View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6]
7
8
9
10
11
12
13
14
15
16
17
18
- Tail Wag Trex 450X Gy401 Futaba 9650
- whats the best 3d blade
- Tail bobbing up and down- why?
- HV-85 problems and headspeed
- Flycam cool view
- T-Rex 450 Tail Drive Gear/Pulley Issue - # AGNH1133
- O Ring Damper missing(?) and one torn
- REALLY ANNOYED, first crash not my fault
- help please, losing altitude during turns
- Slow spinup on the head
- trex500 tail bob problems
- pics of what goes where - electronics
- 450 or 500 or 600 trex?
- rotor metal hub fixing
- Non Align Head options
- Wobble around main shaft align 450
- Having quality issues with T-Rex 450 XL
- Trex 600 cyclic sensitivity
- what do you guys have holding your servos in place
- Flybar weight and length question
- GY240 setup
- It's not an authentic Trex
- Changing DS285 to a DS285MG
- Servos T-Rex 450 SE
- FIRST INVERTED HOVER!!!!!!!!!
- ALign Motors Junk or Good
- AR6100 Rec. Hookup?
- HDX450 Swash (similar to TREX450 Swash)
- Trex 600 XL motor problem overheating
- Trex 600 First Flights
- Scale Head on T-rex 450
- Newb ? about belt
- 401 gyro and trex 450 setup with dx6
- flight time?
- Charger/Balancer for 450?
- T-Rex 500 Crash
- T-Rex 450SE Rec wiring sevos
- Head adjustment?
- Wanting another t-rex,but dont know what?
- Need assembly instructions for HDX 450SE V3B
- Switch for leds on AR7000 Aux2
- XL Motor failures?
- Trex 450 SE V?? Unknow Frame design / Mfgr?? - SOLVED!
- Best bang for the buck battery for trex 600
- Help! Problems with T-Rex 450SA
- T-REX 600 vs. Blade 400
- Which charger?
- need new servos
- trex verses blackhawk 500
- TREX 450 V2 head MOD of 450XL HDE
- DX6 T-REX 450 SE V2 Tail setup!?!? HELP PLEASE!!!!!!!!!!!!!
- T-REX SE V2 Auto problem.
- NEED HELP T-REX 450se V2 + DX7
- ? about lipo's trex 450 and care
- 325 pro wood blades
- Help, how to change the damper rubber in head
- Help...Vibration issues TREX SE V2
- My 2nd crash...Video
- I think I stuffed my brand new air thunder lipo
- scared to fly pt.2
- Tested a new Heli Fuselage
- need input on kong power lipos
- Trex 450x to SA, SE conversion
- Just got a 600 GF-advice?
- tail drive gear spun loose - help!
- my first heli video
- Spektrum DX7 set ups for T-rex 450se v2
- Inverted not sure its possible with N settings
- trex 450 tail drive gear / pully assembly
- Finally did it
- What happens when you have the tail fins on backwards and good news...
- Best balancing charger??
- ESC issues, battery, and charger maybe too.
- 4S setup?
- 450SE V2 Bodies?
- Punching full throttle from hover and tail kicks out.
- increasing throttle end point for higher headspeed
- Hecell 22.2V 3000mah lipo for Trex 500
- scared to fly
- GY401 / 9254 intermittent slow tail problem
- Trex 500 motor replacment
- Heli P0RN!! Topless T-Rex 450!! mMMmMMmm
- DX6i trainer to DX6 master with Trex450
- Lipos - "The cost of flight!"
- We all like vids
- Side Rail Batteries for Trex 600
- T-Rex Canopy Question
- any good shops for trex / hdx parts in the uk?
- OK. Next problem. Logictec 2100
- Pitch reversed
- DX6i - limitations?
- Is there a clutch on the blades and gears of an Align 450?
- Sorry I double posted
- Gyro / Wag / Tail / Rudder issue SOLUTIONS!!
- Bad reciver?
- Rotorhead - "Can someone help?"
- What wires go where??
- JR 770 or Futaba 401?
- what is diffference between 450XL and SA
- Align T-Rex 900 Spyshots and Video from Taiwan
- T-Rex 450 build
- T Rex DX7 set up
- Pics of my Zit (T-Rex450sa)
- Tested a new Fuselage on the Rex
- Short flight time on the 600 Rx li-poly?
- newbe to everything t-rex 450xl
- How to maximise flight time on T-Rex 500?
- Need some help...
- Trex450 v Belt cp
- Bell 222 Fuselage Broken wheels
- Trex 450
- New Canomod Canopy
- Technical rebuild question 450 SA
- New (used) 450SE-V1 owner.
- 450se/450se V2 ?
- Tail Wag on T-REX 450 SE
- need help with gy401 setup
- Smacked My baby!
