View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6
7
8
9]
10
11
12
13
14
15
16
17
18
- fusono airwolf body
- T-Rex 450 SE V2 Question
- T-Rex 500CF Red Canopy
- Screws on frame of trex se v2
- Head Linkage lengths
- Maiden flight
- JR Xp783 VS. G500t !!!
- IS A T-REX too big a leap from a CX-2?
- Futaba 6EX-PCM Servos
- Happy Helidays Everyone
- Real Vs Sim?
- trex 450 flight time?
- T-REX or blade 400 ?
- Mode 1 set up and Mode 2 setup
- futaba 6ex radio and 401 gyro setup
- Helicopter Balance
- Real Flight G4 and T-Rex...
- Setting up a 120 degree Swash plate
- DX7 GY401 ?
- Trex600 shaft drive tail rotor vibration??
- T-Rex 500CF
- How to order tail pitch slider assembly
- New Digs For my TREX
- GY401 Help
- idle up not kicking in...
- real quick help please 450SE V1 and V2 differences
- Lithium iron phosphate batteries
- pitch angle
- Improving the 450Xl
- futaba 6ex radio settings for a 450sa
- Which heli is better...
- TREX... 2ND Hover Video...
- Official T-Rex 700 Thread
- Raising voltage?!
- $ no issue, whats the best battery for the rex
- Best pinion choices for a new TREX?
- li-poly's too low
- xl hde conversion? xl slop
- 2 ?'s: Main shaft and main gear...
- what is the maximum speed a t-rex can reach...
- when is time to push it more?????
- Upgraded to T-rexX V2 450
- New TREX for Christmas!
- T-Rex 500 Vids
- HOT "Whats in the Box Review" Trex 500
- EBAY!!!
- Trex 450 SE V2 "Stutters" turning hard right
- ThunderTiger E325 or T-Rex 450
- What kind of damage can be done?
- TREX 450SE V2 Electronics Setup
- Trex 450se where to buy
- White 3k tail rotors
- The next heli
- Tail Drive gear/pulley
- JR G500t gyro setup help
- Adding a Retract Servo
- Any of you guys hurricane owners
- Trex 500
- Gyro shutting off mid flight??
- 450 se's stable in wind?
- Lipo puffiness, life and $$$
- spektrum receivers, what to use?
- V2 SE power surge?
- Trex 450SE V2 Glass Fibre Frame
- question about tail drive gear
- what`s the name and site address please
- 600CF servo question..
- check out these decals Amainhobbies is going to get!!
- A good Heli
- 450 sa mixing levers breaking (lots)
- Unusual cyclic noise from main gear area
- What model Trex?
- wierd noises??????????????
- What do you think about this combo?
- Question about V2 Blade grips, feathering shaft and dampeners
- 3 point woes
- Bad Glitching
- dx6 idle up question
- New T-Rex500 Specs
- proline t-rex canopies, any good
- Severe Tail Wag after installing blue main gear
- T-rex 600 electrics
- Where can I get a thin lipo battery for my futaba 6ex radio
- Tail slightly moving to the left...
- Metal tail drive gear now standard!
- Is this a dumb idea??
- Blade sizes: Does it matter?
- Show me your canopies!
- DX7 setting for my 450 SE V2, will they work?
- trex450SE V2 question
- first heli build complete - now some questions
- Futaba 6EX - 2.4GHz + gy401 setup
- Align ESC BL35- THROTTLE RESPONSE
- Question about Revo Mixing and HH Gyros
- dx-7 air or heli diff?
- Trex 450SA Align RCE500X Gyro Help
- DX7: Throttle and Pitch curve +/- keys on Tx
- T Rex 450 v2 Largest Blades Possible???
- Questions about a T-Rex
- Slight turn left when power is increased
- Electric problems look alike trex
- trex questions
- mixing servos help
- 6ex or dx7?
- New V2 worth $200 more than SA?
- pitch setting help needed
- throttle/pitch curves?
- Good charger for Trex lipo's
- Beware of False Trex 450 V2s
- Best CYCLIC pitch for Trex 450S
- trex V2 belt problem
- More n00b Videoz
- Futaba 7C and 9C
- DX6 settings for 450SA?
- Swash leveling (DX7 ?)
- TREX 450SE yaws left when punching the throttle
- Trex altitude problem
- CopterX 450SE V2
- DX-7 Binding to AR6100 ? How ?
- flying below 0
- Throttle curves Dx6
- Emergency SPEKTRUM Question!
- n00b Question: Best way to align shaft and main gear when replacing
- T-Rex 500 waiting list
- 450 sa tail boom?
