View Full Version : Aerodynamics
Pages :
1
2
3
4]
5
6
7
8
9
10
11
12
13
14
15
16
- Best low rpm/high efficiency prop choice
- Wing loading for twin?
- Fuselage OK?
- F1E
- f16 set up how will it fly
- Astro Hog Stabilizer
- Wing chord and Alpha limit
- New Aircraft Aerodynamics website- very interesting and highly recommended
- EDF Mounting Incidence and Toe out?
- Knife Edge Different Right and Left
- Kaos Airfoil
- Flustered with futter
- Metal tail
- ENGINE DOWN THRUST ANGLE QUESTION???
- force on a controll surface
- Incidence angles
- Increase lift with flight condition programming?
- pusher vs. tractor
- Aircraft weights
- MOVED: how much error is too much?
- tail heavy or nose heavy
- Extra airfoil thickness
- Aileron size
- What is the physics behind 150+ mph slope soarers without engines?
- 360 deg. turn by jets banked almost 90 deg....How?
- Thrust line, Datum line, Center line?
- Lifting airfoiled tail horizontal stabilizer.....why?
- Anhedral wing on Top Flite Contender??
- MOVED: Can a 40 size decathlon do a flat spin?
- F_84 Control Throws
- aileron throws
- Slope ship with 23 to 1 AR appropriate airfoil help
- CMP Gee Bee wing
- CMP Gee Bee wing
- Ultimat-10-300
- Typical lift coefficient on an RC airplane?
- SIG something extra CG Point
- CG help on unknown plane
- Determining a Biplane's CG question.
- What aerofoil for 80" aerobat?
- wing incidence, symmetrical airfoil?
- TWIN, INLINE, DUCTED FAN'S = TWICE THE TAILPIPE VELOCITY?
- Knifing My Kaos
- Another One.
- Measuring Total Plane Drag
- Cessna 185 Help!!!!
- ground effect need opinions asap :)
- Can I really design my own airfoil?
- Winglets on Sig Cap 231 EX?
- roll coupling on knife edge - problem
- P51d mustang aerofoil section
- CG locations other than 30%mac
- Discussion - Scale aerodynamic characteristics
- Are fairings worth the effort?
- High lift airfoil for heavy lift
- thickness vs chord
- Ideal weight for 35% extra 100c?
- Selecting an airfoil, help needed
- Easy ways to "liven up" a trainer?
- are Extras more tricky then Edge 540?
- Help me with CG Please
- Prop efficiency, 2 versus 3 blades
- Why does roll rate increase when inverted?
- Flat plate equivalent area ?
- Will changing the fuselage from square to round effect it's handling?
- MythBusters Airplane Takeoff Myth
- Two different airfoils on a bi-plane??
- Software for testing
- Horiz. Stab size question
- What is washout?
- help on ideas the most aerodynamic shape
- Loaded Question: Why is it that rc pilots ignore flight physics?
- Slightly off topic
- Center of gravity.
- Geese V formation
- Need some expert advice please
- Wing vortecies- bad or good?
- Lift calculator gone crazy...
- XFOIL reference frame
- Cruise speed for my trainer...
- Why/ need answers.
- Senior Seminar Project
- Airfoil Cood's
- semetrical airfoil and trims
- MOVED: autoCad- any good for designing rc airplanes?
- How flawed can an RC airplane be? :S
- Canard/ flaperon question
- Nose lenght?
- CG VS. MAIN GEAR POSITION ON A TRI-GEAR SETUP????
- Good graphing packages/software?
- Pitch control- what the heck is this??? Help
- Picking the right servos by hinge moment coefficient calculation
- Boundary layer separation, based on pressure diagrams.
- forward swept/swing wings
- digital wind tunnel
- Predicting airflow pattern over a body
- How to calculate induced angle of attack and downwash
- Aileron differential
- Thrust to weight
- NEGATIVE ELEVATOR STAB INCIDENCE - NEEDED?
- Ikon n West Beaver question
- Washout or different tip airfoil?
- Will this still fly OK?
- Big Downthrust angle.
- R/C Hang Glider Project - Elevon Question
- Multiple questions related to prop selection for ice vehicle
- Correct angle of motor shaft in a pusher.
- Identifying optimum incidence or decalage for scratch built
- Ugly Stik 40 center of gravity
- Happy New Year guys.........
- Ritz airfoils
- New Tail Design for Proctor Antic Bipe
- Enlarging Plans
- WHAT'S UP WITH LOW TEMP
- MOVED: Pull Pull Rudder??
- GWS F-15 pusher. motor up benefits?
