PDA
View Full Version : T-Rex heli
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. Tools for building and repairing t-rex
  2. trex 450/ realflightg3.5 sim
  3. New Carbon Blades, MS Composit??
  4. 450 se v2 esc battery and reciver placement
  5. KONG POWER ='s WOW!!!
  6. T-Rex = CopterX 450? Parts interchangeable?
  7. Thoughts on Governor Mode (newbie)
  8. Hitec HS65 servo: HB Vs. MG
  9. TREX 450 SE v2 KIT + DX7 + 401 + etc
  10. will an align 500 hh work on a blade cp?
  11. What are normal temperatures for battery, ESC, and Motor?
  12. what is a blind plug!?!?
  13. Purchase advise reccomendations wanted
  14. Whats a good tail servo to use with the GY240 Gyro?
  15. V2 Fiberglass Canopy, foam tape?
  16. Lifespan of motor/ESC
  17. Trex 450X with JustGoFly 400H Motor
  18. I need help finding a rc heli
  19. Help!! - Hopelessly adicted n00b needs air travel advice
  20. First crash!!!
  21. HDX450 / Chopper X
  22. Is this good T-Rex Deal????
  23. TREX 450 and Walkera G-006 gyro
  24. What is the best battery for a trex 450sa?
  25. What type of charger for align 2100mah bat
  26. Pinion Gear
  27. replacement rotor head button??
  28. is the 450 se v2 worth the money?
  29. Trex recomendation
  30. Would this work?
  31. BROKEN MOTOR SHAFT
  32. Weak Tail Rotor Response (G90, SA)
  33. Can I buy a nitro helicopter and use the same transmiter that I use with a T-rex450sa???
  34. T-Rex 450 V2 Blade Fit - Ouch !
  35. Any TREX 450 Fliers in the San Antonio Area?
  36. hi tech optic 6 setup for 450 se
  37. is weight an issue for a trex?
  38. Trex problem
  39. 450xl parts
  40. My first Piroette, questions.....
  41. walkera to t-rex
  42. canopy troubles?!?!?
  43. who has done this?
  44. Problem with power dropping...
  45. n00b needs help
  46. IDLE UPS FUTABA 7CHP
  47. new trex 450se v2 yipee!
  48. My first outdoor FFF and Nose-in approach!!
  49. Problems with Tail Drive Gear
  50. Elecrtifly 4???
  51. Looking to Upgrade to TRex 450
  52. Alternate mounting of gyro on TREX?
  53. Need your help !
  54. What's the difference between the 450XL and 450SE???
  55. my first trex
  56. 450sa upgrade question
  57. black braided wire sleeving
  58. Horiz stabilizer/ struts needed?
  59. T-rex 600 Vs. rapture 30
  60. experts in T-rex... opinion about this deal please
  61. Are the Align batteries any good?
  62. One overlooked screw
  63. To Govern or not to Govern
  64. 9650 noisy?
  65. Heat shrinking excess wires?
  66. Anyone using Airtronics RD8000 with the T-REX?
  67. ugly flip = twisted paddle
  68. newbie with q on which heli too buy WAY TOO MANY OUT THERE
  69. linkages? perfect?
  70. blades?
  71. Training gear, Yeha!
  72. SET UP DX7 FOR TREX450XL
  73. 450 se v2 esc settings? confused.
  74. UP AND DOWN
  75. TRex 450 SA from Blade CX
  76. Took The Rex Plunge
  77. trex 450 leans to the right
  78. Multiple channel mixes on a DX6?
  79. Lipo, am I going too low?
  80. Belt wear
  81. from shaky to smoooth again
  82. Flying in tight spaces... Video link inside.
  83. spectrum receiver
  84. Charging LiPo's
  85. Motor Upgrade
  86. gyros for digital servos
  87. looking at buy a 5 month old T-Rex 450X
  88. My T-rex fits in a sandwich bag
  89. broken Servo teeth caused by or causing crash?
  90. Clarification of DX6 settings for TRex450
  91. GY401 Not Beeping
  92. Helifever -> Bad
  93. good Trex setup?
  94. Trex Tailbooms - Weak ??
  95. Trex 450 SE Tail is surging.
  96. Power switch mod...
  97. Hitec Eclipse and e-CCPM
  98. Phoenix 450se
  99. flight times
  100. Anyone from Idaho (Boise) flying helicopters?
  101. Tail trouble revalation...uneven left right control
  102. Futaba T6XA S pitch curves for Trex
  103. GWS pg-03 Gyro - has anyone ever gotten a trex to fly with one?
  104. Rite-Aid disposable Camcorder
  105. Upgrade from Blade CX2 to T-Rex?
  106. when I spool up my 450 xl it spins around in circles on the ground HELP!
  107. trex mid stick vibrations
  108. What's the best Heli Flight Simulator???
  109. GY-401 HELP
  110. Any heli flyers in Los Angeles???
  111. So my TRex thinks its a dog (Tail wag problem...)
  112. Lifespan of 430L motor
  113. Difference b/t T-Rex 450S/ 450SE/ 450SA?
  114. Best Servos for the 450XL / Choppersrule
  115. I need tips on nose in hover.
  116. Pirouette in forward flight?
  117. T-REXX 600
  118. First mishap with the beast - HELP!
  119. Any Deals on T-Rex 600 Batteries?
  120. Budget minded pilots
  121. 2007 Align Funfly in Taiwan
  122. flight times on 430XL?