- Problem with a bogging motor
- v1 - v2 compatible parts
- Align Motor and ESC Jumble
- difference between flying t-rex models?
- Another n00b Video
- tail rotor stops spinning?
- Align fuselage,s
- TREX 450S Pitch Curve for Normal Flight
- TREX 450 Se V2 up and flying:Dual Rate/EXP/Auto Duel rate DX7?
- CPM interaction setup?
- Spektrum DX6i for TREX450
- TRex Power Up problems
- headspeed insanely fast (3600rpm), how do I slow it down?
- No Crashes Today - New Canopy!
- T-Rex for a noob 13 year old?
- 2 ?s- 1 swash leveling
- Build was so much fun I want to do it again!
- Which T-Rex 400/450??
- JR DS 285 Servo Question...
- Tail rotor not centering
- Main shaft replacement
- Purpose of Thrust Bearings
- hand made t-rex case
- VALUE of a futaba 6exhp
- Wire cutting/clean-up?
- Maximize Flight Time
- Upgrading to eccpm - Is this all I need?
- 450 V2 First Flight and First Crash!
- the right tools....
- Trex 450SA Newbie Questions
- Does anyone have a clue about the TREX 500 yet?
- Ever notice this? unclear esc definition for throttle response setting ?????
- GY401 with the Spektrum AR7000 (DX7) reciever
- Is it time yet?
- Swashplate repair
- New TREX 450 SE problem - wobbling
- What would you buy??? 600 E or N?????? POLL
- Could someone identify what I actually have
- Need help setting up TREX 450 With Futaba 9C
- Best cyclic servos for a T-Rex450 V2
- Finished My TREX 450 V2 Build!
- T-Rex canopy size?
- First spin-up: Heli spins out of control
- T-rex 600 Main Blade problem, advice please.
- TREX 600 Glitch
- GY401 Gyro, what servo to use?
- 3D time!!
- 450SE V2 head problem
- heli turning to the right
- Where to get Combo Pkg T-rex 450 + 2.4G radio and Batts?
- problem with backwards flip
- landing skids
- T-rex 450x and swollen lipo
- Building another one
- LHS IN PHX AZ
- Trex 600 parts
- converting a 450xl to a 450se
- 600 Scale Fuselage
- Do all these parts break every crash?
- Help with 600 nitro kit
- GY401 acting a bit strange on my SA...
- up coming trex
- Align T-Rex 450 cost
- 450se or 450sev2
- Which clone is closest to Trex 450SE v2?
- difference between blades....
- 450 SE Tail Servo Binding Question
- 450sa
- setting up trex with t6xa
- WHICH T-REX TO GET ?
- Align 600 ESC question
- Art-tech mini pred
- 99.00 450 s cf kit?
- T-Rex 500 lives
- Trex 450 building too difficult!!!!
- what kind of gyro!?
- help with spinning in air..
- lubrication!!
- Bell 222/airwolf help!!!
- Ar6100 Connections for TREX 450 V2
- 450 sa
- TREX 450 Setup services
- Trex 450 Aluminum Case
- WOOO HOOO First Loops and Rools!!!
- 4 blade rotor head
- FREE carbon fiber boom (not xl)
- New T-REX 600 CF Build Thread
- which motor
- left turn vs right turn
- Hot motor from continuous flying?
- aileron mess up.
- N00b needs help mounting JR DS285 Servos
- 450se v2 main head
- my tail is wagging
- question about lipo chargers
- difference between 430lf and xl
- Safety Alert!
- and 600 T-REX PRO
- Hey guys, new at this but got some probs..
- CLOSED New BUILD THREAD COMING
- DRIVE BELT FRICTION
- anyone use a 6EXH with a t-rex 450XL (CCPM)
- 600 Stabilizer ?
- are these t-rex parts?
- Gyro for T-Rex
- keep the heli low or high?
- Charging Problems...taking 6 hrs for 2200 maH?
- please help - setting up an Align 35G ESC
- First piro... too fast!
- Carrying Case for Trex 600 cf?
- Trex 450SE mutt
- Tall Man
- Help with gyro adjust
- tail belt problem
- How to install tail servo 9650?
- Lipo Storage
- T-rex Servo Choice help
- Swash & Servo question
- Heli drifting right?
- hey guys, need some quick advice - pinion choice
- OMG! the best birthday present ever!
- Can you loop or roll in normal flight set up?
- T-Rex 500 Pictures
- Servo arm for a 600E
- All kinds of rotor head problems