- Reciever switch mounting
- Scorpion HK2221-8 V2
- need pics of trex 450s alum kit
- MOVED: Flybarless 600N
- Dampener
- Anyone seen this T-Rex 700 Video
- Spektrum D6 and Hyperion 50A ESC
- Longer mainshaft and higher blades, disadvantages?
- Constant Amperage Drain
- GY401 vs GY240
- Inverted hover + nerves = FAIL
- TRex 450 SE V2 tail drive belt
- Which battery do you recommend for my T-Rex SE v2 stock?
- Is my one-way bearing working alright?
- ESC choices
- Programming an Align 35 amp ESC
- ?????? 500 or 600n ??????
- PUSH ROD GUIDES
- Idle up with Futaba 6EXH
- First Build
- Does anyone here have MSN?
- Trex 600 Scale Canopy
- ordering trex parts online
- align ESC
- flippin out
- How to change tail drive gear assembly????
- How often do you charge your DX7?
- Copter X
- Using Hughes 500E fuse and now running hotter
- TREX 600E
- T-REX 600 Carbon or T-REX 600 GF
- My very First flip!!!!!
- SUCCESS, My 500 flys!
- Trex 500 experts needed
- Setting Up A Cheap Yet Decent T-Rex
- question about receivers....
- Blade Tracking Question?
- Heli-Bros ???
- I DID IT!
- Flight Time - TREX 450 V2
- has anyone tried this charger????
- foray into 3d
- can you use hh in light 3d moves
- Will Li-Po fit T-Rex 600?
- link rods 450se
- T-Rex photo contest
- Silver carbon main frame
- COPTER X vs ALIGN
- Noobie with videos(Trex 450XL CCPM)
- flight time for Trex 600
- T-rex 450 Canopy
- what do I need to install the 430XL???
- Am i ready to begin some 3D stuff?
- 450 V2 heat
- 450 fire
- Xcite Batteries?
- Motor temp
- Home made nav lights
- Which hdx450 parts are NOT interchangeable with the TREX 450?
- New to helis
- DX7 & GY401 Setup Issues
- dx6 settings for 450se v2
- dx6i binding
- T-REX 450 & 600 Canopy Measurements
- stunts on 450 v2
- My birds before a crash....
- Align 500 fires?
- upgrading from V1 to V2
- Want a Phoenix flight simulator
- To get it str8
- First Flight with Chopper optimized => Setup correctly
- 401 Gyro Questions
- Trex 500 metal main bearing blocks
- Hobbycity.com
- 5S OR 6S for trex 500 ?
- Mistake?
- Align RCE 550 Gyro, any good for idle 430? (like trex 450)
- IDLE 430
- Just call me lucky
- First crash - SE V2
- Trex 600 Nitro Super Pro Red/Blue - Day of Maiden!!!
- charger for t-rex lipos
- Trex 450 tail drive gear/pully assembly replacement
- 15t on 4s 14.8v 3700mah?
- HELP - my rex 450 is pieces !!!!
- Trex 450X, Xl, SE differences...
- My best Lipo-battery
- Looking to buy a 450
- It's no trex450 but
- Disposing of damaged Li Ion cells.
- Align Aluminum Grips Tight?
- Copter X SE V2 parts...
- Align gear grease vs. something else?
- Aileron movement question
- Idle up curves TrexV2?
- Damaged tail screw and collar!
- Tail fin stabilizer fit on all Trex 450's?
- T-Rex setup?
- New Outrage Batteries
- 401 placement?
- DX6I setup trex 450
- trex snobs???? ***!!!!
- Servo mounting on Trex 450 se v2
- Anyone try out FMA CoPilot FS8?
- Blade Sizes vs. Performance
- Flybar not so loose (no free seesaw action)
- 12t vs 13t
- CC 35 issues.
- My new Trex 450
- Just me flying around - video
- Finless Bob Trex 500 build video
- Assistance - Easy CCPM Setup?
- Beginner's Mishap Trex 450 SE V2..
- First crash
- What to order,and from where?
- How long do your LiPos last
- T-rex 450 wobble issues
- Looking for heli flyers in the North Platte, Nebraska area
- TREX600E ESC Placement
- Another T-Rex SE V1.5 in 10 mph winds
- I'm one heli-respectin lucky dude
- TREX 450 V2 in 10 MPH Winds
- TREX 600 - Nitro versus Electric Power
- What do you think of these servos/gyro
- Calculating target headspeed
- Do you get that locked in feel?
- slight glitch in pitch servo
- DX-7 flying question
- Cheaper alternative for trex600 batteries.
- A123 4s battery in my T-Rex
- t600 nitro v t600 electric
- CF Blades required for basic 3D ?
