View Full Version : Aerodynamics
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13]
14
15
16
- Electric VTOL
- Adding flaps to a .46 WM P-51
- Dihedaral
- Pitch/Roll Coupling
- Spoilers on FS 120
- Leading edge shape
- My plane's gone crazy! I need help!
- Cherokee - Engine size and servo requirements
- Stabilator
- Why does my plane do this?
- Augmentation Roll Spoiler
- cg dynamics
- Lift Coefficients.
- Double Reflexed Airfoil / CG
- Aerobatic stability vs. fuse length
- Wing incidence
- A really slow plane ?
- Question about size and structural strength of wing tubes
- Ryan STA
- calculating dihedral.
- Counterbalances on Rudder/Elevator
- Maynard Hill - Contratulations
- What are the effects of this design ??
- dynaflite 81" spitfire floats and Floats
- question about glider airfoil / wing profile
- No question, just a comment about microJET
- Bobcat turbine wing, Why is it designed this way?
- How much positive incedence to use?
- Flaps (and slots?) for newbies...
- Trans Atlantic Crossing
- Wing tip stalls and flaperons?
- R/C car guy building R/C plane, quick question!!
- Sweep forward wings Vs Dihedral
- balancing flying wings
- WHAT THE!!!!?????,Latest design, what ya think?
- reccomend an airfoil ?
- Design specifications
- aerodynamics book
- Any body know where the CG is on this
- Horizontal Stab stalling/ ballooning?
- What should I know if I would like to design a biplane?
- Best way to mass balance control surfaces?
- honeycomb material for constructio of windtunnel
- Changes in Rudder shape (different area) what to expect?
- Airfoil Choice
- Does anyone know the formula for finding the CG on a wing?
- Nose Wheel Strut Length
- Where to begin....
- Does it matter if one flap moves slightly more than the other flap?
- Roll Trim Problems
- trim/attitude/landing/stall
- How to lessen the drag on my Plane
- TF Sierra Left turn problem.....tail wants to slide
- New contributions on our "High Lift" site
- Horizontal Stab Displacement
- Seagull 232 cg?
- Aileron adjustment
- what do i need to know about bipe wings?
- Trainer Characteristics
- Question about AC and CG on airfoils
- More STOL experiments
- Trainer wing tips????
- airfoil design
- Info on airfoils
- aileron aspect ratio
- Duraplane bipe????
- Stall strips on models...?
- model with spin characteristics similar to full scale
- Dr. Jekyl Bipe
- throttle and pitch changes ?
- mixing out rudder bad habits ??
- 3D Biplane questions/ DP-H9 Ultimate Incedence/stagger???
- All-moving wing tips
- What do you need to operate flaperons?
- Joint effort of RCU members, help me come up with a new Mod ideas for my PT-40.
- concept idea, can it , will it work???
- Please help with trimming of plane/possible incidence problem?
- wing incidence question
- sukhio-26(goldberg)-vs-saito 180
- bipe upper wing incidence
- stall small vs. big
- Engine location off C/L results ???
- Thrust line Angle
- COG Aerobird
- Help, need knife edge knowledge!
- Wing Area Calculations
- flight trim question
- Software for analysing model performance
- 9' span trainer foil
- How to setup Airbrakes?
- Tweaking my HOB T-6
- Air temperature and humidity question.
- Wings and verticals....
- Thunder Tiger J3 Cub balance point ?
- Design & CG Excel Spread Sheet
- Edge 540 .90 size
- Cap10B Alot of downtrim
- Eiffel 6 Airfoil Coordinates anyone??
- Help in Project UAV rc helicopter
- Airfoil for a fast plane help?
- Choosing airfoils based on calculated polars
- fast Delta wing profile
- what airfoil to use to prevent tip stall
- aerofoil for Extra 300
- Why do CAP 232s snap roll?
- To thrust or not to thrust...
- Help on design
- The Pheonix : A Solo Sport become a bi-plane
- plane design help
- GENESIS 2 FSW sailplane
- Polars and Reynold’s number
- 12 foot telemaster
- Flying Disk Performance
- Different airfoils
- Lateral balance
- Over-powered Extra 300
- Help!!! Cap 232
- Clark CHY airfoil
- Wing Tip Designs
- Does dihedral really help?
- [Deleted]
- Powered Parachute R/C
- Finding the CG on a spitfire
- Is this plane any good? need suggestions
- airfoil downloads,where?
