- TopFlite Corsair
- first bi-plane
- Aileron Servos For .40 Size Plane
- Marutaka Corsair 20
- First Bipe
- Making a cowl...any tips
- Leading edge wing, covering overlap
- Ultra Stick Question
- Rubberized CA???
- Warp Removel?
- kyosho ferias covering match
- transparent covering tidbits needed
- Need advice on building in an apartment
- Pica 1/5 WACO Kit, anybody built one?
- wing servo lead tubes?
- Float planes
- Joining Solite on glass
- wing bolts
- SIG Smith Miniplane vs. Hog Bipe
- Got both planes in the air today!!
- Great Planes RV-4 Plans
- kits will be gone soon?
- Gaps
- Goldberg Extra 300
- epoxy blues
- My monocote started blistering after 12 months... Help!
- Glenn Torrance Models
- Once and for all...which paint is fuelproof?
- Junk sealing Iron's
- Covering TF Contender Wing Tips
- Where to get Ultracote?
- Can I use thick CA on plastic hinges?
- Tip to Tail length?
- gp extra 300 .40 dihedral
- Has anyone noticed Tower doesn't sell Ultracote anymore?
- CG Ultimate cabane repair
- Dazzler on the board
- Tiger 2 completed
- PT-40 completed
- Wing Construction - all balsa or sheeted foam?
- bte super flyin king
- Missing parts for GP 1/3 Scale Extra
- Proctor Nieuport 28 project
- what is link to pica manufacturing?
- Pica RC-7 Jungmeister BU-133
- HELP!! identify plane
- Goldberg Sukoi landing gear
- What iron on covering works for you???
- fuelproofing
- Cig Citabria on the building board - any tips?
- re-covering the skin of a lanier arf??
- Balancing TF Corsair
- Machining a 4 - Blade warbird prop
- What engine would you recommend for a CG Ultimate?
- Aileron and Elevator or Rudder and Elevator
- GP RV4 aileron
- sig 4* 120
- First Kit
- Getting ready to start building the Dazzler
- HEY,Sig 4*60 Bldrs
- Dubro Hinges
- painting my scale!!!!
- Building instructions/plans for CM A-10
- house of balso stand off kits
- Please Help.
- Tiger 60 Construction Re-re-re-re-visited :)
- Supertigre on Uproar, Good fit?
- Cowl REPAIRING
- construction stand for wing.... and fuse too.
- West Epoxy System?
- Triangle stock and tail feathers
- Goldberg Ultimate instruction manual
- Where's Midwest Sukhoi CG?
- How do I make a "building board" for a P-47????
- balsa and bass wood-where do they come from??
- Minnflyer's sheeting repair article
- Fuel Proofing under Ultracoat?
- Suggested Mods for Astro Hog?
- fluorescent transparent ultracote?
- Whats the advantage of glassing or covering with film?
- Tiger 60 retracts question
- OK to freeze CA?
- Best kit manufaturer??? Opinions welcome.
- I am never using monokote again, ever
- 12 year old daughter wants to fly now.
- Kit for wife after she solo's?
- help need plans for vintage kit!!
- Let's see some Ultimate Bipe covering jobs...
- Solartex question
- Moving thrust line
- GP Ultimate Bipe
- What to build???
- Pica Cessna 182
- Ohio 27% Extra Ready for Covering!
- first and last pictures of Zlin Acrobat
- Did something Stupid
- Gp Patriot Tank Hatch?
- AW 1/4 Edge 540 questions
- gp f4 Phantom throw rate
- Advice for first kit?
- contender CG
- Hob At-6
- GP RV 4 Flap Set-up
- GP Corsair Dihedral Gauge Question
- great planes slow poke .40 ele. throw
- Ben BUckle Fokker HELP!
- GP Extra .60 Wing Warp
- lazy bee question
- GP Dazzler
- short kit's where to buy
- any one built a stangel short kit
- Goldberg Ultimate canopy
- whats the real difference in CA ?
- finishing resin vs. glass
- question on CA
- sheeting turtle deck RV4
- Pilot DJ3
- Recently discontinued kits...
- Does anone have H9 330L building plans?
- Need Help With Retract servo Setup
- Gluing firewalls
- what did you do to get rid of weight in your GP cap 232 kit ?
- Sig Wonder Down....3 to Go
- building without hold downs
- Hitec servo question on my wings.
