PDA
View Full Version : Aerodynamics
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16
  1. CG of a biwing
  2. Forward thrust reduced by too much right thrust?
  3. MIxed signals regarding wing loading numbers.
  4. PT 20 with flaps ????
  5. MOVED: Spar Location
  6. Mass blancing ailerons
  7. Ben Lanterman
  8. CG on Bi Plane
  9. My Spectra Tucked in and Ate It.
  10. Aerodynamic of undercambered vs. flat-bottom airfoil?
  11. THRUST
  12. Taking off with flaps
  13. Recommended airfoil for Pattern-type model?
  14. Trim ???
  15. pros and cons of dual ailerons
  16. What went wrong?
  17. True motivation for Differential Ailerons
  18. Sealing Hinge Gaps
  19. C.G position and flight?
  20. Need some prop advice
  21. Why seal hinge-gaps?
  22. Balancing tailerons?
  23. flaperons or spoilerons for a jet?
  24. Flying Wing Question
  25. Stretching a fuse.... what effects are generated?
  26. What is a used SAE Aerodesign plane good for?
  27. Wing rock in a harrier
  28. calculating servo torque requirements?
  29. Incidence difference on bottom & Top Wing
  30. Effect of CG on knife edge.
  31. Aerodynamic tools, calculators and test links
  32. MAC
  33. Near crash on first flight: Aft cg or too slow???
  34. have i got a dodgy trainer plane?
  35. Leading Edge Shape?
  36. Thrust angle question
  37. Low wing Dihederal OR High wing Anhedera
  38. Wellington Crashed, need Specs
  39. The science behind the Infamous tip stall...
  40. What part turns a plane
  41. super fast !!
  42. change model
  43. Balance point-How far back ?
  44. Knife Edge Flight Fuselage Design
  45. MOVED: Quest for fowler flaps
  46. Trimming Question
  47. thinking about forward swept wings..
  48. Flaperons on P-51??
  49. physics of the downwind turn
  50. 36% Ultimate 10-300 Fat pig or not???
  51. pitches down, balanced
  52. Leading and trailing edges, blunt or sharp??
  53. ducted fan thrust
  54. Interesting bird kites that fly well and.....
  55. Help with CG on Flying wing...
  56. flying wings...a.k.a. tailless aircraft
  57. Brain Stormer
  58. Balancing Jig Need Pics Please
  59. Flying Tail VS Conventional Tail
  60. CGM ultimate 10-300 mods
  61. Rudder and hinge line?
  62. vertical tail
  63. How do I calculate control surface throw and servos torque needed?
  64. Calculate CG on odd wing??
  65. what is the purpose of ANHEDRAL
  66. C of G before mouting wing
  67. http://www.av8n.com/how/htm/airfoils.html
  68. Horizontal Stab placement for downwash
  69. Reflexed Airfoil and Flying Wings - Downwash?
  70. Dihedral in tails ?
  71. Aerodynamic balances---good or bad?
  72. Why is there dihedral on smaller Cap's but not on the 1/3 scale?
  73. Aerobatic Airfoil: Naca vs Eppler?
  74. Trainer Flat Spin
  75. Need airfoil advice
  76. determening dihedral
  77. Horizontal stab stall ?
  78. Anyone experimented with side-force generators??
  79. calculating stab area
  80. Will it Fly :)
  81. Lift is not rubber bands pulling on the wing
  82. LE slats and flaps-worth the effort?
  83. What airfoil(s) for 69" Pitts?
  84. Wing downwash effect on horizontal stab?
  85. add split flaps to strip aileron wing?
  86. stall warning device?
  87. Prop effective speed
  88. Great Neutral Point Calculator - no math needed
  89. MOVED: help
  90. Newbie to Aerodynamics
  91. Dozens of airplane calculators
  92. control surface forces?
  93. Jef Raskin (1944-2005)
  94. inverted fligt
  95. decrease dihedral at high speed
  96. NASA safety wings ?
  97. wing thikness
  98. Tiger 60 with a shorter tail moment ?
  99. Martin Simons book - a free plug
  100. prop trust
  101. Wing Loading
  102. higher aspect raitio wings stall at lower angles of attack
  103. Wind tunnels
  104. Center of Gravity
  105. eliptical wings & induced drag coefficient
  106. Asymetrical Wings
  107. wing fuse fillet on high & mid wings
  108. Science Fair Project
  109. MOVED: Hi all !! Ducted fan question
  110. Wing question..
  111. engine thrust angle / adverse yaw
  112. Down and dirty handbook
  113. Need airfoil coordinates
  114. Prop balance
  115. Build your own wind tunnel
  116. anyone know zero lift angle difference between HQ2.5/8.5 and HQ2.5/9 ?
