View Full Version : Glow Engines
- Saito 100 twin horizontally opposed
- Glow Engines
- Evolution mount problems
- 13,000 RPM OUT OF O.S. FS?????
- Satio 100 loss of RPM
- I loved my Supter Tigre G51, Would I feel the same about the G34?
- fuel tank size
- MoS2 MolyKote etc.Application on glow engine
- New OS 30 FS QUestion
- O.S. 40 review
- 1.08 FSR dissmantle
- Saito 100 (Not enough threads on crankshaft)
- What is PROP shaft size O.S. 1.60 FX??
- Magnum 120 or 180 2 stroke
- Super Tigre G-51 or Thunder Tiger 46 pro
- OPS 60 air 14300RPM
- OS 60 FP remote needle valve
- Muffler Gunk
- Is there a small 61?
- rotory or 4 stroke?
- Magnum Engine + Sukhoi
- Camshaft timing for an OS .70 surpass.
- Saito 0.91 Quiting
- Need help removing screws from .46LA
- Webra 120 question
- Need advice about adjusting an old 1980s engine
- Glow Plug Fouled engine?
- ENYA QUESTION?
- TOP FLITE CORSAIR 60 1:8 scale.SUPER TIGER G90.EXHAUST????????.
- bearing for OS Max-H 40P
- OS 70 surpass 4 cycle
- Saito 150 Engine Mount?
- Thunder Tiger 15V R/C
- Supertigre .90 vibration question
- Thunder Tiger Failures.
- OS 40 FSR Carb
- Saito 65 or 56??? Giles 202
- Tower Muffler on OS50SX
- K&B twister
- tower 46 troubles
- Need parts for old FA-120 Saito
- Saiti 72 question
- RCV Engines
- Used 4 stroke questions
- Perry Pump OS 1.60
- Bearing replacement OS61 4 Stroke
- Anyone have useful info on an Enya .15 III ?
- 1.60 FX-FI - product review
- Another Moki 1.8 question
- OPS 67 marine in aircraft
- Which Perry Pump Is This ??
- Saito 72 - Do I need new bearings?
- OS .40 Engine Trouble - Need Help
- OS Versus Super Tigre
- Saito .91 - old engine, sat for 5 years
- OS Engine Question, Carb Mount
- Tightening engine screws
- Older Super Tiger 90 trouble
- moki 180, perry pump or cline regulator?
- os. 50 new carb.????
- Good HANDHELD /Cordless starter for larger 4 strokes?
- 1.20 Surpass problem
- Cleaning with dishwashing powder
- webra 50 set up?
- OS 70 Surpass
- How can i get more power out of my Os 46fx?
- GMS .47 Full Throttle Flameout
- OS FL 70's, junk or otherwise????
- glow engines and going home question
- os 120 surpass pumped engine
- First inverted engine
- Kangke SK engines
- Instructions for crankshaft swap on a Saito 91
- GMS 1.20 RPM
- surpass versus non surpass question
- OS50SX Muffler Leaking Oil Help!!
- Adjusting Saito 56
- Engine dies at half throttle
- Old OS .21
- Witch engine can run w no nitro
- OS .46 FXi from NexStar question
- early o.s 4 stroke pumped engines
- os 91 crankshaft thread size
- Size muffler nut on Saito 100????
- burnt out glowplugs
- engine mystery
- Magnum XL .28
- What to get to replace my old torq .12
- K&B .45 Sportster
- please help a noob
- tornado prop query
- New OS 46 AX with worn bearings
- Rear needle vavle on a 60 FP.
- g-mark 0.30 five cylinder
- THE NEXT MYTH BUSTER
- os 1.60 v/s moki 2.10
- RPM range OS 70 Surpass
- jen 37 new toy
- Breaking in new Saito 150?
- Removing Baffles from a 2 stroke?
- O.S. .20 FP liner problems?
- Saito 180 used to run great, now doesn't. HELP?
- super tiger twin engine
- Inboard GLOW DRIVER
- Magnum 45 2-stroke needle valve
- Stripped exhaust OS 91FS
- ASP 46; Any Good?
- Muffler for 45 OS or Royal
- Save or Sell OS .40 LA
- ENGINERS MADE IN CHINA THIRTY YEARS AGO
- CAN YOU HELP HELP ME?
- fuel tank size for 91 four stroke
- Engine advice needed
- irvine 150
- Are YOU confused too??
- MOVED: graupner prop
- MPI Onboard Glow Driver
- new Enya 120r
- Saito 80 Barrel
- Saito Carb moves around
- Os 160fx and prop
- Saito 82a Muffler / Silencer
- Saito 91 set up
- Dubro Kwik Fuel Valve
- O.S. or Saito
- 1.60 OS issues...
- 160 FX Break-in props?
- OS 120FS Type II
- Where to buy piston/liner for a Rossi 105 DF?
