese Tissue
- Who makes "L" shape cowl brackets ?
