PDA
View Full Version : Aerodynamics
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16
  1. Calculating Aspect Ratio of multi-wing aircraft
  2. How to figure wing loading
  3. why does plane fly so good/ defied logic
  4. Bipe guys! I Build - You Design. Tall Paul?
  5. Interesting design - blended body
  6. Stab placement.
  7. TsAGI R-II Airfoil needed
  8. Seamaster Question
  9. Biplane wing incidence question
  10. Funtana S 40 Airfoil
  11. Aerofoil needed
  12. Is wing loading relative across sizes?
  13. Wimg Ratio to Plane weight
  14. Question about static thrust and pitch
  15. Do plane dimesnions translate well from full size to scale?
  16. chord help
  17. SUB3D
  18. Can you believe this flies?
  19. Porpoise Problem
  20. Porpoise Problem
  21. Wing Taper and Centre of Gravity
  22. Lancair wing tip stalls
  23. How does a fully semetrical wing work?
  24. Elongated fuselage?
  25. Effects of moving weight fore and aft of CG?
  26. MOVED: CAD?
  27. Trailing edge question....
  28. my funtana 90
  29. Stalling
  30. Kit modifications
  31. Servo Loading
  32. Flat plate Vs Shaped tail feathers.
  33. Thrust vector: Single engine vs Multiple
  34. Dull Leading and Fat Core?
  35. Sig S.E. Wing Washin vs Washout
  36. More of a Physics Question
  37. Longitudinal stability analysis
  38. Aerotow tug hook position?
  39. wing alignment
  40. Thrust rule of Thumb
  41. Wing Loading
  42. Making a ducted fan
  43. Lateral balance fine points
  44. Where can I get Cm Vs Alpha curve
  45. Landing birds.
  46. North Star - Engine down/up thrust
  47. Wing panels
  48. which wing
  49. Tappered leading Edges - for SPEED !!!!!
  50. Would this work(flutter)
  51. Propellers
  52. Choice of Engines for an Unmanned Aerial Vehicle
  53. Inverted airfoil on tail surface?
  54. Anhedral tailplanes on aerobatic types
  55. School Aerospace Question.
  56. NACA airfoil software
  57. Aerodynamics formulas
  58. "Eliminator 2" Sport Jet progress
  59. Great planes you can do
  60. How to get a shoulder wing configuration behave neutral
  61. Maynard Hill TAM 5 Aspect Ratio
  62. Wing Dihedral and flight
  63. Frontal area inside the prop wash
  64. Biplane wings
  65. Deleted
  66. Fuel tank location in models and real planes
  67. HELP!! Aresti Diagrams
  68. flying cheese wedge
  69. wing worries
  70. Bending the prop tips at 90 degrees
  71. roll coupling in knife edge
  72. Scaled up Somethin' Extra
  73. Wing incidence.
  74. How do you determine the size of counterbalance?
  75. balance off - down thrust or try again ?
  76. Advantage of rounded tips?
  77. increasing thrust
  78. To brace or not to brace
  79. Ozark Mountain Jets photos
  80. What propeller?
  81. How do I enter a spin?
  82. Tip Stalling Fixes?
  83. Coupling
  84. Aileron Trim
  85. Never flown with flaps before - Need advice
  86. Foam flat wing and lift
  87. Will this work?
  88. Aeromaster biplane CG
  89. Oversize ailerons
  90. Need help on an odd experiment
  91. wing help
  92. Best tail for flat turns ?
  93. stall strips
  94. replacing a flat bottom wing with a semi symetrical
  95. Wing stall fences
  96. wing loading
  97. Airfoil
  98. Scratch Build Delta Wing CG Problem
  99. Wings v Lift?
  100. Stall Angle Vs Airfoil Geometry- Help!
  101. Flying wing CG?
  102. Something besides CG?
  103. Understtanding CG calculations.
  104. Should wide,flat trailing edge be included in Chord?
  105. basic flying wing c.g. calculations?
