View Full Version : T-Rex heli
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16]
17
18
- Help with 450XL CDE
- Programming the Futaba 7CHP for the T-Rex 450 CDE
- hitec hs65 which ones??
- T-Rex 450 SE Radio Setup
- Align ESC BLG35 HELP Needed
- Heli-Max MX400 @$99
- Trex Setup Question
- Phoenix Simulator or XTR
- Good replacement/upgrade canopy
- HELP!!!
- Serious trouble with T-Rex SE and loss of control
- 450 XL/JR 6102 Setup HELP Needed
- 14.8v on standard Align ESC & BEC
- LIPO Battery Pack Swelling
- Centering a servo need the device or can the TX do it?
- How fast will trex go?
- About to place Trex Order -- What am I forgetting!
- LIPO Battery Connectors
- Is the Futaba 6EXH adequate for the Rex 450XL?
- Are Futaba 3107 servos ok w/ the Rex?
- Sa or XL?
- TREX motor gear
- My New T-Rex 450SE
- Heli starts to raise on the left side skid
- Heli slightly spins to the left when powered ready to hover
- is this ebay t rex worth it ??
- My flight setup and review
- Yet another "What do you think of this set up?" thread **Order placed!!*
- Is the Trex 450x good ?
- transmitter for trex 450xl (ccpm)?
- 325mm carbon F
- SM22 Hi-Speed sub Micro Servo
- t-rex xl vs. se vs. 600?
- Building TREX 450Se
- throttle hold setting for optic 6 tx??
- Which Tacho
- Thunder Power For The T-Rex 600
- Cheapest Trex 450 Setup?
- Balance Charger
- Bat. EVO 2500mAh for Trex SE
- slight lean to one side while hovering???
- Just how loose should ball links be?
- Trex 450XL (CCpM) help
- FLYING IN COLD WEATHER
- HeliMax MX400Pro Blade Flex??
- thinking about getting my first heli
- Tail gets stuck
- ESC Cooker
- Thunder Power eXtreme ( Whats the difference)
- 450 SE Build Question/Problem
- SUPERBRAIN 989 8C LIPO AC DC CHARGER
- Align High-Power Li-Polymer Battery
- TRex Scale Body Question
- Recievers?
- battery
- Servos and a trex SE
- Kudos to TP
- AEROFLY PRO?
- BALL LINK PLIERS?
- RC sim?
- anyone have any landing skid end caps?
- Mad at Blade CP: Help me build a Trex
- T-Rex Tuning Website
- 9C throttle hold prob.
- Head Shake???
- futaba 401
- I CHANGED THE T-REX!
- Second Heli
- WHAT DO YOU THINK OF THIS T-REX?
- Michigan Fun Fly, South East
- trex 450x suggestions!
- T-rex setup help
- THROTTLE PROBLEM WITH 35A
- Transmitter
- TRex or Electric heli gadgets...!
- New Apex 2100 for TREX
- ESC Align 35 help
- lipo , feeling the heat
- 1010 charger and 210 balancer walkthrough
- Aluminum case?
- 450x 450xl and 450se
- Tx for a 450SA
- Trex 450SE How much should I budget?
- SUPER BRAIN 989
- Trex 450XL (CDE) Help
- Which blades for hovering?
- Installing servos on the T-Rex XL (HDE)
- slow tail response
- T-REX Helis, parts and upgrades
- MX400 Tail question??
- t-rex 450xl ccpm and spektrum DX setup
- Which charger??
- Used 450 CDE, 1st flight
- Which RC equipment for 450SE - newbie
- new to helis
- Cat Saver
- hex wrenches
- Best esc (speed controller) no-matter the price!!!
- 240 or 401
- antenna best way to have it?
- Trex Aluminum Frame ?s
- TREX radio installation
- Flight Characteristics of the T-Rex family
- pitch thotttle curves for newbi??
- SE for Beginner?
- 401 setup on jr 9303 HELP!!!!
- Buying a new radio
- Proof that plastic blades suck...
- Trex Advice
- Big mistake on my new t-rex
- Heli-max wiring
- Trex 600 questions
- Li-po and charger
- Trex 450SE tail boom slipping, belt loosening
- TR600 Blades limited to 600mm?
- upgraded to 450xl ccpm need help..
- Build Cheap&reliable trex
- what about blades?
- 401 set up ?
- movin up
- Tail moves right on takeoff
- TREX 600CF Canada
- landing gear glueing??
- TREX 600CF
- Got a used one...
- LIPO battery charger question
- has anyone ever seen the build video???
- did i just kill my gyro ??
- pinion keeps coming loose
- Is there a point?