- Swept forward wing.
- Can any of you guys help out
- Park Bench Ailerons
- Tight turns, stability, and rudder-throttle control all-in-one
- Is it me or the air that is dense
- wing area question
- Flying wing question
- Aileron Shovels anyone?
- Tiger 2
- A/R same engine, area, . . . .same everything. How much difference will higher A/R..
- 72in span, 7in avg chord: Is it worth it to taper the wing???
- Accurate Wing Ribs.
- 25% Hanger 9 Cap trim problem
- Stall Strips
- Dual elevator servos, Best method to determine equal travel?
- How Do You Determine MAC?
- Electric flight calculator
- Do all design?
- Rolling from knife edge!!
- what is the difference????
- Grafic metod to find Canard CG
- Stability web site
- Bi Plane noses down with rudder ?
- Aileron pushrod exit
- Computer Programs for Aerodynamics
- ignore, double post
- physics project - smoke wind tunnel
- simple stall question
- Airfoil for areobatics...funfly type
- new vtol project, i need your help!
- up thrust to trim?
- Canards
- b-29 rudder cross section purpose
- AOA indicator
- dazzler, magic or magic extra?
- Reflex Ailerons to Shorten Glide?
- Airfoil advice please - slope soaring flying wing
- Explanation of Wing Incidence
- Tell Me again about Canard wings
- I have a c/g question.....
- more on dihedral
- V-tail question
- angle of elevons on a delta flying wing?
- Wing Loading
- LE slats
- Axial Rolls??
- ANother question
- Airfoil question
- Un-commanded roll at high speed
- Super Stick C.G.
- Joe Nall Fllyin
- spin of death ... Edge540
- JTwo questions...
- CG location on a lifting body
- Wing and Stab Incidence for the TF 60 Corsair Need Help
- wing planform and fuse coordinates
- Empannage_Round vs Flat Surfaces
- Servos
- Flaperons vs Spoilerons
- Propeller answers
- Spoiler diagram
- This is a "Fowler" flap!!!(and a 737 flap)
- A GREAT .gov aero website!!!
- Why does plate fly with airfoil upside down?
- Why is my undercambered ifo only flying upside down?
- Sukhoi 26 Rolls right
- Please Double Check My C.g
- Spoilers VS Flaps
- How will it fly?
- with or without wingtips
- Lift and Drag calculation: which wing area?
- What is the effect of a loose rudder?
- Prop & Duct bell housing design
- Bipes- Any ratios or Guides for vertical seperation?
- Elevator to Aileron Mixing/servo placement
- Prop selection & Trying to maximize speed,
- Propeller questions
- Is it possible to have flying wing with a v-tail?
- Yaw stability
- Rudder coupling on CG Extreem 330
- Airliner finlets???
- aileron linkage more up than down help
- reflex / speed flap
- What's the best airfoil/wing for pylon racing? Low drag? Swept? AR?
- How to you determine/estimate the amount of lift on a lifting body design?
- Two Questions...
- Incidences
- Duraplane trainer 20 stall problem
- Designing a modern 60 size patten plane
- Control surface + MAC calculation
- HELP : My Design
- Balancing ailerons
- P-51 wiggles in yaw,
- General Questions
- r shape vs ^ shape airfoil
- Adding airfoil on IFO
- Standard Calculation for wing angle, speed, air pressure
- Living room flyer help
- Anhedral in heavy lifters
- Fuel effect on cg, slosh slosh slosh
- Real plane aero site, "LoPresti Speed Merchants"
- Predicting Maximum payload (heavy lift challenge)
- Incidence readings?
- model keeps gaining altitude
- c g help
- Extra 300 tail design questions
- MAC for double swept wing
- A couple basic aerodynamic questions?
- Stearman Problem
- Airfoil suggestions for a Turbine jet???
- Scratch Plane
- F-22 Raptor Variable Lift
- Multi-Bladed Folding Prop?
- qualitys of a zero-coupled design?
- Down thrust and aileron neutral position.
- Dorky Science Question
- Do I need downhrust or Upthrust?
- Pressure or Profile Drag Question
- Low vs High Aspect Ratio Props
- Swept wing bi-planes
- Dethermalizing with R/C
- 1/2a Cap 232
- Wing Tip shape!
- Need a little CG adjustment help.
- wing change
