PDA
View Full Version : Aerodynamics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16
  1. flaps
  2. Incidence referenced to what?
  3. 1 Negative thrust (what is this)
  4. Engine wing and tail alignment for pattern style aircraft
  5. flying wings - some basics and formulas
  6. End plates and winglets- do they prevent tip stall?
  7. C'mon aerodynamicists- figure this out!
  8. TIPstalling & Flaperons
  9. Biplane desing question
  10. What is faster... A heavy or light R/C aircraft?
  11. trublesome tailwheels, ground looping
  12. Reading lift/drag graphs
  13. Reduced Fin area & semi symetrical wing - Effects?
  14. Playing with spoilers...
  15. Profili 2.13 software
  16. Is this wing area is suitable for OS.46?
  17. Hi speed flatter! Why and how?
  18. Rudder Problem Four Star 60
  19. Simple question...or is it?
  20. I have a problem with the area of the wing span.
  21. Thoughts on Wind Tunnel
  22. Rutan Proteus Airfoil selection
  23. Aerodynamic airfoil books?
  24. Fin design at subsonic speeds
  25. How much for incidence
  26. Designing from 3-view drawing
  27. Airfoil for light 2m HLG
  28. DesignCad - Anybody using it?
  29. Please tell me the weight that my plan should be.
  30. Where can I find the 3-views of Pitts?
  31. Aircraft CG
  32. UIUC AIAA Design/Build/Fly Project
  33. Wing Angle
  34. determining lines of reference??
  35. overlapping props
  36. Should a prop driven aircraft actually be symmetrical?
  37. Zinger Simatar vs. Standard Props?
  38. Thunder tiger fun tiger with O.S. 61 FSR????
  39. Is the Stinger a well Aerodynamic plane?
  40. Article by Maynard Hill on Speed Configurations
  41. Weight & Balance
  42. Canopy effect on aerodynamics ?
  43. how to calculate ballast required?
  44. Downthrust On A Twin
  45. Coanda Effect
  46. How to slow landings?
  47. Tip plates - Can they significantly increase aileron effectiveness??
  48. 38% Christen Eagle knife edge pitching
  49. Flaperons
  50. How can I make one servo control both elevators? Read on....
  51. Speed, racing, drag, and "toes in the wind"
  52. Glider design experts input needed
  53. Aerodynamics of Delta vs Conventional
  54. Airfoil for a Storch
  55. Is the S1223 airfoil really the best...!!!
  56. Aileron differential?
  57. Contant speed propellor design
  58. 100% Eagle
  59. need NACA 2417
  60. Double T-Tail?
  61. 60 inch wing verus 48 inch wing??
  62. progressive airfoils
  63. Quick flying wing question
  64. Knife Edge Roll Coupling.
  65. What are boost tabs???
  66. Servo tab pros/cons
  67. Incidence angle for the HQ 3,0 - 12 airfoil?
  68. Yak3-Wing foil selection
  69. comparing airfoils, picking a CL
  70. Need help with fuse design
  71. Reducing the dihedral in a trainer
  72. Dihedral question
  73. Wing area versus lift questions.
  74. Wing/Tail/Fin ratio
  75. Elevator vs. all moving stab?
  76. planform - straight leading or trailing edge on a tapered wing
  77. Airfoil question & crude drawing attached
  78. Wing problem, i need some input before first flight***
  79. Reynolds number
  80. Sharpening prop LE?
  81. Lift calculations from airfoil and wing area data
  82. Questions concerning $* 40 kitbash
  83. Important question for you brainy folks..
  84. Need Profili Foil data
  85. Richard Pearse- Kiwi, and First to Fly?
  86. links
  87. Washout...
  88. what engine we use for such a body?
  89. Balance point on SkyRangers park flyer
  90. which aerobatic airfoil should I use?
  91. Anyoone make the Avistar tail wheel mod? Need input.
  92. Profili registration troubles cleared thx to RCU...
  93. Sort of aerodynamic question
  94. I Need A Full Design Can U Help Me
  95. Choosing an airfoil for a f16 RCM
  96. Pros/Cons Of High-Aspect Wing
  97. real P-51 CG CENTER
  98. center of gravity
  99. Aerodynamics education?
  100. wing loading
  101. P-51 Laminar wind
  102. Modifying wings of Super Skybolt
  103. Preventing tip stall with aileron reflex?
  104. Wing and Stab. Incidence
  105. Swept Forward?
  106. Biplane Wing Incidence
  107. Help in bashing a kit
  108. load on flight controls and servo selection
  109. Hinge positions to reduce flutter
  110. What would be the effect of slight dihedral in an elevator....
  111. Stupid quesiton about airfoils?
  112. skeg-less control surfaces
  113. Other than diameter and pitch, how else can props vary?
  114. Naca 12 airfoil download for auto cad 2000
  115. CG problems
  116. 11x7 prop being turned 14000RPMs. How much thrust is this?.....
