PDA
View Full Version : Aerodynamics
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16
  1. Using leading edge flaps?
  2. Airfoil thickness ??
  3. Bi plane on center of gravity machine
  4. Wingloading
  5. Converting mono to bipe
  6. Balancing tailerons?
  7. INSERTING PDF/IMAGES
  8. Adequate static thrust for model?
  9. Airfoil for a B-2
  10. Rudder contol surfaces
  11. How a wing makes lift!
  12. Biplane (CG)
  13. Biplane problem
  14. how do these effect flight?
  15. Can you compare props by calculating volume of one prop spin?
  16. WING GRID
  17. ALL WING MIDDLE EFFECT
  18. PROP AFFECT LIFT OVER THE WING
  19. inverted spin
  20. New address for airfoil site?
  21. Kansas State University of Technology and Aviation
  22. Name this plane
  23. COG Agressor 240
  24. ALL WING DESIGN
  25. LERX-useful?
  26. Effect of wing incidence?
  27. is a rudder really needed?
  28. Rudder Coupling Causes & Fixes
  29. Taking Dihedral Out Of An Avistar
  30. Measuring wing incidence
  31. Wing loading formula...
  32. Selig 1223 Turbulators
  33. Avistar aileron setup question
  34. Airflow Separation?
  35. NACA 13% at root to NACA 25% at tip?
  36. aileron differential
  37. angle of incidence for 2M e-glider
  38. Should I remove the wing dihedral?
  39. SAE Aerodesign pics & discussion
  40. SU27 Flanker control surfaces?
  41. Airfoil on tail surface OK?
  42. Reverse Engineering NACA parameters
  43. 1/2A RC SPEED IDEAS
  44. Pitch and Efficiency
  45. Stabilizers on control surfaces
  46. Motor-glider Airfoil?
  47. Propeler vs Altitude
  48. INVERTED V-TAIL
  49. V-Tail control surface proportioning
  50. canard+wing giant RC models
  51. TE of the ailerons
  52. Pics from tunnel testing
  53. Flat Spins?
  54. Pattern wing profile question
  55. Own design problems
  56. Airfoil for a fast turbine Jet
  57. Fully symmetrical airfoil and lift
  58. Thin Ailerons
  59. Tail Incidence
  60. HP Heyford
  61. Odd CG results...Tiger 60
  62. V-Tail to Wing Span Ratio
  63. Raising the thrust line
  64. Thicker Wing=Slower Plane?
  65. Wing loading question
  66. Helicopter blade sound
  67. How to size a V-tail when converting a conventionally tailed model?
  68. Loading of Control Surfaces?
  69. accurate geometry
  70. Tail Volume Coefficient
  71. Free floating wing?
  72. Stabilizer and wing at 1.5 degree incidence?
  73. Avoiding spiral dives with rudder-only airplane
  74. What happens if I?
  75. RETRACTING WINGS INCREASE SPEED 20%
  76. wing height over fuselage negatively affect flight?
  77. Aero Help Needed!!! simulation and coefficients
  78. cassut wing
  79. wingspan and transferring tip cg to wing root question
  80. Tail moments for 3D
  81. 'Stick' Wing Trailing Edge Scallops
  82. Rite Hook on Landings
  83. leading edge ailerons.. anyone tried it?
  84. a good book on prop aerodynamics
  85. Engine Thrust Problem?
  86. Trailing edge slightly upturned at wingtips?
  87. CG and high speed turning radius
  88. Request For Comments
  89. So whats the problem(s) with a Giles?
  90. CG Measured With or Without Fuel?
  91. Changing moment arm length
  92. Why not cover the bottom?
  93. Full span ailerons
  94. Hinged vs. All Moving Tail Surfaces
  95. Modifying a kits flight surfaces
  96. Reducing drag through wing tip vortices ?
  97. Magic Wing Loading?
  98. Walking Hover
  99. SAE Cargo Plane with ANHEDRAL?
  100. Flaperons on GP Slow Poke .40
  101. Best .46 2c for second plane.
  102. Correcting wing incidence to stab trim
  103. Aerodynamics of full-flying stab?
  104. the posibilities of parachutes? parafoils? and other foldable materials.