- 8500 rpm for apc 17x6 on moki
- 4-stroke lube path
- YSFS45 sport muffler?
- New ABC...sloppy rich running
- 20% Nitro for OS FL-70?
- Piston port facing...
- Saito 82 fit on engine mount
- lancair 60 arf
- Sullivan Vibration absorbing Engine mount
- Saito? never again.
- Thunder Tiger Parts Source?
- Arne Hende' LEJA .99 Fourstroke Reproduction
- Equipment for YS45
- Fuel tank size for YS 120 DF
- Looking for an O.S. 91FX Quiet Tuned Pipe
- BTE Venture: What engine?
- Saito or OS in 52-82 size 4-stroke
- os 70 fs surpass valve clearances
- Moki 1.8 w/ APC 19x8W, Anyone Got RPM?
- MOVED: Anyone build their own ignition?
- MDS 40 Bit the dust!
- Trx engine trouble
- Saito weights
- 4 Stroke custom mufflers ??
- OS Max H 80 R/C Dual Plug Head
- Supertigre 75 tuned pipe
- super tigre crankshaft too short
- GMS .40 woes
- Magnum XL 91 4-Stroke Exhaust on a OS 91
- Should I buy Manum XLS-52 engine for my 40 size plane?
- O.S. 1.60 gasket?
- neoprene and nitro fuel ok?
- Low speed adjustment
- Glow fuel+styrofoam...good or bad?
- check valve on pressure line?
- Gasping for air??
- MOVED: Battery for Dubro Kwick Start
- Anyone running a mufflerless engine, please read!!!
- Engine Oil
- o.s. 32sx, fuel leak in carb
- 4 stroke fuel line question
- veco 19 tuning and running suggestions
- *OS .61 FX Low End Setting*
- Saito 91 Oil seeping
- 5 cylinder radial WHO can ID this engine?
- tuning .46 OS.
- What do I do with this?
- os 120 pump mods
- porting
- Enya 45 II 6002 needle valve
- How accurate are manufacturers weights?
- Fuel tank size for OS .32SX
- Engine stalls ! ! ! !
- Need special muffler!
- COMO engines
- K&B education
- OS 46 sf disapointing performance
- Show and tell.........
- reassebling os .40 la
- Tower Hobbies .46 - Fast?
- Enya 90-4C Valve Adjusting Screw & Push Rod
- Wildcat's new Curtis Youngblood Performance 30 Heli Mix: What Oil Is In It?
- Enya 60x
- Magnum 120 prop, Please help!!
- OS FS120 Surpass I w/ pump
- Please help, O.S. 70 Ultimate
- ABC...wrong break in?
- OS .40 LA Props
- Saito 82 blowing fuel lines
- Saito .56 engine runs great!
- New MAG .28 XL engine
- St G2300 break-in prop...
- Saito 45 - diss-asembly help
- KLOTZ HELI GLOW ON A DZ
- new satio 220 anyone using it yet
- YS 1.20FZ and Fuel?'s
- Enya 90-4C Operating Instructions/Parts List
- straightening a bent needle
- Thunder Tiger
- Just received .40 LA crankcase from Ebay seller
- Building Power?!?!?
- Aresti Speed With Tuned Pipe
- Does OS FX .91 engine have enough power?
- This may seem like a dumb question about my Saito .65
- os91fx engine problems ?
- What's wrong with my engine?
- Supertiger 75
- first glow engine.... info please
- Saito 120 Cam problem
- MOVED: Need HELP!! Clutch Springs keep breaking!
- TOKI .18 ducted-fan engine
- OS 70 Surpass and 3D flying
- A lesson in online buying - to forgive or not to forgive?
- Engine starting safety
- Help Moki 1.8 Parts/Repair
- opinions on engine please
- Loctite and Aluminum?
- GMS 120 tuning issue
- Enya 120-4C questions
- SuperTigre G61 inverted?
- ATF for after run oil?
- Remember those sweet OS FSR's???
- Glowplugs in Series
- Best fuel for YS 110??
- anyone use technopower radial engines ?
- Prop Selection OPS 60 RIRE
- ASP 2-Stroke .46
- fuel tank height_ help?
- Tuning Low Speed on Saito .82
- Saito .82 props>>>
- CAN YOU USE CRANK CASE PRESSURE (4 STROKE) FOR TANK PRESSURIZING?
- OS 90 4 STROKE PROBLEMS
- New O.S.91FX 2-stroke- has "CLICK" sound?
- New Webra 91 vs Saito 100
- ST 2300 Carb Sticking
- Saito 82 vertical stall
- Magnum 91RFS Pitts Muffler
- os 1.20 four stroke
- fuel pump!!!
- 3 Engine Help Questions
- What Spinner Prop Nut Fits a Thunder Tiger GP 15 ABC w/Muffler?