  106. Effect of wing taper on airspeed
  107. Extra 300 LX in Model Aviation
  108. Prop Questions
  109. Wing Sections for Model Planes
  110. Where to put CG?
  111. Nose-heavy or tail-heavy?
  112. STOL / VTOL research of the 50's and 60's
  113. Plane wants to clime-Global blue max
  114. High wing vs Low wing
  115. Wing Mods for Goldberg Ultimate?
  116. Effect of no no cowl on flight?
  117. Breaking out of the Loop
  118. Somethin extra wing numbers
  119. Boost tab on rudder - ?
  120. Manuverability
  121. Aeromaster Biplane
  122. Aerodynamics for 220 mph (plus) speed plane
  123. FX 63-137 data
  124. Wing Chord
  125. What'a a good airfoil for a 30 inch wingspan pylon racer?
  126. Cougar 2000 wing tips!
  127. Flutter.... fixes
  128. New Monoplanes
  129. EAA Flyin photos and Vortex proof
  130. BIPLANE DESIGN QUESTION
  131. Where does the fuel go while in flight?
  132. Horizontal stab position
  133. UFO rocks back and forth
  134. Caproni - you solved the CG problem, now see the video!
  135. hand launching fundamentals
  136. Spinner/prop/cowl aero interaction
  137. How to calculate wing area?
  138. fiesler storch
  139. ho229 wing profiles
  140. Please tell me what kind of this airfoil?
  141. Need recommendations on dihedral angle
  142. thrust line question
  143. How do I remove coupling in Knife Edge?
  144. Looking for Wing Design Info
  145. ground effect elimination ....
  146. Need Help Bigtime!
  147. Biplane Wing Gap?
  148. Twin engine down thrust
  149. Any programs that let you test aerodynamics?
  150. Laminar Flow
  151. Induced Drag
  152. Horizontal Stab not horizontally aligned to Wings
  153. Question about Renolds Number
  154. 2004-2005 AIAA Design Build Fly Competition
  155. Tri-Motor CG
  156. Hovering aerodynamics
  157. Fairing wing servos
  158. airfoil thickness
  159. Falling Sideways
  160. Strange plane CG Q
  161. MOVED: ?????
  162. Propellor Conversion
  163. what is happening in a spin aerodynamically? and what happens in a 'parachute' manouvre?
  164. Biplane Spin Rate - Effect of Down Elevator
  165. aerobatic idea?
  166. Flying wing kit or plans? I want one in the 100" range...
  167. B Ae Hawk jet airfoil section
  168. CG Calculation for jet wing with LEX
  169. Wing help
  170. RES Airfoil Selection
  171. X-29 CG Question
  172. Prop Tip Mod
  173. 2004 Scale Nats Photos
  174. Aero Design® East 2001 Paper
  175. Aspect Ratio for Elev Assy
  176. Calculating CG for a Biplane
  177. Collecting material for a FAQ
  178. What % MAC?
  179. Flight loads
  180. ijh
  181. NACA 23015 angle of incidence
  182. Funtana wing section?
  183. HELP! propeller ducting question
  184. Patternships Wing span vs Fuselage length
  185. New twist to the washout pivot question
  186. Delta ailerons size?
  187. Low Speed Quirks
  188. Wash out, where to pivot this angle?
  189. Sticking to the ground at take off
  190. Good Books?
  191. Effect of gap between flap and main wing?
  192. Wing/Horizontal Stab Incidence
  193. MOVED: Space Ship One!!!!
  194. Involuntary Roll during loop
  195. How tightly should I bolt the PivotFlex Wing Mounting System?
  196. Thrust calculator
  197. Reinforcements?
  198. center of gravity for U-2 and Global Hawk
  199. C of G BAC Lightning
  200. stab incidence
  201. Out of Balance...
  202. CG Location
  203. Drag question
  204. Canard CG?
  205. Wing Tip Shape on a Constant Cord Wing
  206. IN FLIGHT ANTICS!?
  207. Autorotation in snap rolls
  208. Equal lift for equal chord/size/area?
  209. Pitching and rolling
  210. sig wonder modified
  211. GROUND EFFECT
  212. wing vortex
  213. Airfoil selection for Albatros Byplane!
  214. PROP W/Symmetrical cross profile.
  215. ZERO LIFT ANGLE
  216. Hannover Cl.III layout
  217. Flaperons on a CAP 232
  218. SELIG 8036 question
  219. Stabilators
  220. Converting to taildragger?
  221. TE & LE taper
  222. P factor
  223. Drag rudders vs. "regular" rudders?
  224. big balance problem
  225. really big balance problem!
  226. CP Versus CG Where are the Topics?
  227. LERX and the Laser.
  228. Washout?
  229. about making wooden propellors
  230. Is right thrust always applicable?
  231. Joukowsky transformation
  232. Flaps vs. Flaperons
  233. Use entire wing as aileron?
  234. Surface finish on wings.
  235. Thrust Line
  236. The crazy GeeBee is back!
  237. ARRESTI wiggle in YAW axis
  238. Eppler 387 airfoil
  239. Climbing While Inverted - Weird!
  240. Joe Nall Fly-In
  241. Prop-Hanging on the RealFlight Simulator???
  242. H-9 1/4 scale Cub ground effects.
  243. Effect of moving CG?
  244. STATIC MARGIN
  245. Spoilers
  246. Scratch built ultimate - CG question
  247. MOMENT
  248. Organic Design
  249. How can this rudder-only plane turn?
  250. Up elevator makes my plane snap to the right
