View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6
7
8
9
10
11]
12
13
14
15
16
17
18
- T-Rex 500 EP
- Training Video
- Shaft change
- Align 500X Gyro help
- FUTABA T6EXHP tx question ???
- New Canopy Finally.Post yours...
- Align lipo balance charger RCC-4CX
- 450SA Phantom xl........$90 bucks.
- T-Rex --- 600 or 450 size
- Cut Out and Paint
- XL or S...HDE or CCPM?
- Diablo cnc head and cnc tail anyone using them?
- T-Rex Flight Times and LiPos
- A Day with the T-Rex 450SE
- Trex 450 tail belt problems
- 450 with Helicommand 3D
- First loop can't contain myself!!
- Transmitter help
- T-Rex 450 With G770 3D GYRO
- Thunder Power Battery
- Need help with Cellpro 4s charger!!
- Keep stripping servo gears on 450SE
- puffy battery
- 450SA electronics questions
- FT. Lauderdale
- CableWrap Tutorial for TREX 450
- Need your feedback on my temp readings on my T-Rex 600
- Replacement brushless motor shafts
- something broke..rotor won't rotate??? oneway bearing?
- Spektrum DX6 Setup for T-Rex 450SA
- Tail Drive Gear Failure
- t-rex finnally
- Electric Heli 'Sizes'and T-Rex Spektrum DX6 Setup
- Common Sense RC Charger/Balancer
- Burning Helicopters smell really bad!!!
- New AXI trex size motor review
- Confused abt which Rex 2 get?? Look what I found
- 401 set up
- How to place the DX7 receiver in an XL?
- MaH flight time? how to tell??
- Tail kick
- can this charger be used for the 2200 20c for t-rex????
- roll rates
- Ugh.....Check servos after crash....hm, what should I replace with?
- what is a Tx in MODE 1????
- Anyone have a SmartPlus 1080 charger...
- T-Rex 450 +gy401 +DX7 help
- Futaba 6EX Curves
- sonix 11.1v lipo,any one try one from cncheli
- I NEED HELP
- T-Rex 450 Carry Case
- Lipo "C" size question
- First Crash
- Best online prices on TREX 450SE V2?
- A "night off"
- A vist to an old friend
- BEC or no BEC?
- Trex 450XL problem
- HELP ME PLEEEEASE
- 450seV2 flybar lengh
- newb help.
- Damn my LHS!!!
- Trex owner inputs please
- Recommended upgrades for a V1 SE?
- Good source for 450SE V2 parts???
- hot esc
- Flight Times
- Tail Gear flew apart..Starting to DIS-like Align
- Trex 450SA...What else do I need?
- T-Rex Canopys
- How much can I expect to pay for this configuration?
- CF or AL?
- On a G90HH gyro, and different temps.
- Hm, any info on converting/using a standard Batt charger?
- Help with figuring out what to do with Align ESC
- Futaba T6Exh
- Who all taught themselves how to fly?
- ESC Problem?
- This Trex good?
- Looking for an upgrade helicopter
- Trex 450 SA up and flying =)
- Celectra charger with Thunder power balancer
- 6000 or 6100 for the t-rex 450se?
- Copter X just arrived
- Ugh, cant find set up info on T6exhp for the 450SA Trex
- Got my new Trex450sa last night =)
- SE V2 Kit Quality
- which one !!!!!
- Upgrade CP or get a T-Rex?
- tail wont hold in 3d
- Futaba gyro ?'s
- good battery for the t-rex 450 SE?
- Best model T-Rex 450 for a beginner? SA? SE?
- reprogramming Align esc.
- bad shake
- T-rex 450 blade angles
- First loop attempt ... first BIG crash
- DX7 and T-Rex aluminium case?
- Initial Setup On T-Rex 450 SA
- need dx7 set up for 450sa
- Crashed - Metal or Plastic Next?
- misson
- misson
- Gel Cel for field charger
- Left coasters---mark your calendars: September 21-22
- full alum head upgrade????
- Motor Pulsing - Help
- trex 450se?
- trex 450se? opps
- loops in normal mode
- So I splurged on some Carbon...
- Use metal on tail pitch control?
- Main shaft, tight or tick of play?
- Joining the party
- who sells copter x t-rex type
- which radio for trex 450se
- Best batteries?
- how to
- got it in the air
- T-Rex 600 TP Extreme 6S 5000mah??
- ESC question
- is this a good deal
- Honey Bee K2 vs Trex 450
- Model difference
- T-Rex hover
- copter x vs. t-rex
- Trex 600 Flight Videos...