- painting instead of covering
- Battery location, Herr Cub
- Drill size
- Thunder Tiger 42 GP and a 4 Star 40??
- Ultra Sport Plus Advise
- RV4 flaps and such?
- All American Kit Cutters
- Basswood Spars
- ACE ¼ scale "Clipped-Wing" Taylorcraft
- please help
- Building services
- US40+ Pic 2
- US 40+ Pic
- Goldberg Clipped Wing Cub-engine choice?
- Magnum 1.08 for the GP u-can-do-3d?
- *Tail Wheel for Tiger 2*
- 60 size Super Aeromaster Biplane
- Great planes fuel tank ?
- V tail kits?
- Chekers on my cowling?
- Gluing balsa on a glass table
- tiger 60 GAS ENGINE
- Help- Fuel Tank For My Cg Extra
- Is it a sin?
- CG on a hots
- TopFlite p51
- Help! How much Ultracote is needed??
- Another covering question...
- Chips Acro maiden flight
- T.T. Pro 46 or Tower 46?
- Covering - What type? Silk or Plastic?
- My latest toy
- Canopy Source
- All done!!!
- Filling in large areas in Trailing Edge
- Cowl fitting (AGAIN)
- Anyone in the universe got a Speedy Bee?
- trimming monocote with paint
- tiger .40 vs four star .40
- Sig Fizer Wing Help
- 4 star 40 monokote trim question?
- combat models a-10
- Sig Mid-Star 40 - Roll problem !
- Bought Ultra Sport 40 kit today. Enquiring mind needs advice
- How do you secure kevlar on pull-pull?
- Beechcraft Baron - control horn issue
- new Tiger 2 ?
- Almost finished!
- Help with wing hight
- sig kits
- Need a Pilot for my 1/7 Spitfire
- Joining a wing
- Robart Hinge Placement
- Colombo-Anderson Models 27% 300L Build by RSlocum
- Bridi XLT
- Building 60 topflight Corsair
- C.G. Ultimate Biplane
- wanted plans for a 049 size falcon
- balsanova 1.2
- Top Flite Elder 40
- Gluing windshield on a Slowpoke Sport 40
- bob dively models how to reach
- Venture.60
- UHU Hart Glue
- Somethin' wheel pants
- Proctor Nieuport Fuse bracing "wires"
- Carbon fiber pushrod system sizing
- recommend inexpesive kit (feeling cheap!)
- Sportster 60 dihedral
- Wanted: Plans of Bridi "Chipmunk"
- Ca Glue On Monokote (removing)
- what to build as number two
- Canopy Glue - Secrets to Sucess??
- New Hangar 9 covering iron ?
- Sukhoi Kit?
- edge 540 25-27%
- How to build a cowl from scratch.
- Direct Connection Kit
- Sullivan tail gear spring
- Need Lazy Bee balance point
- Pilot model kits?
- Covering corners
- anyone heard of a MOTUM plane before ?
- Studs for tail mount - Supplier is???
- Solder clevises? How to?
- GP 10-300 Ultimate Wing's
- Covering around symmetrical stab joint
- Nelson Paint?
- 5-15-30
- Nieuport 28, the beginning
- TF P47 Gaint Scale Questions
- Airfoil GP Extra 300s
- G.P. PT-40 balanceing
- beaver kits?
- Tinting a canopy-suggestions?
- T2
- Uproar 60 Balance
- Help me cut ailerons from foam wing
- Profile plans wanted
- Anyone built a Sig Liberty Sport
- Mufflers
- Skybolt vs Hog Bipe
- Goldberg Extra cowl
- AGWagon RC Plans Wanted
- Reccomendation for spinner nut/cone on OS .91 4 stroke?
- Debonding Titebond Wood Glue
- DB SE5a, anyone else?
- Sig vs. Midwest Citabria
- Pilots
- How to smooth CA 'hard spots' in balsa
- finishing balsa
- Next project - Something for my Saito 72
- Want another CA Models 27% 300L building Thread
- GP Super Skybolt vs. Goldberg Ultimate
- kit/plan Vulcan B2?????
- Goldberg Tiger 2
- CG Super Chipmunk landing gear
- Zenoah G26 Fuel Tank
- Building Top Flite P-39
- Correcting Screwup - Thanks For The Help!
- Robart Hinge Points
- engine for Astrohog?
- Fuelers - The real truth sought
- House of Balsa P-51
- Need help finding kit to build