  105. Shabby repare work
  106. CG and COM
  107. Run in OS 46 LA
  108. Elevator Torque estimate
  109. how to find wing loading
  110. Finding cg of a bipe
  111. Wing sweep and washout
  112. Most forward safe CG
  113. Oh great airfoil magicians, I need your thoughts
  114. Nose-over and ground loop same or different?
  115. determining the c/g pre-flight
  116. CG for Pitts S1
  117. Where is axial moment on foil
  118. Thrust line define and short explanation of how to locate, it possible
  119. tailess design
  120. Whistlin' Wing
  121. Asymmetric Design Questions
  122. Home made P - 82 mustang
  123. Are Wingtip Plates Effective?
  124. Which airfoil?
  125. Flap Angles
  126. katana
  127. Possessed GeeBee
  128. MOVED: Space Glider Project
  129. Lifting tails again, numbers supplied
  130. tail surface and wing incedence questions
  131. Three Surface Configurations
  132. Biplane wing incidence
  133. Thrust?
  134. Transitional Airfoil Plots
  135. Dynamic Soaring
  136. Split Elevator
  137. Wing loading.....again
  138. Bernoulli's equation
  139. MOVED: Reduced propeller diameter
  140. Canard Questions
  141. Wing loading opinions
  142. Define some terms for me
  143. Fun fly profile
  144. No question just a comment.
  145. Horizontal tail size and aspect for 3-D plane
  146. How to design an airplane
  147. Pitch moment for airfoil
  148. thrust to weight ratios
  149. Aft CG
  150. Local Cl for a wing during a turn...
  151. CONTROL SURFACE COUNTERBALANCE
  152. Air density - moisture content
  153. How much Right Trust
  154. Estimating washout from Airfoil Transitions?
  155. Thick, FLAT airfoil?
  156. Dutch Roll/adverse yaw, difference?
  157. Quick Left roll on Seagull PC-9 HELP!
  158. just a ?
  159. confused on cg
  160. balance on a 90 in laser
  161. Paoli wing
  162. Abbreviations?
  163. Diagram of rolled model forces
  164. flaps + elevator
  165. Flying wings - stability
  166. Airfoils that don't require trimming, like the FW-190?
  167. this will keep you busy...
  168. Wing dragon
  169. questions questions questions!
  170. question on unstable edge 540
  171. What causes pitch with rudder?
  172. Flying wing designs
  173. blending airfoils
  174. Heres another one????
  175. Calling all Brainiacs - NEED HELP!
  176. canards v. forplane
  177. Somethin' Extra Wing Washin
  178. R&S Hobby F-16
  179. Delta wing vertical stab(s)
  180. Flaps and ailerons or flaperons? Never mind, I found all the flaperon threads!
  181. knife edge question (beginner)
  182. Wattage Mirage CG position
  183. Vee Tail sizing
  184. V-Tail Mixer (mechanical vs. computer) question
  185. Waco wing incidence?
  186. Flat spin recovery
  187. Horiz stab = any lift???
  188. Downthrust for motor
  189. Why do swept wings roll faster?
  190. i need one more little favor
  191. AKM MIG 29 question
  192. Can you answer this?
  193. hinge gap
  194. Delta
  195. Need a point clarified regarding airfoil plotting
  196. Scratch Designing RC Airplanes
  197. Engineering Group needing HELP!!!
  198. Landing My Lazy Ace
  199. What is Prop Pitch
  200. Byron Cap 21 incidence?????
  201. Aerodynamics of Wheelpants
  202. Catastrophic wing failure!!!!!
  203. 2 Blade VS. 3 Blade Prop
  204. Differences in airframes
  205. Four-Star 40 has nasty pitch to the belly in knife edge
  206. Elevator problem...
  207. Problems with trim/pitching up.
  208. anyone ever make an RC constant speed prop?
  209. Need help with wing selection
  210. help. my wing's weird
  211. Flat wing
  212. elevator trim/incidence adjusting
  213. Incedence, rule of thumb?
  214. Weathervaning
  215. MOVED: Mixing Glues
  216. Biplane flying wing?
  217. Enclosed wings?
  218. knife edge question
  219. terminal velocity
  220. calculating weight moment for cg adjustment
  221. Check out this website
  222. ace simple series ultimate
  223. Big mistake! Please help
  224. Who can answer this ONE?
  225. Airfoil equations
  226. Cessna Skymaster type plane...
  227. Ground loops
  228. Downthrust
  229. cg on a biplane
  230. Rpm Vs prop diameter
  231. Slotted Flaps and light wing loading
  232. Landing my W/M T-34
  233. Airtronics Radiant
  234. Canard
  235. HELP.....WOULD DIMPLES (LIKE A GOLF BALL) IN THE PROPELLER INPROVE EFFICIENCY??????????
  236. Choosing an airfoil
  237. Roll trim different inverted?
  238. Taming the P-38
  239. CAN MY AIRPLANE FLY?
  240. High pitch props???
  241. how to make the C of G go rearward
  242. Anyone put stabilizers on the tip of your wings????
  243. thrust line changes
  244. Biplane wing spacing?
  245. Wing incedence question
  246. What stops vertical flight?
  247. C.G. on a trapezoid wing put aft
  248. Model Airfoils listing
  249. airfoil selection - funfly competition model
  250. C.G. of Sig Tri-Star?