- I need some help, trying to get into the air.
- 450 xl compatible with copterx se
- Tail Bouncing
- servo selection
- noob with servo trouble
- convert thunderpower balance plug to align/eflite style-adapter????
- Tail rotor problem
- rce-bl35x setup for newbie
- First Flight of T-REX 450SE v2!!!
- can i charge a Flightpower 2200 extreme 3Cell at 2 C charge?
- HS-65HB... Did they change the servo?
- Heli Newbie Help
- PRE-Flight T-Rex Edition Simulator: Any Good?
- First Invert + Loops
- Another LiPo sollution for DX6/7
- 401 gyro problem
- DX6 or DX7?
- DX7 transmitter only
- carbon fiber tail blades fit question
- throttle curve, forward flight? opinions please
- Digital JR setup or 9650 and HS65HB's
- Catastrophic belt failure
- 450 V2 Shudders - Bad ESC?
- 325 carbon fiber blades
- BCP PRO MEMORIES
- Antenna placement, for those with no 2.4 Ghz
- Could the rotor housing/head bend in a crash??
- flight buddy in pensacola fl
- Trex 600N SUPER COOL!
- 9650, Align ESC & tail wag
- Bach Cong Tu's video: Crazy trex
- DX6 TX battery life
- Best li-po charger/balancer for T-Rex 600
- sorry for stupid question
- WHAT DO I ADJUST...H E L P
- Stoked on new purchase!
- 3cell & 4 cell batteries?
- best 450 v2 esc settings , timing? governor?
- DX6 servos
- t-rex
- Trex 600 Question: EPA and the Tail
- Impromtu flying fields
- Tail Rotor Belt Slipped Off
- new tail control?
- throttle hold function
- Unrelated questions after a repair (flybar length and gyro issues)
- g190 gyro
- Gorilla skids??
- crashed tell me what you think.
- T-REX 600 AND ROTOR HEAT TT 50
- Maiden Flight Of My New T-Rex 450SE V2
- Best way to measure head speed
- My 450XL keeps spinning around!!!
- Is this safe???
- Motor/ESC Question
- update to esc problem please help
- Gyro Placement
- T Rex 450XL HDE
- Can I use a Futaba S3150 on the tail?
- Which T-REX to buy
- using align rce 500 x gyro
- esc problems please help
- rex 600 gy11 set up help
- Can't find Trex 450 new v2 parts
- DX6 set up
- pictures
- heat sink
- T REX 450XL HDE "Help with adjusting collective servo"
- T-REX 450XL
- buy a new t-rex
- does anybody know any webpage to learn 3d maneuvers?
- Help with charge times!
- Phoenix rc flight sim?
- My wicked Trex
- 450 SE and 2100 thunderpower lipo question
- Blade tracking
- Will it be called a clone? TP extreme 450
- temp good or bad for esc motor and battery
- batterys
- Spare parts of T-rex 450 S in canada????
- Need Help with telebee RCE Gyro.
- converting HDE to ccpm?
- 2200 vs 2070 Thunder Power - TREX450
- gyro issues
- TREX 450 SE or MINI TITAN and with what servos?
- G500T and S9650
- where to get loose lipo cells
- Which trex450
- Do i need training gear?
- T-Rex 450 SE with CC35 ESC has mind of it's own!!!
- Where to buy??
- gyro for t-rex
- 11v vs 14v What's this diff. 4s packs users speak up
- Tail DriveGear/Pulley Assembly
- Head speed question
- Really bad glitch - T-Rex 450SA vs Futaba R148DF receiver
- CellPro Adapter Question
- servo arms and balljoint
- How do I power my receiver? (AR7000)
- realfilght 3.5 simulater and dx6
- trex se v2 ?
- T-REX 450 SE with Spektrum DX7
- It's Here!!!!
- Has anyone done this???????????????
- Rotor head setup
- esc dosnt sing
- is this configuration good for the T-rex??????
- t-rex or hbk2? on my first loop
- AR7000 or 6100 rx
- OK to charge at 2C rate??
- Chargers for Li-Pos
- JGF 450 Vs Align 430 vs Mega??
- T-rex 450 intermittent shacking
- Did my first loop today. WOOOOOOOO!
- Trex 450SE blade tracking issue
- I need some help fine tuning my new T-Rex!
- Convert from V1 to V2?
- Recommend a motor for a Trex SE V2
- what servos for se v2
- Trex SE Self Destructing
- lipo size
- A headless T-Rex?? Yup.