- Center mounted engine & prop ?
- Help with Profili!
- Aileron control throw question
- Testing Old Timey airfoils
- How to make a gyroscope ??
- Minimal set of trim adjustments?
- reducing tail area
- roll stability
- Cowl vs cheeks
- Bombardier Global Express
- I have crashed my 90 size pattern on crosswind landing..
- Scaling up a model to full size?
- Effect of tappering a wing with a small chord
- f86 Sabre ... Help me calculate Cog
- Wing tip design questions
- Fully symmetrical wing lift question.
- Canard airfoil
- MOVED: mitsubushi zero
- Project
- Biplane thrust line
- Flutter
- Obese Extra 300
- Canard designs (noob)
- Speed or air brakes
- magnum airfoil
- rudder effects
- One wing
- sopwith camel
- Angle of incidense affect on flight
- CG question - 25% or 33%?
- Wing Area - Corsair
- Fuselage length and ratios for custom design
- Lift plots for LE flap equipped wings?
- Prop pitch........ practice : theory
- Airfoil for my flying wing
- ELEVON ISSUE....
- What are your personal definitions of the words lift and drag?
- What is the difference between Extra 260 and Extra 300
- Fins.....ventral fins PICS ADDED!???
- one to get those brains working.
- COG and thrust location problems.
- Calculate max air speed of a plane?
- Chord line confusion
- Flying wing desing
- Servo Loads
- Airfoil data
- Mean Aerodynamic Chord
- L-410 TURBOLET INVERTED AIRFOIL IN ELEVATOR STAB
- Is there an ideal elevator throw for performing elevator maneuvers?
- AOA and speed
- Zero speed landing possible ?
- Why do people say the top of the wing causes the plane to fly?
- DRAG.....Help please
- MOVED: Model type/controls advise please !
- custom cut wing cores for speed
- Rotational spin speed and exit reliability - accuracy
- Nitro Models At-6 acting strangely upon landing
- F3F-2 scratch build
- what stress are aerobatics putting on a plane?
- Nosen Citabria Flat Wing To Semi-symmetrical
- MOVED: Wing Tube needed
- what's easier to fly in the wind? a trainer or a jet?
- Aileron Differential on a Bipe
- Thrust line maximum degrees.
- NACA numbering scheme
- How to calaculate wing tube size needed?
- Dihedral Question
- which way to go with thrust??
- Why make both engines critical ?
- Help with CG math
- Biplane piches down at full power
- Simple Kite Question
- Another knife edge and coupling query...
- Incidence on a PT 22
- Rudder and Fuse for straight KE
- Annular wing design help.
- Airfoil for Yak54
- Are Flapperons ever a good idea?
- rudder / elev only
- Rudder only flight with a 4 channel trainer.
- Waco bipe CG have measurements
- CG help please
- Does CG affect an aircrtaft's pitch at slow speed?
- Looking for a specific Russian airfoil
- MOVED: WARPED FLAPS
- Bobcat 50 Ideal Airfoil
- Airfoil recco...
- Wingloading 101 help
- Why wont my Kaos spin right
- RC Banner Towing.
- Wing Tip washout popularity
- Mysteries of the (actual) F-22 wing
- Is this wingloading acceptable or high?
- flat airfoil desighn! ( PIC INCLUDED)
- Piloto wont climb!
- Scary maiden
- Help desgning a wing section
- Concept airfoil design- des it work?
- MOVED: Aerobatique manuver
- need advice on the center of gravity
- Surprises with H9 F-22 crow setup
- Won't do Outside loops?
- More drag - prop spinning at idle or dead stick?
- What would be the "perfect trainer"?
- Bio-Inspired flying robots
- Use the scale (full size) airfoil?
- convert flat bottom wing to semi elliptical
- Wing tip shapes, advantages?
- Down thrust and its influence on up!
- Raptor in action!
- tail problems
- Prop fan, would it affect thrust?
- Degrees of Thrust Question
- Control Surface Forces
- Right and down trust
- NEWCOMING BUILDER: Flying wing question
- Need help with landing speeds.
- plane too heavy?
- weight vs. drag
- Zagi Airfoil?
- Do wrinkles in wing covering affect flight performance?
- Spinners Explained?
- Setting Ailerons
- Big Bird Fly-in
- Discussion - Wing Shapes and differences
- Piper Cub instable flight at power
- How does a nose heavy plane react
- Will this thing fly?!
- Center of gravity for delta wing...
- Help with design
- Trainer climbs like a Hot Air Ballon!
- Twin tail alignment
- Does it look tail heavy in this video?
- Vortex Generators