  117. Servo Torque and Arm Length....???
  118. Axial Momentum Theory...application?
  119. Seagull Models Laser 200 Wing Loading
  120. Conventional V tail vs Inverted V
  121. Circular airflow affects aerodynamic decalage?
  122. round vs flat
  123. Delta CG?
  124. Straight chord vs tapered wing
  125. Bi-segmented Rudder........
  126. the Fan wing....
  127. Aerodynamics of Dragonflies
  128. LE slots anyone?
  129. Delta Vs Lifting Body
  130. Wing or elevator incidence problem?
  131. Jef Raskin article on aerodynamics in Fly RC Magazine
  132. using different airfoils from root to tip on glider wing.
  133. Non-Aircraft Aerodynamic Question
  134. Thrust angle for pusher?
  135. sealing aileron gaps
  136. How many blades do you want?
  137. tailplane airfoils
  138. What do we mean by "CG"?
  139. Smoke System and Wing Loading
  140. Where is the CG??
  141. Reynolds Number
  142. Flying wing design
  143. Some graphical data
  144. Best airfoil for 1/2A pylon racer ?
  145. opening up fake ducts on prop jet
  146. Need a hand with calculating wing drag.
  147. Propeller thrust question.
  148. wings built for speed?
  149. Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom)
  150. CJM P51 C of G % of MAC
  151. thrust angle for h9 cap 232????
  152. Model Airplane Dimensions
  153. Rudder not vertical..?
  154. Bipe wing incidence
  155. Hi there,yaw to roll
  156. Oddball Solarbo stability demonstrator
  157. defining wing profile / formulas
  158. Wing warping techniques?
  159. Roll Rate
  160. SPOILERS
  161. tapered swept wings vs constant chord wings?
  162. CG help for model of Spaceshipone
  163. Flat sheet Delta in a spin
  164. Bipe Balance??
  165. Tip Stall--a misnomer?
  166. Airfoiled Stabilizers
  167. Scaling on engine displacement. Is this valid?
  168. Aileron differential again
  169. Why Pull Pull on Rudder, not Elevator
  170. STABILIZER INCIDENCE FOR AEROBATIC?
  171. Foamie Foibles..
  172. bipe tail feather size?
  173. W.S. to tail feathers ratio
  174. fully semmetrical wing?
  175. Best aspect ratio for constant chord flying wing
  176. jets wings
  177. What determines right/down thrust?
  178. Pitching fit.
  179. TT bipe 40
  180. Unchain my plane!
  181. control surface stall?
  182. Aileron Differential
  183. P-40B conversion
  184. Aft CG and aileron effectiveness
  185. Thrust Line ?
  186. Rudder induces opposite roll
  187. Sopwith Triplane CG Determination
  188. Low pressure air inlet at wing
  189. 2004 Scale Masters
  190. Landing speed
  191. flying wing
  192. Aileron settings & engine downthrust
  193. quick questin about ailerons
  194. Wing spar question?
  195. Smooth flying airplane? see this video
  196. Help Huge wing loading
  197. Careful analysis reveals reason for poor climb performance
  198. Frieze Type Ailerons?
  199. Vertical tail size getting smaller??
  200. Staggerwing Wing Incidence
  201. Incidence meter design
  202. Forward Swept Wing?
  203. aerobatic airfoils
  204. propelar sizes.
  205. elevator to wing relations
  206. Prop/Spinner interaction
  207. Explain counter balanced ailerons...
  208. Unusual airfoil number
  209. Altitude concerns. How far do I have to go...
  210. Lancaster vertical tail design
  211. Wing Tip Design
  212. Scaling down airfoils
  213. Creating custom Flaps
  214. X-29 Vertical Canard Placement/Stability Issues
  215. Tandem-wing, 3 surface design
  216. S.T.O.L. Aircraft design parameters
  217. Aileron offset...why?
  218. hi my fellow yoday i need ur sincere help
  219. Wing Airfoil
  220. canard flap location..??
  221. Tail Location
  222. Tailplane height
  223. knife edge flight
  224. Trying to understand incidence
  225. can u make a plane from ................
  226. Barn door vs. strip ailerons
  227. Theorectical Pitch Speed & Prop Slip.
  228. Need some advice!
  229. Yaw/roll/pitch coupling
  230. MOVED: Cessna 172 CAD plans
  231. split rudder theory and execution
  232. Delta
  233. Sloper goes 262 miles per hour.
  234. Flat "airfoils".
  235. Rear Mounted Engines, how does it work?
  236. Free-flight to aileron/RC dihedral
  237. Quixotic plans-pusher plane-muffler ideas?
  238. Biplane top wing removal
  239. Herr Engineering P-51 1/2A Wing loading
  240. WING DESIGN
  241. Help on long-endurance airfoil?
  242. Can Flaps Act as Airbrakes?
  243. Prop Thrust for slow glo pwr planes
  244. rudder rollcoupling
  245. down/right thrust??
  246. Jets, props, thrust analysis
  247. TWINS
  248. Flying stab pivot point
  249. How to calculate viscosity of air
  250. Tail moment / Surface Area can be anything