  117. My Jett engine shipped today! According to Dub Jett, it does.....
  118. Understanding Chart CI readings in Profili
  119. V-tails... what do i need to know.
  120. Co-ordinating rudder & ailerons in turns...
  121. Fowler Flap help please
  122. Thick Tip-will It Prevent Tip Stall?
  123. Balancing ailerons
  124. What are the basics to designing a wing?
  125. differences between stunt planes
  126. Adrenaline (my latest design) - Pictures!
  127. Tractor or Pusher
  128. original airfoil design questions
  129. Aerodesign West Competition
  130. Ve dihedral
  131. Servo Three Views
  132. ailerons
  133. Profili software-Cm graphs
  134. Effect of CG on flight characteristics?
  135. How do you know what size engine to get?
  136. glider with dutch roll?
  137. O.S. 50SX vs. Jett .50 and conversions.
  138. aerodynamics of pylon turns
  139. Reynolds number of tapered wings
  140. Full scale areobatic plane questions
  141. help, finding c of g on a canard plane!
  142. CG / elevator throw / stall
  143. sailplane airfoils
  144. Flaps vs. Spoilers
  145. Variable pitch props for R/C here...
  146. Propeller Tech - "SMALL" article by Joe Wagner
  147. Could someone explain to me RPMs, prop diameter, pitch, thrust, and power?
  148. Aerodynamics site with Flash anims
  149. O.S. 46FX with an 11x7 Topflite wooden prop. How many pounds thrust can I expect?
  150. Short coupled V-tail, elevator or no?
  151. Indicated airspeed and wind
  152. Thousands of pages of NASA docs on hundreds of technical subjects.
  153. Props - 4, 3, 2 and 1(one!) bladed!!! Half bladed?
  154. Stabilizer off center
  155. Contra Rotating Propellers
  156. is it flaps?
  157. canards????
  158. Over Powering Planes
  159. Simple Series J3 trainer wing
  160. Vortex generators.
  161. Aircraft Design HELP NEEDED......!!!!
  162. Need ordinates for a really fast airfoil
  163. X Wing
  164. Spoilerons/flaperons on a seniorita-what to expect? (UPDATE)
  165. Designing a plane
  166. Speed of sound vs. elevation
  167. The lighter the better in weak lift ?
  168. outside loop?
  169. Mixed airfoils on bipe?
  170. The Stabilizer Of A Plane
  171. problem- too much down trim required
  172. Wing Tips, Vorticies or a Fin?
  173. What Engine for Aircraft size
  174. Dihedral braces ??
  175. What is a "tip stall"?
  176. Centennial multiplane canard
  177. Neutral Point?
  178. Can I put flaperons on a plane not designed for them?
  179. Weight lifting competitions.
  180. Aspect Ratio ??
  181. Looking for tip writers for new beginners website
  182. Converting under cambered to flat bottom
  183. relationship of ground effect and wing chord
  184. aileron gap sealing
  185. Model?
  186. landing problem
  187. give me a good web site for aerodynamics
  188. thrust angles
  189. penetration- regarding gliders
  190. What Incidence???
  191. low wing plane
  192. wingmaster 99
  193. How to find the CQ?(need math formula)
  194. Custer Channel Wing info/help.
  195. Tip Plates?
  196. Best Airfoil Designing software?
  197. Using Profili v2 to make airfoils?
  198. Unusual Airfoils
  199. Theoretical airspeed
  200. self righting aerodynamics
  201. elevator control on canards
  202. XFoil and airfoil data
  203. Sharp LE (is it a myth?)
  204. Thrust vectoring with electric fans
  205. Cross-section of a circular fan-in-wing design
  206. Friese (knuckle hinges) vs butt hinges
  207. Slips with a twist
  208. Decalage
  209. Undercambered Symmetrical Airfoils
  210. Using wingtip vortices
  211. Aileron Throws For Small Biplane
  212. Need Help Sizing an Engine
  213. Leading edge shape to minimaze tip stall?
  214. How much does dihedral (11 deg) on a low-wing plane reduce aerobatic ability?
  215. Plotting airfoils can some help?
  216. RAF 34 polar diagrams
  217. QUESTION Trainer vs Wing span
  218. How much aerodynamics should pilots know?
  219. Building calculations
  220. Aerofoil Selection
  221. Flaperons???
  222. Adjustable airfoil wing
  223. Any recommendations for materials to learn aerodynamics
  224. INDUCING flutter on a trainer
  225. Pusher Propeller
  226. Whats Happening In 3d aerobatic aerodynamics?
  227. Symmetric airfoil aerodynamics?
  228. Ground Effect Airfoil Help
  229. Sweepback = Dihedral Effect?
  230. Biplane or Monocoupe
  231. flying stabilizer
  232. Real to Scale Airfoils
  233. Wing incidence on bi-plane
  234. What is a good wing loading?
  235. C.G. Location
  236. Aileron flutter at high speed?
  237. ailerons wider than trailing edge?
  238. Use RealFlight to Experiment in Aero
  239. B-17's Vertical Stab - why so large?
  240. Help, Biplane wing
  241. Pitts / Ultimate
  242. wing alignment on profile plane
  243. Any physics/math competent help here?
  244. Wing Polyhedral
  245. Difference between CAP's
  246. AOA, decalage for 60" slope plane
  247. 4 Blade Props
  248. SZD-20X Vampire 2
  249. Stab, Wing and Engine Placement in Relation to Thrust Line or Centerline
  250. Early 23 and 24 series Learjet airfoils