  123. DX6 or 7 LiPo battery
  124. DX6 internal fuse
  125. HDE TO CCPM
  126. 450SA or 450SE V2
  127. Get the bearing out of Main Rotor holder TREX450SE?
  128. Losing LiPo capacity
  129. Trex 450SE V2 spectrum DX7 setup
  130. How do you set up realflight to change Blade pitch
  131. RCE-BL35Xset up question
  132. Just got a Trex 450sa
  133. 3dx 450 or phoenix 450 as a second heli
  134. Align RCE-BL25T burnout!
  135. Buying T-rex 600 advice
  136. I got a Simulator....Five Simulators!!!!!!
  137. Idle up setting for XL on DX6
  138. Retracted.
  139. 450 XL gyro
  140. TREX setup - a poll of sorts
  141. AH-1W Fuselage for T-REX 450 XL
  142. T-Rex 450 SE?
  143. output voltage too high?
  144. TREX Performance
  145. TREX 450SE? SA? maybe a clone? HDX450SE V3?
  146. T-Rex 450 belt size
  147. Help? T-Rex 450X Servo Setup Help
  148. how do you mount s9650? v2 questions.
  149. Futaba 6ex Good enough or not?
  150. somebody help me pleas...
  151. Wiring question on powering the receiver
  152. DX6/Phoenix simulator need help
  153. Lubing Tail Rotor Drive Belt- QUESTIONS
  154. wobbly main shaft bearings
  155. TREX 450 XL--I need Parts
  156. T-REX 600 TIPS.
  157. Time to retire the MX400, and get a Trex SA
  158. bearings
  159. One Way Bearing (450-SA)?
  160. Futaba 2.4 Gig TX
  161. Thunder power battery
  162. batteries
  163. T-REX VS E-FLITE
  164. Let the magic smoke out of motor and ESC
  165. A little T-Rex 450 SA Q & A
  166. Will DX6 do heading hold or just revo
  167. OK... some guidance here please!
  168. water proofing
  169. Hyperion Y22 Long 3600kv?
  170. cold light string
  171. First Post - Locking for thread lock advice
  172. Need alittle help with a 450SA
  173. closed...thanks
  174. Picture of 450 and 600?
  175. My experience with helihobby.com
  176. Rex motor cuts out intermitently as battery drains. new flyer
  177. align bl35g esc
  178. JR 3400G servo lives up to the hype!
  179. Whats a Good Simulator with the T-Rex Heli
  180. Opinions on Raptor G2
  181. How to mount HS-81 on tail ?
  182. wut kind of gyro is the futaba 401
  183. TREX Versions - Full Explanation
  184. Re; 2.4 ghz tech.
  185. one way bearing tool?
  186. T-Rex SE 450 Rotor Blades
  187. T-REX VS CP PRO
  188. Holy crap this heli is expensive, is it worth it?
  189. TREX450SE 15C batt gets too hot
  190. TREX XPERTS : CAN ONE GO OVERBOARD?
  191. Rex 600 3S series wiring??
  192. 450SA piro rates
  193. 1st flight, oh no
  194. good asking price for T-rex 600?
  195. Mysterious loss of control
  196. Can't control my rex
  197. Crashed my Trex
  198. RCE-BL35X v. RCE-BL35G ??
  199. Flighttime of T-Rex 600
  200. trex batterys
  201. Pitch Adjustment
  202. No hope for my XL
  203. What are the main differences of the T-rex se v1 and v2
  204. TREX 450SE Tail Control Unit...
  205. Navigation lighting and landing lights?
  206. T-Rex, How to choose?
  207. attaching ball links to servo arms? my v2 kit is missing parts?
  208. Will an eflite 11v 0.8a 3cell charger charge a 2200 mah lipo for rex?
  209. New T-Rex owner!
  210. V2 build questions, grip tightness and flybar, please!
  211. new trex ownr, help me plz with batt, motor and spd cntrl numbers plz.
  212. Trex- Walkera mixed breed
  213. A Good, Affordable T-Rex Heli
  214. Trex 450 tail wag with Jr 500T Gyro and 3400G servo
  215. DX6 Help neede for Trex 450 SA
  216. electrifly equinox balancer adapter
  217. need advice on my 450x
  218. THUNDERPOWER BALANCER AND CHARGER
  219. burned out ESC??
  220. Pulsating tail
  221. HDE JR8103 SETUP
  222. Spektrum Radios?
  223. New frame eccpm Trex 450XL CDE
  224. 450s cf servo instalation
  225. Washer fell into motor!
  226. Align RCE-500X Head-Hold Problem - Help appreciated
  227. 450 SE Tail Slider Bearing?
  228. Trex ESC gyro configuration
  229. Trex tail wag
  230. difference btw. 450 SA and SE
  231. video camera on a T-Rex
  232. DX7 Setup (HELP)
  233. check out my rexxy
  234. serious opinion - Trex 450SA or simulator?
  235. E-tailer's Rep?......
  236. 6 volt BEC with spektrum AR6000
  237. trex 450sa vs. mx450 pro
  238. blade cp pro to t rex 450x question
  239. V2 crash...
  240. Head rebuild
  241. Servos for a 450SEV2
  242. Battery and charger question
  243. T-Rex 450 SE V2
  244. An alternative to the classic 9650/GY401 combo?
  245. heading towards a 450SA with a DX7, quick question
  246. budget gyro question
  247. Trimming flight with T-rex 600...
  248. TREx 450- ar6100 or ar7000
  249. help I have an offset between the autorotation and tail drive gears
  250. T-Rex 450SA Adjustment Advice Needed