- TREX help
- More Blade Tracking
- T-Rex 450SE/SA Set-Up Guide
- Main Blade Flutter
- 401 Gyro, Tail Pitch Slider questions
- 7CHP SETUP
- Aftermarket ESC and Motor Combos
- Difference between 325 Pro & 335 Pro Blades
- Help with new 450SE setup please...
- Differances between the T-rex family
- A quick note for T-rex 600 owners.
- Linkage set up on T rex 450x
- blade user --> trex
- Any probs w/ the Align 25A controller???
- Trex on Grass
- 2006 Align Fun Fly Taiwan Photos
- Trex 450 X simulator for G2
- T-Rex 450 XL Vs Raptor 30V2
- Mounting Battery on TRex 450X
- Tail rotor drive shaft too short?
- 450 SE short boom
- Lipo Charger
- TROUBLE SETTING UP ESC
- Trex 450X manual
- Is this a good configration
- Question about CCPM servo choices...
- MOVED: Verification of X-400 repair please.
- Radio Gear Possessed... Help!!!
- Align Servo Vs. Futaba S3110
- Is a Align Receiver a good election???
- big battery on 450x model
- Fun with Tail Rotor
- haywire tail rotor
- SUPER FRAME
- csm lw200?
- T-Rex -Need Help with belt drive gear
- twitchy collective
- Charger/Battery Advice?
- Smoked my TREX today. Please help diagnose
- Help on Trex tail oscillation
- T-rex XL, HS 65, JGF 450th
- 450XL CDE ordered
- TRex 450XL Scale Heli Bodies?
- swash plate
- CSRC 6S2P 4000
- Package Options
- Discussion Groups
- LIPO BATTERY
- TREX 600
- Align T-Rex AirWolf Retracts Needed
- Castle creations phoenix 35 is overheating my 420lf HELP!
- 430L Brushless, which gear?
- T-Rex radio setup problem
- Align esc/motor setup problem
- How hot is HOT
- TRex for a newbie
- Futaba R1490P
- Pitch Adjustment Problem
- New TREX 600
- help am i getting a good price?
- Tokyo Trex
- Do the Ferrite Rings work?
- Help please TREX ?
- Boom Strikes
- trex 600 max payload lift
- V-BLADES FOR A T-REX 450 - 325's
- Which Heli?
- RX help
- Show off your heli!
- Anyone bought a Trex from this site ?
- Futaba GY240 GWS Naro/HP/BB/F+ Tail Hunting
- T-trex 450XL HDE or CDE?
- Is RC-EXPERT A GOOD OR BAD HELI COMPANY TO DO BUSINESS WITH..Continuance
- Sticky Tail Pitch Slider
- Servos for T-REX 450SE
- Mini Heli Setup
- Tail Servo
- WARNING - Telebee HEAD LOCK & STANDARD GYRO
- Vibration and Blade Tracking
- ARK X400
- new trex pilots
- A nice Heli Mag to subcribe too?
- Carbon Frame and Glitches
- Digital Servos had me stumped
- T-rex XL for beginning?
- Buying a T-Rex 450se, Some questions.
- it keeps falling!
- THERMAL INTELLIGENCE ALLOWS HELICOPTER TO FLY VIRTUALLY HANDS FREE ~ For T-REX
- ONLY Want The BEST RC Heli Flight SIMULATOR Software Information
- futaba t6exhp and hitec servos
- Align RCE-500 Gyro initialization problem
- IS RC-Expert A Good or Bad Heli Company To Do Bussiness With
- What Are The Very BEST Electric Heli For Indoor ~N~ Outdoor
- New Sub-Forum for T-Rex 600???
- TREX HDE TAIL WOBBLE.
- T-rex 600 Safety Announcement on RunRyder!
- New T-Rex.
- AUTO-ROTATION GEAR PROBLEM !!!HELP!!!
- MAIN GEAR PROBLEM
- TREX CARRY CASE?
- power supply for LiPo charger
- Son of a glitch
- Has anyone purchase one of these gyros? Looks like a Futaba GY401 copy
- Lost the manual of my Darthdrk Hughes 500
- Receiver Question
- Which radio gear for 450XL
- All in one Question on new purchase (TREX SE)
- Blade tracking
- Metal rotor head vs Plastic Rotor head
- What do I buy
- Which T-rex
- Just picked up my 600CF
- Twinn Rexx Tandem
- trex motor
- No bug splats on your blades??
- Need help with my T-rex 450XL
- Programming a Spektrum DX6 for a 450 CDE
- "Head's" Up! or down?
- Frame conversion for TREX XL.?.?
- CNC aluminum parts - only blue??
